Missing Cornering Light in mfd
loperro2006
Pirate
Walking the Plank
Buenos Aires, Argentina
LP/IP
Hi guys, I hope you are well, my query is as follows, I own a vw
vento / jetta mk6 of the year 2012, I took it to change a foggy headlamp and place led believe, on occasions I detected a burnt lamp, then I disabled the cornering of the instruments. No more screen appears that included it to activate from there. Any solution?
Thank you very much.
myounus
Northwest UK
C?ID=321059
Hi
Please kindly post an autoscan. Please check the logs for your previous coding and revert it back.
loperro2006
Pirate
Walking the Plank
LP/IP
Thanks, for answering, my problem is that I do not have the previous configuration saved, since they did it in a workshop in which I did not finish with a good relationship.:banghead::banghead:
Removed.   Data from a clone/pirate copy of VCDS is not acceptable here.
