How do you turn off the TPMS in VCDS? My sensors are now about 8 years old and one started throwing a code. I would like to turn this system off and just go with the old school tire inflator gauge.
I figured out how to disable the TPMS till I change out my rubber. and then I can change the sensors.. BTW, I found reasonable 433 mhz sensors on Amazon.
In VCDS go to 17. Instruments > then long coding > Byte 4 Bit 0 is the TPMS enable/disable. Uncheck the box to disable or change the long coding to 00100010 for disabled. (TPMS active is 00100011)
