Results 1 to 7 of 7
Thread: 4F A6 not starting
    Meme Master Katie Ross's Avatar
    May 2015
    Somewhere
    4F A6 not starting
    The dash lights up but the engine isn't even trying.
    Friday,21,February,2020,14:46:14:04895
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4513.4
    VIN:    License Plate: 22112019
    Mileage: 118610km-73700mi   Repair Order:
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 67 72 77
       Mileage: 118610km-73700miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
       Component: FBSAUDIC6 ELV   H30 0210
       Revision: 27120501    Serial number: 10600300127140
       Coding: 0000015
       Shop #: WSC 03743 444 20474
       VCID: E386E90B2246275758-80B6
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H43 0070
       Component: FBSAUDIC6 KSG   H26 0080
    00288 - Steering Column Lock Actuator (N360)
                014 - Defective
                        Fault Status: 01111110
                        Reset counter: 183
                        Mileage: 118613 km
                        Date: 2020.02.21
                        Time: 14:26:04
       Part No SW: 4F0 910 731 T    HW: 4E0 035 729
       Component: Interfacebox    H43 3360
       Revision: 00000000    Serial number: 360BL057519740
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       VCID: B326594BD226F7D7E8-80E6
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000114429
       Subsystem 3 - Serial number: 0122.02.050000000100010688’
       Subsystem 4 - Serial number: 010688’
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Reset counter: 191
                        Mileage: 115848 km
                        Date: 2019.12.28
                        Time: 18:43:06
    00658 - Control Head
                        Reset counter: 191
                        Mileage: 115853 km
                        Date: 2019.12.29
                        Time: 18:00:57
                        Bin. Bits:      001
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000026    Serial number: 00000000119115
       Coding: 0524326
       Shop #: WSC 02327 785 00200
       VCID: DBF6D1EB1A361F9710-808E
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 34
                        Reset counter: 95
                        Mileage: 111353 km
                        Date: 2019.08.30
                        Time: 17:45:21
                        Temperature: 33.0°C
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H14 0190
       Coding: 0013123
       Shop #: WSC 03763 444 58363
       VCID: AA18442F05ECB61F5B-80FE
       Subsystem 1 - Component: Fehler Lin-Slave 01
       Subsystem 2 - Component: Fehler Lin-Slave 02
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7125079
       VCID: 9C7492F75FB858AFD9-80C8
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
       Component: SDAR XM         H04 0670
       Revision: 00000000    Serial number: AUZ4Z7D2021085
       VCID: AB16412B0A16AF17A0-80FE
    Address 15: Airbags
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90025050480214
       Coding: 0002041
       Shop #: WSC 02323 785 00200
       VCID: E680F01FD174527FBF-80B2
       Component: Lenkradmodul    H06 0080
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
       Component: KOMBIINSTR. M73 H10 0670
       Revision: 00500000    Serial number: 4R853ZR25
       Coding: 0065201
       Shop #: WSC 06485 067 57207
       VCID: 9E7098FF49A44ABF37-80CA
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
       Revision: 09          Serial number: 080080521900E6
       Coding: 6CFE73CC1B7904
       VCID: A71EBD1B16FE8B7744-80F2
       Coding: 0082954
       Shop #: WSC 02325 785 00200
       VCID: E18AE303385A35474A-80B4
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H44 1100
       Revision: 00000000    Serial number: 378BU057517436
       VCID: B83C6E67CB40148FDD-80EC
    02261 - Data Medium
                        Fault Status: 00101110
                        Fault Frequency: 7
                        Reset counter: 218
                        Mileage: 114410 km
                        Date: 2019.11.17
                        Time: 14:29:40
                        Hex Value: 0x5E46
                        Hex Value: 0xACEE
                        Hex Value: 0x0000
                        Hex Value: 0xFD17
    02927 - DVD Read Error
                        Fault Frequency: 25
                        Reset counter: 223
                        Mileage: 114008 km
                        Date: 2019.11.10
                        Time: 11:46:03
                        Hex Value: 0x5E4E
                        Hex Value: 0xB41F
                        Hex Value: 0x0401
                        Hex Value: 0x0000
    Address 46: Central Conv.
       Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
       Component: DSP-High C6     H14 0310
       Revision: PROD_01     Serial number: 00000000025340
       Coding: 0000026
       VCID: A404AA1767C8606F61-80F0
       Component: ILM Beifahrer   H09 0050
       Revision:             Serial number: 00000000070724
       Coding: 0001114
       VCID: DEF0D8FF09240ABF77-808A
    Address 52: Door Elect, Pass.
    Address 53: Parking Brake
    Address 55: Headlight Range
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394BM057520850
       VCID: AE10483F3904DA3F87-80FA
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000024866
       VCID: A306A90B62C6675718-80F6
       Subsystem 1 - Part No: 000 915 105 DK
       Component: von VA0  020627R0Z5
       Coding: 303030393135313035444B56413030323036323752305A35
       Shop #: WSC 54332 321 22222
                        Mileage: 110652 km
                        Date: 2019.06.28
                        Time: 19:10:12
    02276 - Quiescent Current Stage 5
                        Mileage: 110652 km
                        Date: 2019.06.28
                        Time: 19:10:22
    02274 - Quiescent Current Stage 3
                        Mileage: 110652 km
                        Date: 2019.06.28
                        Time: 19:10:32
                        Mileage: 110652 km
                        Date: 2019.06.28
                        Time: 19:10:42
    00532 - Supply Voltage B+
                        Reset counter: 191
                        Mileage: 115848 km
                        Date: 2019.12.28
                        Time: 14:18:38
    Address 62: Door, Rear Left
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000502160018
       Shop #: WSC 12336 024 394758
       VCID: B4245A57D728F0EFF1-80E0
    Address 72: Door, Rear Right
       Part No SW: 4F0 910 336 D    HW: 4E0 862 335
       Component: Handyvorb2      H10 0700
       Revision: 00000000    Serial number: 00000007516826
       Coding: 0010900
    End----(Elapsed Time: 01:51, VBatt start/end: 14.0V/14.0V. VIgn 0.7V)------
  2. Likes Uwe, Fredrick Awuor liked this post
  3. #2
    Hello Ms. Katie,
    Is the Kessy wet?
    Terminal 15 relay?
    Need something direct email or PM..
  4. Likes Uwe liked this post
  5. #3
    Same as last year; it was dang cold up there last night.
    George supposedly did de-pin the thing last summer, so it can't actually lock up your steering column.
    Anyway, over the phone: We cleared the faults in 05 -- Acc/Start Auth and the car started right up.
    "VCDS -- don't leave home without it!"
  6. Likes PetrolDave liked this post
  7. #4
    Oh cool glad it's gutted............
  8. #5
    Tartu, Estonia
    Unlock the steering, clear faults and cut wire for escl so it will never bothers again.
    The world is my oyster...
  9. #6
    Which wire can be cut that will keep the Kessy happy?
  10. #7
    Ones to the worm gear servo motor & instead did you know you could just add a switch?
    Did you know it doesn't work in all cars?
    Did you also know the controller after authorization just believes the column is unlocked provided the embedded micro switch & "which fails on the boards all the time" is attached to worm gear & is in unlocked position and will then take longer time to activate the alarm when setting and going to sleep mode?
    Did you know since it saves this position it remains in the authorized position provided the transponder is authorized on next boot up?
    Also did you know if push button is used & a weak battery remote being too far away from D2, this can cause it to not wake up the next time and require, well hence the reason for switch & a DTC reset again with VCDS from the glove box?
