Results 1 to 3 of 3
Thread: 2019 VW Virtus - EPS Crash Fault
    Sep 2015
    Uruguay
    Hello
    I am working on a 2019 VW Virtus 1.6L which has been crashed and repaired. Electronic power steering is not working and a DTC is stored in the Module. From other similar VW models i was able to clear the adaptations and delete the Crash event from the module.
    In this car I managed to get the code for Security Access but the Crash does not clear.
    Here is a AutoScan of the car. Will be possible to clear this DTC?
    Wednesday,19,February,2020,17:52:41:09698
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: STM
    VIN: 9BWDL5BZ7KP511898   License Plate: AAA1234
    Mileage: 22278km-13842mi   Repair Order:
    Chassis Type: BZ-VW27 (2Q0)
    Scan: 01 03 05 08 09 10 15 17 19 44 5F
    VIN: 9BWDL5BZ7KP511898   Mileage: 22278km-13842miles
    Address 01: Engine (0001-CWSA)       Labels:. 04E-907-431-V1.clb
       Part No SW: 04E 906 032 AQ    HW: 04E 907 425 F
       Component: R4 1.6l MPIH04 5247
       Revision: --H04---
       Coding: 01110016022400001000
       Shop #: WSC 16975 004 1048576
       ASAM Dataset: EV_ECM16MPI02104E906032AQ 002003
       ROD: EV_ECM16MPI02104E906032AQ_002.rod
       VCID: 6FAE1BD4B6B8EE374C-803A
    17178 - Implausible Data Received from ESP Control Module
              U0416 00 [047] - -
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 02:05:34
                        Coolant temperature: 44 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 12.031 V
                        Engine status-Engine: operating status: ES
                        Time since engine start: 0 s
                        ECM system status-ECU_STATE: ENG_STOP
    21312 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [047] - -
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:30
                        Coolant temperature: 50 °C
                        Intake air temperature: 43 °C
                        Voltage terminal 30: 12.089 V
    16803 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [047] - -
                        Fault Frequency: 9
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:32
                        Coolant temperature at engine start: 51.00 °C
                        Coolant temperature model value-TCO_SUB: 53.78 °C
                        Outside air temperature: 215 °C
    16802 - Implausible Data Received from Body Control Module (Central Electric)
              U0422 00 [047] - -
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:30
       Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
       Component: ESC_base      H13 0222
       Serial number: 86400183180404
       Coding: 39048B671B429CAED104D81F14E2626A4994A926224A242444542254452846569229956444522424222A442AA22924400494240220
       Shop #: WSC 01530 935 00200
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: 3E30F690A15257BF97-806A
    0716 - Databus
              [Scl_KBI_Aussen_Temp_gef_Error]
                        Fault Frequency: 13
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:41
    0717 - Databus
              U1122 00 [009] - Implausible Message
              [Scl_KBI_Aussen_Temp_gef_Invalid]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:41
    1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
              [Scl_LWI_Lenkradwinkel_Error]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:36
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0474630357
       Coding: 132C0C0623
       ROD: EV_KessyHellaMQBAB_VW27.rod
              U1400 00 [008] - -
                        Reset counter: 101
                        Mileage: 22279 km
                        Date: 2019.08.03
                        Time: 03:11:58
                        ZAT_pressed: OFF
                        Park selector lever position: Not engaged and not locked
                        Enabling Steering Column Lock: Condition met
                        Control Module Voltage: 8.783 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 102.0 /min
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: Open
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
       Part No SW: 2G0 907 057 E    HW: 2G0 907 057 E
       Component: Climatronic   H04 0501
       Coding: 1120000008000000100004000040010D0000000000000000000000000000
       ASAM Dataset: EV_ACClimaBHBMQBA0 004017
       ROD: EV_ACClimaBHBMQBA0_VW27.rod
       VCID: 2A18CAC04DDACB1FDB-807E
    459527 - Databus
              [Klima_Sensor_02 - empfangener Fehlerwert]
                        Fault Frequency: 16
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:41
       Part No SW: 2Q0 937 089     HW: 2Q0 937 089
       Component: BCM A0 Std    H97 0916
       Serial number: 70118104017201
       ASAM Dataset: EV_BCMA0 204001
       ROD: EV_BCMA0_204.rod
       VCID: 77BE23B4CEE8A6F794-8022
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  050 0105
       Serial number: S7Y18M04D13H14M57S09
       Coding: 0038DD
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
       Component: FHSG_DRV  001 0001
       Serial number: 00000000000020376199
       Coding: 138000
       Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000020613037
       Coding: 098000
       Serial number: 000000000ZY180080CBV
       Subsystem 5 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000020221164
       Coding: 030000
       Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000019851655
       Coding: 1B0000
    5130 - Bulb for Front Left Turn Signal
              B11E8 15 [009] - Open or Short to Plus
                        Reset counter: 61
                        Mileage: 22279 km
                        Date: 2019.08.03
                        Time: 03:14:13
                        Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                        Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                        Zusaetzliche Umgebungsdaten-Low beam: not activated
                        Zusaetzliche Umgebungsdaten-OFF: not activated
                        Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                        Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                        Zusaetzliche Umgebungsdaten-Parking light: not activated
                        Zusaetzliche Umgebungsdaten-Parking light left: not activated
                        Zusaetzliche Umgebungsdaten-Parking light right: not activated
                        Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                        Zusaetzliche Umgebungsdaten-last wakeup: 45
                        Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                        Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                        Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
    137217 - Outside temperature sensor
              B103F 1B [009] - Resistance Too High
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:45
                        Zusaetzliche Umgebungsdaten-last wakeup: 33
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
    590853 - Window Regulator; Front Drivers Side
              B14D1 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:00:00
                        Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.6 V
    592133 - Window Regulator; Front Passenger Side
              B14D2 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:00:00
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 55401813936550
       Coding: 0011051001
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 44C48478CFBE3D6FC1-8010
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [008] - Open Circuit
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:30:04
    13637426 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:30:03
    13637888 - Databus
              [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:30:03
    13679372 - Databus
              [Steuergerät für Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:30:03
       Part No SW: 2QB 959 655     HW: 2QB 959 655
       Component: VW22Airbag    010 0246
       Revision: --------
       Coding: 88C0C00000000000540000CF000000000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 0C546C58A76EB52FC9-8058
       Subsystem 1 - Part No SW: -----------    HW: 442 1A1 804 18
       Component: SideSensor_Df  2C4 0148
       Serial number: 349B4D1B52A17B54630O
       Subsystem 2 - Part No SW: -----------    HW: 442 1A1 704 18
       Component: SideSensor_Pf  2C4 0148
       Serial number: 350B4D2A12AAB9F441D%
       Subsystem 3 - Part No SW: -----------    HW: 442 132 502 18
       Component: FrontSensor_D  290 118A
       Serial number: 355AG119D27F0842369X
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:50
    1054981 - Databus
              [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:50
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 6EA 920 740 A    HW: 6EA 920 740 A
       Component: KOMBI         309 0460
       Coding: 04240A002000000C020822001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001020
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 3326D7A49A108AD768-8066
    13639936 - Databus
              [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.02
                        Time: 01:29:55
       Part No SW: 2Q0 909 901     HW: 2Q0 937 089
       Component: GW MQB A0     H97 0916
       Coding: 0101000020086400D80002080A0F00000001070000000000000000000000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_GatewA0 013020
       ROD: EV_GatewA0_VW27.rod
       Subsystem 2 - Part No SW: 56D 959 442     HW: 56D 959 442
       Component: E221__MFL-834  H01 0130
       Serial number: 000000000C0010110418
       Coding: 200000
    131602 - Power Steering Control Module
              U101D 00 [008] - No Communication
              [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                        Reset counter: 101
                        Mileage: 22279 km
                        Date: 2019.08.03
                        Time: 02:17:20
                        Terminal 15: OFF
    197169 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
              [MFL (LIN#2) Timeout]
                        Reset counter: 101
                        Mileage: 22279 km
                        Date: 2019.08.03
                        Time: 01:56:24
                        Terminal 15: OFF
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 610 6030
       Serial number: 02I2S06SCB4J138
       Coding: 00000001000000000101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 393AE58CB87C7087A2-806C
    15788544 - Crash Shut-Down Activated
              P1609 00 [137] - -
              [DEM_FRONT_CRASH_FAULT]
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:00:36
                        Engine speed: 0 /min
                        Voltage terminal 30: 14.32 V
                        Power steering current consumption: 0.5 A
                        max.value: 0.5 A
                        End stage temperature: 215 °C
                        Steering assistance: engine output: 100 %
                        Engine angle: 65535 °
                        Electric motor speed: 45535 /min
                        Steering assistance: target engine torque: 0.0 Nm
                        Steering torque: 0.7 Nm
    10535936 - Databus
              [DEM_CAN_EXT_TEMP_INVALID_FAULT]
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:00:37
                        max.value: 0.5 A
       Part No SW: 5G0 035 280 C    HW: 5G0 035 280 C
       Component: MU-G--RW      557 5516
       Serial number: VWZ7Z2U5601831
       Coding: 02721100BE00000000220001010000002F0000040000010003
       ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
       ROD: EV_MUGlb4CGen25TPWR_VW27.rod
       VCID: 210A2DEC30EC08478A-8074
    End----------(Elapsed Time: 00:52, VBatt start/end: 14.5V/14.5V)-----------
       Revision: --H04---
              U0428 00 [039] - -
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:20
                        Coolant temperature: 37 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 14.472 V
              U0423 00 [039] - -
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:22
                        Coolant temperature at engine start: 39.00 °C
                        Coolant temperature model value-TCO_SUB: 29.25 °C
              U0422 00 [039] - -
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:20
    0716 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:23
    0717 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:23
              U0428 00 [137] - -
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
       Coding: 132C0C0623
    459527 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:17
       Coding: 0038DD
       Coding: 138000
       Coding: 098000
       Coding: 030000
       Coding: 1B0000
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
                        Zusaetzliche Umgebungsdaten-voltage measurement: 14.4 V
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:19
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:19
       Coding: 0011051001
              B10FC 13 [009] - Open Circuit
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:19
    13637426 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
    13637888 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
    13679372 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
       Revision: --------
    1050117 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 31:13:18
    1054981 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 31:13:18
    13639936 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:17
       Coding: 200000
              P1609 00 [137] - -
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
                        Voltage terminal 30: 14.40 V
                        max.value: 0.5 A
                        Steering torque: -0.4 Nm
    10535936 - Databus
                        Reset counter: 61
                        Mileage: 22278 km
                        Date: 2019.08.04
                        Time: 00:13:18
                        max.value: 0.5 A
    End----------(Elapsed Time: 00:51, VBatt start/end: 14.5V/14.5V)-----------
    Thank you!
    Last edited by Uwe; 02-19-2020 at 05:47 PM. Reason: QUOTE -> CODE & split sections
    16.4905° S, 151.7375° W
    There are a lot of fault codes with freeze frame data that indicates the battery voltage is/was below 12V.
    We recommend to use a battery maintainer when clearing codes. I suggest to clear ALL the DTCs and see what comes back.
    Have you seen this Ross-Tech forum post? This may help to clear the "Crash Shut-Down Activated " fault code in the [44-Steering Assist] controller.
    EPS_TRW_ALow procedure
    Source: P1609 - Crash Shut-Down Activated
    Let us know how this works for you.
    drpeter
    May 2017
    And if the VCDS does not clear it, this one works but needs additional tools https://forums.ross-tech.com/showthr...l=1#post175962
