Results 1 to 10 of 11
Thread: Caddy 2K 2016 MFSW Help
    Jan 2020
    Suffolk, UK
    Exclamation Caddy 2K 2016 MFSW Help
    Hello all, i have a customer whos wanting me to fit a MFSW Into a caddy, it all fits but nothing works and it wont let me code the MFSW in the coding boxs
    i have seen this ( http://wiki.ross-tech.com/wiki/index...odule_Versions )
    and am i correct in thinking, that .....
    5K0-953-569-BB Midline Yes Yes Yes No No this is what is fitted and
    i will need anything that says highline and that has MFSW (Yes) to be able to to make this work?
    i have attached the auto scan
    any help would be great,
    the scan was taken with the MFSW installed
    Thursday,20,February,2020,16:41:43:14161
    VCDS Version: 19.6.2.2 (x64)
    VIN: WV1ZZZ2KZGX061265   License Plate: WAYNE CADDY
    Mileage: 123640km-76826mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
    VIN: WV1ZZZ2KZGX061265   Mileage: 123640km-76826miles
    Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 GT    HW: 04L 907 309 K
       Component: R4 2,0L EDC   X20 1774
       Revision: 8AX20---
       Coding: 0111001204250D090000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
       ROD: EV_ECM20TDI01104L906016GR_001_VN35.rod
       VCID: 010E3238903E5B47AA-8054
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 42885000002859
       Coding: 1079409B9268A47F0877027C498725E37900F0
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3F8AF4C0A64AEDB79C-806A
    0297 - Steering angle sensor
              B1168 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 127
                        Mileage: 123027 km
                        Date: 2020.01.15
                        Time: 00:00:00
       Part No SW: 1K8 907 426 AH    HW: 1K8 907 426 AH
       Component: AC Manuell    H20 0808
       Revision: 00001002
       Coding: 0010004003
       VCID: 79FE5AD8F8EE0387E2-802C
       Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
       Component: BCM PQ35 M+   122 0183
       Revision: BD122001
       Coding: 431A5A3E8021E16A08800082940081EC03D1000842228220648087000041
       Shop #: WSC 35110 377 08192
       VCID: 73E268F0D28279D7A8-8026
       Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 05101  27  0512
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 101115 03  37  0059
       Coding: 0228DD
       Subsystem 3 - Part No: 7N0 951 172
       Component: Sensor, DWA 0  005 0502
       Part No SW: 1K8 919 465     HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0479
       Revision: --------    Serial number: 39291529600546
       Coding: 0001050001
       ASAM Dataset: EV_EPHVA14VW364GP00 001006
       ROD: EV_EPHVA14VW364GP00_VW36.rod
       VCID: 76E451E4C9F06CFF8F-8022
       Part No SW: 2K5 959 655     HW: 2K5 959 655
       Component: VW10Airbag00K 008 0016
       Revision: --------    Serial number: 003QV000YDS6
       Coding: 00000000000000000000000000000000304B
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       Serial number: 3497ARB40653H71S8OVX
       Serial number: 3507ARB401A54UJMN3P.
       Part No SW: 1K5 953 521 CL    HW: 5K0 953 569 BB
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20151022300456
       Coding: 4080160010
       ROD: EV_SMLSNGVOLWSR8C.rod
       Part No SW: 2K5 920 966 A    HW: 2K5 920 966 A
       Component: KOMBI         H04 1009
       Coding: 480A001200
       VCID: 3362A8F09A0239D768-8066
    13654544 - Databus
                        Fault Frequency: 47
                        Reset counter: 122
                        Mileage: 123026 km
                        Date: 2020.01.15
                        Time: 12:27:51
       Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1674
       Revision:   H58       Serial number: 301015F1000492
       Coding: 357421
       Shop #: WSC 00000 288 08067
       VCID: 74E06BECD78C7EEFB1-8020
                        Reset counter: 122
                        Mileage: 123645 km
                        Date: 2020.02.20
                        Time: 16:12:17
       Component: IMMO          H04 1009
       VCID: 6ADC75948D48B81F1B-803E
       Part No SW: 2K5 959 701     HW: 2K5 959 701
       Component: Tuer-SG         009 2144
       Coding: 0131632
       VCID: 71EE62F8689E4BC75A-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 397E9AD8706EC387A2-806C
       Part No SW: 2K5 959 702     HW: 2K5 959 702
       Coding: 0131632
       VCID: 72EC6DF46D9870DFA3-8026
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1674
       Coding: 030F1873
       VCID: 71EE62F8A89E4BC75A-8024
       Component: J367-BDM  H07 0180
       Serial number: 42296430321491940824
    End-------------------------(Elapsed Time: 02:36)--------------------------
    Tartu, Estonia
    Quote Originally Posted by Normus19 View Post
    Yes Highline SWCM that actually supports MFSW.
    Direct replacement would be 5k0-953-569-bd. You don't want to go lower because some options may not be supported like Limiter.
    The world is my oyster...
  3. Likes Uwe liked this post
    Jan 2020
    Suffolk, UK
    https://rover.ebay.com/rover/0/0/0?m...2F253455793970
    So if I order this .... fingers crossed I should all work
    Tartu, Estonia
    Please be noted that label file may not be loaded correctly due to being Audi SW nr, though HW is identical.
    There was talk about this on some other thread, but I don't have access to redir file to confirm this particular SWCM.
    If You fit and unable to code, post back to this thread and we can give LCode.
  6. Likes kamold, Dana liked this post
    Jun 2014
    Poland
    hmm... with Lowline cluster he can be able only Volue Up / Down I think ...no more
    but hard to say - radio also not exist in that car
    what was the org SWCM number ?
    Jan 2020
    Suffolk, UK
    Everything is the same as stock apart from the radio be bought a genuine polo 6r one, so everything that is on the coding above is stock parts, a part from radio and steering wheel changed but no module
    Jan 2020
    Suffolk, UK
    sooo update, new Squib ring in and everything working accept the Cruise control, it used to be on the stalk for indicators, but with the new steering wheel should be on the MFSW Button,
    I have tried most things, and it seems happy but one code stuck in steering wheel module, any help please
    when i press the cruise button the horn goes off, but the horn still works on the actual horn button its self
    Monday,24,February,2020,18:48:18:14161
    VIN: WV1ZZZ2KZGX061265   License Plate: CADDY MFSW
    Mileage: 123810km-76931mi   Repair Order: 3
    VIN: WV1ZZZ2KZGX061265   Mileage: 123810km-76931miles
       Revision: 8AX20---
       Coding: 0111001204050D090000
       Revision: 00001002
       Coding: 0010004003
       Revision: BD122001
       Coding: 009795
       Coding: 0228DD
       Coding: 0001050001
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 AE    HW: 5K0 953 569 BD
       Revision: FF010018    Serial number: 20161117100700
       Coding: 088A440000
       Shop #: WSC 00046 000 00000
       VCID: 7F0AB4C0E6CA2DB7DC-802A
       Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H03 0102
       Serial number: 29150002128630025435
       Coding: B0FFFF
    0516 - Databus
                        Reset counter: 130
                        Mileage: 123811 km
                        Date: 2020.02.24
                        Time: 18:36:54
       Coding: 480A001200
       Coding: 357421
       Coding: 0131632
       Revision: 00H22000
       Coding: 0131632
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0449
       Serial number: VWZAZ2T5233357
       Coding: 026200013C00000011111101008808001F0107C600200100CF
       Shop #: WSC 00020 999 00000
       ROD: EV_MUStd4CTSAT_SK26.rod
       VCID: 254646A824D65767F6-8070
       Coding: 030F1873
    End-------------------------(Elapsed Time: 02:40)--------------------------
  10. #8
    Tartu, Estonia
    You May wannaa try: 088A440008
  11. Likes Uwe, Dana liked this post
  12. #9
    United States
    I Agree. Looks like we got that bit added to the label per an earlier conversation with Magnus. LCH includes the drop-down in Byte 2 for Hex 40 Cruise Control controlled via Multi-Function-Steering-Wheel (MFSW) and his latest suggestion:
    LC,04,3,Multi-Function-Steering-Wheel (MFSW) for MQB-Platform installed
  13. Likes Uwe liked this post
  14. #10
    Jan 2020
    Suffolk, UK
    Everything is coded as per convo ^ its still doesnt work, the horn still works on the power button for cruise, anymore help please ?
