2014 2.0 TSI VW CC DSG / FULL OVERHAUL / IDLE PROBLEM / PARK POSITION DOES NOT WORK
   #21
Well OP what's the status?
Did you know you can power up the ECU directly and supply ground and see if you can do the adaptation too to isolate?
   #22
CCSLEEPER
C?ID=391753
Sunday,01,March,2020,11:28:16:43263
VIN: WVWBP7AN1EE501643   License Plate:
Mileage: 178240km-110753mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 55 56
          62 65 72 75 77
VIN: WVWBP7AN1EE501643   Mileage: 178240km-110753miles
1C-Position Sensing -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Not registered 0001
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 906 027 GP    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 5696
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 040401081C070160
   Shop #: WSC 16448 032 526344
   VCID: 7F5B04081BF7F30FB0F-802A
6 Faults Found:
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - MIL ON
                    Fault Status: 11100000
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:18
                    RPM: 993 /min
                    Load: 32.1 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.716 V
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:18
                    RPM: 1018 /min
                    Load: 33.3 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.843 V
005497 - Throttle Actuator (J338)
               P1579 - 000 - Adaptation Not Started
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:18
                    RPM: 1018 /min
                    Load: 33.3 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.843 V
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:26
                    RPM: 1026 /min
                    Load: 31.8 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.716 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:28
                    RPM: 995 /min
                    Load: 32.5 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.716 V
000323 - Oxygen (Lambda) Sensor B1 S3
               P0143 - 000 - Signal too Low
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:41:04
                    RPM: 1042 /min
                    Load: 30.6 %
                    Temperature: 87.0∞C
                    Temperature: 39.0∞C
                    Voltage: 13.716 V
Readiness: 1110 0101
   Part No SW: 02E 300 062 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 4007
   Revision: 05651213    Serial number: 00001304060223
   Shop #: WSC 05311 000 00000
   VCID: 1577C6A0098B195F0A3-8040
   Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
   Component: J104   C2 450M V490 0030
   Revision: --H07---    Serial number: 00000007050014
   Coding: 0004495
   VCID: 7BA3F0180FEFEF2F9C7-802E
03366 - Vacuum Sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 28
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:14:57
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 26
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:14:58
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 BH    HW: 3AA 907 044 BH
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0714019048
   Shop #: WSC 00015 115 00000
   VCID: 77ABEC283F47CB4FF8F-8022
          B10AB F0 [009] - Too Low
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 00080000000000000098028194000BC020550B0840200D20E484402400C0
   Shop #: WSC 05311 123 12345
   VCID: 49CF5AD019B38DBF5EB-801C
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 240413  010 0604
   Serial number: 240413
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M05D21H20M07S09S4
   Coding: 0228DD
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__517 VW10 HI   2318
   Revision: 27019000    Serial number: 003N5P8JUF21
   Coding: 0012599
   VCID: 005987F466098CF7C95-8054
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 0000000000CU2N
   Subsystem 3 - Serial number: 0015.03.130000300000850023ˇÜ63
   Subsystem 4 - Serial number: 850023ˇÜ6332MTS624961183 ˇÜ63
   Subsystem 5 - Serial number: 61183 ˇÜ6342MTS611191173 ˇÜ63
   Subsystem 6 - Serial number: 91173 ˇÜ6351HTS69S8NRBKJ ˇÜ63
   Subsystem 7 - Serial number: NRBKJ ˇÜ6361HTS6HVA9RBKR ˇÜ63
   Subsystem 8 - Serial number: 9RBKR ˇÜ63727TS6J5IORBKR ˇÜ63
   Subsystem 9 - Serial number: ORBKR ˇÜ63827TS64G9ORBKJ ˇ
   Subsystem 10 - Serial number: ORBKJ ˇ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:21:20
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010042    Serial number: 20130511201262
   Coding: 018A270000
   Shop #: WSC 00015 115 12345
   VCID: 6B83C058730F7FAF0C7-803E
   Coding: E20000
   Part No SW: 3C8 920 971 E    HW: 3C8 920 971 E
   Component: KOMBI         H04 0811
   Coding: 240F00
   Shop #: WSC 05314 115 12345
   VCID: 2F3B14488797C38F60F-807A
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 150513F1000793
   Coding: 461006
   Shop #: WSC 05314 123 12345
   VCID: 7CA1F30406E1E81795D-8028
01304 - Radio
                    Reset counter: 184
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:34:05
                    Fault Frequency: 9
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:14:58
00484 - Vehicle Position Recognition Control Module (J603)
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:15:03
Address 1C: Position Sensing
   Part No SW: 3AA 959 433 C    HW: 3AA 959 433 C
   Component:    IMMO         042 0407
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 392F2A1045531D3FCEB-806C
Address 2E: Media Player 3
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0555
   Revision: 12110009    Serial number: 0006993716
   Coding: 0004B7
   Shop #: WSC 05311 115 08193
   VCID: 6D87CE404D1B719F123-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003474663
   Coding: 010490
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 184
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.302 1202
   Revision: 1BH04737    Serial number: 00131220337801
   Coding: 0000258
   VCID: 3FDB44085B77330FF0F-806A
   Component:    KSG PQ47 ELV 042 0645
   Coding: 1B910F8001862E521204141FF08A0F0E107802
   Shop #: WSC 05311 000 08193
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FBBD4484797838F20F-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0555
   Revision: 14110009    Serial number: 0006986952
   Coding: 0004B6
   Shop #: WSC 05311 115 00000
   VCID: 6E85C94C401D8A872B9-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003451714
   Coding: 010490
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
   Revision:   H19       Serial number: 00000001027098
   Coding: 0022156
   VCID: 3635212C744DF247239-8062
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   VCID: 372B2C287FC70B4F38F-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
Address 56: Radio
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000218930
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 3537262065CBF95F2A3-8060
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0078
   Serial number: 000003554140500
   Coding: 02640402C2421A107F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53F378B8CB7FC76F247-8006
0036 - Databus
          [CAN TO GPS data]
                    Fault Frequency: 28
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:15:03
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 23:26:52
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664788291
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
   VCID: 2E05094C809DCA876B9-807A
9457426 - Left audio channel for speech/telephone
          B104F 12 [009] - Short to GND
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
9457170 - Right audio channel for speech/telephone
          B104E 12 [009] - Short to GND
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
End----------(Elapsed Time: 01:37, VBatt start/end: 14.3V/14.2V)-----------
Monday,02,March,2020,19:55:21:43263
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 53 55
          56 62 65 72 75 77
                    Date: 2047.15.31
                    Time: 31:63:63
                    Speed: 255.0 km/h
                    Temperature: 25.0∞C
                    Temperature: 22.0∞C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 12.573 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 25.0∞C
                    Temperature: 22.0∞C
                    Voltage: 12.573 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 25.0∞C
                    Temperature: 22.0∞C
                    Voltage: 12.573 V
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 00:06:40
                    RPM: 1212 /min
                    Load: 27.0 %
                    Temperature: 26.0∞C
                    Temperature: 21.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 00:06:41
                    RPM: 1212 /min
                    Load: 27.0 %
                    Temperature: 26.0∞C
                    Temperature: 21.0∞C
                    Voltage: 13.843 V
   Component: J104   C2 450M V493 0030
   Coding: 0004495
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:15
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:16
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0714019048
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
            000 - - - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 00:06:01
   Coding: 0582270000
   Coding: E20000
97284 - Databus
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
   Coding: 240B00
   Coding: 460006
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:20
01304 - Radio
                    Reset counter: 187
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:33:47
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:20
Address 37: Navigation
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
                    Reset counter: 147
   Coding: 0000258
   Coding: 1B910F8001862E521204141FF08A0F0E105802
   Shop #: WSC 05311 123 08193
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
                    Reset counter: 147
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:21
                    Fault Priority: 8
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 00:13:55
   ROD: EV_UHVUMI.rod
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
End----------(Elapsed Time: 01:39, VBatt start/end: 14.2V/14.1V)-----------
CCSLEEPER
C?ID=391753
Triple checked my wiring. Found one wire for the Knock sensor on the wire harness that wasnt up to par.
   #24
CCSLEEPER
C?ID=391753
          62 65 72 75 77
6 Faults Found:
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:18
                    RPM: 993 /min
                    Load: 32.1 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.716 V
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:18
                    RPM: 1018 /min
                    Load: 33.3 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:18
                    RPM: 1018 /min
                    Load: 33.3 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:26
                    RPM: 1026 /min
                    Load: 31.8 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.716 V
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:33:28
                    RPM: 995 /min
                    Load: 32.5 %
                    Temperature: 79.0∞C
                    Temperature: 36.0∞C
                    Voltage: 13.716 V
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:41:04
                    RPM: 1042 /min
                    Load: 30.6 %
                    Temperature: 87.0∞C
                    Temperature: 39.0∞C
                    Voltage: 13.716 V
   Coding: 0004495
                    Fault Frequency: 28
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:14:57
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
                    Fault Frequency: 26
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:14:58
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0714019048
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
            000 - - - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:21:20
   Coding: 018A270000
   Coding: E20000
   Coding: 240F00
   Coding: 461006
01304 - Radio
                    Reset counter: 184
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:34:05
                    Fault Frequency: 9
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:14:58
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2014.07.23
                    Time: 00:15:03
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
                    Reset counter: 184
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
   Coding: 0000258
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
0036 - Databus
          [CAN TO GPS data]
                    Fault Frequency: 28
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:15:03
                    Fault Priority: 8
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 23:26:52
   ROD: EV_UHVUMI.rod
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
                    Reset counter: 144
                    Mileage: 178243 km
                    Date: 2020.03.01
                    Time: 00:14:58
          56 62 65 72 75 77
                    Date: 2047.15.31
                    Time: 31:63:63
                    Speed: 255.0 km/h
                    Temperature: 25.0∞C
                    Temperature: 22.0∞C
                    Voltage: 12.573 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 25.0∞C
                    Temperature: 22.0∞C
                    Voltage: 12.573 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 25.0∞C
                    Temperature: 22.0∞C
                    Voltage: 12.573 V
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 00:06:40
                    RPM: 1212 /min
                    Load: 27.0 %
                    Temperature: 26.0∞C
                    Temperature: 21.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 00:06:41
                    RPM: 1212 /min
                    Load: 27.0 %
                    Temperature: 26.0∞C
                    Temperature: 21.0∞C
                    Voltage: 13.843 V
   Coding: 0004495
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:15
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:16
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0714019048
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
            000 - - - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 00:06:01
   Coding: 0582270000
   Coding: E20000
97284 - Databus
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
   Coding: 240B00
   Coding: 460006
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:20
01304 - Radio
                    Reset counter: 187
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:33:47
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2014.07.24
                    Time: 02:25:20
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
                    Reset counter: 147
   Coding: 0000258
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
                    Reset counter: 147
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:21
                    Fault Priority: 8
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 00:13:55
   ROD: EV_UHVUMI.rod
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
                    Reset counter: 147
                    Mileage: 178243 km
                    Date: 2020.03.02
                    Time: 02:25:16
CCSLEEPER
C?ID=391753
Tuesday,31,March,2020,14:04:43:43263
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 55 56 62
          65 72 75 77
01-Engine -- Status:                                 Malfunction 0010
03-ABS Brakes -- Status:                             Malfunction 0010
56-Radio -- Status:                                 Malfunction 0010
6 Faults Found:
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 000 - Short to Ground
Readiness: 1110 1101
   Component: J104   C2 450M V4BA 0030
   Coding: 0004495
   Revision: 00001K01
   Coding: 0010001008
   Revision: BD422001
   Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
   Coding: 198A270000
   Coding: E20000
   Coding: 240F01
   Coding: 469006
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   Coding: 1B910F8001862E521204141FF08A0F0E105801
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
0036 - Databus
          [CAN TO GPS data]
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 13.6V/13.5V)-----------
CCSLEEPER
C?ID=391753
Im having problems with setting Readiness / Adaptations. I've done the TV adapt with "ADT OK" 60, 62, 63. Im also getting a "Brake Servo Error". Not sure what im doing wrong when it comes to procedures to set Readiness. Ive tried this below but im having problems finding A, B, D, in the Advanced Measuring Values. And when it says Coolant temperature are you suppose to select ALL of them or just the Coolant Temperature on the top pertaining to that group?
Select [01-Engine]
- Check and clear fault codes, even if there are none.
Start engine
- Select [Basic settings]
[Automatic test sequence]
Now choose these Advanced Measuring Values by pressing
[Show Measuring Data] | (definitions)
a- [Operating Instructions] - (As is says, follow instructions)
b- [Currently running routine] - (Current test being performed)
c- [Status of actuator test] - (Current status)
d- [Test steps still to be performed] - (This should count down to 0)
e- [Engine speed] - (Follow instructions, above)
f - [Coolant temperature] - (Should be at least 80'C)
Press [Go] for the Basic Settings
Press and hold brake/accelerator pedal
(The ECM should have control of the engine speed at this time)
wait until the test has finished or there is an error.
   #27
CCSLEEPER
C?ID=391753
NOTE:
Car is Modified Stage 2 with Integrated Engineering Tune
BUT is reverted to Stock right now with new KO4 Turbo.
HPA Manifold so hence:
   #28
CCSLEEPER
C?ID=391753
EPC Code puts the car into Limp Mode and from what i gathered i might have to drive the car for a bit before it could clear ?
   #29
You need to fix faults first.....
Fuses and grounds Okay?
Most likely wiring, bad TV or ECU.....un-modify and install stock ECU to verify TV adapts.
CCSLEEPER
C?ID=391753
Yes i've done everything:
- Fuses, Relays, and grounds have been checked periodically.
- The service action or TSB for the TV has been rewired with wire harness.
- The car is currently in stock mode.
- I've checked ground & feed currents.
Practiced the 6' rule while in public places.
Currently wearing my black rubber gloves.
And I can actually wear them in public and NOT look like a serial killer.
Constantly washing my hands and always carry disiNfecting wipes.
:eek::confused::banghead::thumbs:
CCSLEEPER
C?ID=391753
Thursday,02,April,2020,08:52:19:43263
          65 72 75 77
   VCID: 7F5B04081BF7F3032A8-802A
7 Faults Found:
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:15
                    RPM: 1047 /min
                    Load: 27.4 %
                    Temperature: 97.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:15
                    RPM: 1068 /min
                    Load: 27.4 %
                    Temperature: 97.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.843 V
008454 Throttle Valve Actuator Module (J338)
P2106 - 000 - Power Limited due to Malfunction - MIL ON
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:15
                    RPM: 1068 /min
                    Load: 27.4 %
                    Temperature: 97.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:15
                    RPM: 1068 /min
                    Load: 27.4 %
                    Temperature: 97.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:15
                    RPM: 1024 /min
                    Load: 29.0 %
                    Temperature: 97.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.589 V
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:23
                    RPM: 1051 /min
                    Load: 29.0 %
                    Temperature: 96.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.843 V
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:50:24
                    RPM: 1000 /min
                    Load: 29.8 %
                    Temperature: 96.0∞C
                    Temperature: 53.0∞C
                    Voltage: 13.970 V
   VCID: 1577C6A0098B1953904-8040
   Component: J104   C2 450M V4BE 0030
   Coding: 0004495
   VCID: 7BA3F0180FEFEF23060-802E
                    Reset counter: 190
                    Mileage: 178243 km
                    Date: 2014.08.24
                    Time: 20:49:01
                    Hex Value: 0x0000
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0010001008
   VCID: 77ABEC283F47CB43628-8022
   Revision: BD422001
   VCID: 49CF5AD019B38DB3C4C-801C
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
   VCID: 005987F466098CFB532-8054
   Coding: 198A270000
   VCID: 6B83C058730F7FA3960-803E
   Coding: E20000
   Coding: 240F01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
   VCID: 2F3B14488797C383FA8-807A
   Coding: 469006
   VCID: 7CA1F30406E1E81B0FA-8028
   VCID: 392F2A1045531D3354C-806C
   Coding: 0004B7
   VCID: 6D87CE404D1B7193884-8038
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   VCID: 3FDB44085B7733036A8-806A
   Coding: 00000008
   VCID: 6FBBD44847978383BA8-803A
   Coding: 0004B6
   VCID: 6E85C94C401D8A8BB1E-803A
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   VCID: 3635212C744DF24BB9E-8062
   VCID: 372B2C287FC70B43A28-8062
   Coding: 350000
   Coding: 350000
Address 56: Radio
   VCID: 3537262065CBF953B04-8060
   VCID: 53F378B8CB7FC763BE0-8006
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 190
                    Mileage: 178243 km
                    Date: 2020.04.02
                    Time: 20:49:05
                    Fault Priority: 8
                    Reset counter: 190
                    Mileage: 178243 km
                    Date: 2020.04.02
                    Time: 20:49:00
   ROD: EV_UHVUMI.rod
   VCID: 2E05094C809DCA8BF1E-807A
                    Reset counter: 190
                    Mileage: 178243 km
                    Date: 2020.04.02
                    Time: 20:49:00
                    Reset counter: 190
                    Mileage: 178243 km
                    Date: 2020.04.02
                    Time: 20:49:00
End----------(Elapsed Time: 01:36, VBatt start/end: 13.8V/13.8V)-----------
Did you unplug everything with exception of TV under hood and attempt a TV adaption yet to isolate everything in engine bay?
If the aforementioned permits the TV to adapt, could you not plug in each consumer or sensor & one item at a time, further while re-scanning and re adapting to verify the culprit?
Are you sure the harness can carry current from ECU to TV and is sufficient current available at module directly to begin with?
   #33
CCSLEEPER
C?ID=391753
Radiator Fans Do Not Run with New coolant Temp. Sensor.
When i unplug the wire harness from the coolant temperature sensor (New Sensor) the fans work when i put the key into the ignition (Engine Not Running).
I replaced both coolant sensors. The one next to water pump and inline to the radiator.
Thursday,09,April,2020,10:23:24:43263
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 55 56 61
          62 65 72 75 77
6 Faults Found:
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:12:18
                    RPM: 1024 /min
                    Load: 44.3 %
                    Temperature: 67.0∞C
                    Temperature: 15.0∞C
                    Voltage: 13.589 V
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:12:18
                    RPM: 1015 /min
                    Load: 45.1 %
                    Temperature: 67.0∞C
                    Temperature: 15.0∞C
                    Voltage: 13.589 V
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:12:18
                    RPM: 1015 /min
                    Load: 45.1 %
                    Temperature: 67.0∞C
                    Temperature: 15.0∞C
                    Voltage: 13.589 V
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:12:19
                    RPM: 1009 /min
                    Load: 45.1 %
                    Temperature: 67.0∞C
                    Temperature: 15.0∞C
                    Voltage: 13.716 V
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:12:26
                    RPM: 1025 /min
                    Load: 44.7 %
                    Temperature: 68.0∞C
                    Temperature: 15.0∞C
                    Voltage: 13.716 V
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:12:28
                    RPM: 1021 /min
                    Load: 44.7 %
                    Temperature: 68.0∞C
                    Temperature: 15.0∞C
                    Voltage: 13.589 V
   Component: J104   C2 450M V4D8 0030
   Coding: 0004495
                    Reset counter: 216
                    Mileage: 178243 km
                    Date: 2014.08.31
                    Time: 16:14:31
                    Hex Value: 0x0000
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0010001008
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
   Coding: 198A270000
   Coding: E20000
   Coding: 240F01
   Coding: 460006
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
   Component: Batt.regelung H56 1642
   Coding: F000185A
   VCID: 71BFD23051A39573ACC-8024
   Coding: 0264003280001A103E1400000000
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 216
                    Mileage: 178243 km
                    Date: 2020.04.09
                    Time: 16:14:36
                    Fault Priority: 8
                    Reset counter: 216
                    Mileage: 178243 km
                    Date: 2020.04.09
                    Time: 16:14:31
   Coding: 0A11030150010100
   ROD: EV_UHVUMI.rod
                    Reset counter: 216
                    Mileage: 178243 km
                    Date: 2020.04.09
                    Time: 16:14:31
                    Reset counter: 216
                    Mileage: 178243 km
                    Date: 2020.04.09
                    Time: 16:14:31
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
          [Bedieneinheit f¸r Handyvorbereitung (Drei Tasten Module): Unterbrechung]
                    Reset counter: 216
                    Mileage: 178243 km
                    Date: 2020.04.09
                    Time: 16:14:31
End----------(Elapsed Time: 01:39, VBatt start/end: 13.7V/13.7V)-----------
   #34
Is the sensor correct part number and is the temperature at target to turn on the fans or is climate control setting signal proper?
Are you sure that is not a default function to operate fans if the controller believes the sensor is faulty when unplugged as a keep alive?
Why have TV errors not been rectified?
   #35
CCSLEEPER
C?ID=391753
Qffrc7DFM1H5CYMi7
Ive checked the wiring and thought ive done the TV ADP.
https://photos.app.goo.gl/KMQF1xgEscXBd1zk6
   #36
CCSLEEPER
C?ID=391753
Qffrc7DFM1H5CYMi7
   #38
Dana
Western PA, USA
I was able to open the photo in post 35:
3wyJe6jLykdhWnMBi8VhbLKd13HpQB9GZb-6wz-mR2jDKDsaeio4s0x-v9l1kcXrrxxq3aAlZ2d1GguZAMU-Men4H9wIbzvKjlPXjrPoBOxGDlaqcXXJ3reRz9O7ST_aEPOn6iSNVKEfdlwemi0j_dKZETfV6ZOwzeOVPZdMjFC9uX2TKqHGlMJrEKwsaXezVYKK82rtgDAllEZqFygP7PtEjm50-BrrZUzUNl6o8M2TuFuuqoyjejrwvpTeE4-1vmw54Uaxxy_tlSVzXGh3cgGHuHM-H4O12DDQ-FuGZgZBmT2X78m2qbrGg0b5grGiYajHaj6d0-1zwp8c58sd_iqqJIFkghG1Yj4m1hjZHzxC-TkVcurY5WLmjdLhGKIlGteHQYuMYW7Ye8T00HB-kOWqy9ebhepPGy4zIkjBW1OCNdhpgubd4IpgnpdgAe7L7ZGv6Jkn0eI-2CYnMmaR3t5TFCZNu_eRxEmHFmHAYqqVP5G9hk6j071O72I9W869pGVNUpXXbA0uuGJOMywW1nFv4j1QW2a3L6L2NcSQTcbeZjkiBUhfT7XnqhkL3XzuddltGNqk89-RMOGlJP1vhDh0KWPQZiIBeXF1m-3LjEjnxAXXLMc_wMQFUC8CSNn_Tp2yX8KtA8P-yzBpxsSJ2_xB-58Hi5Ms-59bMvufDv9Ekvcs5IO4dKq6d6A46677e708UUTOj0jP-CrLeSkCp8DDQ6Ig0QNfB-idXtpGOqWVKiBtkoimicI=w1366-h768-no
.. but that's Measuring Blocks rather than Basic Settings group 060. Please try 060 under Basic Settings using [On/Off/Next] to turn it ON so we can see if it shows ADP OK -or- Error.
   #39
CCSLEEPER
C?ID=391753
2 Radiator Fan DO NOT turn ON. Basic Settings TBA ERROR.
Friday,10,April,2020,10:16:45:43263
Gateway Installation List:  7N0 907 530 AN
Friday,10,April,2020,10:48:23:43263
          65 72 75 77
                    Mileage: 178243 km
                    Date: 2014.09.01
                    Time: 16:24:44
                    Temperature: 96.0∞C
                    Temperature: 40.0∞C
                    Voltage: 12.319 V
                    Mileage: 178243 km
                    Date: 2014.09.01
                    Time: 16:24:44
                    Temperature: 96.0∞C
                    Temperature: 40.0∞C
                    Voltage: 12.319 V
                    Mileage: 178243 km
                    Date: 2014.09.01
                    Time: 16:24:45
                    Temperature: 96.0∞C
                    Temperature: 40.0∞C
                    Voltage: 12.319 V
   Component: J104   C2 450M V4DA 0030
   Coding: 0004495
   Revision: 00001K01
   Coding: 0010001008
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
   Coding: 198A270000
   Coding: E20000
   Coding: 240F01
   Coding: 460006
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
                    Fault Priority: 8
                    Reset counter: 218
                    Mileage: 178243 km
                    Date: 2020.04.10
                    Time: 16:26:22
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:55, VBatt start/end: 12.4V/12.3V)-----------
CCSLEEPER
C?ID=391753
The coolant temperature sensor might be the problem as Jack has mention because i installed a New Duralast sensor and maybe because its not oem its not liking it. The fans should run initially when you put the key in the ignition.
The 2 fans were working one day with the New sensor and Now they dont. IDK what im doing wrong.
