Results 1 to 10 of 17
Thread: Mk5 jetta 2.5 crank no start
    New User
    Jan 2020
    I took a chance and bought a cheap jetta that had a no start condition . Ive got the car to at least crank now but I cant get vcds to connect to the ecu .Ive checked fuses and they are good and ive checked wiring from ecu to roughly the firewall and i cant visibly see or feel any bumps in the wiring . any suggestions or places to look
    What kind of VCDS cable are you using?
    What do/does the LED(s) do when you plug it into the car (only the car, no computer on the other end).
    Does it connect to any of the other modules in the car, like the CAN Gateway?
    New User
    Jan 2020
    I can get you an answer to the led question tomorrow. I did do a scan and this is what I got . the car kept blowing fuse sb10 for the ecu so I searched and didnít see anything , eventually I unplugged the secondary air injection pump which stopped blowing the fuse and allowed the car to crank but still not Start . The battery is bad in this car and I eventually will replace but I wanna make sure it runs before I dump a bunch of money in it
    https://cdn.fbsbx.com/v/t59.2708-21/...=5E382D62&dl=1
    Editorial note: When posting an Auto-Scan here please copy and paste it inline between [code] and [/code] tags, not as an attachment.
    New User
    Jan 2020
    The light is solid green . I did another scan but itís not really any different than the first
  6. #6
    New User
    Jan 2020
    Sorry to keep posting but I did another scan and itís different now that I got the car to crank . I donít fully understand the scan but a couple of the errors are because of the headlight switch. And dimmer switch and the footwell light on the drivers side being disconnected.
     Sunday,02,February,2020,16:11:43:16521
    VCDS Version: 19.6.2.0 (x64)
    VIN: 3VWRF71K66M630543   License Plate:
    Mileage: 243230km-151136mi   Repair Order:
    Chassis Type: 1K (1K0)
    VIN: 3VWRF71K66M630543   Mileage: 243230km-151136miles
    01-Engine -- Status: Cannot be reached 1100
    Address 01: Engine
       Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
       Revision: 00T12001
       Coding: 0021122
       Shop #: WSC 00066 000 00000
       VCID: 408F7E0313C34A4FE7-8014
       Part No: 1K0 820 047 DK
       Component: Climatic PQ35   090 0505
       VCID: 70EFEEC363E39ACF57-8024
                013 - Check DTC Memory
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Revision: 00H37000    Serial number: 00000000107702
       Coding: 04050E234004180000140000001400000008730B5C
       VCID: 2A5B3CAB85BFA01FD9-807E
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0402
       Coding: 00065493
       Shop #: WSC 00066
    7 Faults Found:
                        Fault Status: 01101100
                        Reset counter: 81
                        Voltage: 12.35 V
    00834 - Signal for Activation of Heated Rear Window
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 81
                        Voltage: 12.35 V
    01800 - Light Switch (E1)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 81
                        Mileage: 243231 km
                        Voltage: 12.00 V
                        Reset counter: 81
                        Mileage: 243231 km
                        Voltage: 12.00 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 81
                        Voltage: 12.35 V
                        Reset counter: 81
                        Voltage: 12.35 V
                        Reset counter: 81
                        Voltage: 12.35 V
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1S AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD02JXR
       Coding: 0012627
       VCID: 2E5330BBB957CC3F05-807A
       Subsystem 1 - Component: BF-Gewichtsens.
       Subsystem 2 - Serial number: 6332MSME0A1B04412
       Subsystem 3 - Serial number: 6342MSME0866701CC
       Subsystem 4 - Serial number: 6351HSME07385E69J
       Subsystem 5 - Serial number: 6361HSME073B26276
       Subsystem 6 - Serial number: 63727SME07104070M
       Subsystem 7 - Serial number: 63827SME0710427B-
    02511 - Control Module for Seat Occupied Recognition (J706)
                008 - Implausible Signal - MIL ON
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0000021
       VCID: 78FFD6E30B93C28F9F-802C
       Part No: 1K0 920 952 C
       Component: KOMBIINSTRUMENT 3HL 1012
       Coding: 0023203
       Revision:   H10       Serial number: 2800105423817F
       Coding: 3D3F0340071002
                        Reset counter: 81
                        Mileage: 243231 km
                        Time: 21:48:52
                        Fault Frequency: 21
                        Reset counter: 81
                        Mileage: 243231 km
                        Time: 21:48:53
    01304 - Radio
                        Fault Frequency: 21
                        Reset counter: 81
                        Mileage: 243231 km
                        Time: 21:48:57
       Component: IMMO            3HL 1012
       Shop #: WSC 09416 444 68462
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2339
       Coding: 0001269
       VCID: 366318DB4107F4FF4D-8062
       Part No: 1K1 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 326B24CBAD6FE8DF61-8066
                        Mileage: 3200 km
                        Temperature: 7.0įC
                        Voltage: 12.10 V
                        Voltage: 12.00 V
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 137803281B09058F880F048051A0
       VCID: 74E7E2D317FBA6EFB3-8020
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 377D15DF460D0DF756-8062
    Address 56: Radio
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2416
       Coding: 0000144
       VCID: 31692BC7A869D3C718-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:34)--------------------------
  7. #7
    Engine Control Module is off-line. Check power and ground connections to it.
  8. #8
    New User
    Jan 2020
    I can check them right at the ecu correct ? Also would appreciate it if you verified the wires I need to check as well . Just to make sure Iím right , thereís 2 brown ground wires and thereís 4 power wires a red/green, white , yellow/purple, red/black
  9. #9
    Quote Originally Posted by Imprez07 View Post
    I can check them right at the ecu correct ? Also would appreciate it if you verified the wires I need to check as well . Just to make sure I’m right , there’s 2 brown ground wires and there’s 4 power wires a red/green, white , yellow/purple, red/black
    If that's what the WD for your car shows (check from erwin) ...
  10. Likes Uwe liked this post
  11. #10
    New User
    Jan 2020
    honestly cant find a diagram . ive been using mitchell prodemand for alot of stuff but it doesnt show power and ground pinouts, i assumed those were the wires because of a video i saw. i do know t121/62 the red black wire has power and is in good shape.
