Results 1 to 10 of 10
Thread: C7.5 A6 - Changing Center Display Model Logo
    Feb 2016
    CT, USA
    Question C7.5 A6 - Changing Center Display Model Logo
    Hi there,
    Trying to figure out how to leverage VCDS to change the logo displayed on my A6's center display to either the S6 or RS6 logo. I did it with my A3, don't hate... Just like the logo
    I was told on another forum that using a tool called "OBD11" you could easily do this by going into 17 for Instruments and then Byte 9 to change from a dropdown which is what I was honestly expecting as it was done that way with my A3... However, in the A6 I don't see that in the long coding helper. If it's possible using OBD11, I would assume it's possible using VCDS as well no?
    This is what was given to me as far as instructions using OBD11:
    Audi Logo Change
    Select Control unit 17 (Dashboard)
    Control unit Long Coding
    Byte 9
    Value set in accordance with 00 - A6 Startup Screen 01 - A7 Startup Screen 02 - S6 Startup Screen 03 - S7 Startup Screen 04 - RS6 Startup Screen 05 - RS7 Startup Screen 06 - S6 allroad Startup Screen 07 - S6 Hybrid Startup Screen 08 - A6 Startup Screen 09 - A7 Startup Screen
    The code for my car is:
    Monday,18,November,2019,13:12:17:61036
    VCDS Version: 19.6.2.0
    VIN: WAUFGAFC2GN086144   License Plate:
    Mileage: 139193km-86490mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 3C 42 44 46 52 53 55 5F
              62 6C 72 8F 90
    VIN: WAUFGAFC2GN086144   Mileage: 139193km-86490miles
    Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G2 907 551 A    HW: 4H2 907 551 A
       Component: 3.0l V6 TFSI  H10 0004
       Revision: --H10---
       Coding: 0A2A00320526010D3000
       ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
       ROD: EV_ECM30TFS0214G2907551A_002.rod
       VCID: 2959C69548174E07D0-807C
    24194 - PCV Valve Malfunction
              P052E 00 [109] - -
                        Mileage: 138465 km
                        Date: 2019.09.25
                        Time: 16:13:48
                        Engine speed: 705.75 /min
                        Normed load value: 23.9 %
                        Coolant temperature: 88 °C
                        Intake air temperature: 37 °C
                        Voltage terminal 30: 14.375 V
                        Air mass: actual value (mg/stroke): 151.40 mg/stroke
                        Throttle valve angle: 3.188 °
                        Oxygen ctrl factor with precontrol correction: -2.48 %
                        Oxygen control factor with precontrol correction: bank 2: -2.67 %
                        Engine status: Idling
                        Charge air pressure: actual value: 0.438 bar
                        Ambient air pressure: 0.998 bar
       Part No SW: 4G0 927 158 AM    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H19 1004
       Revision: --H19---
       Coding: 000001
       VCID: 79F9D6D5F8373E87E0-802C
       Coding: 44A7964122E569821B00
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: 41897E35D067A647E8-8014
       Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
       Component: BCM2 2.0      H37 0572
       Coding: 0DA86F4E000000000000
       VCID: 7F0D38CDEE1310B7DE-802A
       Serial number: 2315000204935016
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 4G0 820 043 CG    HW: 4G0 820 043 CG
       Component: KLIMA 2 ZONEN H14 0112
       Serial number: 11091500111261
       Coding: 66013118490000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 66C38DA99989A17F3D-8032
       Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
       Revision: 21020001    Serial number: 00001168863001
       Coding: 01050011003C9FE081004087C0003800CF9CD208A608022180000414F110150200600034030000
       VCID: 76E3DDE9C12951FF8D-8022
       Component: WWS57X 150808  H38 0080
       Serial number:         150820093130
       Coding: 0045F7
       Serial number: 20673541
       Coding: 02006D
       Component: E1 - LDS  H07 0044
       Serial number: 23 09 2015  00001126
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z020D7A31
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA121750000015669172
       Coding: 020300
       Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Serial number: 16188AC7000000000001
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G0002HTBZ
       Coding: 303331343135303334394A55304C34473053
       VCID: 346727E19FD503EF73-8060
       Component: BF-Gewichtss.  H11 0046
       Serial number: 6940000Y150001E2V70S
       Serial number: 3575HRB405N3JUCUD1OO
       Serial number: 3585HRB405T3JUCU5G4I
       Serial number: 3515JRB405P3I87IFHCV
       Serial number: 3525JRB405L3IT4AD85K
       Serial number: 3554VRB401A535LQ896C
       Serial number: 3564VRB401A535LQN1KY
       Revision: C0068538    Serial number: 90862OIJ00191
       Coding: 000034
       VCID: 3B750CDDBA8BCC97B2-806E
       Serial number: 14 08 2015  G0042630
       Part No SW: 4G8 920 986 P    HW: 4G8 920 986 P
       Component: TBenUsa       H11 0106
       Revision: 07001088    Serial number: 658190915592013
       Coding: 0BE609040B41D705020000
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K_AU57.rod
       VCID: 45816A25C44F8A67D4-8010
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000001986435
       Coding: C0CD073010
       ASAM Dataset: EV_GatewPkoUDS 001028
       VCID: 3B750CDDB28BCC97B2-806E
       Serial number: 9120167903
       Voltage stabilizer:
       Serial number: 15071700000000000279
       Revision: AA000000    Serial number: 00000166691003
       VCID: 77FDD0EDC62328F796-8022
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720KM1FI
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336524FD9ADB04D76A-8066
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0381171629
       Coding: 040211
       VCID: 397916D5B8B7FE87A0-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0381799031
       Coding: 040211
       Coding: 011F17015E00628002000012
       VCID: 479D602DF643987726-8012
       Component: RCevo         H53 0202
       Revision: 00000002    Serial number: 0000242066
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A7B09D9BDB1F59FA9-806E
       Revision: 00002001    Serial number: 0374675264
       Coding: 0106063A00FA408580B0080402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000312181
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST000JEXF900000
       Coding: 101F02
       Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93614170
       Coding: 011F17015E00628002000002
       VCID: 46836D29F149817FDD-8012
       Revision: --------    Serial number: 00000001603776
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D5132857CFF52273C-8078
       Coding: 04FA021122200400
       Coding: E01E00
       Coding: E01E00
    13705487 - Databus
                        Reset counter: 213
                        Mileage: 138515 km
                        Date: 2019.11.09
                        Time: 16:20:35
       Part No SW: 4G1 035 027 M    HW: 4G1 035 027
       Component: MU-H-LNS-US   042 1062
       Serial number: A279I0F7500082
       Coding: 017501020000000013220002041A00102F0006E5F17001047E
       Shop #: WSC 00612 002 1048576
       VCID: 2A5B39994D11451FD9-807E
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9FY802FML
       Multimedia Operating Unit:
       Serial number: 90349PJB000TV
       Component: Gracenote2  --- 3006
       VCID: 49996615E0576E0730-801C
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 0275000102002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
       VCID: 78FFD3D1C33D278F9F-802C
       Component: RGS-VL        H14 0080
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 31692EF560C736C718-8064
       Component: RGS-VR        H14 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326B21F965C10DDF61-8066
    End-------------------------(Elapsed Time: 05:59)--------------------------
    Byte 9 does appear to have the possibility of different start-up screens. Try values between what you have there now (00) and 0B. I would start with 01 and see what that does. Then 02, and so on.
  3. Likes PetrolDave, Dana, AudiSportB5S4 liked this post
    Feb 2016
    CT, USA
    Thanks Uwe! Question and forgive my ignorance here - is this something I'd do in the long coding helper? If I toggle onto Byte 9 in the LCH, I don't see anywhere (from memory) that I can enter in a value.
    You can choose Experimental Coding, there it is shown.
    No, actually he cannot. He is using a legacy interface.
    Quote Originally Posted by AudiSportB5S4 View Post
    Yes, you can do it there; just change the value manually.
  8. Likes AudiSportB5S4 liked this post
    Feb 2016
    CT, USA
    ^ Thanks Uwe! That worked... In VCDS in byte 9, the dropdown in the long-coding helper shows countries listed, not the different models. So when I changed it to 04 for the RS6 logo, it changed to something like Great Britain.. Maybe just mislabeled by Ross Tech?
    Now to figure out how to change the logo on the Navi screen!
  10. Likes Dana liked this post
  11. #8
    United States
    The Experiential Coding Helper (available with current Ross-Tech interfaces) shows various Start Up Screen in options Byte 9 but I see the conflict based on the label file and traditional coding helper options.
    They are in fact country based and ... that may be why I've noticed many NAR factory coding values set to HEX 00 "Country: Germany (D) / Left-Hand-Drive (LHD) OR Not Specified" rather than "Country: United States of America (USA) / Left-Hand-Drive (LHD)".
    It that's incorrect we can fix the label in a future update.
    P.S. I just noticed 5F doesn't have a label.
    I'll look into that as well.
  12. Likes Uwe, AudiSportB5S4 liked this post
  13. #9
    United States
    Your 5F part number is added to the redirect now but that alone won't load a coding chart since the label doesn't have one currently. Per the Experiential coding data for 5F that may be "Skinning" in Byte 17. If so, the options range between HEX 00 and 08 but they are rather generic (i.e. Skin_1, Skin_2, etc) so I don't know what to suggest. You may need to try a handful.
  14. Likes Uwe liked this post
  15. #10
    Feb 2016
    CT, USA
    Thanks!! I'll take a peek and report back.
  16. Likes Dana liked this post
