Audi S5 ECU toomuch comms errors
RyMar
South Africa
C?ID=133909
Vehicle towed in to our workshop and bought at auction. Cannot interrogate ECU to check errors. Vehicle not cranking/starting.
Tuesday,25,February,2020,16:39:22:48706
VIN:    License Plate: HM19NRGP
Mileage: 182590km-113456mi   Repair Order:
Chassis Type: 8T0
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56
          5F 6C
   Mileage: 182590km-113456miles
Address 01: Engine        Labels:
   VCID: 55E264B9ACBF14E7A4-FFFE
   Note: Excessive Comm Errors
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 H    HW: 0B6 927 156
   Component: 0B6 42 FSIRdW H05 0005
   Revision: --H05---
   Coding: 001011
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3B36D201B2DBE297B2-806E
4785 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [039] - -
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:25
                    Transmission input speed: 0 /min
                    Transmission output speed: 0 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 25 °C
                    Accelerator position: 60.0 %
                    Clutch status: 0
2468 - Implausible Data Received from Engine Control Module
          U0401 00 [167] - -
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:25
                    Engine torque: 0 Nm
                    Accelerator position: 0.0 %
                    Clutch status: 0
4778 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [175] - -
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:26
                    Engine torque: 0 Nm
                    Clutch status: 0
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 124D08
   VCID: 7AB81705F5611B9FE9-802E
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0326
   Coding: 011000
   VCID: 014A60E998B74847A8-8054
   Subsystem 1 - Part No SW: 8T0 959 754 Q    HW: 8T0 959 754 Q
   Serial number: 0509000052903002
   Serial number: 0209000085142007
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:21
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001010033464
   Coding: 00217025002C00000000
   VCID: 43C6AAE1C22B9A57FA-8016
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01261120090857
   Coding: 48160000
   VCID: 76A00335C1797FFF8D-8022
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:21
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000397987
   Coding: 2600D0914034AF010009000000005D5D0F1D438800010141000000
   VCID: 3A38D705B5E1DB9FA9-806E
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 231109  H12 0070
   Serial number: SWF09110230045
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10690140
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001711090836
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:00
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:00
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840932300498
   Coding: 300102
   VCID: 40CCA5EDD33D814FE7-8014
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD07RR8S
   Coding: 30323433363030303030554A305238543053
   VCID: 41CAA0E9D0378847E8-8014
   Serial number: 6334MSME4D607205A
   Serial number: 6344MSME4D63550CM
   Serial number: 6352QSME024542363
   Serial number: 6362QSME56435826H
   Serial number: 63732SME3244453E
   Serial number: 63832SME07443812T
   Revision: --------    Serial number: 90304IKL0000M
   Coding: 000036
   VCID: 3D32DC19A4CFECA78C-8068
   Part No SW: 8T0 920 931 E    HW: 8T0 920 931 E
   Component: KOMBIINSTR.   H34 0255
   Revision: 00000000    Serial number: CI3707EC9
   Coding: 2F07010003000008010000
   VCID: 393AC809B0E7D087A0-806C
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E09B1400FC
   Coding: 00C303
   VCID: 52E89FA50D5103DF41-8006
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0170
   Serial number: 1909B00E091109
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010033291
   Coding: 00397325002C00000000
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1201
   Coding: 011C02225E01120102
   VCID: 50EC95AD035D71CF77-8004
   Revision: 00002001    Serial number: 0124286629
   Coding: 011A0682003904840030003280000000
   Component: J245EE20SKB13  H01 0220
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:21
00230 - Transmission Park Selector Switch (F305)
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:32:29
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882000533801
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1201
   VCID: 4FEE96D11E636E376E-801A
   Revision: 00000003    Serial number: 20000000253442
   VCID: 3424F93D97852DEF73-8060
                    Fault Status: 11101101
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:20
                    Voltage: 12.20 V
                    Count: 58
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 11100100
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:20
                    Voltage: 12.20 V
                    Count: 64
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 8K5 907 357
   Shop #: WSC 06324 000 00000
   VCID: 77BE0E31067306F796-8022
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:22
                    Reset counter: 27
                    Mileage: 182592 km
                    Date: 2020.02.25
                    Time: 16:30:22
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H45 0020
   Revision: AB001007    Serial number: 341K-097680408
   Coding: 060003010000000001
   VCID: 1C74319D1F1585AF5B-8048
   Part No SW: 8T2 035 754 D    HW: 8T2 035 754 D
   Component: H-BN-RW       H45 0047
   Revision: --------    Serial number: 485K7097512995
   Coding: 010901020206A1EF41000B0E000000030001
   Subsystem 1 - Part No: 8R0 060 884 D
   Component: ROW 2009/2010  5103
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356KT091140554
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000415500
   Subsystem 4 - Part No: 8R0 906 961 A
   Component:   CD-Database  1293
   Revision: --H03---    Serial number: 525PA8-J9Y9014
   Coding: 1022008
   VCID: 383CCD0D4BEDC98F5F-806C
End----(Elapsed Time: 02:06, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
Other modules have problems communicating with the ECU as well.
If it were mine, the first thing I would do is unplug the ECU from the harness and inspect the connectors on both the harness and the ECU itself, and perhaps open the ECU to check for water ingress and/or corrosion.
