Results 1 to 3 of 3
Thread: Airbag Control Module
    Feb 2020
    Finally got VCDS. Probably about 180,000 miles too late. From my research I think I need to replace the airbag module or do an air bag reset. Just looking for some advice, which is the preferred method. Autoscan below:
    Saturday,22,February,2020,16:51:29:57445
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 75 77
    VIN: 3VWD07AJ0EM383361   Mileage: 291360km-181042miles
    Address 01: Engine (J623-CPKA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 070 D    HW: 06K 907 425
       Component: Simos12.2     H09 6864
       Revision: --H09---    Serial number: 00000000000000
       Coding: 001A0012242400160000
       Shop #: WSC 00066 000 00228
       ASAM Dataset: EV_ECM18TFS02006K906070D 001010
       ROD: EV_ECM18TFS02006K906070D.rod
       VCID: 2B0301E5038B360F4C7-807E
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
       Part No SW: 09G 927 749 A    HW: 09G 927 749 A
       Component: AISIN AG6 G3  101 2856
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 001004
       ROD: EV_TCMAQ250031_001_VW32.rod
       VCID: 372B2D95CFC382EF38F-8062
       Revision: 00H31001
       Coding: A14B400C492A00FD850E02EA921A0041A71000
       VCID: 7DA7FFBDADFF68BFA23-8028
       Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
       Component: J301  Klimaanlage   0204
       Revision: 2001012S    Serial number: 00000001818915
       VCID: 6099A6C9364DA557A95-8034
       Part No SW: 5C0 937 087 J    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H34 0411
       Revision: B2034001    Serial number: 08013285130396
       Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300050002000
       VCID: 34311A99DE3569F71DD-8060
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Serial number: 14102585130911170315
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Serial number: 14102584130918171703
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0409910 FLE 20130814
       Coding: 020000
       Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587130917154757
       Coding: 800000
       Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586130918065448
       Coding: 800000
       Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
       Component: AirbagVW10    102 0912
       Serial number: 003MVD01FXXM
       Coding: 00004138
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 74B1DA999E3529F7DDD-8020
       Serial number: 6940000Y130000Y4130D
       Coding: 303036
       Serial number: 3572MSME6D50647CZZZ3
       Serial number: 3582MSME1619167DZZZ
       Serial number: 3516KSME2B2B1028ZZZQ
       Serial number: 3526KSME7A724227ZZZV
       Serial number: 3556LSME18217127ZZZN
       Serial number: 3566LSME744E6527ZZZ1
    10485769 - Internal Control Module Memory Check Sum Error
              B2000 09 [137] - Component Failure
              [Electronic Control Unit Malfunction]
                        Mileage: 254664 km
                        Date: 2019.06.26
                        Time: 07:52:54
       Part No SW: 5C6 920 953 B    HW: 5C6 920 953 B
       Component: KOMBI         H04 0809
       Coding: 270A01
       VCID: 2C0102F90685313745D-8078
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H34 0411
       Revision: B2034001
       Coding: 102200
       VCID: 70B9D689EAAD15D7395-8024
       Component: IMMO          H04 0809
       VCID: 6A8DC4E1CCF1EF07771-803E
    Address 2E: Media Player 3
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 69     3501
       Revision: 00H22000
       VCID: 392F2BADF557949FCEB-806C
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H03 0005
       Revision: -----07S    Serial number: VWZ4Z6N3657208
       Coding: 01000400020006
       VCID: 2517F7DD65EF007F9A3-8070
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0086
       Serial number: 000003554140506
       Coding: 02630102C2161A107F1606000000
       ROD: EV_OCULow_001.rod
       VCID: 53F379057B7B4ECF247-8006
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
              [roofline module open load]
                        Reset counter: 195
                        Mileage: 291360 km
                        Date: 2020.02.22
                        Time: 04:38:17
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 195
                        Mileage: 291360 km
                        Date: 2020.02.22
                        Time: 04:38:17
       Component: TELEFON       H05 0315
       Revision: 1B001001    Serial number: 00007665101716
       Coding: 0A10030080010110
       Shop #: WSC 01383 790 50316
       ROD: EV_UHVUMI.rod
       VCID: 2E0508F1309943276B9-807A
    End----------(Elapsed Time: 01:26, VBatt start/end: 14.4V/14.3V)-----------
    16.4905 S, 151.7375 W
    The fault code below, if it does not clear, would be a good indication there is an internal fault with the J234-Airbag Control Module.
    Based on some more research, this is further confirmed by the Volkswagen repair information and we have a Ross-Tech wiki page for this fault code.
    B2000 - Control Module: Defective
    ref:
    We recommend the use of the Official Factory Repair Information when attempting to diagnose and repair these vehicles.
    Hope this helps,
    drpeter
  3. Likes PetrolDave, Uwe, insanespiv liked this post
    Feb 2020
    DrPeter Thanks for the quick response!
