Results 1 to 6 of 6
Thread: '16 Touareg TDI with battery questions that I "suspect" caused emission test failure
    Apr 2018
    Autoscan shows no issues but I do not know how to read or interpret the battery history. I would like to know for starters, what the columns under heading "no-load voltage underranging" signify? Clearly the first four columns are the date, but what do the rest of the numbers mean? The other categories have more columns with more indecipherable numbers. Is there any way to look up their meanings?
    By the way, the Connecticut emissions failure was merely because three categories were not "ready" and gave no reading, resulting in failure. [The Connecticut system merely reads info from the OBD terminal - there is no real "test".] I suspect ongoing low battery voltage, generally in the md-11volts is the original culprit. The dealer is largely unhelpful because their factory scan also shows no faults.
    Thursday,06,February,2020,11:16:19:48630
    VIN: WVGEP9BP6GD001166   License Plate: TOUAREG
    Mileage: 53563km-33282mi   Repair Order: 2-6-20
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56 5F
              62 65 69 6C 6D 72
    VIN: WVGEP9BP6GD001166   Mileage: 53563km-33282miles
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P1 907 401 C    HW: 7P0 907 401 K
       Component: 3.0TDI FSA    H21 0010
       Revision: 56H21---
       Coding: 292A4012233600050000
       Shop #: WSC 08060 444 00000
       ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
       ROD: EV_ECM30TDI0117P1907401C.rod
       VCID: 3039ECE6DAA88CE7797-8064
    Readiness: 0 0 0 1 0
    Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
       Part No SW: 0C8 927 755 R    HW: 0C8 927 755
       Component: AL1000 AISIN  130 3374
       Coding: 010500000C008400000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_TCMAL991031 003118
       ROD: EV_TCMAL991031_003.rod
       VCID: 40D9BC266A081C67897-8014
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
       Component: MK25A         H37 0521
       Revision: --------    Serial number: 43524438364721
       Coding: 5B7613C349242554DAF5C89992D8A4607301
       ASAM Dataset: EV_MK25AXT 010001
       ROD: EV_ESPMK25A01000.rod
       VCID: 4CC198165640C80765F-8018
       Part No SW: 4H0 907 064 GK    HW: 4H0 907 064 GK
       Component: BCM2 2.0      H37 0572
       Coding: 0D860016000000000000
       VCID: 78A914C672D894A7F17-802C
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 3215000088374012
       Part No SW: 7P6 907 040 CN    HW: 7P6 907 040 CN
       Component: Klima 2 Zonen H23 1507
       Coding: B606200A80
       VCID: 025D762E2484CE77DF3-8056
       Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
       Revision: 22020001    Serial number: 00001089080001
       Coding: 26000096963C5D010020480000005D4C431C6608A2010265000000008040110000000000000000
       VCID: 6A8D3E8E3C743637773-803E
       Component: WWS    150519  033 0021
       Serial number: 90243400150527194104
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 20571056
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
       Component: E1 - LDS  H02 0040
       Serial number: 00000000001905150273
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01F2630B
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0137720470
       Coding: 952F00
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 D    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0030
       Revision: --------    Serial number: 28231514203462
       Coding: 310504
       ASAM Dataset: EV_VW526ParkiAssis2 001013
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 44D1B0367E100047ADF-8010
       Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
       Component: VW10Airbag04Z H10 0043
       Revision: --------    Serial number: 003NK003UTT8
       Coding: 00000000000000000000000000000000345A
       ASAM Dataset: EV_AirbaVW10BPAVW526 002001
       ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
       VCID: 43D3B32A7B1E077F945-8016
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R154270LQRZ
       Serial number: 3575LRB40553ALK43G86
       Serial number: 3585LRB405L3A1784O94
       Serial number: 3517ARB401654Q414JKT
       Serial number: 3527ARB401454Q40QRTN
       Serial number: 3557BRB404V3EENA39JV
       Serial number: 3567BRB404V3EENAE0Q+
       Part No SW: 4H0 953 568 L    HW: 7P6 953 507 AF
       Revision: --------    Serial number: 01374OEP000JL
       Coding: 0000D5
       VCID: 3C21C8D606607887D5F-8068
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H05 0028
       Serial number: 0029674 TRW 20150317
       Part No SW: 7P6 920 983 A    HW: 7P6 920 983 A
       Component: Kombi         H13 0515
       Revision: 13240302    Serial number: 658020615592045
       Coding: 8B7733022B08CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001022
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 3D27C5D21DFA718FE21-8068
       Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6042
       Revision: --------    Serial number: 00000001860405
       Coding: 000103AD00
       ASAM Dataset: EV_GatewVW526UDS 001007
       ROD: EV_GatewUDS_VW52.rod
       VCID: 42DDB62E64040E779F3-8016
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 42139A41045701970610
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000150996496
       Coding: C0581B0015004001000001010101202020202121202020
       VCID: 3537DDF2254AA9CF2A1-8060
       Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
       Component: SWA Master    H06 0021
       Serial number: 0369803325
       Coding: 030221
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 3FDBBFDA17F6639FF0D-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0021
       Serial number: 0369723517
       Coding: 030221
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000151536292
       Coding: 011D17205E00453005080000
       VCID: 7AAD0ECE4CD486B7873-802E
       Revision: 00002001    Serial number: 0369632683
       Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
       Component: GTO BT  H20 0059
       Serial number: 112153893
       Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS30.408  H03 0004
       Serial number: 0000FST000APL9T00000
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
       Component: J394 PS30.408  H03 0004
       Serial number: 0000FST000BJFPY00000
       Coding: 191100
       Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
       Component: GEB.F.Heckoef  H16 0813
       Serial number: 65020455
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000152115205
       VCID: 48C9A40642B82427417-801C
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1552400368
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 3635DAFE38CCA2D723B-8062
       Slave 3:
       Coding: 012A02010B000400
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0005
       Coding: B00000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0005
       Coding: B00000
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156F.0F8272405
       Coding: 020007020100000001
       VCID: 241110B69ED020478DF-8070
       Part No SW: 7P6 035 664 K    HW: 7P6 035 664 A
       Component: H-BN-NA       H41 0933
       Revision: --------    Serial number: 606FY0FB006251
       Coding: 010200050040E1EF51022B0E00000003F00001030000000000
       VCID: 40D9BC266A881C67897-8014
       Subsystem 1 - Part No: 7P6 060 884 B
       Component: NAR 2015  1202
       Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: DU8 SV Touch  H56 0046
       Serial number: VWZ8Z9RX8005H8
       Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: CD-Database  6208
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000152155643
       Coding: 011817200000253005080000
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 40000000017908
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
       VCID: 45D7AD32752A394FBA1-8010
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
       Component: Anhaenger     H20 0160
       Revision: 7C001003    Serial number: 0370461241
       Coding: 0200000200000000
       ROD: EV_TrailFunctGener2Hella_VW52.rod
       VCID: 372BD7FA3FC65BDF38D-8062
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Fault Frequency: 12
                        Reset counter: 220
                        Mileage: 53460 km
                        Date: 2020.01.28
                        Time: 12:41:51
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H08000    Serial number: 525 PA8JA42599
       Coding: 0130001
       VCID: 372BD7FA33465BDF38D-8062
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 142501493
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202142
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000152154236
    End----(Elapsed Time: 02:13, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
    History scan:
    Sunday,16,February,2020,15:10:41:48630
    VIN: WVGEP9BP6GD001166   License Plate: BATTERY HX
    Mileage: 33524   Repair Order: 2-16-20
    Control Module Part Number: 7P6 907 530 M
      Component and/or Version: GW-CAN-L-MOST H13 6042
               Software Coding: 000103AD00
                Work Shop Code: WSC 31414
                          VCID: 42DDB62E64040E779F1-8016
    History Data
    Record 1/16: No-load voltage underranging
    2020-02-16-12:48*21.2*05*01211***
    2020-02-15-12:20*01.6*05**
    2020-02-15-10:46*16.9*05**
    2020-02-14-10:16*00.1*05**
    2020-02-13-10:05*02.2*05**
    2020-02-13-07:53*24.0*05**
    2020-02-12-07:38*11.7*05**
    2020-01-22-14:19*00.0*05*00110***
    2020-01-22-12:57*00.0*05**
    2019-12-22-10:54*16.0*05**
    2019-12-16-09:31*01.7*05**
    2019-12-16-08:02*15.1*05**
    2019-12-15-16:50*24.0*05**
    2019-12-14-16:48*24.4*05**
    2019-10-01-13:42*00.0*04*00000***
    2019-10-01-13:40*00.0*04**
    2019-10-01-13:38*00.0*04**
    2019-10-01-13:36*00.0*04**
    2019-10-01-13:33*00.0*04**
    2019-10-01-13:31*00.0*04**
    2019-10-01-13:29*00.0*04**
    Record 2/16: No-load current overranging
    2019-11-26-08:11*0003*044*-00.15*0-0-0-0-0-0*0*05*00017**
    2019-11-25-22:19*0010*042*-00.13*0-0-0-0-0-0*0*05**
    2016-04-07-10:47*0004*037*-00.13*0-0-0-0-0-0*0*05**
    2015-08-17-17:03*0001*073*-01.81*0-0-1-0-0-0*0*01**
    2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
    Record 3/16: Shut-off stage history
    2019-11-25-21:18*1*0*053*037*-06.98*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-10-01-11:40*3*0*005*000*-01.79*0-0-0-0-0-0*1*0*00.0*00.1**
    2019-10-01-11:34*3*0*000*000*-06.73*0-0-0-0-0-0*1*0*00.0*00.0**
    2019-10-01-11:34*2*0*000*000*-06.99*0-0-0-0-0-0*1*0*00.0*00.0**
    2019-10-01-11:31*1*0*000*000*-09.47*0-0-0-0-0-0*1*0*00.0*00.0**
    2019-09-14-10:33*3*0*020*000*-06.92*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-01-17-09:44*1*0*051*000*-14.69*0-0-0-0-0-0*0*0*00.0*00.1**
    2019-01-10-06:55*3*0*034*000*-06.97*0-0-0-0-0-0*0*0*00.0*00.1**
    2019-01-06-06:49*3*0*030*000*-06.93*0-0-0-0-0-0*0*0*00.0*00.0**
    2018-12-20-17:59*3*0*041*000*-08.90*0-0-0-0-0-0*0*0*00.0*00.0**
    2018-12-18-06:21*3*0*034*000*-06.87*0-0-0-0-0-0*0*0*00.0*00.0**
    2018-11-23-11:14*1*0*045*000*-17.32*0-0-0-0-0-0*0*0*00.0*00.0**
    2018-01-17-15:01*1*0*033*005*-14.50*0-0-0-0-0-0*0*0*00.0*00.1**
    2018-01-17-15:00*1*0*033*006*-09.07*0-0-0-0-0-0*0*0*00.0*00.1**
    2018-01-17-14:42*3*0*026*000*-08.59*0-0-0-0-0-0*0*0*00.0*00.1**
    Record 4/16: Battery change history
    2019-11-25-16:12*05*110*VAO*370621L07V*10001*00215*0000*0000*0000**
    2019-01-18-13:04*04*110*VAO*1111111111*10000*00913*0000*0000*0000**
    2018-11-21-16:07*03*110*VAO*1111111111*10006*00125*0000*0000*0000**
    2018-11-19-12:36*02*110*VAO*1111111111*10000*00000*0000*0000*0000**
    2015-06-10-13:01*01*110*VAO*VAO3F5J0AX*09994*02001*0000*0000*0000**
    Record 5/16: Energy-critical vehicle states
    2019-09-14-10:33*-00.09*-00.09*-06.92*11.65*000*07*-48.2*00744*09953*050691*0-0-0-0-0-0*0*00.0*00.0*524.3*02*00*01**
    2019-01-17-09:43*-00.08*-00.11*-15.17*11.43*000*04*-12.9*00115*09996*043750*0-0-0-0-0-0*0*00.0*00.1*112.7*04*04*06**
    2019-01-10-06:55*-00.09*-00.11*-06.97*11.78*000*05*-10.2*00084*09998*042835*0-0-0-0-0-0*0*00.0*00.1*087.3*05*03*05**
    2019-01-06-06:49*-00.08*-00.08*-06.93*11.78*000*05*-11.2*00068*09998*042744*0-0-0-0-0-0*0*00.0*00.0*130.1*01*00*04**
    2018-12-31-14:50*-00.08*-00.08*-11.43*11.69*000*05*-10.3*00054*09999*042589*0-0-0-0-0-0*0*00.0*00.0*118.3*01*00*03**
    Record 6/16: Energy balances (last 20 trips)
    2020-02-16-13:32*047*-02*+001.1*00.15**
    2020-02-16-12:49*046*-03*+000.9*00.15**
    2020-02-15-14:55*043*-06*+000.8*00.46**
    2020-02-15-12:21*031*-09*+000.9*00.48**
    2020-02-14-10:16*053*+01*+000.6*00.28**
    2020-02-14-07:33*057*+02*+000.5*00.25**
    2020-02-13-17:58*072*+09*+000.5*00.08**
    2020-02-13-16:48*076*+09*+003.3*01.00**
    2020-02-13-11:50*051*+05*+003.8*00.21**
    2020-02-13-11:25*047*+03*+000.5*00.05**
    2020-02-13-10:51*048*+02*+001.5*00.16**
    2020-02-13-10:32*047*+02*+002.2*00.15**
    2020-02-13-10:07*047*+01*+001.2*00.18**
    2020-02-12-07:39*048*+02*+000.1*00.03**
    2020-02-11-13:22*061*+06*+000.9*00.15**
    2020-02-11-12:49*060*+05*+000.9*00.18**
    2020-02-11-12:12*057*+04*+000.6*00.06**
    2020-02-11-11:26*059*+04*+000.8*00.11**
    2020-02-11-11:21*057*+03*+000.5*00.01**
    2020-02-11-10:56*063*+03*+000.8*00.23**
    Record 7/16: Energy balances (last 20 standing times)
    2020-02-16-12:59*037*-000.9*000.5*00.0*00.0**
    2020-02-15-15:23*031*-001.3*021.4*00.0*00.0**
    2020-02-15-12:51*028*-000.4*002.0*00.0*00.0**
    2020-02-14-10:34*015*-001.1*025.8*00.0*00.0**
    2020-02-14-07:48*045*-000.4*002.4*00.0*00.0**
    2020-02-13-18:04*049*-000.6*013.5*00.0*00.0**
    2020-02-13-17:48*075*-000.4*000.1*00.0*00.0**
    2020-02-13-12:03*054*-001.3*004.7*00.0*00.0**
    2020-02-13-11:28*044*-003.5*000.3*00.3*00.0**
    2020-02-13-11:01*042*-000.8*000.3*00.0*00.0**
    2020-02-13-10:41*045*-001.0*000.1*00.0*00.0**
    2020-02-13-10:18*041*-002.3*000.2*00.0*00.0**
    2020-02-12-07:41*036*-001.1*026.5*00.0*00.0**
    2020-02-11-13:31*040*-000.6*018.1*00.0*00.0**
    2020-02-11-13:00*056*-000.9*000.3*00.0*00.0**
    2020-02-11-12:17*052*-000.6*000.5*00.0*00.0**
    2020-02-11-11:34*052*-000.5*000.6*00.0*00.0**
    2020-02-11-11:23*056*-000.3*000.0*00.0*00.0**
    2020-02-11-11:11*058*-000.9*000.1*00.0*00.0**
    2020-02-10-14:24*051*-000.9*020.5*00.0*00.0**
    Record 8/16: Battery manipulation (e.g. charging)
    2019-10-22-15:34*4*03*00*00*04*05*2019-10-22-03:32*04**
    2019-10-10-03:43*4*03*00*00*03*05*2019-10-10-15:09*04**
    2019-10-01-12:06*5*03*00*00*02*05*2000-01-01-00:00*04**
    2019-10-01-11:40*7*03*00*00*02*04*2000-01-01-00:00*04**
    2019-01-18-13:02*4*03*00*00*02*03*2019-01-18-00:02*03**
    Record 9/16: Battery aging
    2019-11-25-16:12*100*100*100*027*00000*12.10*+16*05*12.70*00000*00000**
    2020-01-22-10:25*096*097*066*024*00125*12.30*-10*05*12.70*00003*00000**
    2019-12-22-10:54*100*094*070*035*00090*12.40*-07*05*12.70*00002*00000**
    2019-01-18-13:04*100*100*100*068*00000*12.50*+12*04*12.70*00000*00000**
    2019-11-14-09:08*094*085*059*023*00871*12.20*-07*04*12.70*00014*00000**
    2019-10-10-14:38*094*086*053*037*00811*12.10*+10*04*12.70*00013*00000**
    2019-09-14-10:33*097*099*020*000*00744*11.70*+13*04*12.70*00012*00000**
    2019-08-01-10:47*097*100*053*043*00580*12.10*+20*04*12.70*00010*00000**
    2019-07-03-10:18*096*100*063*055*00499*12.30*+21*04*12.70*00009*00000**
    2019-06-05-13:49*097*097*086*080*00400*12.60*+15*04*12.70*00009*00000**
    2019-05-08-13:47*097*093*077*069*00258*12.50*+15*04*12.70*00007*00000**
    2019-04-12-13:08*097*094*084*070*00195*12.60*+06*04*12.70*00006*00000**
    Record 10/16: Dynamic energy management
    2018-11-21-16:08*1*000.5*1*000.4*0*000.0*00.01**
    2018-11-21-16:07*1*000.5*1*000.2*0*000.0*00.01**
    2018-11-21-16:06*1*000.3*0*000.0*0*000.0*00.00**
    2018-11-21-14:35*1*000.5*1*011.0*0*000.0*00.18**
    2018-11-21-14:00*1*000.8*0*000.0*0*000.0*00.01**
    2018-11-14-12:57*0*0*0*00.00**
    2018-11-14-12:57*0*0*0*00.01**
    2018-11-14-12:57*0*0*0*00.08**
    2018-11-14-12:57*0*0*0*00.10**
    2018-11-21-16:09*2*000.4*00.01**
    2018-11-21-16:07*2*000.2*00.01**
    2018-11-21-14:46*2*011.0*00.18**
    2018-11-19-12:12*2*001.8*00.03**
    2018-11-14-13:26*2*004.3*00.08**
    2000-01-01-00:00*00*00.00*00.00*00.00**
    Record 11/16: Recuperation
    2019-11-26-13:00*000*000*000*000*0356*006*00.0*00.9*092*079*094*084*01*00035*00066*00056*00126*00161**
    2019-08-10-16:18*000*000*000*000*0262*004*00.0*00.6*090*083*093*089*01**
    2019-08-10-15:24*000*000*000*000*0252*004*00.0*00.5*091*086*093*089*01**
    2019-08-10-13:55*000*004*002*030*1127*057*02.6*03.8*091*087*094*090*01**
    2019-08-10-13:04*000*000*008*021*0479*067*00.7*01.6*082*074*092*087*01**
    2019-08-09-12:58*000*000*002*006*0214*021*00.1*00.5*089*085*090*086*01**
    2019-08-08-13:38*000*000*000*012*0227*041*00.1*00.5*087*084*090*087*01**
    2019-08-07-11:53*000*002*004*051*0727*086*01.8*03.6*089*085*091*088*01**
    2019-08-07-10:43*000*000*000*003*0013*004*00.1*00.3*091*088*091*087*01**
    2019-08-07-10:00*000*003*000*015*0822*061*02.1*03.2*080*070*092*089*01**
    Record 12/16: Start-Stop
    2020-01-22-14:25*1*067*034*-05*02*+30.0*+00.7*14.2*1**
    2020-01-12-15:02*2*059*046*+14*01*+30.0*+02.1*12.1*1**
    2019-12-22-11:42*1*070*039*-05*02*+30.0*+00.4*14.9*1**
    2019-12-16-13:42*2*059*031*+01*01*+30.0*+02.6*13.3*1**
    2019-12-16-12:10*1*060*037*+00*02*+30.0*+01.9*14.8*1**
    00005*00002*00000**
    Record 13/16: Sporadic alternator faults
    2018-11-14-12:54*0-0-0-1-0*000.1*00001**
    2000-01-01-00:00*0-0-0-0-0*000.0**
    Record 14/16: Small battery for hybrid vehicle
    2000-01-01-00:00*00*---*---*----------*00000*00000**
    2000-01-01-00:00*0*00*00*00*00*00**
    00000*00000*00000**
    2000-01-01-00:00*0-0-0-0-0-0-0-0**
    00000*00000*00000*00000*00000*00000*00000*00000**
    2000-01-01-00:00*0*000*000*00*00000*00000**
    00000*00000*00000**
    Record 15/16: Local activ.
    2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
    Record 16/16: Vehicle energy balance
    053953**
    00001*00016*00170*00009*00000**
    00080*00009*00002*00000**
    00346*00020*00001*00000**
    00029*00042*00016*00066**
    00077*00062*00014**
    00142*00005*00004*00000**
    00064*00000*00000**
    00000*00000*00000**
    00000*00001*00000**
    00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Seems like you have had a few issues there including a few battery changes-that's the change history. Hopefully you have a genuine battery fitted now capable of doing the job. Give me a day I can source some info and hopefully point you in the right direction of potential fault locations.
    Regards Danners
    Since it's a 2016, it probably sat around for a LONG time...
    I don't think the battery is causing the emissions failure. Please show us [OBD-II] -> [Mode 1-01 Readiness].
    Apr 2018
    Fourth battery
    Quote Originally Posted by Danners74 View Post
    Regards Danners
    You are correct. This car is now on it's fourth battery and second alternator:
    1. OEM battery from Slovakia
    2. Replaced 1-18-18 at dealer when I traded my '12 Touareg for this '16 that had 20,000 miles on it.
    3. 11-04-18 . Jump by AAA as battery was DEAD
    4. 11-12-18 Dealer replaced alternator as battery had been going flat. My note afterward was that it seemed better but that the battery was still not up to 12 volts even after driving.
    5. 1-18-19 27,192 mi. Battery still going flat – a continuing problem. Battery tested as “defective” at Hartford VW and replaced.
    6. 10-1-19 (mileage not recorded. Battery totally flat; jump by AAA
    7. 11-29-19 32,124mi. Battery still losing charge. Htfd VW “readapted” battery, Insists all is OK.
    8. 2-06-20 33,286 FAILED emissions test. NO codes – unable to get readings for a reason I don't understand. I was told to drive the car for 100 miles & come back for free retest.
    More history and ongoing: The car went totally dead twice after not being driven for a month. So dead that I had to use the mechanical emergency key to get in. I've been watching voltage regularly and keeping readings. The battery is NEVER twelve volts or higher, even after 90 highway miles. [I understand that a fully charged battery should be 12.5 v or higher.] It generally loses voltage overnight but not always. The dealer says this is OK and will not investigate further without diagnostic fee. I rebel as this should be warranty. 60k mile emissions warranty = emissions failure should be covered.
    The three systems "not ready" causing the emissions failure were Catalyst, Fuel system and Oxygen sensor heated. Two have resolved themselves according to the readiness printout.
    The emission test guy told me that battery replacement can cause unreadiness and to go drive 100 miles and come back. I did but only one had reset = continued fail. There had been no recent battery change so this is why I suspect battery ongoing undervoltage to be the cause.
    Thank you so much. You guys are so great. I wish I knew more about VCDS but I'm learning!
    Thursday,20,February,2020,14:51:07:48630
    VIN: WVGEP9BP6GD001166 License Plate: 2-20-20
    Mileage: Repair Order: obd readiness
    Mode 01 - PID 01 : Readiness -- Address 7E8
    Number of DTCs stored: 0 -- MIL Status: MIL OFF
    Misfire monitoring: Passed
    Fuel System: Passed
    Comprehensive Components: Passed
    Catalyst monitoring: Passed
    Heated catalyst monitoring: Passed
    Evaporative system monitoring: Not installed.
    Secondary air system monitoring: Passed
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring: Passed
    Oxygen sensor heater monitoring: Fail
    Apr 2018
    It did not sit around -was leased by finance guy at dealership & had 20k miles when I traded '12 Touareg TDI pursuant to the diesel settlement [a really good deal for me].
    OBDII attached. See also long note to Danners re battery history. THANKS!!
    Fuel System: Passed
    Quote Originally Posted by hts1190 View Post
    Yes, it certainly can. I'd expect to see all the monitored systems read "Fail" immediately after a battery disconnect. But you only have one that's currently reading "Fail", the Oxygen sensor heater monitoring. I find it a but curious that the Oxygen sensor monitoring itself has passed, but the heater monitoring hasn't. Also, I don't see a way to explicitly force the heater monitoring test to run.
