Rain Sensor/ Wipers / VW Touareg V10 2005
Wully
C?ID=345461
Hi
The wipers on my VW Touareg have stopped working
VCDS said it was the rain sensor.
Can the rain sensor be disabled within VCDS to emable manual operation?
Also if I get a replacement rain sensor , will it have to be coded to the car after fitting?
Bill
Monday,24,February,2020,18:47:17:05546
VIN: WVGZZZ7LZ5D052324   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ5D052324   Mileage: 170970km-106235miles
   Part No SW: 070 906 016 AA    HW: 028 101 148 1
   Component: V10 5,0L EDCG000AGMª6189
   Coding: 0010575
   Shop #: WSC 31414 000 00000
   VCID: 4FFB70550BCC76DF00F-5160
Readiness: 0 0 X X X
   Part No: 09D 927 750 BM
   Component: AL 750 6A           0545
   Coding: 0004136
   VCID: 7AADF181E0CE0377871-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D273A9DB160F44FE23-5160
   Part No SW: 3D0 909 135 Q    HW: 5WK 470 22
   Component: 0P Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D3288452
   Coding: 0147688
   VCID: 33331CA58724323F047-5160
7 Faults Found:
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
00183 - Interior Access/Start Authorization Antenna 1 (R138)
00192 - Rear Left Door Handle Touch Sensor (G417)
            007 - Short to Ground
00190 - Driver's Door Handle Touch Sensor (G415)
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
            009 - Open or Short to Ground
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77ABE8B5D3DC1E1FF8F-5160
   Part No: 7L6 907 044 H
   Component: CLIMAtronic 2+2   X 3717
   Coding: 0000030
   VCID: 392F2E8DA548C86FCEB-5160
   Subsystem 1 - Part No: 7L6 907 049 C
   Component: CLIMAtronic FOND  X 0306
7 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
02193 - Supply Voltage for Regulator for Fresh Air Blower
            010 - Open or Short to Plus
            014 - Defective
00445 - Loss of Refrigerant
                    Temperature: 73.0°C
                    RPM: 576 /min
                    Absolute Pres.: 0.0 bar
                    Temperature: -1.0°C
                    Temperature: 31.0°C
                    Temperature: 96.0°C
02599 - Rear Left Temperature Flap Motor (V313)
00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111868
   VCID: 47CB5875E3BCAE9F48F-5160
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª6189
   Coding: 0010575
16694 - Cylinder 10
            P0310 - 000 - Misfire Detected
                    RPM: 588 /min
                    Torque: 71.1 Nm
                    Voltage: 13.83 V
                    Temperature: 18.9°C
18361 - Turbocharger Control Module 2
            P1953 - 000 - Defective - Intermittent
                    RPM: 1890 /min
                    Torque: 347.6 Nm
                    Speed: 44.0 km/h
                    Load: 31.0 %
                    Bin. Bits: 00000000
                    Bin. Bits: 00100000
                    Absolute Pres.: 1438.2 mbar
                    Absolute Pres.: 1499.4 mbar
   Part No: 3D0 909 601 F
   Component: 0B Airbag 8.4E+ H11 1151
   Coding: 0012354
   VCID: 2615F5F144F65797939-5160
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 40D94369C69299A7895-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 980 T
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007411
   Shop #: WSC 00792 210 89726
   VCID: 49CF5E4DF5A858EF5EB-5160
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 C
   Component: Standheizung E1MAC
   Coding: 0000000
   VCID: 323D19A1783E3B370F1-5160
02251 - Heater Unit Locked
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D3A9B6B24927395-5160
00467 - TV Tuner (R78)
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5B0095FBEC265FB0F-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 6695B5F184769797539-513C
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 363525B194562717239-5160
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7L6 919 887 K
   Component:      Navigation     0634
   VCID: 4EC56D510CC67FD70B9-5160
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: 678BB8F5837C8E9F68F-513C
   Part No: 7L0 959 933 E
   Component: F9 HSG              0201
   Coding: 0000085
   Shop #: WSC 00792 210 91867
   VCID: 3E253D91BC66EF57FB9-4B00
   Subsystem 1 - Part No: 7L0 959 701 L
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 L
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
   Subsystem 5 - Part No: 7L0 907 719
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171
   Component: A  Innenraumsensor  0019
9 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
01134 - Alarm Horn (H12)
00485 - Drivers Outside Door Handle Central Locking Button (E369)
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 7L6 035 466
   Component: 12K-AUDIOVERST      0108
   VCID: 71BFD6ADBDB8402F36B-5160
00419 - Left Front DSP Midrange Speaker (R103)
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 A
   Component:        Radio        0634
   Coding: 0017057
   VCID: 313F16AD7D38002F76B-5160
Address 69: Trailer        Labels: 7L0-907-383-1D9.lbl
   Part No SW: 7L0 907 383 M    HW: 7L0 907 383 M
   Component: J345  Anhaenger     0080
   Revision: 4C009001    Serial number: 00000193386675
   Coding: 0016521
   VCID: 3E253D91BC66EF57FB9-5160
00532 - Supply Voltage B+
                    Fault Frequency: 13
                    Reset counter: 40
02564 - Trailer; Left Tail Lamps (M60)
            010 - Open or Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101010
                    Reset counter: 40
02563 - Trailer; Right Tail Lamps (M61)
                    Reset counter: 40
02565 - Trailer; Right Turn Signals (M63)
                    Reset counter: 40
   Part No: 7L0 919 283 F
   Component: 0F Einparkhilfe     1107
No Faults Found
Address 77: Telephone        Labels: Redir Fail!
   Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
   Component: FSE_275x        H18 0020
   Revision: 00000001    Serial number: 00000000149178
   Coding: 0000411
End----(Elapsed Time: 08:19, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
I think it would be appropriate to post an Auto-Scan so people can see the specifics, i.e. exactly how the vehicle is equipped and configured, and exactly what relevant faults it has.
Wully
C?ID=345461
ok thanks, Ill do that :)
Wully
C?ID=345461
Hi all
I've now inserted the latest Autoscan from this evening which shows the rain sensor fault code : 01520
thanks in anticipation :)
bill
Since the Rain/Light sensor doesn't show up as a sub-system in your CECM, I think it is not codable.
If you would like to try to eliminate it, subtract 8 from your CECM's coding. In other words, change it from 0111868 to 0111860.
Wully
C?ID=345461
Thanks for the reply Uwe. I have a feeling somehow that I need to check the circuit to the wipers before I alter any codes as Im not that confident in doing so yet
within VCDS :)
B
