AUDI Q5
VOLKS
New Member
Algeria
H11-004518 (2nd hand?)
HI
I have Audi Q5 rear right left and passenger door cant open from outside only driver door
Saturday,22,February,2020,12:49:06:01473
VIN: WAUZZZ8RX9A044290   License Plate:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 62 72
VIN: WAUZZZ8RX9A044290   Mileage: 149690km-93013miles
Address 01: Engine (J623-CAHB)       Labels:* None
   Part No SW: 03L 906 022 NJ    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H01 9978
   Revision: 11H01---
   Coding: 01210023180F2118
   Shop #: WSC 39546 001 1048576
   ASAM Dataset: EV_ECM20TDI03L906022NJ A01008
   ROD: EV_ECM20TDI03L906022HN.rod
   VCID: 7AAD0F4D0C5F05C7871-802E
8621 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [032] - Circuit Malfunction
                    Mileage: 149652 km
                    Date: 2020.02.22
                    Time: 11:08:57
                    Engine speed: 1625.00 /min
                    Vehicle speed: 36 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.320 V
                    Crankshaft speed (RPM): 1625.0 /min
                    Vehicle speed: 37.33 km/h
                    Vehicle voltage terminal 30: 14320 mV
                    Coolant temperature: 77.3 °C
                    Exhaust gas temp.bef.turbocharger: 1000.0 °C
                    Exh t Sens TP Flt Us: 184.7 °C
                    Exhaust gas temperature before particulate filter: 263.8 °C
4875 - Coolant Pump 2
          P261A 00 [032] - Open circuit
5260 - Sensor 1 for Exhaust Temp Bank 1 (G235)
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [109] - Electrical Fault
                    Mileage: 144701 km
                    Date: 2019.07.10
                    Time: 09:16:30
                    Engine speed: 875.50 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 13 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.200 V
                    Crankshaft speed (RPM): 875.5 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 11200 mV
                    Coolant temperature: 13.7 °C
                    Glow status-Bits 0-7: 0
                    Preheat time: 1400 ms
                    Fuel temperature: 13.7 °C
4892 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
   Component: ESP8 quattro  H06 0230
   Coding: 0C1500
   Shop #: WSC 06335 000 00000
   VCID: 40D9BDA52A839F17895-8014
   Part No SW: 8K0 907 064 P    HW: 8K0 907 064 P
   Component: BCM2 1.1      H80 0145
   Coding: 030500
   VCID: 3D27C4515D71F2FFE23-8068
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000014050008
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000017689004
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A1000000    Serial number: 01250320090551
   Coding: 34010000
   VCID: 70B92D655AA34F97395-8024
01273 - Fresh Air Blower (V2)
                    Fault Status: 00101001
                    Fault Frequency: 143
                    Reset counter: 66
                    Mileage: 144635 km
                    Date: 2019.07.05
                    Time: 10:48:55
                    Temperature: 25.0°C
                    Voltage: 11.10 V
                    Current: 0.000 A
                    Voltage: 11.90 V
01844 - Control Module for Fresh Air Blower (J126)
                    Fault Status: 00101110
                    Fault Frequency: 26
                    Reset counter: 58
                    Mileage: 144716 km
                    Date: 2019.07.11
                    Time: 09:08:15
                    Temperature: 20.0°C
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000239544
   Coding: 690040B10034A7000001000300005F5F0F1C060800000101000000
   VCID: 3039ED659A230F97795-8064
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090317  H10 0041
   Serial number: 90243014090310223412
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10422665
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000002403090666
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40130908501889
   Coding: 000005
   VCID: 3C21C955466BFBF7D5D-8068
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 B    HW: 8R0 959 655 B
   Component: AirbagVW-AU10 H03 0310
   Serial number: 003E8D03EXDF
   Coding: 30343131313030303030554A304C38523053
   ASAM Dataset: EV_AirbaAU10SMEAU416 001001
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 43D3B2A93B15840F947-8016
   Serial number: 6334MSME462057164
   Serial number: 6344MSME43016F1FJ
   Serial number: 6352QSME371F2024B
   Serial number: 6362QSME491A3A0AP
   Serial number: 63732SME7321200AO
   Serial number: 63832SME5A1E46120
   Revision: --------    Serial number: 90304ICU0008J
   Coding: 000017
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 900 D    HW: 8R0 920 900 D
   Component: KOMBIINSTR.   H08 0224
   Revision: 00000000    Serial number: 9EK741T39
   Coding: 0F04220002000008010000
   VCID: 323DE76D942F3D870F1-8066
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G0931680AF
   Coding: 000303
   VCID: 4BC39A8913C54C4F6C7-801E
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140455771
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008687428
   Coding: 011D02205000440004
   VCID: 41DFB8A12189961F86B-8014
                    Fault Frequency: 70
                    Reset counter: 75
                    Mileage: 137936 km
                    Date: 2018.09.10
                    Time: 16:41:27
   Revision: 00002001    Serial number: 0117723046
   Coding: 01000620203900C0052005
02615 - Fuel Tank Cap; Lock
                    Fault Status: 01101001
                    Reset counter: 82
                    Mileage: 130781 km
                    Date: 2018.01.16
                    Time: 12:44:02
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 82
                    Mileage: 130781 km
                    Date: 2018.01.16
                    Time: 13:02:17
03451 - Left Brake/Tail Light Lamp 3
                    Fault Status: 00101100
                    Reset counter: 55
                    Mileage: 148400 km
                    Date: 2020.01.21
                    Time: 18:12:45
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008693640
                    Fault Frequency: 81
                    Reset counter: 35
                    Mileage: 146297 km
                    Date: 2019.09.03
                    Time: 11:02:57
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000338014
   VCID: 3333E2696B35348F047-8066
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H02 0310
   Revision: 00000005    Serial number: AUZ5Z6I1193629
   Coding: 0500048004050500015B070000
   VCID: 44D1B1B53E9B8337ADD-8010
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Revision:             Serial number: 0000008683041
   Coding: 010C02204000240004
   VCID: 43D3B2A93B95840F947-8016
                    Fault Frequency: 199
                    Reset counter: 35
                    Mileage: 130779 km
                    Date: 2018.01.16
                    Time: 12:39:18
   Revision:             Serial number: 0000008683006
                    Reset counter: 32
                    Mileage: 130839 km
                    Date: 2018.01.18
                    Time: 09:28:54
End----(Elapsed Time: 01:12, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
how can fix this ??
thank you
Moving to from General VW/Audi Repair to New Users section.
Sounds like it's configure for "Selective Unlocking". What happens if you "double click" the remote?
VOLKS
New Member
Algeria
HI
probelem solved it was only connection
Thank you
