Results 1 to 8 of 8
Thread: Lost abs coding help please (2006 3C Passat)
    Nov 2019
    Trinidad and Tobago
    Hello everyone the customer attempted to change a comfort control module on his b6 passat in order to fix a door lock issue it did not fix the problem so he reinstalled his original unit and lost the coding for the abs module any assistance in getting it back would be nice I used the long coding helper to code it back but it keeps saying incorrect coding when I scan for faults.
    Wednesday,19,February,2020,15:42:55:50820
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ3CZ6P187205   License Plate: B6PASSAT
    Mileage: 171540km-106590mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 36 42 44 46 52 53 56 62 72 76
    VIN: WVWZZZ3CZ6P187205   Mileage: 171540km-106590miles
    46-Central Conv. -- Status: Malfunction 1010
       Part No SW: 3C0 907 115 R    HW: 3C0 907 115 D
       Revision: --H14---    Serial number: VWZCZ000000000
       Coding: 0404001019070160
       Shop #: WSC 00001 898 62730
       VCID: 2F672870BEDBC8370E-807A
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 004 -  - Intermittent
                        Fault Frequency: 23
                        Mileage: 171540 km
                        Date: 2019.07.11
                        Time: 02:14:43
                        Temperature: 33.0C
                        Temperature: 33.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 11.684 V
    012555 - Low Pressure Fuel regulation
                   P310B - 002 - Fuel Pressure Outside Specification
                        Fault Status: 01100010
                        Mileage: 171540 km
                        Date: 2019.07.11
                        Time: 02:16:07
                        RPM: 1171 /min
                        Load: 36.8 %
                        Temperature: 33.0C
                        Temperature: 33.0C
                        Voltage: 13.970 V
                   P0087 - 002 - Too Low
                        Mileage: 171540 km
                        Date: 2019.07.11
                        Time: 02:27:49
                        RPM: 1289 /min
                        Load: 22.3 %
                        Temperature: 47.0C
                        Temperature: 35.0C
                        Voltage: 13.843 V
    Readiness: 0110 0101
       Part No SW: 09G 927 750 T    HW: 09G 927 750 T
       Component: AQ 250 6F           0832
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 00028 028 00001
       VCID: 428171C41D49555FF1-8016
                        Fault Status: 00101101
                        Reset counter: 155
                        Reset counter: 155
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0667160376
       Coding: 0001425
       VCID: 30652B0CA3E5D7CF17-8064
                        Reset counter: 52
                        Mileage: 171540 km
                        Date: 2019.07.11
                        Time: 02:48:02
                        Reset counter: 52
                        Mileage: 171540 km
                        Date: 2019.07.11
                        Time: 02:48:02
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       VCID: 62C19144BD89355FD1-8036
    01810 - Actuating Motor for Temperature Flap; Right (V159)
                        Fault Status: 00110000
                        Reset counter: 93
                        Mileage: 171539 km
                        Date: 2019.07.06
                        Time: 04:39:25
       Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000003915328
       Coding: E5848F0700041A00000A00000F00000000085D435C0000
       Shop #: WSC 07737 898 999999
       Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 07737
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 07737
    01506 - Bulb for Rear Fog; Right (L47)
                        Reset counter: 53
                        Mileage: 171529 km
                        Date: 2019.06.11
                        Time: 00:27:00
                        Voltage: 13.05 V
                        Reset counter: 88
                        Mileage: 171532 km
                        Date: 2019.06.12
                        Time: 04:04:00
                        Voltage: 12.55 V
                        Reset counter: 88
                        Mileage: 171532 km
                        Date: 2019.06.12
                        Time: 04:04:00
                        Voltage: 12.55 V
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 05 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2P3SRE5V
       Coding: 0012341
       VCID: 2D5B3278B4D7BA273C-8078
       Subsystem 1 - Serial number: 00000000000000000
       Subsystem 2 - Serial number: 6342MSME100B311F
       Subsystem 3 - Serial number: 6351HTS64IK6B5M2
       Subsystem 4 - Serial number: 6361HTS63IKEL5F2
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
       Component: J0527               0030
       Revision: 00035000    Serial number: 3C0953507
       Coding: 0001112
       VCID: 72E1E1046D69A5DFA1-8026
       Part No SW: 3C0 920 970 P    HW: 3C0 920 970 P
       Revision: X0033000    Serial number: 00000000000000
       Coding: 0006405
       Shop #: WSC 07736 611 00993
       VCID: 31632E08A8EFDEC718-8064
                        Reset counter: 91
                        Mileage: 171532 km
                        Date: 2019.06.12
                        Time: 04:04:24
                        Reset counter: 91
                        Mileage: 171533 km
                        Date: 2019.06.15
                        Time: 00:42:41
                        Reset counter: 91
                        Mileage: 171533 km
                        Date: 2019.06.15
                        Time: 00:37:17
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C062181227
       Coding: 3FFD1D04C21003
       VCID: 2143DE48F80F6E4788-8074
                        Reset counter: 48
                        Mileage: 171529 km
                        Date: 2019.06.11
                        Time: 01:30:34
    01304 - Radio
                        Reset counter: 48
                        Mileage: 171529 km
                        Date: 2019.06.11
                        Time: 01:30:37
                        Reset counter: 88
                        Mileage: 171532 km
                        Date: 2019.06.12
                        Time: 04:04:25
                        Reset counter: 88
                        Mileage: 171532 km
                        Date: 2019.06.12
                        Time: 04:04:26
                        Reset counter: 88
                        Mileage: 171533 km
                        Date: 2019.06.15
                        Time: 00:42:42
       Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
       Component:    IMMO         038 0367
       Revision: 00038000    Serial number: VWZCZ000000000
       VCID: 32612104ADE9E5DF61-8066
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
       Component: Sitzverstellung     1001
       Revision: 00004000    Serial number: 00000000000000
    02325 - Switch for Front Seat Height Adjustment (E451)
    02346 - Switch for Memory Position 2 (E219)
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2802
       Coding: 0001015
       VCID: 37771010468B00F756-8062
       Part No: 1K2 909 144 K
       VCID: 346D271C57FDEBEF73-8060
       Component:    KSG PQ46 ELV 038 0455
       Coding: 00910A0801860E76380494157008DF0E103900
    01134 - Alarm Horn (H12)
                        Fault Frequency: 12
                        Reset counter: 51
                        Mileage: 171529 km
                        Date: 2019.06.11
                        Time: 00:14:55
                        Reset counter: 88
                        Mileage: 171529 km
                        Date: 2019.06.11
                        Time: 00:23:58
    00955 - Key 1
                        Fault Status: 00110101
                        Reset counter: 91
                        Mileage: 171529 km
                        Date: 2019.06.11
                        Time: 00:31:18
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1K0 959 702 L
       Coding: 0001014
       VCID: 3875132C4B950F8F5F-806C
    00121 - Outside Warning Light/Door exit Light Passenger Side
       Revision:   013
       Coding: 0000012
                000 - - - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 40
                        Reset counter: 48
                        Voltage: 9.94 V
                        Count: 170
    Address 56: Radio
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2436
       Coding: 0000144
       VCID: 336F240052F3ECD76A-8066
       Part No: 1K0 959 704 F
       Coding: 0000144
    Address 76: Park Assist        Labels: 3C0-919-283.lbl
       Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
       Component: Parkhilfe 8-Kan 004 0011
       Revision: 00004000    Serial number: 82930605308156
       Coding: 0001014
       VCID: 2855C36C9B359F0FCF-807C
    End-------------------------(Elapsed Time: 02:09)--------------------------
    Last edited by MezTech; 02-23-2020 at 06:31 AM. Reason: forgot to attach auto scan
    Mar 2015
    Australia
    Try:
    013728
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  3. Likes Uwe liked this post
    I think it should be:
    0013731
  5. Likes Uwe, Dana liked this post
  6. #4
    Mar 2015
    Australia
    yes you are correct NEtech...I chose BWA engine from PR code, but that is only for 6 speed manual, not 09G automatic.
    Nov 2019
    Trinidad and Tobago
    ok guys thanks will try and report back
    Nov 2019
    Trinidad and Tobago
    Code worked thanks everyone!
  9. Likes Uwe liked this post
  10. #7
    Quote Originally Posted by MezTech View Post
    Which one?
  11. #8
    Nov 2019
    Trinidad and Tobago
    this one 0013731
  12. Likes Uwe liked this post
