Help with Factory Trailer Hitch Retrofit (2016 Mk.7)
GolfOwner
C?ID=392784
Hi, I'm new to VCDS and hoping to get some advice. I have just retrofitted a factory folding towbar to my Golf Mk7. I used a used ORIS factory fit towbar/trailer hitch, the Kufatec wiring loom and a genuine VW but used J345 module (5Q0 907 383 G). I'm in the UK if that makes a difference.
This is the autoscan pre-fitting (there were a few fault codes, but old or known. I cleared them all before fitting):
Sunday,23,February,2020,12:21:36:28737
VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZGP103579   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGP103579   Mileage: 104356km-64843miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2795
   Revision: 22004001
   Coding: 0111401243451D092000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM16TDI03004L906056CL 002008
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 79AE161A595E56DF8EB-802C
Readiness: N/A
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 90476000012945
   Coding: 01FA8AA12420096F077C060741CC2580512490E06082A4F31440F078C002
   VCID: 7EA40506407071E7BB9-802A
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 168
                    Mileage: 85581 km
                    Date: 2019.02.23
                    Time: 20:41:06
   Part No SW: 5G0 907 426 AA    HW: 5G0 907 426 AA
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00120104202100001000000000000002
   Shop #: WSC 00028 028 00068
   VCID: 6A8C39562CF8ED47771-803E
329220 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Reset counter: 38
                    Mileage: 103278 km
                    Date: 2020.01.12
                    Time: 16:04:48
                    Voltage terminal 30: 14.1 V
                    Outside air temperature: 9.0 °C
                    Air distribution flap: actual value: 218
                    Air distribution flap: actual value: 71.0 %
                    Air distribution flap: specified value: 261
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Reset counter: 49
                    Mileage: 98988 km
                    Date: 2019.10.17
                    Time: 05:34:55
                    Voltage terminal 30: 14.2 V
                    Auxiliary heater: in stages-Act.val.: 1
   Serial number: 01061606401268
   Coding: 03000846C241027B0BA44080B11C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045077EE2E9C1B37EDD-8050
   Component: WWS    160221  042 0551
   Serial number:         160226201744
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y16M03D05H15M04S25
   Coding: 90A8DD
   Serial number: 000000000ZY112500FSH
   Serial number: 00000000000065172010
12307 - License Plate Light
          B12CA 01 [008] - Electrical Failure
                    Fault Frequency: 7
                    Reset counter: 56
                    Time: 00:00:00
   Revision: --------    Serial number: 39391605700599
   Coding: 0071051001
   VCID: 43D2B4F26B12DC0F947-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 19021603210553
   Coding: 00000300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A2CC9161CD89DC7C71-806E
   Serial number: 003MLR1J2DU9
   Shop #: WSC 00028 028 00062
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5AF802477A78EFB0F-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169677B08031650781
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169676B09031640668
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 703 16
   Serial number: 35767000000A6038991V
   Subsystem 4 - Part No SW: -----------    HW: 480 000 703 16
   Serial number: 35867000000B2748991.
   Subsystem 5 - Part No SW: -----------    HW: 480 401 003 16
   Serial number: 3516502AF1F353935207
   Subsystem 6 - Part No SW: -----------    HW: 480 401 003 16
   Serial number: 3526502A31F35395E15B
   Subsystem 7 - Part No SW: -----------    HW: 480 401 103 16
   Serial number: 3556502BF1F3539562AP
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 11031604401017
   Coding: 0400
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0D4652CA7DD65A7FB23-8058
   Part No SW: 5G1 920 941 A    HW: 5G1 920 941 A
   Component: KOMBI         202 6420
   Coding: 27A41A002780260001886A011400000000000000
   VCID: 270A0062FF6A102FA8F-8072
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 05031610801327
   Coding: 030100041F087300FB00005C080F00010001050000000000000000000000
   ROD: EV_GatewConti_013.rod
   Serial number: 29160000506740126095
   Coding: 2CFFFF
   Serial number: 2934389403
   Serial number: 0000189328020
   Coding: 00310220D001028000001000
   VCID: 47CAA0E25F2AF02F48F-8012
   Serial number: 00000000000012199033
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 44D0B7EE6E1CDB37ADD-8010
   Serial number: 0000189498101
   Coding: 00310020DE01028000801000
   VCID: 46D4ADE65820E927B39-8012
   Serial number: 00000000000012167820
   Coding: 050000
          B122D 29 [009] - Signal Implausible
                    Reset counter: 82
                    Mileage: 91418 km
                    Date: 2019.06.27
                    Time: 12:43:38
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    H24 0245
   Serial number: VWZAZ2S0107561
   Coding: 02730001FF00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 3038EB3ECAA45797795-8064
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9S0720728
   Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
          B201A 00 [009] - -
                    Reset counter: 7
                    Mileage: 85463 km
                    Date: 2019.02.12
                    Time: 13:32:22
                    Voltage terminal 30: 14.7 V
                    Status_Software_Version_Management-module_name:
5688 - Control Head for Mulimedia System
          B13C9 F2 [008] - On/Off Switch
                    Reset counter: 25
                    Mileage: 102198 km
                    Date: 2020.01.04
                    Time: 17:56:14
                    Voltage terminal 30: 12.6 V
End----(Elapsed Time: 02:11, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
So I fitted all the parts then used the guidance in this thread and links to do the coding. This is what I changed:
19-CAN Gateway] > [Gateway coding] > Check-mark at [69]
1 Engine Module:
to
0111401243551D092000
10 Park/Steer Assist Module:
0071051001
to
0071051201
13 Auto Dist.Reg Module:
00000300FE0739
to
00000B00FE0739
03 ABS Module:
Adaption: IDE04774 Vehicle and trailer stabilisation to ACTIVATED
09 Central Electric Module:
03000846C241027B0BA44080B11C072810000000000000000000000000000
to
03020846C241027B0BA44080B11C072810000000000000000000000000000
I then did the, clear faultcodes, ignition on off cycle mentioned above.
After the changes, dashboard is lit up with lots of warnings and errors. This is the autoscan:
 Tuesday,25,February,2020,11:51:52:28737
Workshop Code: 123 12345 023456
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 69
   Revision: 22004001
   Coding: 0111401243551D092000
   Shop #: WSC 12345 123 23456
25126 - Databus
          U1123 00 [035] - Received Error Message
                    Mileage: 104356 km
                    Coolant temperature: 6 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 10.984 V
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: Initializing
Readiness: N/A
0297 - Steering angle sensor
          B1168 16 [137] - Voltage Too Low
                    Reset counter: 16
                    Date: 2020.02.25
                    Time: 11:32:18
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:43
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:43
   Revision: 00001K06
   Coding: 03020846C241027B0BA44080B11C07281000000000000000000000000000
   Coding: 90A8DD
   Coding: 0071051201
13637426 - Databus
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
   Coding: 00000B00FE0739
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:20
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 11.6 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
   Coding: 333135
   Coding: 333135
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
   Coding: 0400
   Coding: 2CFFFF
   Coding: 0D0000
   Coding: 8103
16130 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
                    Motor status: 00
                    Supply voltage: 11.50 V
                    Temperature: 15.0 °C
                    KFC: 3F
                    KFA: 00 02
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 11.52 V
                    uAdSensI_SwitchedKl30_xdu16: 11.52 V
   Coding: 050000
          B201A 00 [009] - -
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:17
                    Voltage terminal 30: 11.6 V
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0404707205
   Coding: 0100000202000000
   VCID: 3B22CC1213E2A4CFDC7-806E
136203 - Supply Voltage
          P1757 00 [009] - Open Circuit
                    Reset counter: 16
                    Mileage: 104356 km
                    Date: 2020.02.25
                    Time: 11:32:19
End----(Elapsed Time: 01:29, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
So all the trailer stuff works perfectly: Lights, handle locking light, trailer alarm activation etc (only thing I haven't tested is the brake lights). However I currently have ACC, ESP, AIRBAG and TPMS errors in the car which I didn't have before. I haven't started it yet, I wasn't sure if this could help or would make things worse.
I feel like I might have missed some code or got some wrong (hopefully it isn't becuase I have broken something). Can anyone help with what I did wrong or suggest any changes?
As I said, this is my first post, so hopefully I gave the right amount of detail, if you need more or less just let me know.
Thanks for your help.
I've split this out into its own thread from this one.
DV52
C?ID=194404
^^^^ There's a kind-of "collective forum intelligence" in respect of the DTC on the hex 44 module HERE. The G85 sensor gets involved in lots of cross module activities on MQB platform vehicles - so clearing this DTC early-on in your post retrofit investigations is probably advantageous (IMO).
GolfOwner
C?ID=392784
Many thanks to Don, I have made a lot of progress. I did the "Simple Reset" mentioned in the MQB G85 Thread; thought I would give that a go before the full calibration. So I just did the drive round the block, go to both extremes of full lock, then clear the fault codes. This has solved most of the faults, so maybe these were actually as a result of the battery being disconnected. I'm certainly going to remember that in case I ever need to disconnect the battery again. Fitting the wiring to the fuseboard for this retrofit was impossible without disconnecting the power from the fuseboard; at least in a RHD car, very limited access (and the Kufatec instructions recommended disconnecting the battery anyway).
On the trailer; all lights are working, dashboard tells you trailer hitch is being unlocked when you unfold it, eco mode is being made unavailable and the rear parking sensors deactivated (all stuff its supposed to do).
So that's the good news, below is a scan of the remaining fault codes:
Wednesday,26,February,2020,09:03:32:28737
VIN: WVWZZZAUZGP103579   Mileage: 104357km-64844miles
   Revision: 22004001
Readiness: N/A
   Revision: 00001K06
   Coding: 90A8DD
   Coding: 0071051201
   Coding: 333135
   Coding: 333135
   Coding: 0400
   Coding: 2CFFFF
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
          B201A 00 [009] - -
                    Reset counter: 16
                    Mileage: 104357 km
                    Date: 2020.02.26
                    Time: 08:59:31
                    Voltage terminal 30: 12.2 V
                    Reset counter: 16
                    Mileage: 104357 km
                    Date: 2020.02.26
                    Time: 08:59:33
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
Two faults left. I'm not too worried about the SVM fault (that was there before). Not sure what to make of the supply voltage fault on the trailer module though?
Also there isn't a trailer attached light on the dashboard and the start/stop is still available with a trailer connected (this is supposed to be deactivated). When I did the coding, it wouldn't let me change anything other than the adaption in 3C ABS. I also couldn't find any settings to change for A5 Start Stop.
So I'm wondering if there is still a bit of coding missing, does anyone have any suggestions?
DV52
C?ID=194404
^^^GolfOwner: wow you certainly have made progress - well done indeed!! Of course anything is possible, but the DTC descriptor on the hex 69 module is not evocative of a coding fault. "Supply Voltage" - "Open ciruit" sounds more like a physical problem with wiring and/or connectors/fuse.
According to the pin-out on my WD for mk7's, Terminal 30 connections happen on Pin's #3, 4 and 5 of the 6 x pin connector on J345 module. I suggest that you grab a multi-meter and confirm that hard +12 volts appear on these pins. It might also be prudent to check the quality of the earth connection on pin #2.
PS: Did the SVM fault occur after a MIB software update? if so, have you tried using the XOR calculator method to delete the DTC?
GolfOwner
C?ID=392784
I checked the voltages as suggested, all good. The earth pin was reading about 0.8 resistance to the wheel arch earth (729).
There was a quirk (this is how I have understood the wiring diagram) in that the THRL connector that links the towbar earths to the 729 earth in the left rear wheel housing; the towbar loom has three earth cables, the wiring diagram shows three, but the Kufatec cable that links THRL to 729 only has two cables. I wasn't sure if this was important, but I added the extra cable; it hasn't cleared the code though.
Kufatec's loom does have a cable that is supposed to connect to the fuesboard (that should link to that 6x pin connector on the J345 module) that I didn't connect. Their instructions said it was optional, only for version 34350-1. It was supposed to link to SC22 on the fuseboard, but mine didn't look like it had a space for it; do you think it could be needed and causing the fault?
Re the coding; turns out the dashboard trailer light is only for errors (probably good that's not on!) and the start/stop isn't deactivated on factory fit towbars, only 3rd party ones; not sure why thats the case or how the car knows this... Either way it looks now like all the coding could be correct, but difficult to know if I have missed anything in the background.
GolfOwner
C?ID=392784
Re the SVM fault, we have had the car for a year and the last time it went to the dealer was a service when we bought it. The date the fault code first occurred was when or just after the dealer serviced it, so could be what you suggest. I haven't tried the XOR method, would you recommend it?
darkchina811
ITALY
C?ID=333184
SINCE THE DTC STATES YOU ARE MISSING A SUPPLY I WOULD DEFINITELY GIVE IT A SHOT.
YES IT DOESN'T HURT TRYING...
GolfOwner
C?ID=392784
I made a new connection on the fuseboard for the SC22 wire. I think it was just for split charging, so possibly why I hadn't missed the function when I tested the towbar. The open circuit fault has persisted though. Any Ideas what else could be causing it?
                    Reset counter: 16
                    Mileage: 104357 km
                    Date: 2020.02.28
                    Time: 08:53:07
darkchina811
ITALY
C?ID=333184
double and triple check the wiring diagram. you're not sending +12V somewhere where you should... or the diagram is wrong, sometimes it happens.
GolfOwner
C?ID=392784
I checked the wiring diagram again and some different fitting instructions; still no clue as to where the fault could be. In fairness the diagram I’m working from came from er-win. However er-win is clever; it knows my vin number shouldn’t have a towbar so won’t show me a wiring diagram with one. I had to use the generic car option to get a towbar wiring diagram for a golf, but it might not exactly match how mine should be wired though.
The car is now doing everything it’s supposed to do and the towbar is doing all the functions it should. It’s just this one error on Vcds. I have the car in bits at the moment (I was reluctant to put the dash back together until I knew it wouldn’t have to come to bits again). Not sure whether to put it all back together and use it to see if a problem appears or where else to look for a fault tbh? Could this fault code be software not getting the answers it expecting farther than a hardware fault?
Only other thing I thought... I bought the J345 module on the basis it should be the right version for the car and coded correctly, but how would I check?
darkchina811
ITALY
C?ID=333184
my Golf doesn't need to tow anything so I never looked too deeply into this retrofit. hopefully somebody with more expertise will chime in.
DV52
C?ID=194404
Golfowner: I had another look at the WD too - apparently stuff changed around May 2014. I'm not sure about the version J345 on your auto-scan - but perhaps it might be prudent to look more closely at the B socket end of the module: are there any wires on the B socket (from J345) that don't have a matching wire connected to the car's loom?
Dana
Western PA, USA
This suggestion may, or may not, shed light but I'd run a measuring function control module map on 69 and post the results for review. For instance, the info below was from a MQB based factory installed 5Q0 907 383 N Trailer module:
IDE03680-IDE00020,Supply voltages-Terminal 15 status,On,
IDE03680-IDE00773,Supply voltages-Terminal 15 status via CAN,On,
IDE03680-IDE04760,Supply voltages-Terminal 30 status output (pin 9 power outlet),OFF,
IDE03680-IDE04761,Supply voltages-Terminal 30 status output controlled (pin 10 power outlet),not coded/not installed,
IDE03680-IDE05404,Supply voltages-Status terminal 75x via CAN,On,
IDE03680-IDE05967,Supply voltages-Voltage terminal 30 left,12.8, V
IDE03680-IDE05968,Supply voltages-Voltage terminal 30 right,12.8, V
IDE03680-IDE05969,Supply voltages-Voltage terminal 30 trailer supply,12.8, V
IDE03680-IDE05970,Supply voltages-Voltage terminal 30 engine supply,Measured value not available,
IDE03680-IDE10782,Supply voltages-Voltage terminal 30 charging output,Measured value not available,
Observing those results may allow you to determine if there's a Terminal 15 or 30 group that's not reporting properly. If that is the case it may be easier to focus on specific tracks in the diagram (ASSuming the diagram is correct).
Evlogitos
Thessaloniki, Greece
C?ID=494399
Dear Friends, i have a golf 7 2017 hatchback and i want to retrofit an oem Tow hitch but I'm confused with to many vw code parts can anybody to help me what hitch can fit on my golf?
Best regards,
Stef
iichel
Netherlands, eastern part
C?ID=284912
It's probably dependent on the car you have, the hatchback or the combi. And I'm not sure whether you have or want options like folding, detachable, electrically, OEM, 7 or 13 pins, etc.
