Hi guys. Im looking for help with change of coding for ABS and ECM module, building 2010 audi tts racing car and need to remove modules and lots of parts out of it (like lights and comfort sysytems)
Any advice on coding of the two modules?
Wednesday,19,February,2020,10:51:59:52297
VCDS Version: 19.6.2.2 (x64)
VIN: TRUK1AFK8A1020521 License Plate:
Chassis Type: FK (1K0)
Scan: 01 02 03 09 16 17 19 22 25 44 46
VIN: TRUK1AFK8A1020521 Mileage: 75010km-46609miles
Address 01: Engine (CDM) Labels:. 06F-907-115-CDL.clb
Part No SW: 8J0 907 115 AF HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH19--- Serial number: AUX7Z0J2FNS030
Coding: 0113010A1C0F0160
Shop #: WSC 01236 785 00200
VCID: 70E437FE636F5ACF55-8024
6 Faults Found:
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 -
Mileage: 75018 km
Date: 2020.01.15
Time: 02:09:25
Temperature: 15.0°C
Temperature: 15.0°C
Absolute Pres.: 830.0 mbar
Voltage: 12.192 V
049489 - No Communications with Airbag Control Module
U0151 - 008 -
Mileage: 75018 km
Temperature: 15.0°C
Temperature: 15.0°C
Voltage: 12.192 V
049412 - No Communication with Cruise Control Module
U0104 - 008 - - Intermittent
Mileage: 75018 km
Date: 2020.01.15
Time: 02:44:54
Temperature: 24.0°C
Temperature: 18.0°C
Absolute Pres.: 840.0 mbar
Voltage: 12.065 V
009216 - EVAP Leak Detection Pump Control Circuit
P2400 - 004 - Malfunction - MIL ON
Fault Status: 11100100
Mileage: 75018 km
Date: 2020.01.15
Time: 03:05:15
RPM: 1220 /min
Load: 25.5 %
Temperature: 15.0°C
Temperature: 15.0°C
Voltage: 12.446 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
012313 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:07
RPM: 1196 /min
Load: 21.6 %
Temperature: 15.0°C
Temperature: 15.0°C
Voltage: 11.811 V
Readiness: 0110 0101
Part No SW: 02E 300 012 N HW: 02E 927 770 AM
Component: GSG DSG AG6 531 2117
Revision: 53104 Serial number: 00001411040135
Shop #: WSC 04940 001 00001
VCID: 1B3E3052DA69899750-804E
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 D HW: 8J0 614 517 D
Component: ESP MK60E1 0030
Revision: 00H60001
Coding: 0618294
VCID: 2E58E986B9DB0C3F07-807A
00471 - Control Module for Elect. Regulated Dampers (J250)
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:54:20
Count: 128
Count: 8512
Count: 8229
Count: 43520
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:05
Count: 128
Count: 8512
Count: 8232
Count: 43520
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 E HW: 8P0 907 063 E
Component: BCM PQ35 H 105 0575
Revision: 00105 AK
Coding: 00000000000000002034C0200100000010007700000058295C0000400040
Shop #: WSC 01236 758 00200
VCID: 3668C1E6818B34FF4F-8062
9 Faults Found:
01800 - Light Switch (E1)
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:05
Voltage: 11.95 V
Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:05
Voltage: 11.95 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:05
Voltage: 11.95 V
Term 50 Off
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:08
Voltage: 12.00 V
Term 50 Off
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:08
Voltage: 12.00 V
Term 50 Off
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:08
Voltage: 12.00 V
Term 50 Off
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:08
Voltage: 12.00 V
Term 50 Off
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:46:08
Voltage: 12.00 V
Term 50 Off
01134 - Alarm Horn (H12)
Reset counter: 184
Mileage: 75018 km
Date: 2020.01.17
Time: 02:55:30
Voltage: 12.00 V
Term 50 Off
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0011101
VCID: 4688B126316BA47FDF-8012
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 990 J HW: 8J0 920 990 J
Component: KOMBIINSTR. VDO H03 0490
Revision: D0H03005 Serial number: 2242J005000348
Coding: 0003203
Shop #: WSC 32144 003 104857
VCID: 3972CADA7095DB87A2-806C
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4540K103208117
Coding: 6D820702000002004100
VCID: 69D25A9A40B5AB0712-803C
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 438EA83202599157F8-8016
Revision: D0H03005 Serial number: AUX7Z0J2FNS030
Part No: 8J0 909 144 J
Component: EPS_ZFLS Kl. 237 3001
Revision: 00H17000
VCID: 3776CCE24681CDF754-8062
End-------------------------(Elapsed Time: 01:22)--------------------------
