Results 1 to 10 of 12
Thread: Retrofitting multiple parts on Passat B7 EU
    Sep 2017
    Belgium
    Hello everyone,
    This is my first post here so please bear with me.
    I have a 2011 Passat Variant B7 2.0 CR TDI CLBMT 103.
    I was recently involved in an accident that damaged both front and back of my car.
    I decided to fix it myself and found a donor car from witch I've sourced everything.
    Almost everything that I've got is basially a retrofit.
    I already have ParkAssist with 12 PDCs from fatory.
    So here is the list:
    1. Bi-Xenon with static cornering and fog lights + LED tail lights + headlight washing system
    2. Automatic open/close hatch
    3. Backup camera
    4. DCC (I decided not to install the struts since I have Bilstein B16 if I recall)
    5. RNS510 with Blaupunkt 8ch digital amplifier
    I am almost finished with the installation of everything and I've done a quik test with almost everything connected but I saw a lot of expeted errors.
    After I finish with the install I will do another scan and see what is left and post it.
    I am asking for support with where to begin, what stepts to follow, quick links to where I can find exatly what to do.
    I am asking for this help since this is the car that I work with and not a project car that can wait. I have to do it quick so I can start working again.
    Thank you all in advance,
    Rares
    First step here is to post a full unedited VCDS Auto-Scan (using the English version of VCDS) so we have an idea how your Passat is equipped, this will hopefully be a good starting point for us.
  3. Likes Uwe liked this post
    Sep 2017
    Belgium
    Here you have the two scans of before and after:
    Before
    Monday,28,October,2019,22:57:36:48725
    VIN: WVWZZZ3CZCE017535   License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 56 61
              62 72 77
    VIN: WVWZZZ3CZCE017535   Mileage: 375240km-233163miles
       Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
       Component: R4 2.0l TDI   H24 9978
       Revision: 47H24---    Serial number: 00000000000000
       Coding: 00190032042401080000
       Shop #: WSC 00537 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
       ROD: EV_ECM20TDI01103L906018BF.rod
       VCID: 6FB8DB424716E92F20D-803A
    4795 - Mass Air Flow Sensor (G70)
              P0101 00 [096] - Implausible Signal
       Part No SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
       Component: J104   C2 450M VDD7 0022
       Revision: --H07---    Serial number: 00000004369150
       Coding: 0003504
       Shop #: WSC 05311 000 00000
       VCID: 6E86C6464C9CE0272BB-803A
       Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
       Component: AC Manuell    H17 0202
       Revision: 00001012
       Coding: 0000000003
       Shop #: WSC 00015 115 00000
       ROD: EV_ClimaBasis_VW46.rod
       VCID: 3D24310A5DFA4BBFE21-8068
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 C    HW: 3AA 937 087 C
       Component: BCM PQ47 M    413 0455
       Revision: BA413001
       Coding: 000000000000000000180080540000E407510088426D85606480C7200041
       Shop #: WSC 05311 000 08193
       VCID: 3A2E3A164C547C87C73-806E
       Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer 31051  10  0603
       Coding: 00B795
       Component: RLS 220611 05  54  0403
       Coding: 0A302A
                        Fault Status: 00101010
                        Fault Frequency: 235
                        Reset counter: 0
                        Mileage: 366917 km
                        Date: 2014.01.31
                        Time: 18:08:19
                            Term 15 On
                        Voltage: 11.10 V
                        Fault Frequency: 51
                        Reset counter: 0
                        Mileage: 366917 km
                        Date: 2014.01.31
                        Time: 18:08:19
                            Term 15 On
                        Voltage: 11.10 V
                        Fault Frequency: 34
                        Reset counter: 254
                        Mileage: 366927 km
                        Date: 2014.01.31
                        Time: 20:26:13
                            Term 15 On
                        Voltage: 14.85 V
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56231115904504
       Coding: 148206
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 44D244EE3E103A77ADF-8010
       Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
       Component: J234__10H VW10 HI   1918
       Revision: 22014000    Serial number: 003JZPC9JG9I
       Coding: 0012360
       VCID: 4BC06FD21FCEF50F6C5-801E
       Subsystem 1 - Serial number: 6332MTS636381531
       Subsystem 2 - Serial number: 6342MTS604871541
       Subsystem 3 - Serial number: 6351HTS6A44F5AKR
       Subsystem 4 - Serial number: 6361HTS6UP2I5AKR
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20110616100362
       Coding: 118A250000
       VCID: 76B6EE26384CD8E7E3B-8022
       Coding: E20000
       Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
       Coding: 161E01
       Shop #: WSC 05314 115 00000
       VCID: 333017326BBE8DCF045-8066
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 070611F2000494
       Coding: 462006
       Shop #: WSC 05314 000 00000
       VCID: 382A201E72586E97317-806C
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       Revision: 00043000    Serial number: VWZCZ000000000
       VCID: 76B6EE2634CCD8E7E3B-8022
       Revision: A1001003    Serial number: 7660248983
       VCID: 290CF55AB9F2C71FBE9-807C
       Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0533
       Revision: 12110009    Serial number: 0003022674
       Coding: 0210B7
       Shop #: WSC 05311 115 00000
       VCID: 3534292A65CA93FF2A1-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0407
       Serial number: 00000002234674
       Coding: 000090
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.309 0802
       Revision: 1AH03729    Serial number: 00111580309501
       Coding: 0000258
       VCID: 3B203F124F6E458FDC5-806E
       Component:    KSG PQ47 ELV 043 0634
       Coding: 1991020052830E7600029C1CFC084FCE707C01
       Component: EZE_2         H40 1620
       Coding: 00000008
       VCID: 6FB8DB424796E92F20D-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0533
       Revision: 14110009    Serial number: 0003037343
       Coding: 0210B6
       VCID: 36362E2678CC98E723B-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0407
       Serial number: 00000002233294
       Coding: 000090
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000055168
       Coding: 0022167
       VCID: 3534292A694A93FF2A1-8060
       Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
       Component: RCD510        H01 5016
       Revision: -----14S    Serial number: VWZ4Z3L1147906
       Coding: 01000400040011
       VCID: 2B000F52B30ED50F4C5-807E
       Component: Batt.regelung H40 1620
       Coding: 030B185A
       VCID: 71BCDD3A51A2FFDF369-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900735687
    Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
       Component: Telefon       011 0723
       Revision: --------    Serial number: 35909603179017
       Coding: 020000000000000000000000
       ASAM Dataset: EV_UHVPremi A02003
       ROD: EV_UHVPremi_A02.rod
       VCID: 221EE276C4441447FF3-8076
              U1400 00 [008] - -
                        Reset counter: 254
                        Mileage: 374698 km
                        Date: 2019.10.23
                        Time: 20:07:41
    End----------(Elapsed Time: 01:35, VBatt start/end: 14.7V/14.8V)-----------
    After:
    Thursday,27,February,2020,03:09:18:48725
    VIN: WVWZZZ3CZCE017535   License Plate: RARES
    Mileage: 381620km-237127mi   Repair Order:
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 4C 4F 52
              53 55 56 61 62 6C 6D 72 77 A5
    VIN: WVWZZZ3CZCE017535   Mileage: 381620km-237127miles
    2E-Media Player 3 -- Status: Malfunction 0010
    47-Sound System -- Status: Cannot be reached 1100
    4C-Tire Pressure II -- Status: Not registered 0001
    72-Door, Rear Right -- Status: Sporadic communication error 1000
    A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 1100
       VCID: 6FB8DB424716E92F20F-803A
       Component: J104   C2 450M VD18 0022
       Coding: 0003504
       VCID: 6E86C6464C9CE0272B9-803A
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:27:51
                        Speed: 15.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.75 V
                        Bin. Bits: 00011110
                        Count: 247
                        Hex Value: 0x0010
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:28:02
                        Speed: 14.0 km/h
                        Hex Value: 0x0001
                        Voltage: 14.75 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
       Revision: 00001012
       Coding: 0000000003
       Shop #: WSC 00015 115 12345
       VCID: 3D24310A5DFA4BBFE23-8068
    9475861 - Position Sensor for Temperature Flap Motor
              B1097 15 [009] - Open or Short to Plus
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:00:43
    9477141 - Position Sensor for Air Distribution Flap Motor
              B109C 15 [009] - Open or Short to Plus
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:16:03
    13701536 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:08:33
    9472533 - Temperature Sensor for Evaporator Vent
              B108A 15 [009] - Open or Short to Plus
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:00:01
       Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
       Component: BCM PQ47 H+   413 0452
       Revision: BC413001
       Coding: 000000000000000000180088540029F463D50088626D8D60E480C7240049
       Shop #: WSC 05311 123 08193
       VCID: 392C251A4952779FCEB-806C
       Coding: 00B795
       Coding: 0E302A
    8 Faults Found:
    00924 - Relay for Headlamp Cleaning System (J39)
                        Fault Status: 00101001
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:02
                            Term 15 Off
                        Voltage: 12.75 V
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 01101001
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:08
                            Term 15 Off
                        Voltage: 12.75 V
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:04
                            Term 15 Off
                        Voltage: 12.75 V
                        Fault Status: 01101010
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:02:50
                            Term 15 On
                        Voltage: 12.55 V
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:02:50
                            Term 15 On
                        Voltage: 12.55 V
    02092 - Enabling Heated Seat
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:03:34
                            Term 15 On
                        Voltage: 12.60 V
    02235 - Stationary Cornering Lamp (Left) (M51)
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:02:50
                            Term 15 On
                        Voltage: 12.55 V
    02236 - Stationary Right Cornering Lamp (Right) (M52)
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:02:50
                            Term 15 On
                        Voltage: 12.55 V
       Coding: 148206
       Shop #: WSC 99999 102 209715
       VCID: 44D244EE3E103A77ADD-8010
    1080083 - Rear Parking Aid Sensor(s)
              B107B 13 [009] - Open Circuit
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:16:46
    1111316 - Speaker for Front Parking Aid
              B10F5 14 [008] - Open or Short to Ground
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:08:33
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
       Part No SW: 3C0 907 376 A    HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0071
       Revision: 00000000    Serial number: 01121001530001
       VCID: 2708F362AFE6F16FA8F-8072
    8 Faults Found:
    00142 - Left Front Dampening Adjustment Valve (N336)
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Reset counter: 24
                        Bin. Bits: 00000000 00100000
    00143 - Front Right Dampening Adjustment Valve (N337)
                        Reset counter: 24
    00144 - Rear Left Dampening Adjustment Valve (N338)
                        Reset counter: 24
    00776 - Level Control System Sensor; Left Front (G78)
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:32
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:11:09
    00145 - Rear Right Dampening Adjustment Valve (N339)
                        Reset counter: 24
                000 - - - MIL ON
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:11:09
    00149 - End of Line Programming not Completed
                000 - - - MIL ON
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:11:09
       Coding: 0012360
       VCID: 4BC06FD21FCEF50F6C7-801E
    8 Faults Found:
                010 - Open or Short to Plus - Intermittent - MIL ON
                        Fault Status: 10101010
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
    01220 - Rear Side Airbag Igniter; Passenger Side (N202)
                        Fault Status: 10100001
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
    01219 - Rear Side Airbag Igniter; Driver Side (N201)
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:34
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:33
       Coding: 118A250000
       VCID: 76B6EE26384CD8E7E39-8022
       Coding: E20000
       Coding: 061F01
       Shop #: WSC 05314 115 12345
       VCID: 333017326BBE8DCF047-8066
    13648640 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für LaneDepartureWarning: keine Kommunikation]
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:20:01
       Part No SW: 7N0 907 530 G    HW: 1K0 907 951
       Component: J533  Gateway H41 1614
       Revision:   H41       Serial number: 241110F2001549
       Coding: 462006
       Shop #: WSC 45403 141 98537
       VCID: 3432142E6E308AF71DD-8060
                        Fault Status: 00110100
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:02
                        Fault Status: 01101011
                        Fault Frequency: 6
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:02
    00463 - Control Module for Digital Sound Package (J525)
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:06
                        Fault Frequency: 7
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:02
    03850 - Front Sensor Electronics for Driver Assistance Systems
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:00:38
       VCID: 76B6EE2634CCD8E7E39-8022
    02835 - Communications between Steering Column Lock and Convenience System
                        Reset counter: 64
       VCID: 290CF55AB9F2C71FBEB-807C
    03138 - Input AUX IN
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:49:26
       Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
       Component: RNS-MID       H42 2720
       Revision: AB001001    Serial number: VWZ6Z7K9332195
       Coding: 04070002010000A000
       Shop #: WSC 05314 123 12345
       VCID: 2E060646801CA0276B9-807A
                        Reset counter: 24
                        Mileage: 381624 km
    01523 - Microphone for Telephone (R38)
                        Fault Frequency: 12
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:41
                        Fault Status: 00101011
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:41
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:33:35
       Coding: 0210B7
       VCID: 3534292A65CA93FF2A3-8060
       Slave Driver:
       Coding: 000090
       Coding: 0000258
       VCID: 3B203F124F6E458FDC7-806E
    00566 - Steering Assistance Operation
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:13:56
                        (no units): 7.0
                        Steering Angle: 182.04°
                            OK
                        Steering Angle: 136.46°
                        (no units): 15
       Coding: 1891020052834E7E00029C1CFC004FCE707C01
       Shop #: WSC 05311 123 12345
       Subsystem 2 - Component:       NGS No Answer
       Subsystem 3 - Component:      IRUE No Answer
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:02:48
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:02:48
    Address 47: Sound System
       Component: EZE_2         H41 1614
       Coding: 00000008
       VCID: 6FB8DB424796E92F20F-803A
       Coding: 0210B6
       VCID: 36362E2678CC98E7239-8062
       Slave Passenger:
       Coding: 000090
       Coding: 0022167
       VCID: 3534292A694A93FF2A3-8060
       Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0080
       Coding: 02BA00100F000200
       Shop #: WSC 05311 115 08193
       ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
       Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H03 X008
       Coding: 2C0000
       Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H03 X008
       Coding: 2C0000
    5275220 - Headlight
              C107E 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:21:52
    13705990 - Databus
              [Fehlerwert im Signal NI2_Hoehe_VL_Roh]
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 00:21:51
                        Reset counter: 24
                        Mileage: 381624 km
                        Fault Frequency: 12
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:41
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 01:08:41
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2014.07.20
                        Time: 00:33:35
       Component: Batt.regelung H41 1614
       Coding: 032B1864
       VCID: 71BCDD3A51A2FFDF36B-8024
       Part No SW: 3C9 907 441     HW: 3C9 907 441
       Component: J772__Rearview      0020
       Revision: 00H08000    Serial number: 525PA8-J0X2091
       Coding: 0020007
       VCID: 688AB05E6E783E17615-803C
    Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
       Part No SW: 3C9 827 383 J    HW: 3C9 827 383 J
       Component: J605  HECKDECKEL    0804
       Revision: 00H27001
       VCID: 382A201E7E586E97315-806C
       Subsystem 1 - Part No: 3C9 827 384 J
       Component: J756  HECKDECKEL    0804
       Subsystem 2 - Serial number: 1000H27001001A0205˙
       VCID: 221EE276C4441447FF1-8076
    9457427 - Left audio channel for speech/telephone
              B104F 13 [008] - Short to GND
                        Reset counter: 65
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:00:43
    9457171 - Right audio channel for speech/telephone
              B104E 13 [008] - Short to GND
                        Reset counter: 65
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:00:43
    9455635 - Telephone Microphone
              B1048 13 [008] - Open Circuit
                        Reset counter: 65
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:00:43
    9457939 - Telephone baseplate
              B1051 13 [008] - Open Circuit
              [Halterung für Handyhalter (Baseplate): Unterbrechung]
                        Reset counter: 64
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:08:33
    9458193 - Control Module for Cellular Telephone
              B1052 14 [009] - Open or Short to Ground
              [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung/ Kurzschluss nach Masse]
                        Reset counter: 24
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:08:33
    0022 - Radio
              U1066 00 [008] - No Communication
              [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                        Reset counter: 65
                        Mileage: 381627 km
                        Date: 2020.02.27
                        Time: 01:00:48
    Address A5: Frt Sens. Drv. Assist
    End----------(Elapsed Time: 02:04, VBatt start/end: 14.8V/13.4V)-----------
    Sep 2017
    Belgium
    I have the scan from the donor car as well but some components were already removed from the car before scanning it.
    Saturday,01,February,2020,08:46:41:48725
    VIN: WVWZZZ3CZBE320764   License Plate: DONOR
    Mileage: 108580km-67468mi   Repair Order:
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 4F 52 53
    VIN: WVWZZZ3CZBE320764   Mileage: 108580km-67468miles
    14-Susp. Elect. -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    6C-Back-up Cam. -- Status: Cannot be reached 1100
    6D-Trunk Elect. -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
       Part No SW: 03C 906 016 BF    HW: 03C 907 309 E
       Component: 1.4l R4/4V TS H15 9073
       Revision: L5H15---    Serial number: 00000000000000
       Coding: 00190012002401000000
       Shop #: WSC 00017 666 01711
       ASAM Dataset: EV_ECM14TFS01103C906016BF 001006
       ROD: EV_ECM14TFS01103C906016BF.rod
       VCID: 6492A46E9ED05A774DF-8030
    8 Faults Found:
    8221 - System Voltage
              P0562 00 [032] - Too Low
    4635 - Engine Oil Temp. Sensor (G8)
              P0196 00 [032] - Implausible Signal
    2813 - Accelerator Position Sensor (G79)
              P2122 00 [032] - Signal too Low
    2815 - Accelerator Position Sensor 2 (G185)
              P2127 00 [032] - Signal too Low
    4675 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [039] - -
              [Software Incompatibility with Anti-Lockplease read DTC]
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:16
                        Engine speed: 1119.50 /min
                        Normed load value: 16.5 %
                        Coolant temperature: 21 °C
                        Intake air temperature: 11 °C
                        Voltage terminal 30: 11.803 V
                        Cruise Control System (CCS): status-Bits 0-7: 47
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Acceleration: 0.000 m/s²
    4629 - ECM Power Relay Load Circuit
              P068A 00 [039] - Opens Too Early
                        Coolant temperature: 0 °C
                        Intake air temperature: 0 °C
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 13.028 V
                        Mass flow through throttle valve: 0.0 kg/h
                        Median injection timing: 0.000 ms
                        Engine operating condition: Part. load
                        Engine operating condition-Test_Program_Channel 87: 6
    4043 - Boost Pressure Regulation
              P0234 00 [096] - Limit Exceeded (Overboost Condition)
    4044 - Boost Pressure Regulation
              P0299 00 [096] - Control Range Not Reached
       Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
       Component: J104   C2 450M VD18 0005
       Revision: --H07---    Serial number: 00000003463321
       Coding: 0003432
       VCID: 382A201E7E586E97317-806C
                        Fault Frequency: 57
                        Reset counter: 24
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 2
                        Hex Value: 0x0000
                        Fault Frequency: 56
                        Reset counter: 24
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 3
                        Hex Value: 0x0000
                        Fault Frequency: 23
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:01:09
                        Hex Value: 0x0000
                        Voltage: 10.25 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000003
       Shop #: WSC 00015 115 08193
       VCID: 6E86C646401CE0272BB-803A
    13701520 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Türsteuergerät hinten links - kein Signal/Kommunikation]
                        Fault Frequency: 10
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:22
              U1111 00 [009] - -
                        Fault Frequency: 10
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:22
       Revision: BC413001
       VCID: 392C251A4952779FCE9-806C
       Component: Wischer 22091  10  0603
       Coding: 00B795
       Component: RLS 241110 05  54  0403
       Coding: 033028
    15 Faults Found:
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Fault Status: 00101110
                        Reset counter: 64
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:02:55
                            Term 15 On
                        Voltage: 10.40 V
    00317 - Rear Lid Control Module (J605)
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:02:36
                            Term 15 On
                        Voltage: 10.05 V
                        Fault Status: 00100001
                        Fault Frequency: 40
                        Reset counter: 63
                        Mileage: 102588 km
                        Date: 2020.04.06
                        Time: 10:46:13
                            Term 15 On
                        Voltage: 14.85 V
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:23
                            Term 15 On
                        Voltage: 9.55 V
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:23
                            Term 15 On
                        Voltage: 9.55 V
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:02
                            Term 15 On
                        Voltage: 9.35 V
    01503 - Bulb for 3rd Brake Light (M25)
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:03:15
                            Term 15 On
                        Voltage: 14.65 V
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:02:37
                            Term 15 On
                        Voltage: 10.05 V
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:02
                            Term 15 On
                        Voltage: 9.30 V
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:02
                            Term 15 On
                        Voltage: 9.30 V
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:02
                            Term 15 On
                        Voltage: 9.35 V
    02738 - Bulb for Tail/Brake Light; Left
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:03:15
                            Term 15 On
                        Voltage: 14.75 V
    02739 - Bulb for Tail/Brake Light; Right
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:03:15
                            Term 15 On
                        Voltage: 14.70 V
    02740 - Bulb for Tail Light 2; Left
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:03:15
                            Term 15 On
                        Voltage: 14.70 V
    02741 - Bulb for Tail Light 2; Right
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:03:15
                            Term 15 On
                        Voltage: 14.70 V
       Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
       Component: PARKHILFE PLA H04 0007
       Revision: --------    Serial number: 20431032416146
       Coding: 308206
       ASAM Dataset: EV_EPHVA2C000000000 001006
       ROD: EV_EPHVA2C000000000_001_VW36.rod
       VCID: 3C223C0E46E042B7D5F-8068
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:01:29
    13637396 - Databus
              [Bremsensteuergerät - mBremse_10.B10_Wegimp_HL - Fehlerspeicher auslesen]
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:21
    13637397 - Databus
              [Bremsensteuergerät - mBremse_10.B10_Wegimp_HR - Fehlerspeicher auslesen]
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:21
       Revision: 22014000    Serial number: 003JZPNCR3R2
       Coding: 0012360
       Subsystem 1 - Serial number: 6332MTS678272990
       Subsystem 2 - Serial number: 6342MTS605162990
       Subsystem 3 - Serial number: 00000000000000000
       Subsystem 4 - Serial number: 00000000000000000
    9 Faults Found:
    01588 - Igniter for Head-Airbag; Drivers Side (N251)
                        Fault Status: 11100001
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
    01589 - Igniter for Head-Airbag; Passenger Side (N252)
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
    01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
    01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
                        Fault Status: 11101010
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:21
    01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256)
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:21
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101128301046
       Coding: 118A250000
       Coding: E20000
    365060 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Reset counter: 64
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:02:06
       Part No SW: 3AA 920 880     HW: 3AA 920 880
       Component: KOMBI         H02 0206
       Coding: 161F01
       VCID: 70BAD83E5A28F6D7397-8024
    9453074 - Fuel Level Sensor 1
              B103E 1B [009] - Resistance Too High
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:24
    13649664 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Heckdeckelelektronik: keine Kommunikation]
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:04
       Coding: 462006
       VCID: 3432142E6E308AF71DF-8060
    7 Faults Found:
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:01
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:01
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:05
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:05
    00471 - Control Module for Elect. Regulated Dampers (J250)
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:15
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:05
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:02
       Component:    IMMO         043 0399
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7668976375
       VCID: 280AF05EA2F8FE17A17-807C
       Coding: 04010002010000A000
       VCID: 2E060646801CA0276BB-807A
    10 Faults Found:
    00859 - Line-Output; Front Right
                        Reset counter: 64
                        Mileage: 108576 km
    00823 - Line-Output; Front Left
                        Reset counter: 64
                        Mileage: 108576 km
    00869 - Line Output; Rear Right
                        Reset counter: 64
                        Mileage: 108576 km
    00860 - Line-Output; Rear Left
                        Reset counter: 64
                        Mileage: 108576 km
    00856 - Radio Antenna
                        Fault Frequency: 10
                        Reset counter: 24
                        Mileage: 108576 km
                        Fault Frequency: 10
                        Reset counter: 24
                        Mileage: 108576 km
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:07
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:52
                        Fault Frequency: 12
                        Reset counter: 24
                        Mileage: 85819 km
                        Date: 2025.02.05
                        Time: 17:33:10
                        Reset counter: 64
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:12
       Revision: 12110009    Serial number: 0001811102
       Coding: 0210B7
    65538 - Local Data Bus
              U10BA 00 [009] - No Communication
              [Front Timeout LIN Sub bus]
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:02
       Component: J500__APA-BS KL.315 0802
       Revision: 1AH03729    Serial number: 00103270183601
       Coding: 0000258
    01288 - Terminal 30; Steering Assist
                        Fault Priority: 9
                        Reset counter: 24
                            Term 15 On
                        (no units): 2.0
                        Voltage: 12.10 V
    01316 - ABS Control Module
                        Fault Status: 11101101
                        Fault Frequency: 18
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:22
                            Term 15 On
                        (no units): 4.0
                        Voltage: 9.70 V
       Component:    KSG PQ47 ELV 043 0631
       Coding: 01900A00D2830E76300494157C084FCE707C01
       Subsystem 1 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HORN H11 9004
                        Fault Frequency: 11
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:07
                        Reset counter: 64
    00625 - Vehicle Speed Signal
                        Reset counter: 64
    00332 - Control Circuit for Tank Flap
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:12
       Coding: 050B0508
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H02 0220
       Component: J394EE20SKB13  H02 0220
       Subsystem 3 - Part No SW: 3AA 919 204     HW: 3AA 919 204
       Component: Analoguhr  003 0003
       Revision: 14110009    Serial number: 0001833642
       Coding: 0210B6
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2020.02.01
                        Time: 00:00:02
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000063483
       Coding: 0022067
       VCID: 33301732673E8DCF045-8066
                        Fault Status: 01101101
                        Fault Frequency: 43
                        Reset counter: 24
                        Voltage: 11.70 V
                        Count: 104
                        Hex Value: 0x1270
                        Hex Value: 0x0082
                        Hex Value: 0x0101
       Coding: 02B200104F000200
       Coding: 2C0000
       Coding: 2C0000
              U1014 00 [009] - -
              [Steuergeraet falsch kodiert]
                        Reset counter: 24
                        Time: 00:00:00
    13705985 - Databus
              [Fehlerwert im Signal BR3_Rad_kmh_HL]
                        Fault Frequency: 21
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:21
    13705987 - Databus
              [Fehlerwert im Signal BR3_Rad_kmh_HR]
                        Fault Frequency: 21
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:21
    13705473 - Databus
              U1121 00 [137] - Missing Message
              [Timeout mNiveau_2]
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2026.12.11
                        Time: 00:00:03
    10 Faults Found:
                        Reset counter: 64
                        Mileage: 108576 km
                        Reset counter: 64
                        Mileage: 108576 km
                        Reset counter: 64
                        Mileage: 108576 km
                        Reset counter: 64
                        Mileage: 108576 km
                        Fault Frequency: 10
                        Reset counter: 24
                        Mileage: 108576 km
                        Fault Frequency: 10
                        Reset counter: 24
                        Mileage: 108576 km
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:07
                        Reset counter: 24
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:52
                        Fault Frequency: 12
                        Reset counter: 24
                        Mileage: 85819 km
                        Date: 2025.02.05
                        Time: 17:33:10
                        Reset counter: 64
                        Mileage: 108583 km
                        Date: 2021.05.03
                        Time: 00:00:12
       Coding: 032B1864
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370203978
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
       Part No SW: 3AA 980 654     HW: 3AA 980 654
       Component: MFK_Gen1      H08 0102
       Serial number: 0134741949
       Coding: 000002000102020D0200040000000000
       ASAM Dataset: EV_47X 001639
       ROD: EV_47X.rod
       VCID: 75B4E92A254AD3FFEA1-8020
    End----------(Elapsed Time: 01:52, VBatt start/end: 14.9V/14.9V)-----------
    Sep 2017
    Belgium
    I have to mention as well a few things that might be important:
    1. For the DCC the donor car had also a sensor at each wheel hub + the one on the struts witch I don't use as well.
    2. The navigation RNS510 came with the R184 amplifier but I didn't pickup the Dynaudio speakers from the doors so when I've connected the wires to the door connectors I saw that for the front I have only 1 pair but the new cable had 3 pairs (low, miss, highs). For the moment I have no audio and I assume it's because of the speakers that I have. I will try to pick them up next time I go there.
    3. The donor car had a front camera witch I took as well but for now I don't have a windscreen that supports it so if possible I want to disable that feature.
    4. The J533 that I had didn't allow me to start the car so I've used the one from the donor car and that one is working.
    5. I've installed all 3 G-sensors (I don't know if they are needed for AFS or not)
    6. The front left angle sensor is not connected yet since I'm fixing one ball joint due to rust.
    5. The front fog lights and static cornering lights do not work at all but I've tested the wiring and it's all good.
    Thanks.
    Jan 2015
    Bosnia and Herzegovina
    You made an unbelievable mess of this, I like it
    1. For DCC you need all of the sensors connected, from scan there is no communication with dcc module
    2. For Navigation recode that there is no amplifier and reset it holding (< > and star or i button) after that you will have sound if you're retrofit amp scratch this
    3. Front camera can be later retrofitted and can be coded out from J533
    4. J533 needs to be coded to your car / current situation
    5. AFS needs all sensors to operate, directly connected or via can shared connected to dcc
    6. Get it cleaned, if sensor is moving hard, it's toasted
    Best of luck
    Also try to connect all of the electronics, clear errors and post fresh scan
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
    Sep 2017
    Belgium
    you think?
    I will post some pictures later....it was a mess but I said that it can't be that hard to follow Elsa wiring diagrams and cross check each wire where it's going
  9. #8
    Sep 2017
    Belgium
    I can't do the basic settings on the AFS module. The process starts but it keeps running forever (I didn't wait more then 5min). I see the xenon shape on the wall changes but nothing else.
    What else am I missing or how long does it take to do the basic settings?
  10. #9
    Quote Originally Posted by RARES View Post
    It takes until you tell it to stop.
    See Headlight Adjustment section here.
  11. Likes PetrolDave liked this post
  12. #10
    Sep 2017
    Belgium
    Thanks for that info.
    I've cleared that alarm now.
    A few more left
    I still have a J17 pump relay fault that I didn't have before.
    I've seen on the petrol harness that I removed from the donor car that there is a relay right outside of the fuel pump under the back seats.
    My diesel car does not have that there.
    Also the manual AC is not working properly...it is always heating and middle front vents do not open. I've read that there is a way for the climatronic to calibrate it. Is it possible to do it on manual AC as well?
