I have a Crafter in our fleet of vehicles and it's the only one we are having issues with.
It has an ESP Fault / ABS Fault and when this fault is on the dash we cannot read the engine or the ABS or ESP from the vehicle.
Anyone got any ideas to help us?
Auto Scan reads the various areas however there is an
Thank you Very much in advance for your help.
No Faults Found
Tuesday,25,February,2020,13:45:32:50477
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4520.4
VIN: WV1ZZZ2FZE7004416 License Plate:
Address 95: LT3 ESP
Control Module Part Number: 0009013202
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55F7823FF58D047FCA3-8000
VCDS Info:
Labels: None
ROD: CRFT1_ESP.rod
Tuesday,25,February,2020,13:59:04:50477
Chassis Type: 2F (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
B0 B1 B2 B3 B4 B5 B6 C1
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 843 B HW: 906 900 370 2
Component: IMMO 1231 1306
Revision: 00231000 Serial number: VWXDZ0M1041061
VCID: 2615F5F394EB5FE7939-8072
Address 94: LT3 Airbag
Part No HW: 9069005701
Shop #: WSC 00118 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
Address 95: LT3 ESP
Part No HW: 0009013202
Serial number: 000901320210851
ASAM Dataset: CRFT2_ESP 3
ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
Part No SW: 9069025601 HW: 9069010401
VCID: 0655957378AB7FE7F39-8052
No Faults Found
Address 99: LT3 Ign. Switch
Part No HW: 9069003702
Shop #: WSC 22616 044 723723
ASAM Dataset: 67 259
ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 1231 1306
Revision: 00231000 Serial number: 12345678901234
Address 9B: LT3 Driver Door
Part No HW: 9069000501
ASAM Dataset: 33 263
ROD: CRFT_FTUHR_33_263.rod
Address A1: LT3 Navi
Part No SW: 9069020500 HW: 9069060500
ASAM Dataset: 50 275
ROD: CRFT_NAV_50_275.rod
VCID: 7F5B009727712E2FB0F-802A
9472 - Rear Right speaker: Open circuit
Test Complete - Active/Stored
9468 - Rear Left speaker: Open circuit
9463 - Front Left speaker: Open circuit
Test Complete - Stored
94D2 - Radio antenna 1: Open circuit
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BA3F4873369320F9C7-802E
Address B4: LT3 Central Elec.
Part No SW: 9069024301 HW: 9069014300
ASAM Dataset: 33 340
ROD: CRFT_EZE_33_339.rod (*)
VCID: 025D8963548343C7DF1-8056
Address B6: LT3 Steering Wheel
Part No SW: 9065402545 HW: 9065402545
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 08499B4B72BF6997815-805C
End----(Elapsed Time: 05:29, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Tuesday,25,February,2020,14:00:31:50477
Address A1: LT3 Navi Labels: None
Control Module Part Number: 9069060500 HW: 9069060500
Software Coding:
Work Shop Code:
ASAM Dataset: 50 275 ()
Fault Codes have been Erased
Tuesday,25,February,2020,14:03:37:50477
Chassis Type: 2F-N/A (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
Address 01: Engine (J623-CKTC) Labels:. 03L-906-012-CKT.clb
Part No SW: 03L 906 012 C HW: 03L 906 012 A
Component: R4 2,0L EDC H26 5297
Revision: 72H26--- Serial number: VWXDZ0M1041061
Coding: 0119401020440C080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01103L906012C 002014
ROD: EV_ECM20TDI01103L906012A_002.rod
VCID: 2411EFFBEE57ADF78DD-8070
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [096] - Incorrect Correlation
Mileage: 95318 km
Date: 2047.15.31
Time: 31:63:63
Engine speed: 951.00 /min
Normed load value: 6.3 %
Coolant temperature: 81 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.940 V
Engine start: start synchronization: EPM_MODE_VERIFY
Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 33
Address 95: LT3 ESP
ROD: CRFT1_ESP.rod
No Faults Found
ASAM Dataset: 32 1048
ROD: CRFT_KOMBI_32_1048.rod
Address A2: LT3 CD Changer Labels:
VCID: 55F7823FFC0D047FCA3-FFFE
ASAM Dataset: 21 3
End----(Elapsed Time: 01:19, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Tuesday,25,February,2020,14:24:50:50477
Mileage: 95318 km
Date: 2047.15.31
Time: 31:63:63
Address 95: LT3 ESP
ROD: CRFT1_ESP.rod
No Faults Found
ASAM Dataset: 21 3
End----(Elapsed Time: 01:13, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
