Results 11 to 20 of 26
Thread: 03 Avant bulb out messages
    Feb 2020
    Oregon, USA
    I un-deleted post #8 for your. The following two appear to be duplicates. I have no idea what you are doing that's causing them to get deleted. What kind of device are you using to post here?
    Thanks man. I'm on mobile using Firefox Mobile.
  2. #12
    Feb 2020
    Oregon, USA
    Round 2 after a trip into town and 2 light out warning. For some reason it cuts off the front running light filament. All the warning go away once the lights have been turned off and back on. All lights light normally until the blinker is used. This is a different reaction to the old module which turned off the rear parking lamp.
    Could not find anything in the Wiki for the 00985 code. I dont believe the 01498 is a bulb or fuse issue as the light works fine. Everything works fine until the right blinker is used with the lights on. Currently the wiring in the headlight is not modified. That is not the side with the damaged headlight clip.
    Saturday,22,February,2020,10:09:54:31460
    VIN: <SNIP>   License Plate:
    Mileage: 238200km-148010mi   Repair Order:
              67 69 75 76 77
    VIN: <SNIP>  Mileage: 238200km-148010miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 E    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0003
       Coding: 0016711
       Shop #: WSC 63351 000 00000
       VCID: 372B2BF2E35A2AFF38F-5160
    Readiness: 0000 1001
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      4529
       Coding: 04495
       Shop #: WSC 26097
       VCID: 2615F6B631F0A377939-51CE
       Part No: 8E0 820 043 L
       Component:   A4 Klimaautomat   1116
       Coding: 00000
       Shop #: WSC 63351
       VCID: 2A0D028625E88717B71-5160
       Part No: 8E0 907 279 E
       Component: int. Lastmodul  RDW 0305
       Coding: 00011
       VCID: 34311CFEF72CC1E71DD-4B1E
    01498 - Bulb for Parking Lamps; Right (M3)
                57-00 - Electric Circuit Failure
    00985 - Right Tail Light (M2)
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 C
       Component: Airbag 8.4EP        2000
       Coding: 0010607
       VCID: 372B2BF2E35A2AFF38F-5184
       Part No: 8E0 953 549 L
       Component: Lenksáulenmodul     0308
       Coding: 02042
       Shop #: WSC 63351
       VCID: 3C2134DEDF7C09A7D5D-4B1E
       Part No: 8E0 920 950 PX
       Component: KOMBI+WEGFAHRS. RB4 D42
       Coding: 03200
       Shop #: WSC 56747
       VCID: 0E45AE16B940CB374B9-5184
       WAUVT68E03A203983     AUZ6Z0B0268300
    01311 - Information Data Bus
                80-00 - Single-Wire Operation
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0203
       Coding: 00002
       Shop #: WSC 63351
       VCID: 71BFD5EAC88EB4CF36B-4B3C
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0604
       Coding: 00001
       VCID: 6B83C782EA925E1F0C7-513C
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1311
       Coding: 12138
       Shop #: WSC 63351
       VCID: 72BDDAE6CDB88FD7CF1-4B1E
       Subsystem 1 - Part No: 8E1959801
       Component: Tőrsteuer.FS BRM 0002
       Subsystem 2 - Part No: 8E1959802E
       Component: Tőrsteuer.BF BRM 0002
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0002
    01561 - Rear left door
                59-00 - Can't Unlock
       Part No: 4Z7 907 357
       Component: dynamische LWR       D08
       Coding: 00060
       Shop #: WSC 63351
       VCID: 04518C3EE73CB167EDD-4B5C
    End----(Elapsed Time: 05:18, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    2003 A4 3.0 6MT Avant
    1986.5 Nissan Hardbody SE-V6 4x4 VG33 swapped
  3. #13
    Have you checked the condition of the ground(s) for the right tail light assembly?
    And the condition of the bulb sockets themselves?
  4. #14
    Feb 2020
    Oregon, USA
    Rear bulb holder is brand new and was replaced with the original again last night with no change in symptoms. Didn't like the weather seal on the new one. Wouldn't stay in the track.
    The rear ground must be fine because if I add a ground it throws codes. Gets very unhappy if I pull a new ground.
  5. #15
    Feb 2020
    Oregon, USA
    The last 2 scans were with the old holder, not the new one.
  6. #16
    Feb 2020
    Oregon, USA
    Sorry for the crazy multi post. I don't trust my abilities to hit the edit button on mobile.
    I did notice it turned off the right front parking filament when I was pulling the log.
    The rear fog still doesn't illuminate but no faults. 11.55v (subs pulling and engine not running) at the socket. Message on dash thrown when the bulb is removed. New bulb, same result. This is the left side though.
    Bulb also doesn't illuminate when using TEST in VCDS.
    Edit (not on mobile!): I found a setting I missed in Adaptation. The intensity. It was set to 24% for sedan which is why it appeared that the bulb did not go out. Changed that back to 0 and we are back at square 1 everything is exactly the same as the original module. Taillight blinks over so many blinker cycles.
  7. #17
    Feb 2020
    Oregon, USA
    Found 2 burnt contacts on the right front parking light. Replaced the bulb and bulb holder with spares. Got a right parking light message. Right front parking light is out.
    Also noticed that the parking filament in the right front bulb is lighting opposite to the blinker. It dims when the blinker goes bright and goes bright when the blinker dims.
    Rear bulb still goes on and off at it's 7 blink interval.
  8. #18
    Quote Originally Posted by Deerhurst View Post
    That's a sure sign of demonic possession!
    Seriously now, I cannot imagine why overlaying an extra ground wire would make it unhappy. That makes no sense to me at all.
  9. #19
    Feb 2020
    Oregon, USA
    Dude! I'm not ruling out possession at this time! Hahaha!
    Found a possible rubbed wire in the headlight between the two hot leads to the yellow bulb up there. Patched it to test and it did the same thing.
    Update, decided to pull the power off the battery. left it for 5-10 minutes, and came back with VCDS and cleared the low power faults. Gotta drive it to clear the ABS steering angle low power fault. Gotta do that anyways tonight. Havnt checked for the bulb shenanigans.
    I'm afraid to check for an issue because it'll just be back!
    When would you say it's time to take it to someone else?
    I'd rather not spend an arm and a leg on it but it's driving me insane!
  10. #20
    Jul 2015
    Canada
    I don't meant to derail anybodies thought process but for the sake of other people reading this thread.....
    I had a curt trailer wiring controller wired to my Audi A3 MY2008. It worked great at first, but within a year or so I had a never ending stream of bulb out messages, or actual blown bulbs in the car. I chalked it up to an Audi being an Audi. (Electrical gremlins galore) . I had no suspicion of the trailer wiring module as it seemed to work trouble free for a considerable amount of time. Then our vehicle circumstances changed at home and Audi became wifes daily driver, and I started removing the mods on the car. The curt trailer wiring module went along with a couple other things. My bulb errors have decrease 90%. I still blow a taillight bulb every once in a while, but at more 'normal' frequency as compared to other vehicles I've owned. In my opinion.
  11. Likes Uwe liked this post
