Saturday,20,April,2019,15:43:41:56713
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: TMBBG7NE6E0026157 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE6E0026157 Mileage: 145861km-90633miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012030501090000
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F3AE606479094EF377-807A
8 Faults Found:
5227 - Fuel Rail/System Pressure
P0087 00 [032] - Too Low
5231 - Fuel Rail/System Pressure
4635 - Engine Oil Temp. Sensor (G8)
P0196 00 [036] - Implausible Signal
Mileage: 145861 km
Date: 2019.04.20
Time: 15:32:48
Coolant temperature: 15 °C
Intake air temperature: 17 °C
Voltage terminal 30: 13.440 V
Fuel consumption: 0.00 l/h
Engine oil temperature: 27.4 °C
Oil warning threshold: 0.000 mm
Status of oil pressure switches-Bits 0-7: 0
Oil fill level: 120.000 mm
Extern.temp.sens.1 bank 1: raw value: 16.0 °C
Fuel temp. sensor 1 bank 1: raw value: 17.7 °C
4640 - Engine Oil Temp. Sensor (G8)
P0197 00 [036] - Signal too Low
Mileage: 145861 km
Date: 2019.04.20
Time: 15:32:53
Coolant temperature: 16 °C
Engine oil temperature: 27.6 °C
10382 - Thermostat for Cylinder Head
P199E 00 [039] - Open Circuit
Mileage: 145861 km
Date: 2019.04.20
Time: 15:32:45
Voltage terminal 30: 13.180 V
Heater support pump 1 bank 1 second.circuit: activat.: 10.00 %
Shut-off timer: last engine shut-off time: 16726 s
U0428 00 [040] - -
Mileage: 144144 km
Date: 2019.04.11
Time: 11:29:34
Engine speed: 1091.00 /min
Normed load value: 15.7 %
Coolant temperature: 11 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.680 V
Unlearning counter according OBD: 29
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Fault Frequency: 9
Mileage: 127394 km
Date: 2019.01.05
Time: 16:31:07
Engine speed: 1275.00 /min
Normed load value: 100.0 %
Vehicle speed: 20 km/h
Coolant temperature: 92 °C
Intake air temperature: 77 °C
Voltage terminal 30: 14.460 V
Unlearning counter according OBD: 8
Limitation: accelerator pedal: 240.7 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
selected gear-Bits 0-7: 2
20359 - Internal Control Module
P0606 00 [109] - Processor Fault
Mileage: 124926 km
Date: 2018.12.20
Time: 22:42:35
Intake air temperature: 76 °C
Voltage terminal 30: 10.000 V
Accelerator pedal travel: raw value: 0.00 %
Starter control: Interlock- or P/N-signal-Bits 0-7: 65
Engine status: COENG_READY
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 616430000002C8
Coding: 1A078A91242209720078060541CA245851249000608224F000430070C002
VCID: 4BC29296D348C8CF3BF-801E
0294 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 36
Mileage: 144144 km
Date: 2019.04.11
Time: 11:29:34
0297 - Steering angle sensor
Reset counter: 141
Date: 2018.12.16
Time: 17:08:07
Reset counter: 37
Mileage: 144144 km
Date: 2019.04.11
Time: 11:29:52
Part No SW: 5E0 907 044 HW: 5E0 907 044
Component: Climatronic H02 0604
Revision: 00001K06
Coding: 01110104000100011005000000100000
ROD: EV_ACClimaBHBVW37X_002_SK37.rod
VCID: 629C5F3244C26987E89-8036
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011316401734
Coding: 0F000842424700DB07A04082B10407280000000000000000000000000000
Shop #: WSC 73430 790 00063
ROD: EV_BCMBOSCH_011.rod
VCID: 48C8AD9AC23E23D716D-801C
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 130612 041 0570
Serial number: 130614132916
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY13114297F
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000057118745
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20411109
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [008] - Open or Short to Plus
Reset counter: 37
Mileage: 143765 km
Date: 2019.04.09
Time: 20:08:13
12307 - License Plate Light
B12CA 01 [008] - Electrical Failure
Fault Frequency: 58
Reset counter: 41
Mileage: 123935 km
Date: 2018.12.17
Time: 15:42:32
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Fault Frequency: 154
Reset counter: 48
Time: 00:00:00
545300 - Databus
[Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
Reset counter: 37
Mileage: 144144 km
Date: 2019.04.11
Time: 11:29:34
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831316901243
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3828DD5AB2DE535766D-806C
13637426 - Databus
Reset counter: 37
Mileage: 144144 km
Date: 2019.04.11
Time: 11:29:34
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PBXDEKJ
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5AF646D770A46FE77-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 606 13
Serial number: 3576U000000D53092D0A
Subsystem 2 - Part No SW: ----------- HW: 454 000 606 13
Serial number: 3586U0000009D4C8EC0
Subsystem 3 - Part No SW: ----------- HW: 454 800 506 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RA21B7C010000000
Subsystem 4 - Part No SW: ----------- HW: 454 800 506 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RAAF17A01000000B
Subsystem 5 - Part No SW: ----------- HW: 454 802 403 13
Component: FrontSensor_D 114 0149
Serial number: 3556V5F225300000000$
Part No SW: 5Q0 953 507 AB HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 20061304401359
Coding: 0600
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 76B41362F84AE527B41-8022
Part No SW: 5E0 920 961 D HW: 5E0 920 961 D
Component: KOMBI 233 2210
Coding: 27A402002180A60001082A00000000
VCID: 290E081E7974FADFE93-807C
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 D
Component: GW MQB Low 123 1144
Revision: -------- Serial number: 0000673783
Coding: 030000040B087300EF000248080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 392ED85E89D44A5F993-806C
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 1405400703
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000066303029
Coding: 001000208001020000001100
VCID: 55F674EE058C8E3F9DB-8000
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000284656
Coding: 1D0200
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D26CC4E9DFC767FB5B-8068
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000066310638
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000289351
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 842 A HW: 5E0 035 842 A
Component: MU-S-D-ER 040 0421
Serial number: S7E02406130917
Coding: 03730100FF0000001111120100A800002F0000860100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 211E103E0144329FB13-8074
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9NK6001DZ
End----------(Elapsed Time: 01:11, VBatt start/end: 14.2V/14.2V)-----------
