Results 1 to 5 of 5
Thread: Skoda Fabia 2 electric windows fault ?
    Jan 2015
    Hi guys, got a 2008 skoda fabia 2, 5 door model, front electric windows only, if I take the 2 fuses out for the front electric windows, put the fuses back in, both the front the windows work fine, once I turn ignition off, and back on they wont work again until I pull fuses ??
    I know the wires in the door grommets are quite common, but checked them and all ok (and im sure if they were broke, pulling the fuses wouldn't change anything ?)
    anybody ever come across this please ?
    done a full autoscan and no faults logged anywhere …
    possible module ??
    any suggestions welcome please..
    Thanks Glenn
    It could not hurt to post that Auto-Scan. I understand there are no fault, but perhaps someone will spot something that's mis-configured.
    Jan 2015
    Wednesday,26,February,2020,10:15:28:17628
    VCDS Version: 19.6.2.2 (x64)
    VIN: TMBBD25J183055433   License Plate: A19DDG
    Mileage: 27060km-16814mi   Repair Order:
    Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
    Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
    VIN: TMBBD25J183055433   Mileage: 27060km-16814miles
       Part No SW: 03C 906 057 K    HW: 03C 906 057 M
       Component: BOSCH ME7.5.20      9718
       Revision: 21H01---    Serial number: SKZ7Z0G4309993
       Coding: 0000075
       Shop #: WSC 13765 790 00000
       VCID: 2C5D45E98C4FEB2F29-5140
    Readiness: 0110 0101
       Part No SW: 09G 927 750 HM    HW: 09G 927 750 HM
       Component: AQ 250 6F           1012
       Revision: 00H67000    Serial number:
       Coding: 0000072
       VCID: 030FCE554151C457B8-5140
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.clb
       Part No SW: 6Q0 907 379 AP    HW: 6Q0 907 379 AP
       Component: ESP 8.0 front   H03 0001
       Coding: 0000323
       VCID: 0B1FE67569018C17C0-5140
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 5J0 820 045
       Component: Klimaanlage        X0850
       VCID: 62C1EBD1EE0B6D5FD3-5140
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q0 937 049 F
       Component: 0000 BN-SG.         2S36
       Coding: 25742
       Shop #: WSC 13765
       VCID: 3D7B78AD373572A78E-5140
       Part No: 1C0 909 605 K
       Component: QN AIRBAG VW51 Q5   0010
       Coding: 20814
       Shop #: WSC 13765
       VCID: 2C5D45E9DC4FEB2F29-5140
    Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
       Part No: 5J0 920 920 B
       Component: KOMBIINSTR.    V2823466
       Coding: 17403
       Shop #: WSC 13765
       VCID: 2757BAC5C5A9C877C4-5140
       Part No: 6N0 909 901
       Component: 000H GATEWAY CAN    2S36
       Coding: 00015
       Shop #: WSC 13765
       VCID: 70E5919930E7CFCF55-5140
    Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
       Component: IMMOBILIZER    V2823466
       Coding: 17403
       Shop #: WSC 13765
       TMBBD25J183055433     SKZ7Z0G4309993
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeTRW        V270
       Coding: 10110
       Shop #: WSC 13765
       VCID: 6FE792E52DD9D0374C-5140
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 5J0 959 433 A
       Component: 03 Komfortgerát     0001
       Coding: 00019
       Shop #: WSC 13765
       VCID: 3163549DFB6D86C71A-4B04
       Part No SW: 5J0 035 161     HW: 5J0 035 161
       Component: Radio FO3       010 0029
       Revision: 00010000    Serial number: SKZ7Z3G0070871
       Coding: 0000400
       VCID: 5FC7E2258D7940B7FC-5140
    End-------------------------(Elapsed Time: 03:31)--------------------------
    I also unplugged the drivers door window motor/module (part number 6Y1959801) and did another full scan with it unplugged and nothing changed on the scan ? no faults ??
    is the drivers door window motor/module in the address 46 central conv ??
    thank you
    Best to use WD.
    Door controllers are just connected to each other, with LIN.
  5. Likes Uwe liked this post
    Jan 2015
    Purchased new window motor/module from main dealers, all working again now..thanks
  7. Likes Uwe liked this post
