Results 1 to 5 of 5
Thread: 2003 vw golf Poor idle
    Oct 2019
    Bristol, UK
    hi,we have had this car in our workshop for a service , when it arrived the eml indicated a fault p0405 egr excessive flow ( not using a vdcs ) during the service the throttle body was cleaned as was the egr valve .upon restarting the epc warning light was on and the eml . i had a quick look on the net and seen posts about resetting the throttle and egr which i did but with no change to the poor idle . i also carried out a reset of the stored values followed by a reset of the throttle and egr . i have tried a different map sensor with no change and tested for an air leak around the manifold but i was unable to find a cause . I hope someone here has the answer or will be able to point me in the right direction.
    Friday,21,February,2020,18:06:40:42129
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWZZZ1JZ4D094820   Mileage: 303520km-188598miles
    Address 01: Engine        Labels: 036-906-034-AZD.clb
       Part No: 036 906 034 DR
       Component:  MARELLI 4MV        5163
       Coding: 00031
       Shop #: WSC 00659
       VCID: 6597B24B7C7B8F3F5A1-4B5C
       WVWZZZ1JZ4D094820     VWZ7Z0C8450361
    17961 - Barometric / Manifold Pressure Signals
                P1553 - 35-00 - Implausible Correlation
    17912 - Intake Air System
                P1504 - 35-10 - Leak Detected - Intermittent
    Readiness: 1010 0101
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0011266
       Shop #: WSC 31414 000 00000
       VCID: 34311F0F822126B71DF-5184
       Part No: 1C0 909 605 A
       Component: 27 AIRBAG VW51 01   0008
       Coding: 12855
       Shop #: WSC 31414
       VCID: 221DE9572DD5B807FF3-513C
       Part No: 1J0 920 926 A
       Component: KOMBI+WEGFAHRSP VDO V20
       Coding: 01413
       VCID: 2809FB7F4BE95257A17-513C
    01039 - Coolant Temperature Sensor (G2)
                80-10 - Single-Wire Operation - Intermittent
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 31414
       VCID: 70B9D31FB3B95A97397-513C
       Part No: 1C0 959 799 B
       Component: 1X Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 31414
       VCID: 36352507915D34A723B-4B1E
       Subsystem 1 - Part No: 1C2959802A
       Component: 1X Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C2959801A
       Component: 1X Tőrsteuer.BF KLO 0202
       Component: 1X Tőrsteuer.HL KLO 0202
       Component: 1X Tőrsteuer.HR KLO 0202
                36-00 - Open Circuit
    End----(Elapsed Time: 05:09, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Maybe the leak is on PCV side or via N80 or booster circuit?
    Did you try isolating for leaks by crimps & to see if you can vacate the correlation DTC?
    Ever see this thread in sticky area?
    https://forums.ross-tech.com/showthr...ou!-Air-leaks!
  3. Likes Uwe liked this post
    HQ
    You might find this information helpful as well:
    Jef
  5. Likes Uwe liked this post
  6. #4
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Evening.....my experience with these you'll have a map sensor depending on engine size/code. You have what I would call star ship mileage on that old girl. Early ones on throttle body adaption with age youd end up replacing engine ecu because it wouldnt take the adaption.
    The pipework from egr to throttle body base plate can get blocked....clean as required.
    The other way Is readapt both with engine warm- lock the car and leave for 30 mins. Retry. It has worked on some. May disconnect battery for 30 mins that may reset.
    Failing that potential EGR issue are not uncommon or throttle body.
    Agreed............
    Hey did you know these cars are like the ABA in the USA with a TV and the TV must move back 5 MM before it can commence forward to count the idle control stepper position?
    Is the throttle cable too tight and causing the adaption to fail?
    Did you try lubing the TV plate and make sure it moves backward first by massaging it & to see the zero marker of stepper is possible seeing if cable is running any interference?
