Results 1 to 7 of 7
Thread: 2011 Jetta Sportwagen TDI Bucking
    Feb 2020
    New to VW VCDS and this forum. The availability of this community is a large part of the reason we opted to own a VW. Thank you in advance for your assistance.
    I have a new to me 2011 Jetta Sportswagen TDI Manual. Starts runs fine revs fine. Put it in gear and it will move but then starts to buck and act starved. Drive it about 2 miles and the glow plug light will blink with check engine light and will drive normally. Turn it off and process repeats.
    Thursday,20,February,2020,12:49:33:10220
    Mileage: 187210km-116326mi   Repair Order: 2011 WHite
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
    VIN: 3VWML7AJ5BM629243   Mileage: 187210km-116326miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 C    HW: 03L 906 019 DA
       Component: R4 2.0l TDI G000SG  9983
       Revision: 12H08---    Serial number:
       Coding: 0050072
       Shop #: WSC 29269 002 1048576
       VCID: 2E0508FD1C153BB76B9-807A
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 003 - Implausible Signal - Intermittent
                        Fault Status: 00100011
                        Fault Frequency: 42
                        Mileage: 182734 km
                        Date: 2014.03.24
                        Time: 10:27:13
                        Voltage: 12.54 V
                        Lambda: -1.6 %
                        Lambda: 11.8 %
                        Bin. Bits: 00000001
                        Voltage: 0.380 V
    006480 - Radiator Fan (V7)
                   P1950 - 000 - Movement Restricted / Jammed - Intermittent
                        Mileage: 187141 km
                        Date: 2014.05.01
                        Time: 20:49:35
                        RPM: 1564 /min
                        Speed: 26.0 km/h
                        Temperature: 12.6°C
                        Temperature: 85.5°C
                        Temperature: 9.0°C
                        Lambda: 86.8 %
                        Lambda: 0.0 %
    000665 - Boost Pressure Regulation
                   P0299 - 000 - Control Range Not Reached
                        Mileage: 187209 km
                        Date: 2014.07.12
                        Time: 21:31:15
                        RPM: 3128 /min
                        Speed: 26.0 km/h
                        Load: 58.4 %
                        Pressure: 2129.6 mbar
                        Pressure: 955.9 mbar
                        Lambda: 78.1 %
                        Lambda: 80.5 %
                   P0299 - 001 - Control Range Not Reached
                        Fault Status: 01100001
                        Mileage: 187209 km
                        Date: 2014.07.12
                        Time: 21:31:15
                        RPM: 3128 /min
                        Speed: 26.0 km/h
                        Load: 58.4 %
                        Lambda: 78.1 %
                        Lambda: 80.5 %
    Readiness: 0 1 0 0 0
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: 114B600C49240003880D06E8921C0042B70000
       VCID: 74B1DA95BEB95167DDD-8020
    02214 - Tire Pressure Warning
                        Reset counter: 82
                        Mileage: 171388 km
                        Date: 2013.07.28
                        Time: 04:02:56
                        Count: 3
                        Count: 2
                        Count: 20480
                        Count: 16401
                        Count: 52224
                        Count: 65024
                        Count: 254
                        Reset counter: 120
                        Mileage: 187209 km
                        Date: 2014.07.04
                        Time: 00:48:44
                        Count: 3
                        Count: 3
                        Count: 20480
                        Count: 16390
                        Count: 32768
                        Count: 1280
                        Count: 64769
                        Reset counter: 120
                        Mileage: 187209 km
                        Date: 2014.07.12
                        Time: 20:43:28
                        Count: 16391
                        Count: 1
                        Count: 20480
                        Count: 128
                        Count: 28416
                        Count: 512
                        Count: 516
                        Count: 2816
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 00066 000 00147
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 75B7E791B543486FEA3-8020
    13701888 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                        Reset counter: 119
                        Mileage: 187141 km
                        Date: 2019.12.09
                        Time: 20:49:39
    9479699 - Control Circuit for Front Left Seat Heater
              B10A6 13 [009] - Open Circuit
                        Reset counter: 234
                        Mileage: 181505 km
                        Date: 2019.10.23
                        Time: 20:19:53
    Address 09: Cent. Elect.
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R00U02Z
       Coding: 00003044
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 392F2BA1D9DBEC0FCEB-806C
       Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
       Component: BF-Gewichtss.  007 0001
       Serial number: ---0000R--0005C55C00
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME7C345054ZZZX
       Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME5B765555ZZZ0
       Serial number: 3511HSME3E051F23ZZZO
       Serial number: 3521HSME03051323ZZZ%
       Serial number: 35527SME4E400423ZZZ7
       Serial number: 35627SME40620423ZZZ+
    13635840 - Supply voltage
              [Powersupply  lower threshold fall short of]
                        Reset counter: 120
                        Mileage: 187209 km
                        Date: 2020.02.19
                        Time: 20:43:58
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
                        Reset counter: 120
                        Mileage: 187209 km
                        Date: 2020.02.11
                        Time: 00:49:24
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JGS00176
       Coding: 108A140000
       Shop #: WSC 00066 000 00187
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 72BDDC8DC42D5F57CF1-8026
       Serial number: 0082040
       Coding: 820000
       Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
       Component: KOMBI         H03 0406
       Coding: 270F01
       VCID: 2F3B15F9179F32BF60F-807A
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 25091001210449
       Coding: E9807F0600160200002002
       VCID: 6D87CFF1D19380AF123-8038
    01304 - Radio
                        Fault Status: 00110100
                        Reset counter: 120
                        Mileage: 187209 km
                        Date: 2014.05.04
                        Time: 08:27:11
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223R9LWH06
       VCID: 7EA5F8BD8CF50B37BB9-802A
       Component: IMMO          H03 0406
       VCID: 6A8DC4EDECFD9797771-803E
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001413959
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 270BFDD93F6F6AFFA8F-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005134386
       Coding: 000490
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 313F13810D2B244F76B-8064
    Address 46: Central Conv.
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001389012
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 2809FEE532716587A15-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005191337
       Coding: 000490
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H13 0043
       Revision: -----26S    Serial number: VWZ4Z7K3111910
       Coding: 0500040004
       VCID: 619FA3C1114BD4CFA6B-8034
                        Reset counter: 156
                        Mileage: 173159 km
                        Date: 2013.11.23
                        Time: 12:43:12
                        Reset counter: 80
                        Mileage: 173750 km
                        Date: 2013.11.28
                        Time: 07:02:32
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668324554
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 323D1C8D04AD1F570F1-8066
    9457427 - Left audio channel for speech/telephone
              B104F 13 [008] - Short to GND
                        Reset counter: 120
                        Mileage: 173911 km
                        Date: 2019.07.09
                        Time: 07:47:00
    9457171 - Right audio channel for speech/telephone
              B104E 13 [008] - Short to GND
                        Reset counter: 120
                        Mileage: 173911 km
                        Date: 2019.07.09
                        Time: 07:46:58
              U1400 00 [008] - -
                        Reset counter: 120
                        Mileage: 187209 km
                        Date: 2020.02.19
                        Time: 20:43:24
    End----------(Elapsed Time: 01:08, VBatt start/end: 13.8V/13.8V)-----------
  2. Likes Uwe liked this post
  3. #2
    Is there a torn intake, loose boot connection from turbo charger to TV or is turbo failing to achieve boost?
    Any obstructions in air intake scoop or air box and is exhaust flowing proper without a restriction?
    Did you log with VCDS or pressure test the system for boost path?
    Are these faults confirmed in the OBD2 side of scan in Mode 3 too?
    Feb 2020
    We plan to dig further tomorrow. It is Saturday and will be a little warmer here in Ohio.
    One question is whether the dates on these codes makes any difference. They seemed to be recorded back in 2014 but maybe I am not understanding that correctly or it is not important. I need to look up how to log the boost side in mode 3 as you mentioned.
    Audibly I would note I do not hear any turbo whistle. I have a 2013 that is in need of a front clip but moves and it is fairly easy to hear the turbo. Then again it does not have an intercooler connected at the moment so that is not a completely fair comparison. We will test it in VCDS and log it.
    On the P2015 I was wondering if I disconnect the valve if it would prove or disprove it as a cause. IE if the flap/valve is shutting radically or unable to travel appropriately would disabling it allow a test to see if it is the cause of the behavior. Or would that put it into limp in mode which, when the vehicle reaches that condition, allows the 2011 to operate without bucking.
    If you have any other test suggestions please let me know.
    TG
    TG
    You mean to Test, Repair or replace never disable an AECD, right?
    This link to this thread maybe helpful on P2015, no?
    https://forums.ross-tech.com/showthr...osition-Sensor
  7. Likes Uwe liked this post
    Feb 2020
    Glad i asked. Yes I was thinking of disconnecting the control wire/plug so that it would allow the flap to sit in the default open position and not actuate the motor to close it. I think you are saying DO NOT do that which is very helpful.
    We will test that and check the other items you suggested and see if we can run this to ground or at least start eliminating some options or getting further insight. Thank you.
    You are welcome & I hope my questions helped and for simulation of inputs/outputs or other tools are in the JPPSG thread too?
    Did you know when you JPPSG the entire thread & not just the first page, it may save you time, help your consumer or even money?
