Results 1 to 10 of 17
Thread: 2009 Rabbit 2.5 ABS Code lost (MK60EC1)
Hybrid View
    Feb 2020
    Hello Wizards of Ross-tech. Around Christmas ABS module in my Rabbit crashed completely and dozens of lights went off in my dashboard. I went to ‘not the best mechanic’ he was right I needed a ABS module and junkyard was my best bet. I went to the Junkyard and got him a module from the similar model(4 door golf like mine). due to mine or his lack of knowledge we never looked to copy the old code. 8-10 lights changed to 4 lights on the dashboard though. Finally, googled the symptoms and VCDS came back as the answer. Got my cable shipped few days ago but due to my weekly schedule couldn’t scan till now. I have a lot of codes still being raised as per the scans. Priority is to do something about the ABS code as 00s doesn’t look right .
    Will appreciate the magic!
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: WVWDB71K99W132981   Mileage: 128920km-80107miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 M    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   3253
       Revision: G6H01---    Serial number: VWX7Z0H83NT7TY
       Coding: 0000075
       VCID: 38292EBD9E550BD7315-806C
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 000 -  - Intermittent
                        Fault Frequency: 7
                        Mileage: 127107 km
                        Time: 23:17:42
                        RPM: 614 /min
                        Load: 18.0 %
                        Temperature: 90.0°C
                        Temperature: 66.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.208 V
    012408 - Throttle Control
                   P3078 - 000 - Airflow at Idle too Low
                        Mileage: 127502 km
                        Time: 21:21:12
                        RPM: 1185 /min
                        Load: 21.6 %
                        Speed: 26.0 km/h
                        Temperature: 79.0°C
                        Temperature: 37.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.589 V
    005386 - Engine Off Timer Performance
                   P150A - 000 -  - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        RPM: 161 /min
                        Load: 72.5 %
                        Temperature: 7.0°C
                        Temperature: 7.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 9.652 V
       Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
       Component: AQ 250 6F           1377
       Revision: 00H76000    Serial number:
       Coding: 0000840
       VCID: 7DA7FFA9F1F7EEFFA23-8028
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Shop #: WSC 25155 444 12472
       VCID: 7EA5F8A5F0F1F5E7BB9-802A
                        Reset counter: 0
                        Mileage: 127107 km
                        Count: 16391
                        Count: 12
                        Count: 8192
                        Count: 195
                        Count: 45568
                        Fault Status: 01100101
                        Fault Frequency: 17
                        Reset counter: 232
                        Mileage: 127107 km
                        Count: 16391
                        Count: 12
                        Count: 8192
                        Count: 279
                        Count: 45568
                        Fault Frequency: 17
                        Reset counter: 232
                        Mileage: 127107 km
                        Count: 16391
                        Count: 12
                        Count: 8192
                        Count: 295
                        Count: 45568
                        Fault Frequency: 17
                        Reset counter: 232
                        Mileage: 127107 km
                        Count: 16391
                        Count: 12
                        Count: 8192
                        Count: 270
                        Count: 45568
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9EEBDDED5CBD7F15-802C
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
       Revision: 00H54000    Serial number: 00000008945525
       Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
       VCID: 323D1C957829E1870F1-8066
       Component: Wischer 230908 021  0501
       Coding: 00038805
       Shop #: WSC 01357
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Fault Status: 01101100
                        Reset counter: 233
                        Mileage: 128510 km
                        Voltage: 13.85 V
       Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
       Component: SDAR SIRIUS     H07 0150
       Revision: 00000000    Serial number: AUZ4Z7H0426336
       Coding: 0000100
       VCID: 333319918733E88F047-8066
                        Reset counter: 198
                        Mileage: 127107 km
                        Time: 23:17:57
       Component: 6K AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0C2FBU
       Coding: 0013899
       VCID: 6C81C2ED9A8D777705D-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME4135700C3
       Subsystem 3 - Serial number: 6342MSME4135407EA
       Subsystem 4 - Serial number: 6352QSME340C4C02E
       Subsystem 5 - Serial number: 6362QSME620706245
       Subsystem 6 - Serial number: 63727SME19067350Y
       Subsystem 7 - Serial number: 63827SME186B6D05B
    01316 - ABS Control Module
       Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
       Component: J0527           051 0101
       Coding: 0010022
       VCID: 77ABED81D3CBC4AFF8F-8022
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0003000    Serial number: VWX7Z0H83NT7TY
       Coding: 0007203
       VCID: 3C2132ADAA6D27F7D5D-8068
                        Fault Frequency: 11
                        Reset counter: 238
                        Mileage: 127107 km
                        Time: 23:17:48
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 050908F2000857
       Coding: ED807F070003020002
       VCID: 353727898947F6BF2A3-8060
                        Fault Status: 00110100
                        Reset counter: 238
                        Mileage: 127107 km
                        Time: 23:17:51
       Component: IMMO            VDD 1222
       Component: Tuer-SG         006 1219
       Coding: 0001205
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.070 H08 1901
       Component:    KSG PQ35 RDK 052 0221
       Coding: 1B9006885103281B0904058FB0080F0488DC80
       VCID: 04518A4D921D9F37EDD-8050
       Coding: 0001204
       VCID: 392F2BB9A55F12DFCEB-806C
       Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
       Component: Radio PM6       125 0037
       Revision: 00125000    Serial number: VWZ5Z7H2265686
       Coding: 0040401
       VCID: 290FFBF955FFA25FBEB-807C
       Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
       Component: Tuer-SG         006 1302
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       Component:    RDK              0450
       Coding: 0100101
                        Fault Status: 01110100
                        Reset counter: 198
                        Mileage: 127107 km
                        Time: 23:17:59
    00625 - Vehicle Speed Signal
                        Fault Status: 00111000
                        Reset counter: 238
                        Mileage: 127107 km
                        Time: 23:58:20
       Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
       Coding: 0001168
    End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.2V)-----------
    Last edited by 09Rabbit2.5; 02-21-2020 at 07:01 AM. Reason: Adding relevant information!
    Feb 2020
    Did I post it in the right forum? Or email as per instructions??
    Instructions I just Found: http://wiki.ross-tech.com/wiki/index...onics_(MK60EC1)
    Quote Originally Posted by 09Rabbit2.5 View Post
    Here is fine. I'm reasonably confident there are people here who can come up with an appropriate coding for this. Unfortunately, I'm not one of them.
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
    Coding: 0000075
    Coding: 0000840
    Address 03:
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD FAIL! IN INVESTIGATION
    Revision: 00H45001
    PART-NUMBER JPPSG DESCRIPTION REMARK MODEL
    1K0 907 375 AH FOD! Control unit for ABS LEGACY PART NUMBERS
    1K0 614 517 BD
    1K0 907 379 AD
    1K0 907 379 CD
    Scans on net do not show this module in comparison
    OP are you aware that this maybe a completely free repair under recall and can be verified at NHTSA?
    Coding:
    114B000C092500FC881400EC901A00000000 THIS IS NOT YOUR CODE IT IS A STRIP OF ALGORITHM TO VIN # LHD
    PLEASE LOOSEN NOOSE?
    Vehicle Identification No. WVWDB71K99W132981
    Model golf 2.5
    GO
    Date of production 27.10.2008
    Model year 2009
    Sales type 1K17S3
    Engine Code CBUA
    Transmission Code KGL
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HA Vehicle class differentiation -1K0-
    tail pipe 0P1 Rear side exhaust tailpipe
    Hill start assist UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 0GT Emission standard SULEV
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
    Aerials 8ZN Antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KE Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZP Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Component parts set, complying with vehicle type for USA (without California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C24 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JA Rear shock absorption, basic version 1
    Suspension system in front G07 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0ER Installation differentiation for transmission AQ250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MJ Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K4 Separate daytime running light -- NAR --
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YE Weight range 5 installation control only, no requirement forecast
    Weight category front axle L13 Suspension range 13 installation control only, no requirement forecast
    Base engine T8K 5-cylinder SI engine 2.5 l unit 07K.1
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1A 6-speed automatic transmission
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PA Hand brake lever handle in plastic
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Customized installation FC0 Without customized installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Refrigerator 1W2 Glove compartment cooling system
    child safety 4H3 Manual child safety lock
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    Rear head restraints 3T2 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel tank treatment 2LF Fuel tank with special material treatment (coextrusion) with changed protective layer
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A1 Fuel system for fuel-injected SI engine, injection system without fuel return
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Rear license plate carrier 6P2 Rear license plate carrier (NAR)
    Front license plate carrier 6W3 Front license plate carrier (small, NAR)
    Paint preservative/transit coating 5K0 Without surface protection, with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights in front, two in rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H2 Backrest release for right front seat
    Air duct, front area VK1 Air duct, type 1
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 1ME Steering wheel
    Speaker installation 8RW 10 speakers (passive)
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q0 Without multi-function display/ trip computer
    Engine cooling 8Z6 Hot country
    Engine specifications D77 5-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WA Without fog lights
    Upgrading measures GP0 Vehicles without special upgrade measures
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CM6 Alloy wheels 6.5J x 16
    Radios 8US Radio "Premium" (double-size standard radio)
    Smoker's/non-smoker's package 9JF Non-smoker's package (NAR)
    Tire pressure monitoring system 7K4 Tire pressure monitoring system 315 MHz High
    tire H4B All-season tires 205/55 R16 H (NAR)
    Spare wheel/breakdown kit 1G2 Steel spare wheel with original equipment tire
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    P2S Golf 16-inch alloy wheel package
    PEC Exhaust California (only for Golf USA was: PMC)
    Gearshift knob/handle 6Q1 Gearshift knob/handle in plastic
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Comfort seat in front, left
    Front seat, right 3SF Comfort seat, front right
    Nameplate for sales name QD0 Without nameplate for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N0U Seat trim covers in velour
    Seat adjustment 3PD Manual height adjustment for front seats, electric backrest adjustment for left front seat
    seat heater 4A3 seat heating for front seats separat controlable
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) S5K Control (in-plant)
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B2 Body-colored protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JC Comfort bumpers
    Rear stabilizer bar 0BD Rear stabilizer bar
    Front stabilizer bar 0AD Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 0NV Nameplate set "2.5"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5 Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B38 Legal requirements for California
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A2 4 doors
    TV reception/digital radio reception QV8 Satellite radio reception NAR
    Front underbody guard 1SA Without additional front underbody guard
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  5. Likes 09Rabbit2.5 liked this post
    Feb 2020
    That's not a good news .. Uwe said its not the end for this module maybe? before I make attempts to go look for another one again, what can I do?
    cannot undo the noose all the way yet but I am here finally!!
    I did take my car to the dealership, they gave me a run around and said since I never took my car in before ABS broke down, expense will be out of pocket. Should I call NHTSA?
    FOD FAIL!
    Let me translate this for the new member. It means the ABS module installed here isn't the "correct" one for the car. That doesn't necessarily mean it won't work though, but it certainly lessens the odds.
    Jack: It also isn't all that helpful without telling us what the correct one(s) would be.
    United States
    The parts catalog cannot conclusively determine which ABS module was factory installed but I'm reasonably confident it would have been born with 1K0 907 379 AD. If so, that supers to 1K0 907 375 AN if you were to install a new repair kit from the dealer.
    PL24 shows different part numbers so you may have a compatibility concern of some sort as Jack mentioned.
    Either way, I believe the factory coding was:
    113B400D492500FC881402EC921A00413000
  9. Likes DrPeter, Uwe, 09Rabbit2.5 liked this post
  10. #8
    Feb 2020
    Thank youuu. Will try this code and report back in 15- 30 minutes.
  11. Likes Uwe liked this post
  12. #9
    Feb 2020
    It worked!! now I gotta learn how to make it stick and take care of other codes !!
  13. Likes Dana, Uwe, nazdaq100 liked this post
  14. #10
    If it happens to not & regardless OP are you aware that this maybe a completely free repair under recall and can be verified at NHTSA?
  15. Likes Dana, Santos, 09Rabbit2.5 liked this post
