2014 VW Crafter Chassis Cab (Luton) Not allowing reading
playaeamonn
C?ID=345456
I have a Crafter in our fleet of vehicles and it's the only one we are having issues with.
It has an ESP Fault / ABS Fault and when this fault is on the dash we cannot read the engine or the ABS or ESP from the vehicle.
Anyone got any ideas to help us?
Auto Scan reads the various areas however there is an
No Faults Found
Tuesday,25,February,2020,13:45:32:50477
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4520.4
VIN: WV1ZZZ2FZE7004416   License Plate:
                Address 95: LT3 ESP
Control Module Part Number: 0009013202
  Component and/or Version:
           Software Coding:
            Work Shop Code:
                      VCID: 55F7823FF58D047FCA3-8000
VCDS Info:
       Labels: None
       ROD: CRFT1_ESP.rod
Tuesday,25,February,2020,13:59:04:50477
Chassis Type: 2F (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 B    HW: 906 900 370 2
   Component: IMMO          1231  1306
   Revision: 00231000    Serial number: VWXDZ0M1041061
   VCID: 2615F5F394EB5FE7939-8072
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00118 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
Address 95: LT3 ESP
   Part No HW: 0009013202
   Serial number: 000901320210851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069025601    HW: 9069010401
   VCID: 0655957378AB7FE7F39-8052
No Faults Found
Address 99: LT3 Ign. Switch
   Part No HW: 9069003702
   Shop #: WSC 22616 044 723723
   ASAM Dataset: 67 259
   ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        1231  1306
   Revision: 00231000    Serial number: 12345678901234
Address 9B: LT3 Driver Door
   Part No HW: 9069000501
   ASAM Dataset: 33 263
   ROD: CRFT_FTUHR_33_263.rod
Address A1: LT3 Navi
   Part No SW: 9069020500    HW: 9069060500
   ASAM Dataset: 50 275
   ROD: CRFT_NAV_50_275.rod
   VCID: 7F5B009727712E2FB0F-802A
9472 - Rear Right speaker: Open circuit
            Test Complete - Active/Stored
9468 - Rear Left speaker: Open circuit
9463 - Front Left speaker: Open circuit
            Test Complete - Stored
94D2 - Radio antenna 1: Open circuit
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3F4873369320F9C7-802E
Address B4: LT3 Central Elec.
   Part No SW: 9069024301    HW: 9069014300
   ASAM Dataset: 33 340
   ROD: CRFT_EZE_33_339.rod (*)
   VCID: 025D8963548343C7DF1-8056
Address B6: LT3 Steering Wheel
   Part No SW: 9065402545    HW: 9065402545
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 08499B4B72BF6997815-805C
End----(Elapsed Time: 05:29, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Tuesday,25,February,2020,14:00:31:50477
                Address A1: LT3 Navi       Labels: None
Control Module Part Number: 9069060500    HW: 9069060500
           Software Coding:
            Work Shop Code:
              ASAM Dataset: 50 275 ()
Fault Codes have been Erased
Tuesday,25,February,2020,14:03:37:50477
Chassis Type: 2F-N/A (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
Address 01: Engine (J623-CKTC)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 C    HW: 03L 906 012 A
   Component: R4 2,0L EDC   H26 5297
   Revision: 72H26---    Serial number: VWXDZ0M1041061
   Coding: 0119401020440C080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906012C 002014
   ROD: EV_ECM20TDI01103L906012A_002.rod
   VCID: 2411EFFBEE57ADF78DD-8070
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [096] - Incorrect Correlation
                    Mileage: 95318 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine speed: 951.00 /min
                    Normed load value: 6.3 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.940 V
                    Engine start: start synchronization: EPM_MODE_VERIFY
                    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 33
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
   ASAM Dataset: 32 1048
   ROD: CRFT_KOMBI_32_1048.rod
Address A2: LT3 CD Changer        Labels:
   VCID: 55F7823FFC0D047FCA3-FFFE
   ASAM Dataset: 21 3
End----(Elapsed Time: 01:19, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Tuesday,25,February,2020,14:24:50:50477
                    Mileage: 95318 km
                    Date: 2047.15.31
                    Time: 31:63:63
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
   ASAM Dataset: 21 3
End----(Elapsed Time: 01:13, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Thank you Very much in advance for your help.
