2007 Audi RS4 Cruise Control will not function
AndrewG B7 RS4
C?ID=397233
2007 Audi RS4 Cruise Control will not function - Fixed
So I have some sort of issue with my cruise control not coming on, I have checked the long code in engine to make sure cruise control is installed and verified the function of all switches with the measuring blocks in . When I first cycle the key and all the cluster lights cycle the cruise is not one that comes on, any and all help would greatly be appreciated. I am new to VCDS so I may not understand the help at first yet I am learning.
Friday,21,February,2020,15:04:17:10776
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WUARU98E37N904408   License Plate:
          67 69 75 76 77
VIN: WUARU98E37N904408   Mileage: 158650km-98580miles
Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560 A    HW: 8E1 907 560
   Component: 4.2L V8/4V FSI     ª0060
   Revision: 57H13---    Serial number: XXXXXXXXXXXXXX
   Coding: 01040009180F0160
   Shop #: WSC 05140 444 85886
   VCID: A4044A8767F1676F61-80F0
Readiness: 0000 0100
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Component: ESP8 quattro    H06 0150
   Coding: 0004533
   Shop #: WSC 06335 000 00000
   VCID: AB16A1BB0A2FA817A0-80FE
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: ED926FA3A5BB6627FE-50F4
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 01023
   Shop #: WSC 06335
   VCID: BD329FE3B55B36A70E-4AA4
            27-00 - Implausible Signal
            62-00 - No or Incorrect Adjustment
Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0J1J1
   Coding: 0432707
   VCID: BC3492E7FF413FAF39-80E8
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3HKJ4
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB4042615203ÿ†63
   Subsystem 5 - Serial number: 615203ÿ†6342DRB4042606158ÿ†63
   Subsystem 6 - Serial number: 606158ÿ†6352ARB401D1C3E4Uÿ†63
   Subsystem 7 - Serial number: 1C3E4Uÿ†6362ARB4018AEEFACÿ†63
   Subsystem 8 - Serial number: AEEFACÿ†63729RB401CD3E92.ÿ†63
   Subsystem 9 - Serial number: D3E92.ÿ†63829RB401CD3EA2$ÿ
   Subsystem 10 - Serial number: D3EA2$ÿ
Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
   Part No: 8E0 953 549 T
   Component: Lenksáulenmodul     0301
   Coding: 04441
   Shop #: WSC 06335
   VCID: C4C4EA07D6B1476F41-4AA4
   Part No SW: 8E0 920 982 R    HW: 8E0 920 982 R
   Component: KOMBI+WFS 4     H14 0100
   Revision: 0100        Serial number: 00000000000000
   Coding: 0023268
   Shop #: WSC 44706 000 1048576
   VCID: BD329FE3E55B36A70E-5118
   Coding: 0023268
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: F1AA73D3BA8382C7DA-4B1E
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 11816
   Shop #: WSC 06335
   VCID: F8BC4EF7DAF9D38F1D-4AA4
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: A91A5BB300D3BA0752-80FC
   Component: AFS-Modul links H03 0020
   Component: AFS-Modul rechtsH03 0020
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062523
   Shop #: WSC 02197 785 00200
   VCID: AA18A4BF07D5B11F5B-513C
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802030629
   Coding: 0000304
   VCID: B12AB3D32A03C2C79A-5160
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005179874
   Coding: 0011877
   Shop #: WSC 40310 001 1048576
   VCID: B62080CFC06DE5FFCF-50D0
End----(Elapsed Time: 04:55, VBatt start/end: 12.0V/12.1V. VIgn 12.0V)-----
AndrewG B7 RS4
C?ID=397233
Update, found when driving how it opens the top switch contacts, closest to driver, cruise comes on, now im curious if i just remove that switch from the system or how to fix it as it is a new switch.
EDIT: after removing it and ground checking it, the switch always showed a very close amount of continuity no matter the position extended or retracted, decided to just try again. The car work like it should cruise comes on, foot slightly on the clutch kicks it off and still need full clutch depression for the car to start, Thanks to VCDS for allowing me to watch the moment the switch positions change :)
nazdaq100
London, United Kingdom
C?ID=314050
Could you also check long coding under steering wheel? If something needs to be activated and let us know thanks
AndrewG B7 RS4
C?ID=397233
I did that to verify my configs on the car, I just posted an update above you, sorry for the late response had a test drive to make sure its working.
Jef
HQ
Go to 01-08-066. What is the data shown there? Do you see anything change if you depress the clutch pedal down a few inches?
AndrewG B7 RS4
C?ID=397233
Jef, I had an issue with the new switch always showing closed so it never allowed the system to go into cruise, since bench checking and reinstalling making sure not to "lock" it into position to far now the measuring blocks function as they should.
There are 2 clutch switches on the B7 RS4, an upper and lower, and the replacements had (still have probably) an annoying feature that if yo test them before installation they break internally (no visible damage) and hence the new switch doesn't fix the problem.
I had this happen to me when I owned my B7 RS4 and read about many other owners on rs6.com who had the same problem.
A clue whether it's the top clutch switch is that when dipping the clutch to change gear the engine revs seem to hang instead of dropping fairly rapidly ;)
