Results 1 to 5 of 5
Thread: Scoda ooctavia 2 1.9 tdi 2009 engine light is on, almost all control module is dead.
    Verified VCDS User mkivil's Avatar
    May 2018
    Does anybody know what is happening in my scoda
    Wednesday,19,February,2020,17:07:19:51780
    VCDS Version: 19.6.2.2 (x64)
    VIN: TMBBS21ZXA2011394   License Plate:
    Mileage: 281400km-174853mi   Repair Order:
    Chassis Type: 1Z-SK35 (1K0)
    Scan: 01 03 08 09 15 17 19 25 42 44 46 52 55 56 62 69 72 77
    VIN: TMBBS21ZXA2011394   Mileage: 281400km-174853miles
    01-Engine -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Cannot be reached 1100
    09-Cent. Elect. -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Cannot be reached 1100
    46-Central Conv. -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    69-Trailer -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine
    Address 03: ABS Brakes
    Address 08: Auto HVAC
    Address 09: Cent. Elect.
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags
       Part No SW: 1Z0 920 903 D    HW: 1Z0 920 903 D
       Component: KOMBI         H21 0109
       Coding: 010D00
       Shop #: WSC 73430 031 00999
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: 364C71DD898D39FF4F-8062
       Part No SW: 1K0 907 530 S    HW: 1K0 907 951
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K08A150039
       Coding: E9817F44000602002302
       Shop #: WSC 11111 123 12345
       VCID: 37527CD94687C0F754-8062
                        Fault Frequency: 12
                        Reset counter: 89
                        Mileage: 271575 km
                        Date: 2014.01.13
                        Time: 17:32:45
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H21 0109
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 275472 km
                        Date: 2019.11.06
                        Time: 18:38:27
    Address 44: Steering Assist
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
    Address 55: Headlight Range
       Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
       Component: BOLERO        011 0062
       Revision: 0A001001    Serial number: SKZ1Z3L9535605
       Coding: 050004000101
       Shop #: WSC 73430 790 00088
       VCID: 354E76D19C8B32E746-8060
    03138 - Input AUX IN
                        Fault Status: 01101011
                        Reset counter: 201
                        Mileage: 274235 km
                        Date: 2014.02.15
                        Time: 15:57:21
    Address 62: Door, Rear Left
    Address 69: Trailer
    Address 72: Door, Rear Right
    Address 77: Telephone        Labels: RETROFIT77.lbl
       Part No SW: KTC 364 96P     HW: KTC 364 96P
       Component: SWP:3.31.6      H24 0199
       Shop #: WSC 21977 142 74100
       VCID: 3E5C69FD69BDF1BF97-806A
    End-------------------------(Elapsed Time: 01:14)--------------------------
    Fuses? Relays?
    Chances are this stuff simply isn't getting power.
  3. Likes PetrolDave, mkivil liked this post
    May 2018
    Thanks Uwe
    Fuses are all ok. Car and engine works. only thing is that control modules does not respond to vac-com and engine lights is on. I don't know anything about relays. I try to check relays next.
    Quote Originally Posted by mkivil View Post
    The car's Gateway can't talk to those modules either, so this isn't a problem with VCDS.
    May 2014
    ^^mkivil: Hi. Hmm........ total guess and it's entirely likely that there is more than one cause - but I note that lots of "cannot be reached" modules live on the drive-train CAN bus. Perhaps grab a WD and chase the drive-train High-Low CAN wires from the hex 19 module end at each downstream connector (maybe?).
  7. Likes Uwe, PetrolDave liked this post
