2009 Rabbit 2.5 ABS Code lost (MK60EC1)
09Rabbit2.5
C?ID=396240
Hello Wizards of Ross-tech. Around Christmas ABS module in my Rabbit crashed completely and dozens of lights went off in my dashboard. I went to ‘not the best mechanic’ he was right I needed a ABS module and junkyard was my best bet. I went to the Junkyard and got him a module from the similar model(4 door golf like mine). due to mine or his lack of knowledge we never looked to copy the old code. 8-10 lights changed to 4 lights on the dashboard though. Finally, googled the symptoms and VCDS came back as the answer. Got my cable shipped few days ago but due to my weekly schedule couldn’t scan till now. I have a lot of codes still being raised as per the scans. Priority is to do something about the ABS code as 00s doesn’t look right :D.
Will appreciate the magic!
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: WVWDB71K99W132981   Mileage: 128920km-80107miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   3253
   Revision: G6H01---    Serial number: VWX7Z0H83NT7TY
   Coding: 0000075
   VCID: 38292EBD9E550BD7315-806C
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Fault Frequency: 7
                    Mileage: 127107 km
                    Time: 23:17:42
                    RPM: 614 /min
                    Load: 18.0 %
                    Temperature: 90.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.208 V
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Mileage: 127502 km
                    Time: 21:21:12
                    RPM: 1185 /min
                    Load: 21.6 %
                    Speed: 26.0 km/h
                    Temperature: 79.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.589 V
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 161 /min
                    Load: 72.5 %
                    Temperature: 7.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 9.652 V
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DA7FFA9F1F7EEFFA23-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Shop #: WSC 25155 444 12472
   VCID: 7EA5F8A5F0F1F5E7BB9-802A
                    Reset counter: 0
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 195
                    Count: 45568
                    Fault Status: 01100101
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 279
                    Count: 45568
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 295
                    Count: 45568
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 270
                    Count: 45568
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EEBDDED5CBD7F15-802C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000008945525
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   VCID: 323D1C957829E1870F1-8066
   Component: Wischer 230908 021  0501
   Coding: 00038805
   Shop #: WSC 01357
01501 - Bulb for Blinkers; Rear Left (M6)
                    Fault Status: 01101100
                    Reset counter: 233
                    Mileage: 128510 km
                    Voltage: 13.85 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0426336
   Coding: 0000100
   VCID: 333319918733E88F047-8066
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:57
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0C2FBU
   Coding: 0013899
   VCID: 6C81C2ED9A8D777705D-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME4135700C3
   Subsystem 3 - Serial number: 6342MSME4135407EA
   Subsystem 4 - Serial number: 6352QSME340C4C02E
   Subsystem 5 - Serial number: 6362QSME620706245
   Subsystem 6 - Serial number: 63727SME19067350Y
   Subsystem 7 - Serial number: 63827SME186B6D05B
01316 - ABS Control Module
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0101
   Coding: 0010022
   VCID: 77ABED81D3CBC4AFF8F-8022
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0003000    Serial number: VWX7Z0H83NT7TY
   Coding: 0007203
   VCID: 3C2132ADAA6D27F7D5D-8068
                    Fault Frequency: 11
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:48
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 050908F2000857
   Coding: ED807F070003020002
   VCID: 353727898947F6BF2A3-8060
                    Fault Status: 00110100
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:51
   Component: IMMO            VDD 1222
   Component: Tuer-SG         006 1219
   Coding: 0001205
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Component:    KSG PQ35 RDK 052 0221
   Coding: 1B9006885103281B0904058FB0080F0488DC80
   VCID: 04518A4D921D9F37EDD-8050
   Coding: 0001204
   VCID: 392F2BB9A55F12DFCEB-806C
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       125 0037
   Revision: 00125000    Serial number: VWZ5Z7H2265686
   Coding: 0040401
   VCID: 290FFBF955FFA25FBEB-807C
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   Component:    RDK              0450
   Coding: 0100101
                    Fault Status: 01110100
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:59
00625 - Vehicle Speed Signal
                    Fault Status: 00111000
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:58:20
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.2V)-----------
Did I post it in the right forum? Or email as per instructions??
Here is fine. I'm reasonably confident there are people here who can come up with an appropriate coding for this. Unfortunately, I'm not one of them.
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Coding: 0000075
Coding: 0000840
Address 03:
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD FAIL! IN INVESTIGATION
Revision: 00H45001
PART-NUMBERJPPSGDESCRIPTIONREMARK MODEL
1K0 907 375 AHFOD!Control unit for ABSLEGACY PART NUMBERS
1K0 614 517 BD
1K0 907 379 AD
1K0 907 379 CD
Scans on net do not show this module in comparison
OP are you aware that this maybe a completely free repair under recall and can be verified at NHTSA?
Coding:
114B000C092500FC881400EC901A00000000 THIS IS NOT YOUR CODE IT IS A STRIP OF ALGORITHM TO VIN # LHD
PLEASE LOOSEN NOOSE?
Vehicle Identification No.WVWDB71K99W132981
Modelgolf 2.5
GO
Date of production27.10.2008
Model year2009
Sales type1K17S3
Engine CodeCBUA
Transmission CodeKGL
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HAVehicle class differentiation -1K0-
tail pipe0P1Rear side exhaust tailpipe
Hill start assistUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard0GTEmission standard SULEV
Trailer hitch1D0Without trailer hitch
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Aerials8ZNAntenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8XUS comfort equipment
Brake type in rear1KEDisc brakes in rear
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DComponent parts set, complying with vehicle type for USA (without California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC24Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rear1JARear shock absorption, basic version 1
Suspension system in frontG07Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ERInstallation differentiation for transmission AQ250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MJDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running light -- NAR --
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YEWeight range 5 installation control only, no requirement forecast
Weight category front axleL13Suspension range 13 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U1Folding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG1A6-speed automatic transmission
Brackets3P0Without bracket for first aid kit and warning triangle
handle for hand brake lever6PAHand brake lever handle in plastic
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without customized installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Cassette and CD storage unit4W0without cassette / CD tray
Refrigerator1W2Glove compartment cooling system
child safety4H3Manual child safety lock
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y2Tropical zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Rear head restraints3T2Three rear head restraints
Head restraints5ZFFront head restraints
Fuel tank treatment2LFFuel tank with special material treatment (coextrusion) with changed protective layer
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Rear license plate carrier6P2Rear license plate carrier (NAR)
Front license plate carrier6W3Front license plate carrier (small, NAR)
Paint preservative/transit coating5K0Without surface protection, with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights in front, two in rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H2Backrest release for right front seat
Air duct, front areaVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels1MESteering wheel
Speaker installation8RW10 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E3Center armrest in front
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q0Without multi-function display/ trip computer
Engine cooling8Z6Hot country
Engine specificationsD775-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WAWithout fog lights
Upgrading measuresGP0Vehicles without special upgrade measures
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCM6Alloy wheels 6.5J x 16
Radios8USRadio "Premium" (double-size standard radio)
Smoker's/non-smoker's package9JFNon-smoker's package (NAR)
Tire pressure monitoring system7K4Tire pressure monitoring system 315 MHz High
tireH4BAll-season tires 205/55 R16 H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Steel spare wheel with original equipment tire
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
P2SGolf 16-inch alloy wheel package
PECExhaust California (only for Golf USA was: PMC)
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q1Gearshift knob/handle in plastic
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFComfort seat in front, left
Front seat, right3SFComfort seat, front right
Nameplate for sales nameQD0Without nameplate for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN0USeat trim covers in velour
Seat adjustment3PDManual height adjustment for front seats, electric backrest adjustment for left front seat
seat heater4A3seat heating for front seats separat controlable
Safety head restraint system3K0w/o safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Horns8Y1Two-tone horn
Control number (no PR family)S5KControl (in-plant)
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B2Body-colored protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JCComfort bumpers
Rear stabilizer bar0BDRear stabilizer bar
Front stabilizer bar0ADFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0NVNameplate set "2.5"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements for California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV8Satellite radio reception NAR
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
FOD FAIL!
Let me translate this for the new member. It means the ABS module installed here isn't the "correct" one for the car. That doesn't necessarily mean it won't work though, but it certainly lessens the odds.
Jack: It also isn't all that helpful without telling us what the correct one(s) would be.
Dana
Western PA, USA
The parts catalog cannot conclusively determine which ABS module was factory installed but I'm reasonably confident it would have been born with 1K0 907 379 AD. If so, that supers to 1K0 907 375 AN if you were to install a new repair kit from the dealer.
PL24 shows different part numbers so you may have a compatibility concern of some sort as Jack mentioned.
Either way, I believe the factory coding was:
113B400D492500FC881402EC921A00413000
09Rabbit2.5
C?ID=396240
That's not a good news :( .. Uwe said its not the end for this module maybe? before I make attempts to go look for another one again, what can I do?
cannot undo the noose all the way yet but I am here finally!!
I did take my car to the dealership, they gave me a run around and said since I never took my car in before ABS broke down, expense will be out of pocket. Should I call NHTSA?
09Rabbit2.5
C?ID=396240
Thank youuu. Will try this code and report back in 15- 30 minutes.
09Rabbit2.5
C?ID=396240
It worked!! :D now I gotta learn how to make it stick and take care of other codes !!
09Rabbit2.5
C?ID=396240
Everything is looking good now. I am going to run another scan tomorrow and see which codes are still around. I will first reach out to NHTSA and do more research to get VW dealership to honor the recall.
My motivation and concern now is what if this module goes bad later too. At least, between all this I found a amazing community & a way to deal with this car in the long run!!
Thaank you.
nazdaq100
London, United Kingdom
C?ID=314050
Thaank you.
This is a wonderful news I am always intrigued to learn an after auto scan if you can please post. this way we can determine the exact unique long coding which was successful with abs part number
Cheerio
OP and forum readers, recently people have been in apprehension, well " sometimes " & to when I question if a vehicle comports under useful life warranty or recall campaigns, and not sure if people realize this pattern behavior?
Did you know some may see this as an agenda, well, so I'm told and the ones with such apprehension, could it be a vicarious invisible hand?
Did you know as a professional or any professional in this industry or you deal with, they have a lawful responsibility to inform you before taking your money and unless you are made aware of safety or free repair campaigns and possibly sign off on it & before to commence in a paid for repair and with an expectation of estimate when engaging such defects even unwittingly of defect before a possible public disclosure?
Did you know professionals can charge for these estimates or diagnosis too and is why before giving advice professionally in shop, I charge for it with upfront agreed fees & acknowledged before we start; so insurance companies and manufactures become responsible to consumer for my time & as a third party & so the consumer has a claim directly & since I don't accept direction of pay from insurance companies or an OEM?
Did you know If doing estimates in good faith or informing people properly & as a licensed professional, if this is considered an agenda, I guess I'm guilty of it, however, knowing your industry and giving an expectation of professional advice is not legal advice, it's a requirement of working within guidelines of State & Federal regulations?
Even though what I do here is free, I still feel bound by aforementioned, so if I seem bullish on it, I apologize.
Can you see I have no angle other than I take issue with the interference our industry suffers & when it cant make money on it due to parts being too expensive or exceeding a value of a vehicle and due to using said defects or failure to circumvent comporting with a regulation & to effectively curb cars & to even force consumers out of shops or self repair enthusiasts by a creative hidden unjust enrichment scheme & maybe even in spirit of a Vail of alleged high security and into a new car sales floor or only OEM repair franchises to maintain a monopoly?
Does anyone see my point, sorry for being a PITA?
09Rabbit2.5
C?ID=396240
Well, there seems to be a lot more going on then it seems.
Saturday,22,February,2020,10:40:26:26625
Dealer/Shop Name: Home
VIN: WVWDB71K99W132981   License Plate: AAAAAAA
Mileage: 129010km-80163mi   Repair Order:
VIN: WVWDB71K99W132981   Mileage: 129010km-80163miles
03-ABS Brakes -- Status: Sporadic communication error 1000
   Coding: 0000075
                    Fault Frequency: 7
                    Mileage: 127107 km
                    Time: 23:17:42
                    RPM: 614 /min
                    Load: 18.0 %
                    Temperature: 90.0°C
                    Temperature: 66.0°C
                    Voltage: 13.208 V
               P3078 - 000 - Airflow at Idle too Low - Intermittent
                    Mileage: 127502 km
                    Time: 21:21:12
                    RPM: 1185 /min
                    Load: 21.6 %
                    Speed: 26.0 km/h
                    Temperature: 79.0°C
                    Temperature: 37.0°C
                    Voltage: 13.589 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 173 /min
                    Load: 71.0 %
                    Temperature: 26.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 10.287 V
   Coding: 0000840
   Revision: 00H45001
   Coding: 113B400D492500FC881402EC921A00413000
   Coding: 00038805
   Shop #: WSC 01357
                    Reset counter: 236
                    Mileage: 128510 km
                    Voltage: 13.85 V
   Coding: 0000100
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:57
   Coding: 0013899
   Coding: 0010022
   Coding: 0007203
                    Fault Frequency: 11
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:48
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:51
   Coding: 0001205
   Coding: 0001204
   Coding: 0040401
00874 - Treble Speaker Front Left (R20)
                    Fault Status: 01101011
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
00876 - Treble Speaker Rear Left (R14)
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
   Coding: 0001168
   Component:    RDK              0450
   Coding: 0100101
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:59
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:58:20
   Coding: 0001168
End----------(Elapsed Time: 01:14, VBatt start/end: 14.2V/14.3V)-----------
https://forums.ross-tech.com/showth...lost-(MK60EC1)&p=192850&viewfull=1#post192850
Did you know this car has a 15 year 150K warranty for useful life?
Part No SW: 07K 906 055 M HW: 07K 906 055 M <<<<<<<<<<<<<<<<<<<<<<<<<< HERE!
Component: 2,5l R5/4V G 3253 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< NO NO over HERE!
Coding: 0000075
Did you know your car is due for a ton of firmware GHG updates and all these repairs are covered under useful life warranty for these faults or as a result if they illuminate an MIL or not?
Part Version 07K906055M_3859
9203
9970
9971
07K906055M__Z105
See my point of this post?
https://forums.ross-tech.com/showth...lost-(MK60EC1)&p=192949&viewfull=1#post192949
Have you looked your car up here?
https://literature.vw.com/calibration_lookup.asp
You seemed receptive OP, would you like me to continue to document for you in self evident answered questions?
Could you post the OBD2 MODE 3 & 9 data in VCDS?
09Rabbit2.5
C?ID=396240
I’m totally with you on this one. I should have been a smart consumer before attempting all the mojo.
I have read all your post and agree with you. I will have to do things the right way!!
I’ll post the scans your requested shortly!
