Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: New crash sensors fitted...... Do they need??
    Nov 2016
    New crash sensors fitted today, will new ones need coding or will just clearing faults do the trick?
    AUDI A5 B9 2017
    Auto-Scan, please?
    Nov 2016
    Only got this scan from a few days ago.
    Car now starts and drives, steering fault is present, and so is the airbag fault.
    No other lights are on apart from airbag and steering, when i go into airbags module its coming up with crash sensor faults both drivers and passengers
    Nov 2016
    Audi A5 Forum & Audi S5 Forum banner
    Search Community
    A5 & S5 Topics
    non starter a5 b9
    Jump to Latest
    Unfollow
    1 - 7 of 7 Posts
    vw754
    Registered
    Joined Jan 14, 2014 · 481 Posts
    Discussion Starter • #1 • 4 d ago
    car has been in a front end collision,now repaired.
    mileage is quite low,but comes up with starter motor fault,the chaps had starter taken off and checked,all is ok with that,wiring seems good too..........any idea why it isn't turning over ? some unit next to the battery has also been replaced.
    Thursday,20,February,2020,13:36:50:22644
    VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
    VIN: WAUZZZF53HA031640 License Plate: 2017 A5 B9
    Mileage: 52964km-32910mi Repair Order:
    Chassis Type: F5-AU49 (8W5)
    Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
    AC BB BC D6 D7
    VIN: WAUZZZF53HA031640 Mileage: 52964km-32910miles
    29-Left Light -- Status: Cannot be reached 0100
    Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 026 AD HW: 04L 907 309 L
    Component: R4 2.0l TDI H35 1970
    Revision: B1H35---
    Coding: 0A254032232405083408
    Shop #: WSC 06314 790 00001
    ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
    ROD: EV_ECM20TDI01104L906026AD_001.rod
    VCID: 6C81C64BA60E702705F-8038
    5456 - Starter Will Not Turn
    P3054 00 [167] - Jammed or Electrical Malfunction
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:25:33
    Coolant temperature: 8 °C
    Intake air temperature: 9 °C
    Voltage terminal 30: 10.900 V
    Starter control: terminal 50 acknowledgment-Bits 0-7: 36
    Status of starter activation relay-Bits 0-7: 3
    Starter control: release conditions-Bits 0-7: 98
    Starter control: release conditions-Bits 0-7: 90
    Starter control: shut-off conditions 1-Bits 0-7: 0
    Number of manual engine starts-Bits 0-7: 0
    Number of automatic engine starts-Bits 0-7: 0
    Number of automatic engine starts-Bits 0-7: 9
    28252 - Coolant Pump 3
    P26FA 00 [039] - Air in System
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:33
    Voltage terminal 30: 11.420 V
    Engine status: COENG_READY
    23416 - Implausible Data Received from ABS Control Module
    U0415 00 [167] - -
    [Invalid Data Received FromAnti-Lock Brake System Control Module]
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:32
    Cruise Control System (CCS): status-Bits 0-7: 7
    selected gear-Bits 0-7: 0
    23410 - Implausible Data Received from ABS Control Module
    U0415 00 [039] - -
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:32
    Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
    Part No SW: 8W0 927 155 G HW: 0CJ 927 156
    Component: 0CK 20TDI RdW H03 0008
    Revision: --H03--- Serial number: 0000002027
    Coding: 000001
    Shop #: WSC 05761 780 00200
    ASAM Dataset: EV_TCMDL382021 002024
    ROD: EV_TCMDL382021_AU49.rod
    VCID: 43D34DF7EB105F5F945-8016
    Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
    Component: V553 MTFP 002 0572
    Serial number: 75117071170055001872
    Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
    Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
    Component: ESP9 Plus H06 0719
    Coding: 0CAA489A10A50A9711A44895007D5292E6A592301208508812 004A4967A549
    Shop #: WSC 06334 790 00001
    ASAM Dataset: EV_ESP9BOSCHCMP 001001
    ROD: EV_ESP9BOSCHCMP_001.rod
    VCID: 49CF5FDFC93C850F5E9-801C
    4522496 - Wheel Speed Sensor; Left Front
    C0502 00 [167] - Short to GND
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:32
    73 00 83 00 80 00 00 50 00 00
    Address 08: Auto HVAC (E87) Labels:* Redir Fail!
    Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
    Component: Klima Zone 3 H32 0090
    Coding: 141800295544440D0200010088000000000000000000000000 0000000000
    Shop #: WSC 06335 790 00001
    ROD: EV_AirCondiBHTCAU491.rod
    VCID: 372B2927AFC803FF38D-8062
    Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
    Component: J216 FLuftV H08 0003
    Serial number: 00000000000001367063
    Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
    Component: AQ_Hum_Sensor H01 0006
    Serial number: 4EB94B9880PAG0MUFU02
    Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
    Component: E265 Kli Fond H40 0080
    Address 09: Cent. Elect. (J519) Labels:* None
    Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
    Component: BCM1 MLBevo H13 0267
    Coding: 07501143E11800CD054587141BAC80B9110B31080000000000 00000020001A810A450122025601
    VCID: 025D88F3B48A9657DF3-8056
    Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
    Component: 494 RL 170214 036 0471
    Serial number: 00000001702090300234
    Coding: 5FC7F7
    Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
    Serial number: 20314638X81A955555A0
    Coding: 02005D
    Light switch:
    Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
    Component: E1 - LDS H06 0008
    Serial number: 05 07 2016 00717413
    Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
    Component: Y7_Innenspieg H09 0002
    Serial number: GX1CE114011723610049
    Coding: 210000
    Interior Light Module:
    Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
    Component: J528-Dachele H14 0130
    Serial number: B00305389
    Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
    Component: SL-B9/Q5NF H17 0010
    Serial number: 2616000212124002
    6 Faults Found:
    65878 - Databus
    [Brake control module: error value in FL wheel speed]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:32
    average_Voltage_terminals: 11.30 V
    Outside air temperature sensor-Resistance: 0.00 kOhm
    Outside air temperature sensor-Outside air temperature on CAN: 7.00 °C
    interior_temperature: 8.00 °C
    Vehicle speed: 0.00 km/h
    66672 - Control Module for Light Activation/Adjustment; Left
    U116E 00 [009] - No Communications
    [Left LCM: no signal/communication]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    131348 - Databus
    [Brake control module: received error value in signal ESP_FL_wheel-speed]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:31
    196750 - Databus
    [Brake control module: received error value in signal ESP front left distance pulse]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:31
    196754 - Databus
    [Brake control module: received error value in signal ESP front left wheel speed]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:31
    196758 - Databus
    [Brake control module: received error value in signal ESP system status]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:31
    Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
    Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
    Component: Airbag10.44 H03 0106
    Serial number: 003UP003HF5C
    Coding: AACCF0C00C800000585400F3D0CC00000000
    ASAM Dataset: EV_AirbaAU10BPAAU736 006015
    ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
    VCID: 4CC166CBC64E902765F-8018
    Subsystem 1 - Part No SW: ----------- HW: 442 061 403 17
    Serial number: 3577Y00AD20D80F383FH
    Subsystem 2 - Part No SW: ----------- HW: 442 061 403 17
    Serial number: 3587Y00AD20D80F0F3AH
    Subsystem 3 - Part No SW: ----------- HW: 442 0B2 102 17
    Component: SideSensor_Dr 1C7 0148
    Serial number: 3517700102A53DC58758
    Subsystem 4 - Part No SW: ----------- HW: 442 0B2 302 17
    Serial number: 3527700022A55169D7EC
    Subsystem 5 - Part No SW: ----------- HW: 442 0C1 603 17
    Component: FrontSensor_D 1C5 014A
    Serial number: 35575009B21E6005D2BD
    Front Sensor Passenger:
    Subsystem 6 - Part No SW: ----------- HW: 442 0C1 603 17
    Component: FrontSensor_P 1C5 014A
    Serial number: 35675009B21E6003C299
    Pedestrian Protection Center:
    Subsystem 7 - Part No SW: ----------- HW: 442 0C2 303 17
    Component: PedP_Sensor_C 1C5 014A
    Serial number: 2307500102A4CE1978A9
    9735443 - Pedestrian Protection Crash Sensor 2; Driver Side
    B148D 13 [137] - Open Circuit
    Mileage: 52964 km
    Time: 00:00:00
    9735699 - Pedestrian Protection Crash Sensor 2; Passenger Side
    B148E 13 [137] - Open Circuit
    Mileage: 52964 km
    Time: 00:00:00
    9682162 - Multiple collision brake
    B13BC F2 [137] - No function
    Reset counter: 22
    Mileage: 52965 km
    Date: 2019.08.26
    Time: 20:57:16
    1049349 - Databus
    [NWD: 0x103 ESP_03 error value ESP_VL_Radgeschw]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:31
    Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
    Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
    Component: Lenks.Modul H11 0009
    ROD: EV_SMLSKLOAU736_006.rod
    VCID: 76B5E423E842BAF7E3B-8022
    4203520 - Databus
    [Fehlerwert Raddrehzahlen (ESP_03)]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    Address 17: Instruments (J285) Labels:* None-SRI2
    Part No SW: 8W6 920 971 HW: 8W6 920 971
    Component: TDIeGB H09 0523
    Coding: 24A440D6288006000120E9601000000000000000
    ASAM Dataset: EV_DashBoardAU736 001022
    VCID: 015F87FFB18C8D4FC69-8054
    Part No SW: 8W5 907 468 D HW: 8W5 907 468 C
    Component: Gateway H30 0308
    Revision: 5A010004 Serial number: 0485A023717318
    Coding: 03010001000086404107000000590012481000070000000001 75078E10000000
    ASAM Dataset: EV_CGateCONTIAU491 002040
    ROD: EV_CGateCONTIAU491_002_AU49.rod
    VCID: 4ACD60D3CC3A8E17573-801E
    Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
    Component: J453 MFL H04 0002
    Serial number: 20170310205717 22227
    66567 - Local Databus
    U1030 00 [009] - Electrical Malfunction
    [LIN_1_Electric_Error]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:20:22
    Address 29: Left Light
    Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
    Component: ELV-MLBevo H05 0032
    Serial number: 17000056901007
    Coding: 8800000000000000
    ROD: EV_ELVMarquMQBB.rod
    VCID: 323D183344AAE6D70F3-8066
    13637378 - Databus
    [Errorvalue ESP_Wegimpulse]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    Result lock conditions: invalid
    ESCL locked: No
    ESCL unlocked: Yes
    Lock sensor: not activated
    Unlock sensor: operated
    Error mode 1: not active
    Error mode 2: not active
    Clamp S: On
    Clamp 15: On
    Clamp 15 Status: valid
    Remote Start: not active
    Driver door: Open
    Central locking locked external: unlocked
    Central locking safed external: Vehicle not secured
    Clamp Request: No
    Request highside lock: No
    HW highside lock: OFF
    Highside unlock: No
    Motor break: not active
    Activation lowside unlock: OFF
    Activation lowside lock: OFF
    I2C overflow: No
    I2C error pathflags: No
    I2C resetinfo: No
    I2C error cpu: No
    I2C error rom: No
    I2C error ram: No
    I2C length failure: No
    I2C error sda: No
    I2C communication failure: i2c no comm failure
    I2C state esp 10: i2c cnd false
    I2C cnd haco message: valid
    Coco reset: No
    Coco supply: On
    Password IMS OK: Yes
    Signature IMS OK: Yes
    IMS responded: Yes
    Positive authentification in current KL15 cycle: No
    Lifestate: Immobilizer download obtained
    Authentication valid (T1): No
    State of authentication state machine: WFS_AUTH_INIT_e
    UBat internal: 10.7 V
    UMotorBridge: 5.9 V
    Lock condition engine speed: Condition met
    Lock condition clamp S: Condition not met
    Lock condition clamp 15: Condition not met
    Lock condition E2E clamp status: Condition not met
    Lock condition timeout clamp status: Condition met
    Lock condition vehicle speed: Condition not met
    Lock condition E2E vehicle speed: Condition not met
    Lock condition timeout vehicle speed: Condition not met
    Lock condition Mode1: Condition met
    Lock condition drive readiness: Condition met
    Lock condition selector lever position parking: Condition met
    Clamp enable ESCL: not enabled
    Lock condition timeout distance pulse: Condition met
    Lock condition E2E distance pulse: Condition met
    Lock condition difference distance pulse: Condition not met
    Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
    Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
    Component: LCM_MLBevoH05 0024
    VCID: 77ABE927EF48C3FFF8D-8022
    Address 42: Door Elect, Driver (J386) Labels:* None
    Part No SW: 8W0 959 593 E HW: 8W0 959 593
    Component: TSG FS 005 0057
    Serial number: 0000246757509
    Coding: 001FCA625001000000001482
    196660 - Motor for Window Regulator
    B1487 54 [009] - Missing Calibration / Basic Setting
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:32
    Address 44: Steering Assist (J500) Labels:* None
    Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
    Component: EPS_MLBEVO_ZF H08 0409
    Coding: 09000380008000
    ASAM Dataset: EV_EPSZFAU49X 003018
    ROD: EV_EPSZFAU49X_003.rod
    VCID: 41DF47FFF10C4D4F869-8014
    17664 - Databus
    [KFC_ESP_22_SNA]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    Expanded ambient data 1-Engine running: Engine_not_running
    Expanded ambient data 1-Supply voltage: 0.00 V
    Expanded ambient data 1-Temperature: -70 °C
    Expanded ambient data 1-System status: 4
    Expanded ambient data 1: 00
    Expanded ambient data 1-driving_direction: 0
    Expanded ambient data 1-KFA: 0
    Expanded ambient data 1-KFC: 69
    Expanded ambient data 1-Ready_To_Drive_Bit: 0
    Expanded ambient data 1-StartStop Info: 0
    Expanded ambient data 1-Steering_Angle_Calculated: 5 °
    Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
    Expanded ambient data 1-Steering_torque: 0.00 Nm
    Expanded ambient data 1-Steering_Torque_Sign: 1
    Expanded ambient data 14-KFA_FAST_RESET: 0
    Expanded ambient data 14-KFC_FAST_RESET: 0
    Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 11.33 V
    Expanded ambient data 14-Voltage_terminal_30_unfiltered: 11.53 V
    28160 - Databus
    [KFC_ESP_03_SNA]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    Expanded ambient data 1-KFC: 110
    Expanded ambient data 1-Steering_torque: 0.10 Nm
    Address 46: Central Conv. (J393) Labels:* None
    Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
    Component: BCM2 MLBevo 018 0344
    Coding: 013500002F9100406309A0000600080231020010004306502F 04000000040030001F0001000000
    ASAM Dataset: EV_BCM2HellaAU736 012013
    ROD: EV_BCM2HellaAU736_012_AU49.rod
    VCID: 7EA5FC03C072F2B7BBB-802A
    Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
    Serial number: 000000000ZY1704434E2
    Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
    Serial number: 00000000000068981928
    Part No SW: 8W0 959 592 E HW: 8W0 959 592
    Component: TSG BFS 005 0057
    Serial number: 0000247801165
    Coding: 001FCA225C01000000001480
    VCID: 4BC365D7C340971F6C5-801E
    Part No SW: 8W0 035 192 G HW: 8W0 035 192 A
    Component: MU-HS-LND-EU 045 0191
    Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
    ASAM Dataset: EV_MUHigScl6C3DELP 001011
    ROD: EV_MUHigScl6C3DELP.rod
    VCID: 3A2D30139CDA1E97C73-806E
    Subsystem 1 - Part No SW: 8W0 919 866 M HW: -----------
    Component: ECE 2017 --- 0024
    Subsystem 2 - Part No SW: 8W2 919 604 HW: 8W2 919 604
    Component: AU49x_DU_STD H40 0008
    Serial number: AUZ8Z9GBH00V1E
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
    Component: ControlUnit_B H22 0134
    Serial number: APVAK121021700020061
    Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
    Part No SW: 8W8 959 107 B HW: 8W8 959 107
    Component: HDSG-Modul H13 0161
    Revision: -------- Serial number: 31270391200000
    Coding: 0610
    VCID: 48C95ADBD2367C07417-801C
    Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
    Part No SW: 8W2 713 041 L HW: 8W2 713 041 J
    Component: GSM-LL H09 0073
    Revision: 0L0D5012 Serial number: 20170313001576
    ROD: EV_GSMWaehlZFAU736.rod
    VCID: 3D273B0F8DF429AFE21-8068
    Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
    Part No SW: 8W6 907 217 HW: 8W6 907 217
    Component: BVS H14 0042
    Coding: 0404090300000403024023A0A50000FC00F0C020C000
    ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    VCID: 7F5B0107C778FBBFB0D-802A
    1123714 - Databus
    [Airbag_01_AB_Systemfehler]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:32
    Control Module temperature: 15 °C
    Voltage terminal 15: 11.40 V
    1123171 - Databus
    [ESP_03_ESP_VL_Radgeschw]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    1123173 - Databus
    [ESP_21_ESP_Systemstatus]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    1123960 - Databus
    [ESC_Bremsdruckgradient]
    Reset counter: 22
    Mileage: 52964 km
    Date: 2020.02.20
    Time: 13:19:30
    Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
    Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
    Component: SCR-Stg-G3H04 0005
    ASAM Dataset: EV_RDCMINERGAU736 005009
    ROD: EV_RDCMINERGAU736_AU49.rod
    VCID: 3039123B4AA6D4C7797-8064
    Part No SW: 8W0 959 595 E HW: 8W0 959 595
    Component: TSG HFS 005 0057
    Serial number: 0000247429878
    Coding: 000FC8220001000000001080
    VCID: 4EC56CC33052A2370BB-801A
    Component: TSG HBFS 005 0057
    Serial number: 0000247426770
    Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
    Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
    Component: LED1L H09 0008
    VCID: 176BC9A7CF0823FF18D-8042
    Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
    Component: LED1R H09 0008
    End----(Elapsed Time: 01:45, VBatt start/end: 11.3V/11.2V. VIgn 11.2V)-----
    HQ
    If the codes were flagged as "Intermittent", then they could clear out and see where you stand... but they look to be hard codes. Bad sensors? Wiring issues?
    This car has issues.... I'm guessing it is currently not on fire.
    Jef
  6. Likes vw754, Uwe liked this post
    Nov 2016
    �� �� �� Needs setting on fire lol.
    Its a lads i know, he rang me today saying he has fitted new crash sensors, with it being in a accident, so I've been asked go clear the codes, see if that does it.
    Nov 2016
    can you help on a couple of things?
    how do i code the headlight ?
    how do i code new crash sensors ?
  9. #8
    HQ
    As it stands with the airbag, the 2 codes I commented on are not a coding concern. You can't fix and "Open Circuit" with a scan tool.
    • Are the Pedestrian Protection Crash Sensors to factory design for this VIN?
      • If used or purcahsed from 3rd party.... good luck with that.
    • Are the electrical paths to factory design?
      • Wiring damage? Deformed electrical terminals?
    J519:
    For any given component or module to communicate, it must have power/ground/data. You will need to use the factory repair manual (wiring diagrams) and verify you've got those 3 things to the left headlight module. It could be as simple as a popped fuse.
    You need to get hands on with the car... please do so before Jack comes in here and making an ass of himself again.
    Jef
  10. Likes NitrousOxide liked this post
  11. #9
    Nov 2016
    Crash sensors are brand new genuine ones, from the dealers. Guys going double check wiring today.
    Crash sensors normally need coding or just clear the codes?
    No communication with steering either.
  12. #10
    Nov 2016
    Steering wheel says no communication, replaced the light with a new genuine one, cant code it...... But in central electrics, it says no communication.
