VW Passat 2014 ABS Coding (MK60EC1)
bin7r21
UAE
C?ID=396618
hi there .. im talking to you my friends from Dubai and im a new user on this site .. all what i need is ABS Codes for My VW Passat because i replace it .. the old one (1k0 907 379 bk) replace it with (1k0 907 379 bl).. here the all details you need :
Thursday,20,February,2020,15:14:30:14601
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
VIN: WVWCR7A37EC000894   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 25 2B 2E 42 46 47 4F 52 56
          62 72 77
VIN: WVWCR7A37EC000894   Mileage: 104330km-64827miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CB    HW: 07K 907 309 B
   Component: 2,5L 125KW      G01 1202
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 70ACF6C7639A1ACF57-8024
001393 - Brake Switch (F)
               P0571 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 104337 km
                    Date: 2014.07.05
                    Time: 16:18:34
                    RPM: 790 /min
                    Load: 33.7 %
                    Speed: 7.0 km/h
                    Temperature: 56.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1020.0 mbar
Readiness: 0010 0001
   Part No SW: 09G 927 750 NH    HW: 09G 927 750 NH
   Component: AQ 250 6F           2244
   Revision: 00H97000    Serial number:
   Coding: 0000328
   VCID: 0444AA174722166F83-8050
   Revision: 00H31001
   Shop #: WSC 00028 028 00001
   VCID: 7DB2DFF3E4C867A7CC-8028
                    Reset counter: 125
                    Mileage: 104338 km
                    Date: 2014.07.05
                    Time: 17:01:54
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 320
                    Count: 48640
                    Count: 10496
                    Count: 8704
                    Reset counter: 125
                    Mileage: 104338 km
                    Date: 2014.07.05
                    Time: 17:01:56
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 195
                    Count: 48640
                    Count: 10496
                    Count: 65280
                    Count: 8704
                    Fault Status: 01100101
                    Reset counter: 125
                    Mileage: 104338 km
                    Date: 2014.07.05
                    Time: 17:01:54
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 279
                    Count: 48640
                    Count: 10496
                    Count: 8704
                    Reset counter: 125
                    Mileage: 104338 km
                    Date: 2014.07.05
                    Time: 17:01:54
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 295
                    Count: 48640
                    Count: 10496
                    Count: 8704
                    Reset counter: 125
                    Mileage: 104338 km
                    Date: 2014.07.05
                    Time: 17:01:54
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 270
                    Count: 48640
                    Count: 10496
                    Count: 8704
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0199297623
   Coding: 030C0C
   VCID: 34243AD79F0266EF73-8060
   Part No SW: 561 907 044 R    HW: 561 907 044 R
   Component: Climatronic   H03 0405
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 2600D09F59DE047FFD-8072
   Part No SW: 5K0 937 086 P    HW: 5K0 937 086 P
   Component: BCM PQ35 M+   021 0068
   Revision: BD021001
   Coding: 68200E3B802908D400080000340081E00371008645A00DF064806000AC70
   VCID: 41CA6303D8B0C347E8-8014
   Component: RLS 050213 05  54  0403
   Coding: 02300A
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 124
                    Mileage: 104337 km
                    Date: 2014.07.05
                    Time: 16:07:16
                    Voltage: 11.95 V
   Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
   Component: AirbagVW10G   014 0851
   Serial number: 003MWM01FAJ
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75A2C7D3D4F83FE784-8020
   Serial number: 6940000Y130000SJJ20$
   Coding: 303046
   Serial number: 3572MSME71266578ZZZZ
   Serial number: 3582MSME7E6F1478ZZZD
   Serial number: 3516KSME46746822ZZZS
   Serial number: 3526KSME632A3F22ZZZX
   Serial number: 3556LSME28703921ZZZQ
   Serial number: 3566LSME724C3921ZZZZ
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 104337 km
                    Date: 2020.02.12
                    Time: 16:06:13
   Part No SW: 1K5 953 501 S    HW: 5K0 953 569 L
   Revision: FF010041    Serial number: 20121125100110
   Coding: 010A140000
   VCID: 3B3611EBB25CA997B2-806E
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 870 B    HW: 561 920 870 B
   Component: KOMBI         H07 0705
   Coding: 631E01
   VCID: 187CEE67E3AAA28F7F-804C
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 02041303290542
   Coding: 461000
   Shop #: WSC 12345 123 61029
   VCID: 76A0C0DFC1FE34FF8D-8022
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R44D406
   VCID: 6386898BA26CB157DA-8036
   Component: IMMO          H07 0705
   Coding: 000007
   VCID: 6A98E4AF8D46E01F19-803E
   Revision: 00000000    Serial number: 13000003861002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 302C36C76B1A5ACF17-8064
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664509691
   Coding: 010100
   VCID: 2A1824AF45C6201FD9-807E
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0006474867
   Coding: 0404FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BF6B16B521C899792-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630130410104818
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 165
                    Mileage: 104337 km
                    Date: 2020.02.12
                    Time: 16:06:15
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0034290
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FAEF5BBBEA405374E-803A
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Serial number: 53388786011232400873
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0006500806
   Coding: 0404FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CF4B27757128EAF9B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130409180554
   Coding: 800000
67074 - Motors for Central Locking
          B122B 01 [009] - Electrical Failure
                    Reset counter: 125
                    Reset counter: 165
                    Mileage: 104337 km
                    Date: 2020.02.12
                    Time: 16:06:18
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  051 0213
   Revision: 00000001    Serial number: VWZ1Z3M8406516
   Coding: 0102004001000B
   VCID: 2306C98B22ECF1579A-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664291009
   Coding: 0A00000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A3814EFBD66909FA9-806E
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
waiting for your respond .. with respect
Moved to Car Repair Support.
bin7r21
UAE
C?ID=396618
Thank you for you'r support
Dana
Western PA, USA
This Passat is similar to the NMS sold in the US market which means they do not use conventional PR-Codes for the brake components. That makes it very difficult to build lost coding from scratch. For that reason, please make sure you don't have the original coding saved in an earlier Auto-Scan. You may find one in either of these locations:
C:\Ross-Tech\VCDS\Logs
C:\Ross-Tech\VCDS\Scans
That is explained in more detail via a link from: https://forums.ross-tech.com/showthread.php?20619-MK60EC1-ABS-FAQ
Do let us know if an earlier scan cannot be located so we can try to build a coding string.
Internal note; one of these AGCC scans may be of assistance: E?ID=210258 or E?ID=325227
That is explained in more detail via a link from: https://forums.ross-tech.com/showthr...K60EC1-ABS-FAQ
What about comparing hardware and software versions to VCDS scans on the net?
OP did you look for them and if you do, post them here in code tags?
Dana
Western PA, USA
We do use baseline scans (I was lucky enough to locate 2 AGCC scans in our system after I replied) but I often need to compare the front pads/rotor, rear pad/rotor, master cylinder and brake booster part numbers. That's somewhat crazy .. all because VW decided the NMS didn't need normal VW PR-Codes?!? :banghead: I don't get excited when a Crafter plays by special rules but this is a Golf-based car!
Vehicle Identification No.WVWCR7A37EC000894
ModelNew Passat
PA
Date of production24.04.2013
Model year2013
Sales typeA324S6
Engine CodeCBTA
Transmission CodePDW
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components7LPVehicle class differentiation -560-
tail pipe0P2Exhaust tailpipe with trim
Hill start assistUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard0GVEmission standard EU2 (critical vapor pressure)
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Aerials8L6"diversity" window antenna
Exterior mirror setting6XXExterior mirrors, power-adjustable (type 2)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8FSports equipment
batteriesJ0NBattery 330 A (61 Ah)
Controls (steering wheel/steering column)4LCControls for radio and telephone
Beverage holders4M9Beverage holders
Component part sets with country-specific design requirementsB0MComponent parts set, complying with vehicle type for AGCC countries, various parts
Brake systems1ATElectronic stability control (ESC)
Owner's manuals7YPInformation kit in Arabic and US-English
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
Chrome packageQJ3Chrome package (version 2)
General operating permit, alterationsC00Operating permit, initial registration
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rear1JARear shock absorption, basic version 1
Suspension system in frontG02Shock absorption in front
Load-through hatch/ski bag3X2Load-through hatch
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0ERInstallation differentiation for transmission AQ250 -- vehicle components --
Theft protection system7AAElectronic immobilizer
Inserts5MQDecorative inserts
Electric interface for external use UF8Electric interface for external use
fire extinguisher6A6Fire extinguisher, front passenger seat
Headlight activation8K9Separate daytime running light with automatic headlight control and Coming Home feature
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G7tiptronic
Weight category rear axle0YBWeight range 2 installation control only, no requirement forecast
Weight category front axleL01Suspension range 01 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Garage door openerVC2Garage door opener
Transmission specificationsG1A6-speed automatic transmission
glove box4Z3Lockable glove compartment door, with light
handle for hand brake lever6PCHand brake lever handle in leather
Rear spoiler5J0Without rear spoiler
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8IDHalogen twin headlamps
Customized installationFC0Without customized installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5FInstrument cluster, km/h speedometer - AGCC -
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body styleK8BNotchback
Climatic zones0Y2Tropical zones
Compass/road sign displayQR1With compass
Fuel tank treatment2LCFuel tank with special material treatment (coextrusion)
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Camera systems/accident sensorsKA1With rear view camera system (type 1)
Radiator grille6KJRadiator grille with chrome molding
Front license plate carrier6W8Front license plate carrier (AGCC countries)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Steering system arrangementL0LLeft-hand drive
Reading lamp8S72 reading lights in front
steering1N1Power steering
Backrest release3H0Without backrest release for front seats
Lumbar support8I5Power-adjustable lumbar support in front seat backrest, 2-way function
steering wheels2PPLeather-wrapped multi-function steering wheel
Driving on the left/on the rightAV1Driving on the right
Speaker installation8RUSound system with subwoofer "branded"
Center armrest in rear6D2Center armrest in rear with storage compartment
Center armrest6E2Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z9Super hot country
Engine specificationsD775-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7Q0without navigation system
Front fog lamp/additional headlamp8WHFront fog lamp and cornering lamp
Hubcaps1NLTrims for alloy wheels
WheelsC2MAlloy wheels 7J x 17
Radios8DDRadio "RCD510 World Variant"
Smoker's/non-smoker's package9JDSmoker's package, ashtray in front
Tire pressure monitoring system7K9Tire pressure monitoring system
tireHI2Tires 215/55 R17 94V
Tire suppliersV0ATires without specification of tire brand
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
W73"PL2"
W89Technical mandatory conditions for AGCC
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SWLabels in Arabic
Tail lamp assemblies8SJRear combination lamp, standard design (NAR)
Service indicatorQI4Service indicator 15 000 km or 1 year ( fix )
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
seat coversN2QSeat trim covers in leatherette
Seat adjustment3PBPower seat on the left, right seat with manual height adjustment
seat heater4A3seat heating for front seats separat controlable
Control number (no PR family)S0BSales model year does not match production model year
Protective side molding4B4Protective side molding
Bumper2JLComfort bumpers
Rear stabilizer bar0BBRear stabilizer bar
starter7U0Standard engine starter
Front stabilizer bar0ABFront stabilizer bar
Windshield wiper intermittent control/ light/rain sensor8N6Windshield wiper intermittent control with light/rain sensor
Nameplate set0NBNameplate set in basic style
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and lid locking system4I3Central locking system Keyless Entry without SAFELOCK
Type approval countries/countries with special requirementsB88Type approval country Abu Dhabi
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Door and side trim panels3LMdoor and side trim panels
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Assembly parts for engine (drive bearing)1VBInstallation parts for five-cylinder engine
Identification plates1EBwithout identification plate
Telephone / telematics9ZRPreparation for telephone without 3-button module
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
floor mats0TDFront and rear floor mats
Decorative trims4ZGChrome-plated decorative trims
Auxiliary heating system9M0Without auxiliary heater/parking heater
PART NUMBERJPPSG FOD!DESCRIPTIONLEGACYMODEL
1K0 907 375 BK
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Control unit for ABS
1K0 907 379 BK
1K0 614 517 EA
1K0 614 517 DN
PR-UG0
OP Did you know Module you have is for UG1 you need UG0?
Revision: 00H31001
bin7r21
UAE
C?ID=396618
I did the scan but unfortunately its showed me that the vehicle had no ABS on it
bin7r21
UAE
C?ID=396618
Revision: 00H31001
your absolutely %100 correct the old one is (1K0 907 379 BK) your really a big help to me & I manged some how to find out the coding by my self and its
C54BC0F5892208FAA31303ED911D10612110F019
only thing are reaming is to find UG0 & install it.
Dana
Western PA, USA
I came up with the following per the mentioned AGCC baseline scans with your original module part number 1K0 907 379 BK :
C54BC0F5892208FAA31303ED911D1061261000
That's very similar to the coding you came up with and included in post #12:
Since your coding is longer than the current module supports I would suggest using the string I posted to see if it is accepted followed by fine tuning it with the long coding helper (if needed).
Dana
Western PA, USA
Hi Jack,
In regards to posts 7 and 9 we may want to move this to a new thread specific to A32/A33 chassis MK60EC1 coding charts/PR-Codes but I'm sure you noticed they do not use standard VW/Audi PR-codes for the installed brakes. Luckily they still use 1AT (versus 1AS) but all conventional codes such as 1ZD/1KE, 1LJ/1KD, 1ZF/1KD, 1ZE/1KD, 1ZA/1KD, 1ZB/1KY .. etc are missing entirely.
Because there are a handful of master cylinder and booster combinations with VIN splits for the various pad/rotors and caliper combinations I tread very lightly if we can't match up the brake component part numbers.
I do believe you are correct in regards to 312x25 fronts discs -and- 272x10 solid rear disc observation.
Hi Jack,
Hello Dana,
Indeed, however, isn't that why we check part numbers and measure the size of the components mechanicals to verify the data we need plus compare scan's?
:rolleyes:
bin7r21
UAE
C?ID=396618
I tried it & it's accepted, but showing the same issue it seem that I must replace it with UG0.
bin7r21
UAE
C?ID=396618
HI,
Hopefully everyone are okay, I took a long time searching in scrap yards to find ABS part # 1K0 907 379 BK and every time when I found one and after I fix it on the car it showed to me there are no ABS so finally I found this 1K0 907 379 BM which worked for me but the only remaining thing is that the long coding so can some one help with that please.
Thank you
Monday,18,May,2020,22:51:02:14601
VCDS Version: 20.4.1.0  HEX-NET CB: 0.4508.4
                Address 01: Engine  (07K 906 055 CB)
22:50:58
  0.0 km/h   Vehicle Speed
  0.0 km/h   Vehicle Speed (current)
  0.0 km/h   Vehicle Speed (specified)
  0.0 km/h   Median Vehicle Speed
Monday,18,May,2020,23:01:20:14601
          62 72 77
VIN: WVWCR7A37EC000894   Mileage: 104390km-64864miles
   Coding: 0000075
   VCID: 70ACF6C7639A1A06FB-8024
               U1017 - 000 -
                    Mileage: 104393 km
                    Date: 2014.10.09
                    Time: 22:55:31
                    RPM: 779 /min
                    Load: 26.7 %
                    Temperature: 87.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1000.0 mbar
Readiness: 1110 0001
   Coding: 0000328
   VCID: 0444AA17472216A62F-8050
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F5492200FAA31303ED921D006124101112
   VCID: 7EB0D8FFE9CE7C7679-802A
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 136
                    Mileage: 104393 km
                    Date: 2014.10.09
                    Time: 22:56:05
                    Count: 3
                    Count: 14
                    Count: 8704
                    Count: 71
                    Count: 49408
                    Count: 254
03839 - RPM Sensor Front Left: Incorrect Signal
                    Reset counter: 136
                    Mileage: 104393 km
                    Date: 2014.10.09
                    Time: 22:56:05
                    Count: 3
                    Count: 14
                    Count: 8704
                    Count: 39
                    Count: 49408
                    Count: 254
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 136
                    Mileage: 104393 km
                    Date: 2014.10.09
                    Time: 22:59:46
                    Count: 3
                    Count: 14
                    Count: 8192
                    Count: 128
                    Count: 45568
                    Count: 254
                    Count: 7168
                    Reset counter: 136
                    Mileage: 104393 km
                    Date: 2014.10.09
                    Time: 22:56:12
                    Count: 3
                    Count: 14
                    Count: 8704
                    Count: 8226
                    Count: 49664
                    Count: 254
   Coding: 030C0C
   VCID: 34243AD79F026626DF-8060
   Revision: 00001K01
   Coding: 0010001002
   VCID: 2600D09F59DE04B651-8072
   Revision: BD021001
   VCID: 41CA6303D8B0C38E44-8014
   Coding: 02300A
                    Reset counter: 136
                    Mileage: 104393 km
                    Date: 2014.10.09
                    Time: 22:59:46
                    Voltage: 12.85 V
   Coding: 00005033
   VCID: 75A2C7D3D4F83F2E28-8020
   Coding: 303046
                    Mileage: 104393 km
                    Date: 2020.05.18
                    Time: 22:56:09
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 136
                    Mileage: 104393 km
                    Date: 2020.05.18
                    Time: 22:56:22
   Coding: 010A140000
   VCID: 3B3611EBB25CA95E1E-806E
   Coding: E20000
   Coding: 631E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 187CEE67E3AAA246D3-804C
   Coding: 461000
   VCID: 76A0C0DFC1FE343621-8022
   VCID: 6386898BA26CB19E76-8036
   Coding: 000007
   VCID: 6A98E4AF8D46E0D6B5-803E
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 302C36C76B1A5A06BB-8064
   Coding: 010100
   VCID: 2A1824AF45C620D675-807E
   Coding: 0404FD
   VCID: 5BF6B16B521C895E3E-800E
   Slave Driver:
   Coding: 800000
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   Coding: 01030108
   VCID: 6FAEF5BBBEA405FEE2-803A
   Coding: 181100
   Coding: 0404FC
   VCID: 5CF4B27757128E6637-8008
   Slave Passenger:
   Coding: 800000
   VCID: 2306C98B22ECF19E36-8076
   VCID: 3A3814EFBD66905605-806E
End----------(Elapsed Time: 01:21, VBatt start/end: 13.7V/13.6V)-----------
bin7r21
UAE
C?ID=396618
No I'm not but as I wrote earlier this is the only thing that worked on the car after I used a dozen of them :banghead:
