2010 Audi TTS ABS and ECM coding help please
matus008
C?ID=78225
Hi guys. Im looking for help with change of coding for ABS and ECM module, building 2010 audi tts racing car and need to remove modules and lots of parts out of it (like lights and comfort sysytems)
Any advice on coding of the two modules?
Wednesday,19,February,2020,10:51:59:52297
VCDS Version: 19.6.2.2 (x64)
VIN: TRUK1AFK8A1020521   License Plate:
Chassis Type: FK (1K0)
Scan: 01 02 03 09 16 17 19 22 25 44 46
VIN: TRUK1AFK8A1020521   Mileage: 75010km-46609miles
Address 01: Engine (CDM)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8J0 907 115 AF    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH19---    Serial number: AUX7Z0J2FNS030
   Coding: 0113010A1C0F0160
   Shop #: WSC 01236 785 00200
   VCID: 70E437FE636F5ACF55-8024
6 Faults Found:
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 02:09:25
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 12.192 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -
                    Mileage: 75018 km
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.192 V
049412 - No Communication with Cruise Control Module
               U0104 - 008 -  - Intermittent
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 02:44:54
                    Temperature: 24.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 840.0 mbar
                    Voltage: 12.065 V
009216 - EVAP Leak Detection Pump Control Circuit
               P2400 - 004 - Malfunction - MIL ON
                    Fault Status: 11100100
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 03:05:15
                    RPM: 1220 /min
                    Load: 25.5 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.446 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
012313 - Valve for Exhaust Flap 1 (N321)
               P3019 - 004 - Open Circuit
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:07
                    RPM: 1196 /min
                    Load: 21.6 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 11.811 V
Readiness: 0110 0101
   Part No SW: 02E 300 012 N    HW: 02E 927 770 AM
   Component: GSG DSG AG6     531 2117
   Revision:    53104    Serial number: 00001411040135
   Shop #: WSC 04940 001 00001
   VCID: 1B3E3052DA69899750-804E
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 D    HW: 8J0 614 517 D
   Component: ESP MK60E1          0030
   Revision: 00H60001
   Coding: 0618294
   VCID: 2E58E986B9DB0C3F07-807A
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:54:20
                    Count: 128
                    Count: 8512
                    Count: 8229
                    Count: 43520
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Count: 128
                    Count: 8512
                    Count: 8232
                    Count: 43520
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 E    HW: 8P0 907 063 E
   Component: BCM PQ35  H   105 0575
   Revision: 00105 AK
   Coding: 00000000000000002034C0200100000010007700000058295C0000400040
   Shop #: WSC 01236 758 00200
   VCID: 3668C1E6818B34FF4F-8062
9 Faults Found:
01800 - Light Switch (E1)
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
01134 - Alarm Horn (H12)
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:55:30
                    Voltage: 12.00 V
                        Term 50 Off
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0011101
   VCID: 4688B126316BA47FDF-8012
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 J    HW: 8J0 920 990 J
   Component: KOMBIINSTR. VDO H03 0490
   Revision: D0H03005    Serial number: 2242J005000348
   Coding: 0003203
   Shop #: WSC 32144 003 104857
   VCID: 3972CADA7095DB87A2-806C
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4540K103208117
   Coding: 6D820702000002004100
   VCID: 69D25A9A40B5AB0712-803C
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 438EA83202599157F8-8016
   Revision: D0H03005    Serial number: AUX7Z0J2FNS030
   Part No: 8J0 909 144 J
   Component: EPS_ZFLS Kl. 237    3001
   Revision: 00H17000
   VCID: 3776CCE24681CDF754-8062
End-------------------------(Elapsed Time: 01:22)--------------------------
NEtech
C?ID=56995
0113010A1C090060 coding for engine, there will probably still be 2 DTC's
0609846 or 0609078 coding for ABS, I don't know Airbag in this coding.
matus008
C?ID=78225
So ABS took the coding and i have only airbag fault
ECM i was trying the same coding before but it everytime said error31 request out of range
Wednesday,19,February,2020,13:08:14:52297
6 Faults Found:
               U0164 - 008 -
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 02:09:25
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.192 V
               U0151 - 008 -
                    Mileage: 75018 km
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.192 V
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 02:44:54
                    Temperature: 24.0°C
                    Temperature: 18.0°C
                    Voltage: 12.065 V
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 03:05:15
                    RPM: 1220 /min
                    Load: 25.5 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.446 V
                    Voltage: 0.000 V
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:07
                    RPM: 1196 /min
                    Load: 21.6 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 11.811 V
   Revision: 00H60001
   Coding: 0609844
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:09:48
                    Count: 128
                    Count: 8640
                    Count: 8232
                    Count: 43520
   Revision: 00105 AK
11 Faults Found:
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:55:30
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:07:35
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:07:36
                    Voltage: 12.05 V
                        Term 50 Off
   Coding: 0011101
            014 - Defective
   Coding: 0003203
   Coding: 0000005
   Revision: 00H17000
End-------------------------(Elapsed Time: 01:21)--------------------------
do i need to do security login first?
matus008
C?ID=78225
how is the coding on ABS generated?
NEtech
C?ID=56995
Don't think SA is needed, if so probably unknown.
Try one Bit change for each coding testing, all information is there, Byte 5 and Byte 6, Long Coding helper.
The ABS Coding is not one of the 2 codings I suggested!
Current in Autoscan is wrong.
matus008
C?ID=78225
my fault thanks for catching it
will the esp and abs still work correctly even having fault for airbag?
Wednesday,19,February,2020,14:14:17:52297
6 Faults Found:
               U0164 - 008 -
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 02:09:25
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.192 V
               U0151 - 008 -
                    Mileage: 75018 km
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.192 V
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 02:44:54
                    Temperature: 24.0°C
                    Temperature: 18.0°C
                    Voltage: 12.065 V
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 03:05:15
                    RPM: 1220 /min
                    Load: 25.5 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 12.446 V
                    Voltage: 0.000 V
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:07
                    RPM: 1196 /min
                    Load: 21.6 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 11.811 V
   Revision: 00H60001
   Coding: 0609846
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 06:17:22
                    Count: 128
                    Count: 8512
                    Count: 8232
                    Count: 43264
   Revision: 00105 AK
13 Faults Found:
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:05
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:46:08
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 02:55:30
                    Voltage: 12.00 V
                        Term 50 Off
                    Fault Frequency: 7
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:07:35
                    Voltage: 12.05 V
                        Term 50 Off
                    Fault Frequency: 7
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:07:36
                    Voltage: 12.05 V
                        Term 50 Off
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:22:50
                        Term 15 Off
                    Voltage: 11.90 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.17
                    Time: 05:30:11
                    Voltage: 11.90 V
                        Term 50 Off
   Coding: 0011101
            014 - Defective
   Coding: 0003203
   Coding: 0000005
   Revision: 00H17000
End-------------------------(Elapsed Time: 01:23)--------------------------
NEtech
C?ID=56995
As I wrote, I don't coding for Airbag (if it is in coding).
Try these 2, one at a time.
0609078
0593718
matus008
C?ID=78225
coding
0609078 out of range
0593718 works
0609846 works
which one should i use?
matus008
C?ID=78225
sorry had crazy day. The two codes that works i have code only for airbag module.
That is the reason im asking which one
On either coding the auto scan has same result
matus008
C?ID=78225
this is how far i got it:
Lots of code in CC module but i code instrument cluster to turn off DIS
:):thanks:
Thursday,20,February,2020,20:42:25:52297
   Coding: 0113010A1C0B0060
               U0151 - 008 -
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:12:38
                    Temperature: 27.0°C
                    Temperature: 16.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 11.811 V
   Revision: 00H60001
   Coding: 0593718
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:09:39
                    Count: 128
                    Count: 8512
                    Count: 8232
                    Count: 44032
   Revision: 00105 AK
12 Faults Found:
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:51
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:51
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:51
                    Voltage: 11.90 V
                        Term 50 Off
02391 - Terminal 30 Reference
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:51
                    Voltage: 11.90 V
                        Term 50 Off
03266 - Control Circuit for Signal Horn
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:51
                    Voltage: 11.90 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:51
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:55
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:55
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:55
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:55
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:10:55
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 75018 km
                    Date: 2020.01.18
                    Time: 00:14:32
                    Voltage: 11.80 V
                        Term 50 Off
   Coding: 0011101
            014 - Defective
   Coding: 0003203
   Coding: 0000005
   Revision: 00H17000
End-------------------------(Elapsed Time: 01:20)--------------------------
matus008
C?ID=78225
The one where there are no fault code.
Im sorry to bug you, but you helped me in past with my abs coding, I replaced front and rear calipers for bigger ones. Now on track I have issue with the tracking, I turn off systems ASR and EPC but after min or two on track it comes back on. Is there any way to permanently disable the systems?
Thanks for any info
