Been having an intermittent starting problems.
Any one seen this code before? It happened once today at my office on my way home. Happened again an hour ago on my driveway on my way to get fuel. Then once again when I stopped at the coin op car wash to give it a quick wash.
Funny enough all times I tried starting it via the starting button then nothing happened; just a click. I then keyed it then it fired right up.
Terminal 30 @ 10.5V makes me clinch my eyebrows...
What do you all think...I'll throw in a new battery this week when I'm doing brakes...considering the battery is original...
The starter...does it require the entire motor / tranny assembly to be dropped to replace? Just want to prepare myself mentally for a worse case scenario SHTF scenario...
Thanks.
VIN: WVGEP9BP0DD012787 License Plate: AWZR150
Mileage: 107867km
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGEP9BP0DD012787 Mileage: 107867km-67025miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0013
Revision: 56H21---
Coding: 292A4012233600050000
Shop #: WSC 93008 999 00000
ASAM Dataset: EV_ECM30TDI0117P0907401K 001014
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: 373ED3AA8EF6DCF756-8062
5456 - Starter Will Not Turn
P3054 00 [046] - Jammed or Electrical Malfunction
Mileage: 107419 km
Date: 2020.02.07
Time: 11:06:12
Coolant temperature: 20 ∞C
Intake air temperature: 14 ∞C
Voltage terminal 30: 10.500 V
Starter control: Interlock- or P/N-signal-Bits 0-7: 17
Engine status: COENG_READY
Thanks.
