RS5 Spoiler
Cryptex
Estonia
C?ID=357213
I'm about to install the RS5 electrical spoiler on my S5. Most of it is pretty clear and understandable. I'm just confused over some things in the Wiring Diagram.
There are a couple of connection that I need help with.
B528 Connection 1 (LIN BUS) in main wiring harness; B473 Connection 9 in main wiring harness and B490 Connection 26 in main wiring harness.
What am I looking for exactly? Do they look like earth points or do I just have to open up the main harness and splice into the wires?
And thank you Ross Tech for the videos about learning how to read the wiring diagrams.
darkchina811
ITALY
C?ID=333184
that's correct, you splice into the wire, anywhere you find it / anywhere convenient.
Cryptex
Estonia
C?ID=357213
How do I identify the B528, B473 & B490 wires in the main wiring harness? There is no legend for them to tell color coding or anything like that.
PetrolDave
Westbury, UK
C?ID=1423
Look at the wiring diagrams you have posted, what color wires are shown on them?
Cryptex
Estonia
C?ID=357213
Yes I see those colors but I might be misunderstanding something. For example the first drawing, the wire going from J223 to J393 on the way it has to be spliced into B528 (LIN bus). As I understand I have to find the LIN bus wire and I suppose that is a different color coding than the wire from J224 to J393. I'm confused on how to locate the B528 in the wiring harness.
darkchina811
ITALY
C?ID=333184
B528 is already a splice point, means that the wire can go somewhere else, means that you'd probably find B528 on another page of the wiring diagram.
just find the wire and splice anywhere along its lenght. you know where it starts from and where it goes to, it's easy to splice close to control units.
Cryptex
Estonia
C?ID=357213
Okay. Thank you. I guess I will have a better picture once I actually start wiring.
vastechnics
C?ID=143747
you also need check that central conv need support
Cryptex
Estonia
C?ID=357213
I did. It has the 'Spoiler Installed Option'. :)
Cryptex
Estonia
C?ID=357213
Hey!
It's been a while and I have made some progress with the retrofit. The spoiler is installed and operating but I have a new problem and thought I'll continue on with this thread and hopefully find some help.
As you will see in the video below, my spoiler will not sit flush when retracted. It overshoots the target.
At first I thought it might just be a coding error and module 46 has to be thought where the spoiler zero position is. I did not find any basic settings nor adaptations related to the spoiler.
What I did find is that Measuring Blocks groups 160; 162 and 165 seem to have something to do with it. The numbers keep changing when I extend and retract the spoiler but sadly the fields in those blocks have no units so I can't say what the numbers correlate to.
From what I have gathered is that there are 2 limit switches ( F135 & F136 ) on the spoiler motor. So far I have been concentrating on the F135 which should be the lower limit switch. I also opened up the spoiler motor and thought maybe I can adjust the switch somehow but I found it to be one of the hall switches. So to my knowledge it can't just be moved around to specific target.
Even as I did the wiring myself I have also double checked the wiring from the motor to the control unit J223 and it is as it should per wiring diagram.
[video]https://1drv.ms/v/s!AkgJezHiOxFvlAWlDbudLeAQiAnG?e=1SFgoc[/video]
Wednesday,08,July,2020,16:15:16:39506
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8T89A0xxxxx   License Plate:
Mileage:    Repair Order: auto scan 08.07.20
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 10 13 15 16 17 18 19 1B 1E 36 37
          3C 42 46 47 52 53 56 57 6C 77
VIN: WAUZZZ8T89A0xxxxx   Mileage: 291730km-181272miles
Address 01: Engine (J623-CAUA)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 C    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0002
   Revision: 76H10---
   Coding: 01140003190F0220
   Shop #: WSC 00458 995 83769
   VCID: 3A2D307DBC563CFB5DF-806E
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 B    HW: 0B6 927 156
   Component: 0B6 42 FSIRdW H04 0030
   Revision: --H04---
   Coding: 001001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01001
   ROD: EV_TCMAL651.rod
   VCID: 3537234195C8D383B0D-8060
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 126D00
   VCID: 7BA3F579F3ECC5F3069-802E
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H08 0437
   Coding: 050000
   VCID: 015F87919100AF235C5-8054
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000032706014
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001104813
   Coding: C80170250F2400001000
   VCID: 42DD489DD486743B05F-8016
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 331GT087526681
   Coding: 0025001
   Shop #: WSC 00000 785 00200
   VCID: 46D5548DF4AE481B297-8012
   Subsystem 1 - Part No: 8T0 919 609 C
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000109019
   Subsystem 3 - Serial number: 0102.07.080000000100010073ÿ
   Subsystem 4 - Serial number: 010073ÿ
   Part No SW: 8T1 820 043 AD    HW: 8T1 820 043 AD
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C3000000    Serial number: 0103.06.080346
   Coding: 480A0006
   VCID: 73B3DD59DBBC8DB35E9-8026
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000071630
   Coding: 2600D0954034AF311709000000005D5D0F9CC3C80001014100  0000
   Shop #: WSC 52203 462 52877
   VCID: 303912556A2AF6ABE3B-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 020708  H13 0040
   Serial number: SWFBIE 0000123
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10175372
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 E    HW: 8K0 941 531 E
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002012070047
01771 - Control Module for Headlight Range (J431)
                    Reset counter: 120
                    Mileage: 291620 km
                    Date: 2020.07.07
                    Time: 17:13:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8492661
   VCID: 2A0D003D40F68C7B2DF-807E
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52830819300396
   Coding: 300102
   VCID: 3B233579B36C05F3469-806E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H07 0080
   Coding: 002BA0
   VCID: 6FBBD129B794A953BA1-803A
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD178G6
   Coding: 30313433363030303030554A304C38543053
   VCID: 3C213665B6E202CB4F3-8068
   Serial number: 6334MSME3D733253C
   Serial number: 6344MSME3D356D21K
   Serial number: 6352QSME77284F03N
   Serial number: 6362QSME78622475J
   Serial number: 63732SME7F0745734
   Serial number: 63832SME4E330F185
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90315HFQ000F8
   Coding: 00003E
   VCID: 3E253C6DA07E10DB617-806A
   Part No SW: 8T0 920 930 T    HW: 8T0 920 930 T
   Component: KOMBIINSTR.   H14 0221
   Revision: 00000000    Serial number: 97Y19E778
   Coding: 0F0701002F000008000000
   VCID: 47CB5989FFA45113D21-8012
                    Reset counter: 120
                    Mileage: 291620 km
                    Date: 2020.07.07
                    Time: 17:13:37
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 D    HW: 4H0 265 105 D
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20111126155722
   Coding: 4D2000
   Shop #: WSC 01455 003 1048576
   VCID: 2313ED192BDC5D336E9-8076
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F08627811F
   Coding: 000303
   VCID: 4ACD60BDECB6AC7BCDF-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1802A91A180608
   Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
   Component: DYNAMIKLENK.  H05 0490
   Revision: 50000003    Serial number: --------------
   Coding: 840000
   VCID: 2E050C2D701EE05BF17-807A
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B030539430C9573D69-807E
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001105079
   Coding: C8197B250F2400001000
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1060
   Revision: 00000000    Serial number: 333GQ087590324
   Shop #: WSC 01088 995 83683
   VCID: 3B233579BF6C05F3469-806E
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000104
   VCID: 3635244D844ED89BB97-8062
   Subsystem 1 - Part No: 8K0 907 568 B
   Component: J0770_SWA_Slave_H01 0040
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F15.07.0800H010003CD10134ÿ
   Subsystem 4 - Serial number: D10134ÿ
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: 	8
   Coding: 011C12225E002201
   VCID: 7DA7FB61EDF8CBC338D-8028
   Revision: 00002001    Serial number: 0527482987
   Coding: 011A0E80003985850030000000000000
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA101433000000296878
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814002106501
   Coding: 020101
   Shop #: WSC 12336 024 394758
   VCID: 3FDB4169A77419D36A1-806A
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: …AA
   VCID: 7CA1F665F6E2C2CB0F3-8028
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000168393
   VCID: 313F17516120FFA3EC5-8064
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Revision: 00000000    Serial number: 336G.087576724
   VCID: 2E050C2D7C1EE05BF17-807A
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 D    HW: 4E0 919 148
   Component: R78 TVHybridDVB     0440
   Revision: R0H06000    Serial number: 76300801631401
   Coding: 0000201
   VCID: 2411EE0522D25A0B173-8070
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J86902M
   Coding: 1021008
   VCID: 372B294983442193A21-8062
   Part No SW: 4E0 910 336 L    HW: 4E0 862 335
   Component: Handyvorb2      H20 1120
   Revision: 00000000    Serial number: 00000005195318
   Coding: 0010910
   VCID: 2B0305394F0C9573D69-807E
End----------(Elapsed Time: 01:56, VBatt start/end: 12.1V/12.1V)-----------
Still hoping that it Is just a matter of changing an adaptation to set a new end position.
NEtech
C?ID=56995
Maybe post Controller Maps in the different positions.
[Applications]
[Controller Channel Map]
- Controller Address = 46
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
File is placed in c:\Ross-Tech\Logs
There is also spoiler info at MWB 092
Cryptex
Estonia
C?ID=357213
Here is the CSV output with Spoiler extended
;SW:8K0-907-064-CQ   HW:8K0-907-064-CQ ---  Central Conv.
;Component:BCM2 2.0      H08 0437, Coding:011A0E80003985850030000000000000
;Wednesday,08,July,2020,23:23:32:39506
;VCDS Version: Release 20.4.1  Data version: 20200331 DS317.0
;VCID: 015F87919100AF235C5-8054
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,12.20 V,,12.20 V,,12.10 V,,    0000,,
2,Not Oper.,,Not Oper.,,Not Installed,,Closed,,
3,Not Installed,,Not Installed,,Not Installed,,Not Oper.,,
4,Not Installed,,Not Installed,,Not Installed,,Not Oper.,,
5,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
6,Door Closed,,Not Oper.,,Unlocked,,Not Safe,,
7,Door Closed,,Not Oper.,,Unlocked,,Not Safe,,
8,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
9,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
10,    0011,,    0000,,    0000,, ,,
11,0,,0,,Not Installed,,Not Installed,,
12,Not Installed,,Not Installed,,OFF,,Not Installed,,
13,Not Installed,,Not Installed,,0.0,,0.0,,
14,0.00 km/h,,Init. value,, ,, ,,
15,Retracted,,      00,,0.000 A,,20.0°C,,
16,Not Installed,,Not Installed,,      00,,OFF,,
17,0.5°,,Inactive,,6.5°,,Inactive,,
18,1.0,,1.0,,1.0,,3.0,,
19,1.0,,1.0,,1.0,,1.0,,
20,Inactive,,Inactive,,Inactive,,      00,,
21,255,,2127:15:31,,255:255 h,, ,,
22,255,,2127:15:31,,255:255 h,, ,,
23,255,,2127:15:31,,255:255 h,, ,,
24,255,,2127:15:31,,255:255 h,, ,,
25,     000,,      00,,OFF,, ,,
26,Not Oper.,,Lid close,,Not Connected,,Not Oper.,,
27,No,,ON,,Not Installed,,    0000,,
28,  010000,,00000000,,00000000,,      00,,
29, 0000000,, 0000000,, 0000000,, ,,
30,0.0,, 0000110,,      00,,10000110,,
31,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
32,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
33,0.0,,17.0°C,,  000001,, 0000000,,
34,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
35,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
36,21.0°C,,49.0,,9.9°C,,16.7°C,,
38, ,,10000110,, ,, ,,
39,00000000,,0.0,,0.0,,0.0,,
41,OFF,,OFF,,OFF,,OFF,,
42,      00,,Not Installed,,5.0,,      11,,
43,10100111,,00010000,,00000000,,      01,,
44,      00,,Not Installed,,OFF,,Not Installed,,
45,ON,,OFF,,ON,, ,,
46,Not Installed,,Not Installed,,     000,,      00,,
47,Not Installed,,Not Installed,,Not Installed,, ,,
48,2.0,,0.0,,4.0,,0.0,,
50,4,,OPEN,,Unlock,,1,,
51,5,,OPEN,,Single Door,,1,,
52,5,,OPEN,,Single Door,,1,,
53,4,,Closed,,safe,,1,,
54,19,,OPEN,,Unlock,,0,,
55,2020:07:09,,0:17 h,, ,, ,,
56,2020:07:08,,22:25 h,, ,, ,,
57,2020:07:08,,22:12 h,, ,, ,,
58,2020:07:08,,21:31 h,, ,, ,,
59,2020:07:08,,21:31 h,, ,, ,,
60,0,,   00000,,0,,   00000,,
61,9.0,,  000000,,10000110,,10000110,,
68,Not Installed,, ,, ,, ,,
73,0,,00011000,,    0010,, ,,
74,10000111,,  000100,,      00,, ,,
75,01000000,,00100010,,00010010,,01111100,,
76,0.0,,0.0,,0.0,,0.0,,
77,0.0,,0.0,,0.0,,0.0,,
78,217.0,,66.0,,0.0,,0.0,,
79,0.0,,7.0,,0.0,,4.0,,
80,0.0,,0.0,,0.0,,0.0,,
81,0.0,,        ,,        ,,        ,,
85,00000000,,00000000,,00000000,,00000000,,
86,0x0000,,0x0000,,0x0000,,0x0000,,
87,0x0000,,0x0000,,0x0000,, ,,
88,0.0,,0.0,,0.0,,0.0,,
90,167.0,,01000100,,0.0,,00000110,,
91,00000000,,11110000,,00000011,,00000000,,
92,122.0,,00100010,,10000100,,00000001,,
93,Not Occup.,,11111110,,Not Occup.,,Not Occup.,,
98,0.0,,4.0,,29488.0,,765.0,,
100,01,, ,, ,, ,,
101,0.0,,0.0,,0.0,,0.0,,
102,0.0,,0.0,,0.0,,0.0,,
103,0.0,,0.0,,0.0,,0.0,,
104,0.0,,0.0,,0.0,,0.0,,
105,0.0,,0.0,,0.0,,0.0,,
106,0.0,,0.0,,0.0,,0.0,,
107,0.0,,0.0,,0.0,,0.0,,
108,00000000,,0.0,,01101011 11100111,,124.0,,
110,--,,--,,--,,--,,
111,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
112,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
113,Not Installed,,Not Installed,,Not Installed,,Not Installed,,
120,--,,--,,--,,--,,
160,3.0,,188.0,,1.0,,0.0,,
161,0.0,,1.0,,0.0,,0.00 V,,
162,6.0,,22.0,,4.0,,22.0,,
163,2018:02:04,, ,, ,, ,,
165,16.0,,49.0,,2.0,,6.0,,
166,0.0,,0.0,,0.0,,3.0,,
167,0.0,,0.0,,0.0,,0.0,,
168,2018:02:04,, ,, ,, ,,
169,2018:02:04,, ,, ,, ,,
240,10101100 11110101,,10101000 11110101,,0.0,,11834.0,,
241,00001010 00100010,,00100010 00110011,,00001010 00001010,,00001010 00001010,,
242,11110011 11111111,,00000010 00000000,,00000000 00000000,,01001010 00000000,,
243,01011010 10100101,,10100101 01011010,,511.0,,1530.0,,
244,0.0,,0.0,,0.0,,0.0,,
245,0.0,,0.0,,0.0,,0.0,,
246,0.0,,0.0,,0.0,,0.0,,
Here is the CSV output with Spoiler retracted
;Wednesday,08,July,2020,23:25:18:39506
36,22.0°C,,48.0,,10.4°C,,16.8°C,,
45,ON,,OFF,,ON,, ,,
61,4.0,,  000000,,10000110,,10000110,,
81,0.0,,        ,,        ,,        ,,
90,202.0,,01001100,,0.0,,00000110,,
92,71.0,,00000111,,10000010,,00000001,,
100,01,, ,, ,, ,,
160,7.0,,27.0,,0.0,,1.0,,
161,0.0,,0.0,,0.0,,0.00 V,,
162,22.0,,6.0,,22.0,,4.0,,
165,32.0,,49.0,,0.0,,6.0,,
166,0.0,,0.0,,0.0,,5.0,,
242,11110011 11111111,,00000101 00000000,,00000000 00000000,,01001010 00000000,,
I do want to point out that group 092 field 1 & 2 act very erratically even when the spoiler is stationary and not in transition.
NEtech
C?ID=56995
Please copy data from the csv file direct with Notepad, not excel or similar, the formating of status values brake.
See also this thread.
Cryptex
Estonia
C?ID=357213
Hey, I edited the previous post and copied the CSV contents from notepad.
I also went through your suggested thread. Biffyg seemed to have a similar problem although his/hers spoiler would show a fault code, mine does not.
Going back to MWB 092.
Field 1 - Erratic readings spoiler stationary or in transition.
Field 2 - status for switch E127, seems to be erratic at first but it goes through a repeated sequence and I can make out that it does show when the button is pressed/released/activated.
Field 3 - status for the limit F135/F136 switches. Clearly shows when spoiler is in transition and when either of the switches is activated.
Field 4 - don't know what status this shows. It is constantly 00000001.
I also looked at the video for measuring the hall sensor voltage.
Measuring the voltage I got 10.8V. I know it is supposed to be at 5V ( according to video ), so I thought maybe I'm measuring something wrong and kept at it and funnily it was 4.67V for a brief time.
But it returned to 10.8V. I could not measure the running voltage because I need someone to push the E127 button, so maybe later I can come back with those figures as well.
Now that being said, there was one thing that made my head hurt.
There are 4 wires going into the motor. 2 signal wires and 2 power wires. There is a visual difference of the thickness of the wires. My logic says that the thicker ones are the + and - for the motor power and thinner ones for the hall sensor signal wires.
According to the WD 1 thin wire is signal for the hall sensor and 1 thick one is ground for the hall sensor. As it did not make sense to me, I took of the cap of the motor to look inside.
The WD correlates to the upper left and lower right pins being the signal wires for the hall sensor.
I can clearly see that the upper two pins connect to the hall sensor on PCB and the lower 2 run into the motor.
Can it be that the WD is wrong somehow, but then again I don't know how the motor is running at all then. I'm no electrical engineer and I might be completely wrong but I am still curious enough to dissect things to find out how they work. :)
NEtech
C?ID=56995
Which model does the spoiler items come from ?
A long shot, it looks like CAN Gateway has different coding for RS5 with spoiler.
00E303 (maybe especially Byte 1 Bit 5)
But if that is correct, your CAN Gateway is to old, need software version 117.
Cryptex
Estonia
C?ID=357213
The spoiler comes from an 2011 RS5.
Did not know that the CAN gateway has anything to do with it. I've read other retrofits about it and the thing that people have to check is that the 46 Central Convenience Module supports the spoiler. Mine previously did not and I replaced it.
I looked into module 19 coding and under Byte 1 I only have a drop down list with 2 options.
If it is too old, is it possible to just update the software?
Control Module Part Number: 8T0 907 468 L
  Component and/or Version: GW-BEM 5CAN-M H10 0092
           Software Coding: 000303
            Work Shop Code: WSC 06325
Advanced Identification
     Identification: TF7-MNL
     Revision: FB402044
     Date: 27.06.08
     Manufacturer number: 0F01
     Test stand number: 811F
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Status: 00000000
     Flash Date: 0000.00.00
     Flash Tool Code: 00000 000 00000
Software
     OSEK-OS: 03.02.00
     HiSpd Net: 01.07.00
     LIN 2.0: 00.01.12
     MOST Net: 01.0A.03
Misc.
     Hardware number: 8T0 907 468 L
     Workshop System Name: J533
VCDS Info:
       Labels: 8T0-907-468.clb
NEtech
C?ID=56995
I don't know if it is needed, as I wrote, long shot.
I have Autoscan of 7 RS5 2011 that have Spoiler with this coding, but it can certainly mean something else.
These are the only one out of 710 CAN Gateways that have Bit 5 active, Bit 6 and 7 are often active (from 2010, about efficiency).
8T0 907 468 AD 8T0 907 468 K GW-BEM 4CAN-M H09 0117 00E303
8T0 907 468 AE 8T0 907 468 L GW-BEM 5CAN-M H10 0117 00E303
Cryptex
Estonia
C?ID=357213
Is there no way to tell 46 where the spoiler is supposed to stop? Like through adaptations or basic settings?
NEtech
C?ID=56995
I have not found anything.
I guess it is done by hall-element and F135/136.
Cryptex
Estonia
C?ID=357213
HEUREKA!!!
Found it. It is channel 89 in adaptations. My guess is the number there represents revolutions.
It was originally set to 780 but I adjusted it many time and settled at 650. It WORKS now. :)
Thnx for all your help NEtech.
