Saturday,22,February,2020,12:05:30:43263
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWBP7AN1EE501643 License Plate:
Mileage: 178240km-110753mi Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 53
55 56 62 65 72 75 77
VIN: WVWBP7AN1EE501643 Mileage: 178240km-110753miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 906 027 GP HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 06 5696
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 040401081C070160
Shop #: WSC 16448 032 526344
VCID: 7F5B04081BF7F30FB0F-802A
8 Faults Found:
000290 - Throttle Position Sensor (G69)
P0122 - 000 - Signal too Low - MIL ON
Fault Status: 11100000
Mileage: 178243 km
Date: 2014.07.14
Time: 05:45:59
RPM: 955 /min
Load: 32.9 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Absolute Pres.: 980.0 mbar
Voltage: 12.954 V
000546 - Angle Sensor 2 for Throttle (G188)
P0222 - 000 - Signal Too Low - MIL ON
Mileage: 178243 km
Date: 2014.07.14
Time: 05:45:59
RPM: 955 /min
Load: 32.9 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 12.954 V
005497 - Throttle Actuator (J338)
P1579 - 000 - Adaptation Not Started
Mileage: 178243 km
Date: 2014.07.14
Time: 05:45:59
RPM: 970 /min
Load: 32.9 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 12.954 V
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open - MIL ON
Mileage: 178243 km
Date: 2014.07.14
Time: 05:46:04
RPM: 1035 /min
Load: 31.4 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 13.208 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal
Mileage: 178243 km
Date: 2014.07.14
Time: 05:46:06
RPM: 1002 /min
Load: 30.6 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 13.208 V
000566 - Manifold Pressure / Boost Sensor (G31)
P0236 - 000 - Implausible Signal
Mileage: 178243 km
Date: 2014.07.14
Time: 05:59:10
Load: 0.0 %
Temperature: 81.0∞C
Temperature: 45.0∞C
Voltage: 12.065 V
001378 - System Voltage
P0562 - 000 - Too Low
Mileage: 178243 km
Date: 2014.07.14
Time: 23:44:50
Load: 0.0 %
Temperature: 15.0∞C
Temperature: 16.0∞C
Voltage: 8.636 V
012372 - Starter Will Not Turn
P3054 - 000 - Jammed or Electrical Malfunction - MIL ON
Mileage: 178243 km
Date: 2014.07.14
Time: 23:56:13
Load: 0.0 %
Temperature: 16.0∞C
Temperature: 16.0∞C
Voltage: 6.223 V
Readiness: 1110 1101
Part No SW: 02E 300 062 C HW: 02E 927 770 AL
Component: GSG DSG AG6 512 4007
Revision: 05651213 Serial number: 00001304060223
Shop #: WSC 05311 000 00000
VCID: 1577C6A0098B195F0A3-8040
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP
Component: J104 C2 450M V48E 0030
Revision: --H07--- Serial number: 00000007050014
Coding: 0004495
VCID: 7BA3F0180FEFEF2F9C7-802E
03366 - Vacuum Sensor
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 6
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:48:47
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 8.00 V
Bin. Bits: 00011111
Count: 137
Hex Value: 0x0000
00532 - Supply Voltage B+
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:50:43
Hex Value: 0x0000
Voltage: 7.75 V
Bin. Bits: 00011111
Count: 115
Hex Value: 0x0000
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:59:25
Hex Value: 0x0000
Voltage: 10.50 V
Bin. Bits: 00011111
Count: 278
Hex Value: 0x0000
Part No SW: 3AA 907 044 BH HW: 3AA 907 044 BH
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0714019048
Shop #: WSC 00015 115 00000
VCID: 77ABEC283F47CB4FF8F-8022
B10AB F0 [009] - Too Low
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:57
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 R HW: 3AA 937 087 R
Component: BCM PQ47 H++ 422 0474
Revision: BD422001
Coding: 00080000000000000098028194000BC020550B0840200D20E484402400C0
Shop #: WSC 05311 123 12345
VCID: 49CF5AD019B38DBF5EB-801C
Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
Component: WWS464 240413 010 0604
Serial number: 240413
Coding: 00B795
Component: RLFS 024 0042
Serial number: Y13M05D21H20M07S09S4
Coding: 0228DD
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:53:31
Term 15 On
Voltage: 7.55 V
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:53:29
Term 15 On
Voltage: 7.55 V
Address 10: Park/Steer Assist
Part No SW: 5N0 959 655 AE HW: 5N0 959 655 AE
Component: J234__517 VW10 HI 2318
Revision: 27019000 Serial number: 003N5P8JUF21
Coding: 0012599
VCID: 005987F466098CF7C95-8054
Subsystem 1 - Part No: 3C8 959 339 A
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 0000000000CU2N
Subsystem 3 - Serial number: 0015.03.130000300000850023ˇÜ63
Subsystem 4 - Serial number: 850023ˇÜ6332MTS624961183 ˇÜ63
Subsystem 5 - Serial number: 61183 ˇÜ6342MTS611191173 ˇÜ63
Subsystem 6 - Serial number: 91173 ˇÜ6351HTS69S8NRBKJ ˇÜ63
Subsystem 7 - Serial number: NRBKJ ˇÜ6361HTS6HVA9RBKR ˇÜ63
Subsystem 8 - Serial number: 9RBKR ˇÜ63727TS6J5IORBKR ˇÜ63
Subsystem 9 - Serial number: ORBKR ˇÜ63827TS64G9ORBKJ ˇ
Subsystem 10 - Serial number: ORBKJ ˇ
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - MIL ON
Fault Frequency: 6
Mileage: 178243 km
Date: 2014.07.14
Time: 23:49:03
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:49:02
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Revision: FF010042 Serial number: 20130511201262
Coding: 018A270000
Shop #: WSC 00015 115 12345
VCID: 6B83C058730F7FAF0C7-803E
Component: E221__MFL-TK6 H07 0022
Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
136194 - Supply voltage
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Part No SW: 3C8 920 971 E HW: 3C8 920 971 E
Component: KOMBI H04 0811
Coding: 240F00
Shop #: WSC 05314 115 12345
VCID: 2F3B14488797C38F60F-807A
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuerger‰t f¸r Einparkhilfe: keine Kommunikation]
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.22
Time: 00:01:44
[Supply voltage too low]
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 150513F1000793
Coding: 461006
Shop #: WSC 05314 123 12345
VCID: 7CA1F30406E1E81795D-8028
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:58:54
01304 - Radio
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:58:54
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:49:48
00484 - Vehicle Position Recognition Control Module (J603)
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:58:54
03075 - Parallel Parking Assistance Control Module (J791)
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:59:26
Address 1C: Position Sensing
Part No SW: 3AA 959 433 C HW: 3AA 959 433 C
Component: IMMO 042 0407
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 392F2A1045531D3FCEB-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:56:19
Address 2E: Media Player 3
Address 37: Navigation
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0555
Revision: 12110009 Serial number: 0006993716
Coding: 0004B7
Shop #: WSC 05311 115 08193
VCID: 6D87CE404D1B719F123-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003474663
Coding: 010490
65793 - Supply voltage
[Front DCU undervoltage]
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
131329 - Rear Door Control Module
B11ED F0 [008] - Supply Voltage too Low
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.302 1202
Revision: 1BH04737 Serial number: 00131220337801
Coding: 0000258
VCID: 3FDB44085B77330FF0F-806A
Component: KSG PQ47 ELV 042 0645
Coding: 1B910F8001862E521204141FF08A0F0E107802
Shop #: WSC 05311 000 08193
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:48:47
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 00000008
VCID: 6FBBD4484797838F20F-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0555
Revision: 14110009 Serial number: 0006986952
Coding: 0004B6
Shop #: WSC 05311 115 00000
VCID: 6E85C94C401D8A872B9-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003451714
Coding: 010490
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Revision: H19 Serial number: 00000001027098
Coding: 0022156
VCID: 3635212C744DF247239-8062
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:49:47
Voltage: 8.00 V
Count: 48
Hex Value: 0x1263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 071200010B000400
VCID: 372B2C287FC70B4F38F-8062
Subsystem 1 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 350000
Subsystem 2 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 350000
Address 56: Radio
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000218930
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
VCID: 3537262065CBF95F2A3-8060
12652544 - Supply voltage
[Versorgungsspannung unterer Grenzwert unterschritten]
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:52:57
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0078
Serial number: 000003554140500
Coding: 02640402C2421A107F1606000000
ROD: EV_OCULow_001.rod
VCID: 53F378B8CB7FC76F247-8006
0036 - Databus
[CAN TO GPS data]
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.21
Time: 05:58:11
[supply voltage lower limit exceeded]
Reset counter: 40
Mileage: 178243 km
Date: 2020.02.21
Time: 23:37:06
2103041 - Control Module
Fault Priority: 8
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.22
Time: 00:03:59
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664788291
Coding: 0A100300A0010110
ROD: EV_UHVUMI.rod
VCID: 2E05094C809DCA876B9-807A
[Klemme 30: unterer Grenzwert unterschritten]
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:50
U1400 00 [008] - -
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:50
End----(Elapsed Time: 01:45, VBatt start/end: 11.2V/11.1V. VIgn 11.1V)-----
Saturday,22,February,2020,12:25:28:43263
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 53 55
56 62 65 72 75 77
2E-Media Player 3 -- Status: Not registered 0001
8 Faults Found:
Mileage: 178243 km
Date: 2014.07.14
Time: 05:45:59
RPM: 955 /min
Load: 32.9 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 12.954 V
Mileage: 178243 km
Date: 2014.07.14
Time: 05:45:59
RPM: 955 /min
Load: 32.9 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 12.954 V
Mileage: 178243 km
Date: 2014.07.14
Time: 05:45:59
RPM: 970 /min
Load: 32.9 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 12.954 V
Mileage: 178243 km
Date: 2014.07.14
Time: 05:46:04
RPM: 1035 /min
Load: 31.4 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 13.208 V
Mileage: 178243 km
Date: 2014.07.14
Time: 05:46:06
RPM: 1002 /min
Load: 30.6 %
Temperature: 55.0∞C
Temperature: 30.0∞C
Voltage: 13.208 V
Mileage: 178243 km
Date: 2014.07.14
Time: 05:59:10
Load: 0.0 %
Temperature: 81.0∞C
Temperature: 45.0∞C
Voltage: 12.065 V
Mileage: 178243 km
Date: 2014.07.14
Time: 23:44:50
Load: 0.0 %
Temperature: 15.0∞C
Temperature: 16.0∞C
Voltage: 8.636 V
Mileage: 178243 km
Date: 2014.07.14
Time: 23:56:13
Load: 0.0 %
Temperature: 16.0∞C
Temperature: 16.0∞C
Voltage: 6.223 V
Coding: 0004495
Fault Frequency: 6
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:48:47
Hex Value: 0x0000
Voltage: 8.00 V
Bin. Bits: 00011111
Count: 137
Hex Value: 0x0000
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:50:43
Hex Value: 0x0000
Voltage: 7.75 V
Bin. Bits: 00011111
Count: 115
Hex Value: 0x0000
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.14
Time: 23:59:25
Hex Value: 0x0000
Voltage: 10.50 V
Bin. Bits: 00011111
Count: 278
Hex Value: 0x0000
Revision: 00001K01
Coding: 0714019048
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:57
Revision: BD422001
Coding: 00B795
Coding: 0228DD
Coding: 0012599
000 - - - MIL ON
Fault Frequency: 8
Mileage: 178243 km
Date: 2014.07.14
Time: 23:49:03
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:49:02
Coding: 018A270000
Coding: E20000
U1400 00 [008] - -
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Coding: 240F00
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Coding: 461006
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.15
Time: 00:16:14
Mileage: 178243 km
Date: 2014.07.15
Time: 00:16:10
Reset counter: 142
Mileage: 178243 km
Date: 2014.07.15
Time: 00:16:14
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:56:19
Coding: 0004B7
Slave Driver:
Coding: 010490
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Coding: 0000258
Reset counter: 182
Mileage: 178243 km
Date: 2014.07.14
Time: 23:48:47
Coding: 00000008
Coding: 0004B6
Slave Passenger:
Coding: 010490
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:48
Coding: 0022156
Coding: 350000
Coding: 350000
Address 56: Radio
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:52:57
0036 - Databus
[CAN TO GPS data]
Fault Frequency: 6
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.21
Time: 05:58:11
Reset counter: 40
Mileage: 178243 km
Date: 2020.02.21
Time: 23:37:06
Fault Priority: 8
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.22
Time: 00:03:59
ROD: EV_UHVUMI.rod
9457426 - Left audio channel for speech/telephone
B104F 12 [009] - Short to GND
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.22
Time: 00:04:02
9457170 - Right audio channel for speech/telephone
B104E 12 [009] - Short to GND
Reset counter: 142
Mileage: 178243 km
Date: 2020.02.22
Time: 00:04:02
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:50
U1400 00 [008] - -
Reset counter: 182
Mileage: 178243 km
Date: 2020.02.21
Time: 23:48:50
End(Elapsed Time: 01:42, VBatt start/end: 11.4V/10.9V. VIgn 10.9V, udsna)--
