Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 03 Avant bulb out messages
    Feb 2020
    Oregon, USA
    No fault codes outside it being unhappy with the S2 cats.
    When the lights are on and the right blinker is active the right rear tail brake filament turns on and off about every 7 blinks at a reduced intensity. After the the blinker is cancelled a bulb out message is thrown.
    The bulb holder is new, bulbs are new, CECM has been replaced with "working condition" used module which acts similarly as the old unit. Cannot find an issue in the wiring by basic diagnostics.
    Car does have a Curt trailer light controller that has not caused issues in the past.
    Even though there are no fault codes we'll still need to see a full unedited VCDS Auto-Scan
  3. Likes Jack@European_Parts, Uwe, nazdaq100 liked this post
    Feb 2020
    Oregon, USA
    I'll see what I can do later this evening.
    What would the scan tell you that error messages won't?
    Full system wide scan or just a scan of that module?
    Quote Originally Posted by Deerhurst View Post
    Everything; the whole car please. Even in 2003, cars were already a computer network on wheels.
    Mar 2019
    London, United Kingdom
    As mentioned above by petroldave if you can please post a full auto scan. Once you carry out a full auto scan
    You can walk your way to Local C/primary drive > RossTech > scans> open the file. Copy all the information CTRL + A> CTRL + C = clicking a # above in this typo CTRL + V from a full auto scan we can learn and tell you more about the car. Also advise you an appropriate ideal solution for your vehicle. Alternatively please click on the link below on how to post an Auto Scan
    https://youtu.be/AK1lK5DRNcg
    Feb 2020
    Oregon, USA
    These things really are an awesome super computer on wheels. Im not a noobie on computer stuff, just VCDS. Managed to bumble my way though adaptation and coding of the Central Electronics module that I changed out. Trailer light controller was removed tonight. Its a car. If I need to tow Im using a body on frame vehicle like the one parked next to it which is 34 years old a not a computer on wheels. It hardly knows how to pulse an injector.
    The controller was tied into a Green/Black wire that is missing on my chiltons wiring diagrams. It was rather crudely spliced in. Its been cleaned up, soldered and shrink wrapped. What is that wire on the right rear tail light assembly?
    I do have an aftermarket head unit that sits on CANBUS and sends info to the dash. I do have an aftermarket amp and subs that have completely replaced the OEM amp/sub box. Otherwise the car should be stock.
    I couldnt find info on a 01311 code. Its a new one I havnt seen before. The S2 O2 "codes" have gone away (battery recently disconnected for the CECM swap) as has my sticky rear door lock code, for now. No CEL for the cats.
    Not comfortable with having my VIN floating around. If anyone from Ross-Tech needs licensing confirmation, please ask and Ill PM.
    Current VCDS log: Please excuse formatting.
    Friday,21,February,2020,19:23:39:31460
    VIN: <SNIP>   License Plate:
    Mileage: 238180km-147998mi   Repair Order:
              67 69 75 76 77
    VIN: <SNIP>   Mileage: 238180km-147998miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 E    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0003
       Coding: 0016711
       Shop #: WSC 63351 000 00000
       VCID: 372B2BF2E35A2AFF38F-5160
    Readiness: 0110 1101
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      4529
       Coding: 04495
       Shop #: WSC 26097
       VCID: 2615F6B631F0A377939-51CE
       Part No: 8E0 820 043 L
       Component:   A4 Klimaautomat   1116
       Coding: 00000
       Shop #: WSC 63351
       VCID: 2A0D028625E88717B71-5160
       Part No: 8E0 907 279 E
       Component: int. Lastmodul  RDW 0305
       Coding: 00011
       VCID: 34311CFEF72CC1E71DD-4B1E
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 C
       Component: Airbag 8.4EP        2000
       Coding: 0010607
       VCID: 372B2BF2E35A2AFF38F-5184
       Part No: 8E0 953 549 L
       Component: Lenksáulenmodul     0308
       Coding: 02042
       Shop #: WSC 63351
       VCID: 3C2134DEDF7C09A7D5D-4B1E
       Part No: 8E0 920 950 PX
       Component: KOMBI+WEGFAHRS. RB4 D42
       Coding: 03200
       Shop #: WSC 56747
       VCID: 0E45AE16B940CB374B9-5184
       WAUVT68E03A203983     AUZ6Z0B0268300
    01311 - Information Data Bus
                80-00 - Single-Wire Operation
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0203
       Coding: 00002
       Shop #: WSC 63351
       VCID: 71BFD5EAC88EB4CF36B-4B3C
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0604
       Coding: 00001
       VCID: 6B83C782EA925E1F0C7-513C
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1311
       Coding: 12138
       Shop #: WSC 63351
       VCID: 72BDDAE6CDB88FD7CF1-4B1E
       Subsystem 1 - Part No: 8E1959801
       Component: Tőrsteuer.FS BRM 0002
       Subsystem 2 - Part No: 8E1959802E
       Component: Tőrsteuer.BF BRM 0002
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0002
       Part No: 4Z7 907 357
       Component: dynamische LWR       D08
       Coding: 00060
       Shop #: WSC 63351
       VCID: 04518C3EE73CB167EDD-4B5C
    End----(Elapsed Time: 05:16, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  8. Likes Uwe liked this post
    One of the CAN buses connected to the instrument cluster is in backup mode, where data can only flow through a single wire rather that the differential signal on a twisted pair. I think it's the one that connects to the radio, but I'm not 100% certain of that. Anyway, it may be an artifact of the aftermarket HU.
    Nah, we know it's legit. In some cases the VIN is needed to build a coding or look stuff up, but that's not the case here.
    As for the bulb out message, I'm stumped. I'd expect to see something in the scan about that.
  10. #8
    Feb 2020
    Oregon, USA
    I'm thinking head unit is the cause of that too. It havnt popped up till now and I've had the head unit in there for a while. I bet a cold boot could fix that.
    I'm super stumped and getting pretty annoyed at the bulb out. As soon as the lights are cycled the message goes away. I do have a rear fog out which doesn't throw a code until I physically remove the bulb. Probably lost the vacuum on the bulb.
    Here is a YouTube of what the bulb does. It's subtile but it turns on and off the brake filament at a reduced intensity. Super unprofessional video but it was originally made for a buddy to see what it is doing.
    https://youtu.be/uphfuKQeLqQ
  11. #9
    Feb 2020
    Oregon, USA
    So, attempt #4 to post. Every time I try to edit a post it gets deleted. I select the text area and the page reloads and deleted my post. Each post is getting shorter and shorter due to level of aggravation of having to do it all over again.
    Quick unprofessional clip of what the bulb does while the blinker is on. It's subtle. Gotta run into town tomorrow so I'll try to get a VCDS log with an active bulb out on the dash.
  12. #10
    I un-deleted post #8 for your. The following two appear to be duplicates. I have no idea what you are doing that's causing them to get deleted. What kind of device are you using to post here?
