Results 1 to 2 of 2
Thread: Suspension Error Code: 2010 Audi R8
    Feb 2020
    Taiwan
    Dear Forum Members,
    I am seeking some advice for an 2010 Audi R8
    I have removed the channel (14) Suspension Electronics, but Instruments have displayed Suspension error lamp , Channel (03) ABS Fault code 00471 control Module No Signal.
    Can someone please share Channel (03) ABS coding number to Keine Suspension Electronics Module.
    Thank you in advance.
    The following is the AutoScan Log:
    Saturday,15,February,2020,23:14:37:33160
    VCDS Version: 18.9.1.0
    VIN: WUAZZZ424AN001124   License Plate:
    Mileage: 41520km-25799mi   Repair Order:
    Chassis Type: 42 (1K0)
    Scan: 01 02 03 08 09 10 11 31 15 16 17 19 25 37 42 46 47 52 56 65
              6C 77
    VIN: WUAZZZ424AN001124   Mileage: 41520km-25799miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    Address 01: Engine (BUJ)       Labels: None
       Part No SW: 420 910 552 S    HW: 420 907 552 A
       Component: 5.2L V10HDZ/4V F   ?010
       Revision: F2H02---    Serial number: AUX7Z0I9FN50G9
       Coding: 011000031B0F0120
       Shop #: WSC 11000 285 179750
       VCID: 1F478914CE3C54B2C4-804A
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Mileage: 41525 km
                        Date: 2020.02.15
                        Time: 23:08:58
                        RPM: 173 /min
                        Load: 100.0 %
                        Temperature: 94.0C
                        Temperature: 63.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 9.398 V
    Address 02: Auto Trans        Labels: 420-910-156-V2.clb
       Part No SW: 420 910 156 G    HW: 420 927 156
       Component: SL600 5.2L FSI HDZ  0070
       Revision: SBH02001    Serial number: 7ZNN0KN9J
       Shop #: WSC 00046 000 00000
       VCID: 132FD52432F400D270-8046
       Subsystem 1 - Part No: 420 713 041 C
       Component: A11 C02  28.07.09   0A11
    Address 03: ABS Brakes        Labels: 420-910-517.lbl
       Part No SW: 420 910 517 B    HW: 420 614 517 B
       Component: ESP8 quattro    H01 0100
       Coding: 0000268
       Shop #: WSC 02197 785 00200
       VCID: 0F27D9541EDCE43254-805A
    00471 - Control Module for Elect. Regulated Dampers (J250)
                        Reset counter: 89
                        Mileage: 41525 km
                        Date: 2020.02.15
                        Time: 23:08:39
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x0013
                        Hex Value: 0x2A95
                        Hex Value: 0x0000
       Part No SW: 420 820 043 J    HW: 420 820 043 J
       Component: J255  Klima 1 Zone  0130
       Revision: 00H06009    Serial number: 00000001257851
       Coding: 1572874
       VCID: 1123DF2C08E8F2C242-8044
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 E    HW: 8P0 907 063 E
       Component: BCM PQ35  H   105 0563
       Revision: 00105 AI
       Coding: 06000A2FB005F320007040E001200048577268003020C92ADC00081C0040
       Shop #: WSC 57758 002 104857
       VCID: 36694CB081C6F5FA37-8062
       Subsystem 1 - Part No SW: 423 955 113     HW: 423 955 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiR  H22 0040
       Coding: 005912
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 025B32
       Subsystem 3 - Part No: 8J0 951 177
       Component: DWA-Sensor H0  H03 0020
    Address 10: Park/Steer Assist (J446)       Labels:. 420-919-475.clb
       Part No SW: 420 919 475     HW: 420 919 475
       Component: PARKHILFE 8K  H07 0130
       Revision: 11001001    Serial number: 79940921601266
       Coding: 30010C
       Shop #: WSC 02391 823 56573
       VCID: 59B3E70C5098FA82FA-800C
    Address 11: Engine II        Labels: None
    000373 - Fuel Trim; Bank 2
                   P0175 - 008 - System Too Rich - Intermittent
                        Mileage: 41478 km
                        Date: 2020.02.14
                        Time: 15:46:00
                        RPM: 784 /min
                        Load: 16.9 %
                        Temperature: 96.0C
                        Temperature: 43.0C
                        Voltage: 13.843 V
    Address 15: Airbags        Labels: 420-959-655.lbl
       Part No SW: 420 959 655     HW: 420 959 655
       Component: SL Airbag 9.43  H02 0020
       Revision: 93H02002    Serial number: 003B8000BNS+
       Coding: 0021324
       VCID: 5DBBF31C84B006A296-8008
       Subsystem 1 - Serial number: 63328RB404ECC45B/
       Subsystem 2 - Serial number: 63428RB404ECC4B5+
       Subsystem 3 - Serial number: 63747RB404F24289R
       Subsystem 4 - Serial number: 63847RB404F2425FV
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Coding: 0004141
       VCID: 41832F6C1808424292-8014
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 420-920-xxx-17.clb
       Part No SW: 420 920 930 J    HW: 420 920 930 J
       Component: KOMBIINSTR. VDO H03 0490
       Revision: D0H03004    Serial number: 2249I004000523
       Coding: 0081128
       VCID: 1737A134260C2CF20C-8042
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0232
       Revision:   H16       Serial number: 4440K097168029
       Coding: AFA01F07504602004100
       VCID: 69D3D7CC40F86A026A-803C
       Revision: D0H03004    Serial number: AUX7Z0I9FN50G9
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 423 035 195 D    HW: 423 035 195 D
       Component: RS-E PU EU      H02 0080
       Revision: 0000003S    Serial number: AUZBZ7J6700045
       Coding: 0730757
       VCID: 142DD63837FA07EA69-8040
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 420 959 801 D    HW: 420 959 801 D
       Component: Tuer-SG         004 0100
       Coding: 0004213
       VCID: 1A31B800D51E319A33-804E
    Address 47: Sound System        Labels: 420-035-223.lbl
       Part No SW: 420 035 223 D    HW: 420 035 223 A
       Component: J525 Amp High   H14 0230
       Revision: 00H14001    Serial number: 34844000521002
       Coding: 0246111
       VCID: 0913F74C60B8CA028A-805C
       Part No SW: 420 959 802 D    HW: 420 959 802 D
       Coding: 0004213
       VCID: 1B3FBD04DA24489228-804E
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0730757
    Address 65: Tire Pressure        Labels: None
       Part No SW: 420 910 273     HW: 4F0 907 273 A
       Component: Reifendruck 3   H05 0030
       Revision: 00050030    Serial number: 00000900005392
       Coding: 0422426
       VCID: 4C9D0E582F4A9F2A71-8018
    Address 6C: Back-up Cam.        Labels: 420-910-441.clb
       Part No SW: 420 910 441 A    HW: 7L6 907 441 C
       Component: J772__Rearview      0010
       Revision: --H13---    Serial number: 525PA8-J996014
       Coding: 1020412
       Shop #: WSC 00999 444 64523
       VCID: 0A11C84065BEC11A83-805E
       Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
       Component: FSE_256x BT     H34 0600
       Revision: 00000000    Serial number: 00000005124166
       Coding: 0011492
       Shop #: WSC 02556 785 00200
       VCID: 75EB8BBC1C40BEE2FE-8020
    End-------------------------(Elapsed Time: 02:26)--------------------------
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000266,(02197/785/00200),
    Address 03: DTCs cleared
    Address 03,420 910 517 B,recoded (Short coding),from,0000266,to,0000260,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000260,to,0000268,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000739,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0020239,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0020239,to,0020739,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0020739,to,0000268,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0001268,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0002268,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0020739,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0020739,to,0020768,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0020739,to,0020738,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0020738,to,0020768,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0020738,to,0000268,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000168,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000368,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000468,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000068,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000200,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000208,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000222,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000277,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000248,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000268,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000288,(02197/785/00200),
    Address 03,420 910 517 B,recoded (Short coding),from,0000268,to,0000228,(02197/785/00200),
    Since it seems you are retrofitting a non-standard suspension, moved from Product Support to Retrofits.
    Please update your VCDS. People around here tend to regard seriously outdated software with considerable suspicion.
  3. Likes PetrolDave liked this post
