Results 1 to 7 of 7
Thread: VW T6.1 Transporter ROD Files missing
    Dec 2016
    Hello currently have latest version of ross-tech 19.6.2 running on a 2020 VW T6.1 Transporter. It says some ROD files are missing. I have downloaded the latest beta files that VCDS can find but still no luck.
    Wednesday,19,February,2020,12:36:52:53429
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    Dealer/Shop Name: Bespoke Services
    VIN: WV1ZZZ7HZLX007504   License Plate:
    Mileage: 138   Repair Order:
    Chassis Type: 7H-VN75 (3Q0)
    Scan: 01 03 08 09 10 13 15 17 19 44 5F 65 75
    65-Tire Pressure -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CXHA)       Labels: None
       Part No SW: 04L 906 056 RS    HW: 04L 907 445 M
       Component: R4 2.0l TDI   H01 9705
       Revision: 23301001
       Coding: 001940144344050900000000000000000000000000000000
       Shop #: WSC 00035 377 00146
       ASAM Dataset: EV_ECM20TDI03004L906056RS 004007
       ROD: EV_ECM20TDI03004L906056LE.rod
       VCID: 0F6E4E04D68DD9372E-805A
    Readiness: N/A
       Part No SW: 7LB 614 517 A    HW: 7LB 614 517
       Component: ESC_base      H01 0700
       Serial number: 08508555191030
       Coding: 305524524847EE8C0C5924A4126A7706392320B8
       Shop #: WSC 00035 377 00127
       ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
       ROD: EV_Brake1ESP90iBOSCHVN46X.rod
       VCID: 3E30C3C0A1A700BF95-806A
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 7LA 907 426     HW: 7LA 907 426
       Component: AC Manuell    H01 0502
       Coding: A03110000810000001000800504001050000000000010000800000000000
       ASAM Dataset: EV_AirCondiBHTCT6PA 001004
       ROD: N/A
       VCID: 55E27C6C34D1E3E7A4-8000
    No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
       Part No SW: 2Q5 937 090     HW: 2Q5 937 090
       Component: BCM T6PA Std+ H10 0935
       Serial number: 01101931600981
       Shop #: WSC 00035 377 00145
       ASAM Dataset: EV_BCMA0 205001
       ROD: EV_BCMA0_204.rod
       VCID: 74A421E8DF6B9AEFB3-8020
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  050 0105
       Serial number: S5Y19M10D11H17M22S55
       Coding: 02B8EE
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
       Component: FHSG_DRV  001 0002
       Serial number: 00000000000035228373
       Coding: 1F0007
       Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000035230695
       Coding: 050007
       Serial number: 000000000ZY193003SEC
       Serial number: 00000000000031899304
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058419315
       Coding: 0471151801
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       ROD: EV_EPHVA18AU3700000_003.rod
       VCID: 50EC8D780B3386CF77-8004
    Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
       Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0372
       Coding: 2A00600241FF8748949C815560508700000000000000000004
       ASAM Dataset: EV_ACCMRRCONTIVW376 003016
       VCID: 43C6B234CA456D57FA-8016
       Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
       Component: VW22Airbag    013 0506
       Revision: --------
       Coding: 8800C00000000000400000CF008C40000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 7F4EFEC4E62DC9B7DE-802A
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 7LA 920 941     HW: 7LA 920 941
       Component: KOMBI         204 6750
       Coding: 27A40A802480260001886A050401000000600000
       ROD: N/A
       VCID: 7DB204CCEC21DBA7CC-8028
    No ASAM data for: "EV_DashBoardVDDMQBAB" (VN75)
    16777014 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 7
                        Mileage: 222 km
                        Date: 2020.02.19
                        Time: 12:32:00
    16776989 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 7
                        Mileage: 222 km
                        Date: 2020.02.19
                        Time: 12:31:57
       Component: GW MQB High   521 5388
       Serial number: 18111911600665
       Coding: 030100344F05730400000018000F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 70AC2DF8AB73A6CF57-8024
       Component: 4-01-09-01-04
       Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440066319191939
       Coding: 2C1D00
       Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
       Component: J367-BDMConti  H03 1052
       Serial number: 773433010019110600A5
    131595 - Tire Pressure Monitoring Module
              U0127 00 [009] - No Communications
              [Timeout Knoten 0x0B / 65 - Steuergerät für Reifendrucküberwachung]
                        Reset counter: 7
                        Mileage: 222 km
                        Date: 2020.02.19
                        Time: 12:31:58
                        Supply voltage: Terminal 30: 11.7 V
                        Terminal 15: On
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
       Component: EPS_MQB_ZFLS  751 7150
       Coding: 0106
       ASAM Dataset: EV_SteerAssisMNB 002012
       ROD: N/A
       VCID: 45C2AC2CC4715367D4-8010
    No ASAM data for: "EV_SteerAssisMNB" (VN75)
       Part No SW: 3G5 035 820     HW: 3G5 035 820
       Component: MU-O-ND-EU    H12 0156
       Serial number: VWZAZ2W1188315
       Coding: 64600008000020000000000000000000000000000000000000
       ASAM Dataset: EV_MUOIMQB 001001
       ROD: N/A
       VCID: 618A58BC70991F47C8-8034
    No ASAM data for: "EV_MUOIMQB" (VN75)
    7175 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 222 km
                        Date: 2020.02.19
                        Time: 12:32:00
    Address 65: Tire Pressure
    Address 75: Telematics (J949)       Labels: None
       Part No SW: 5WA 035 284     HW: 5WA 035 284
       Component: OCUGen3High   H20 0083
       Serial number: 0000000908VIMU9
       Coding: 06462000196898209005460160000607
       ASAM Dataset: EV_OCUGen3High 002115
       ROD: N/A
       VCID: 034672348AC5AD57BA-8056
    No ASAM data for: "EV_OCUGen3High" (VN75)
    7170 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 40
                        Mileage: 222 km
                        Date: 2020.02.19
                        Time: 12:32:01
    End----(Elapsed Time: 01:14, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
  2. Likes Mike@Gendan liked this post
  3. #2
    I am confident these will be covered when a public version 20.x Beta is released.
  4. Likes hadez16 liked this post
  5. #3
    Mar 2020
    Switzerland
    Hi all
    I wanted to code the N279 of my Multivan T6.1 to heat also the cooling circuit of the engine - unfortunately I have the same issue with 19.6.2
    I attach also the autoscan:
    Samstag,21,März,2020,15:35:49:61222
    VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
    VCDS Version: AIB 19.6.2.1  HEX-V2 CB: 0.4508.4
    Datenstand: 20200302 DS308.0
    www.vcds.de
    Fahrzeug-Ident.-Nr.: WV2ZZZ7HZLH048100   KFZ-Kennzeichen:
    Kilometerstand: 90   Reparaturauftrag:
    Fahrzeugtyp: 7H-VN75 (3Q0)
    Scan: 01 02 03 08 09 10 13 14 15 17 18 19 22 3C 44 55 5F 69 6D 75
              A5 D6 D7
    03-Bremsenelektronik -- Status: i.O. 0000
    09-Zentralelektrik -- Status: i.O. 0000
    13-Distanzregelung -- Status: i.O. 0000
    14-Raddämpfung -- Status: i.O. 0000
    17-Schalttafeleinsatz -- Status: Fehler 0010
    18-Standheizung -- Status: i.O. 0000
    19-Diagnoseinterface -- Status: i.O. 0000
    22-Allrad -- Status: i.O. 0000
    3C-Spurwechsel -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    55-Leuchtweitenreg. -- Status: i.O. 0000
    5F-Informationselek. I -- Status: i.O. 0000
    69-Anhänger -- Status: i.O. 0000
    6D-Heckklappe -- Status: i.O. 0000
    75-Telematik -- Status: Fehler 0010
    A5-Front-/Vorfeldkamera -- Status: i.O. 0000
    D6-Lichtsteuerung links 2 -- Status: i.O. 0000
    D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
    Adresse 01: Motorelektronik (J623-CXFA)       Labeldatei: Keine
       Teilenummer SW: 04L 906 056 QJ    HW: 04L 907 445 M
       Bauteil: R4 2.0l TDI   H01 9696
       Revision: 23301001
       Codierung: 0025401C4366050800000000000000000000000000000000
       Betriebsnr.: WSC 00012 790 00025
       ASAM Datensatz: EV_ECM20TDI03004L906056QJ 004004
       ROD: EV_ECM20TDI03004L906056QF.rod
       VCID: 0556687465AFD44FFA0-8050
    Readiness: Nicht Verfügbar
    Adresse 02: Getriebe (J743)       Labeldatei: DRV\0BH-927-711.clb
       Teilenummer SW: 0BT 300 012 E    HW: 0GC 927 711 H
       Bauteil: GSG DQ500     H06 3105
       Revision: 00H06V11
       Codierung: 0014
       ASAM Datensatz: EV_TCMDQ500021 001001
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 313EECA481A7A8EF768-8064
    Adresse 03: Bremsenelektronik (J104)       Labeldatei: Keine
       Teilenummer SW: 7LA 614 517 A    HW: 7LA 614 517
       Bauteil: ESC_high      H01 0700
       Seriennummer: 08512742200124
       Codierung: 10554452C84BE68D085522A413666766383720B8
       ASAM Datensatz: EV_Brake1ESP90iBOSCHVN46X 002010
       VCID: 3D26C0944DFF5C8FE20-8068
    Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei: Keine
       Teilenummer SW: 7LA 907 040 A    HW: 7LA 907 040 A
       Bauteil: Climatronic   H01 0502
       Codierung: 0030100008101100010009005040010500000000000B1101A08000000000
       ASAM Datensatz: EV_AirCondiBHTCT6PA 001004
       ROD: n.v.
       VCID: 392ED48459D760AFCE8-806C
       Subsystem 1 - Teilenummer SW: 7LA 907 049 D    HW: 7LA 907 049 D
       Bauteil: E857  H02 0301
       Seriennummer: 00005066064509121312
       Subsystem 2 - Teilenummer SW: 7LA 907 049 F    HW: 7LA 907 049 F
       Seriennummer: 00002160120140459602
       Codierung: 000000
    Keine ASAM Daten verfügbar: "EV_AirCondiBHTCT6PA" (VN75)
    Adresse 09: Zentralelektrik (J519)       Labeldatei: Keine
       Teilenummer SW: 2Q5 937 090     HW: 2Q5 937 090
       Bauteil: BCM T6PA Std+ H10 0935
       Seriennummer: 01102003700124
       Betriebsnr.: WSC 00012 790 00067
       ASAM Datensatz: EV_BCMA0 205001
       VCID: 74B025B03E35DDC7DDE-8020
       Sensor für Regen- und Lichterkennung:
       Subsystem 1 - Teilenummer SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labeldatei: DRV\5Q0-955-547.CLB
       Bauteil: RLS  050 0105
       Seriennummer: S4Y20M01D03H12M21S31
       Codierung: 02B8EE
       Türsteuergerät Fahrerseite:
       Subsystem 2 - Teilenummer SW: 7L2 959 405 B    HW: 7L2 959 163 B
       Bauteil: FHSG_DRV  001 0002
       Seriennummer: 00000000000037989366
       Codierung: 130007
       Türsteuergerät Beifahrerseite:
       Subsystem 3 - Teilenummer SW: 7L2 959 406 B    HW: 7L2 959 164 B
       Bauteil: FHSG_PSG  001 0002
       Seriennummer: 00000000000038015494
       Codierung: 090007
    Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\5Q0-919-298.clb
       Teilenummer SW: 5QA 919 298 H    HW: 5QA 919 298 A
       Bauteil: PLA 3.0 12K   H08 0061
       Seriennummer: 000150057220032
       Codierung: 0279167851
       ASAM Datensatz: EV_EPHVA2CAU3700000 009048
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 55F67834D58FA4CFCA0-8000
    Adresse 13: Distanzregelung (J428)       Labeldatei:. 2Q0-907-572.clb
       Teilenummer SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
       Bauteil: ACCCONTIMQB   H03 0372
       Codierung: 3204678B49FF8748949C815580508700000000000000000004
       ASAM Datensatz: EV_ACCMRRCONTIVW376 003016
       VCID: 43D2B66C2B1B2A7F944-8016
    Adresse 14: Raddämpfung (J250)       Labeldatei: 5Q0-907-376.clb
       Teilenummer SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
       Bauteil: DAEMPFUNGS-SG H17 0130
       Seriennummer: 03012041350574
       ASAM Datensatz: EV_DRCONTITEMIC 001019
       ROD: n.v.
    Keine ASAM Daten verfügbar: "EV_DRCONTITEMIC" (VN75)
    Adresse 15: Airbag (J234)       Labeldatei:* Keine
       Teilenummer SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
       Bauteil: VW22Airbag    015 0506
       Revision: --------
       Codierung: 88CFC00000000000800000CF000C40000065
       ASAM Datensatz: EV_AirbaVW22BPAVW27X 001022
       VCID: 005879607A8DF167C96-8054
       Subsystem 1 - Teilenummer SW: -----------    HW: 442 062 801 20
       Bauteil: SideSensor_Df  1E2 0887
       Seriennummer: 3577Y519933C68C4F2DT
       Codierung: 2D2D2D
       Subsystem 2 - Teilenummer SW: -----------    HW: 442 062 801 20
       Bauteil: SideSensor_Pf  1E2 0887
       Seriennummer: 3587Y51A53398AA124DC
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Fahrerseite:
       Subsystem 3 - Teilenummer SW: -----------    HW: 442 0D2 401 20
       Bauteil: SideSensor_Dr  30F 1108
       Seriennummer: 351CF11C733144D1E48Q
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Beifahrerseite:
       Subsystem 4 - Teilenummer SW: -----------    HW: 442 0D2 401 20
       Bauteil: SideSensor_Pr  30F 1108
       Seriennummer: 352CF11C733144D2555H
       Codierung: 2D2D2D
    Adresse 17: Schalttafeleinsatz (J285)       Labeldatei: Keine
       Teilenummer SW: 7LA 920 320     HW: 7LA 920 320
       Bauteil: KOMBI         503 4193
       Codierung: 04A408087D8C00080188620B1001000800601E02
       ASAM Datensatz: EV_DashBoardVDDMQBA0 001042
       ROD: n.v.
    Keine ASAM Daten verfügbar: "EV_DashBoardVDDMQBA0" (VN75)
    1 Fehler gefunden:
    16711681 - ROD - Unbekannter Fehlercode
              - 00 [008]
              Sporadisch - bestätigt - geprüft seit letzter Löschung
                 Umgebungsbedingungen:
                        Fehlerstatus: 00000001
                        Fehlerpriorität: 4
                        Fehlerhäufigkeit: 10
                        Verlernzähler: 44
                        Kilometerstand: 85 km
                        Datum: 2020.03.21
                        Zeit: 14:57:22
    Adresse 18: Standheizung (J364)       Labeldatei: Keine
       Teilenummer SW: 5WA 963 272 A    HW: 5WA 963 272 A
       Bauteil: STH-VW37x     006 0010
       Seriennummer: 000000000000002
       Codierung: 3543222054121512DCE519
       ASAM Datensatz: EV_AuxilHeateWOSVW38X 001009
       ROD: n.v.
       VCID: 4BC29E4C034BE23F6C4-801E
    Keine ASAM Daten verfügbar: "EV_AuxilHeateWOSVW38X" (VN75)
    Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
       Teilenummer SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Bauteil: GW MQB High   521 5388
       Seriennummer: 25012010520609
       Codierung: 030100344F05730499100218900F00010001070000000000000000000000
       ASAM Datensatz: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       VCID: 70B829A04A2DE1E7396-8024
       Generator:
       Bauteil: 4-00-11-01-04
       Steuergerät für Multifunktionslenkrad:
       Subsystem 2 - Teilenummer SW: 3G0 959 442 F    HW: 3G0 959 442 F
       Bauteil: E221__MFL-PR6  H06 0110
       Seriennummer: PR6-0440036028200972
       Codierung: 2C1D00
       Steuergerät für Batterieüberwachung:
       Subsystem 3 - Teilenummer SW: 7E0 915 181 L    HW: 7E0 915 181 L
       Bauteil: J367-BDMConti  H03 1051
       Seriennummer: 77197200001912070507
    Adresse 22: Allrad (J492)       Labeldatei:* DRV\0CQ-907-554.clb
       Teilenummer SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
       Bauteil: Haldex4Motion H56 7822
       Seriennummer: HA1-00011.12.19
       Codierung: 0001
       ASAM Datensatz: EV_AllWheelContrHA1VW37X 004013
       VCID: 4EC49758F059D7170BA-801A
    Adresse 3C: Spurwechsel (J1086)       Labeldatei:* Keine
       Teilenummer SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Bauteil: HRE3_Kl15_Mst H06 0150
       Seriennummer: 00000536744459
       Codierung: 52954640
       ASAM Datensatz: EV_HREntryHellaGen3Kl15 002001
       ROD: EV_HREntryHellaGen3Kl15.rod
    Adresse 44: Lenkhilfe (J500)       Labeldatei:. DRV\2N0-909-143.clb
       Teilenummer SW: 7LA 909 144 F    HW: 7LA 909 144 D
       Bauteil: EPS_MQB_ZFLS  751 7150
       Codierung: 9306
       ASAM Datensatz: EV_SteerAssisMNB 002012
       ROD: n.v.
       VCID: 45D6A874252F144FBA0-8010
    Keine ASAM Daten verfügbar: "EV_SteerAssisMNB" (VN75)
    Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:. DRV\7P6-907-357.clb
       Teilenummer SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Bauteil: AFS-ECU       H07 0080
       Revision: --------    Seriennummer: --------------
       Codierung: 0C82020009210003
       Betriebsnr.: WSC 00012 790 00156
       ASAM Datensatz: EV_HeadlRegulAFSMQBMAX 001001
       ROD: n.v.
       VCID: 41DEBC643107386F868-8014
    Keine ASAM Daten verfügbar: "EV_HeadlRegulAFSMQBMAX" (VN75)
    Adresse 5F: Informationselek. I (J794)       Labeldatei: Umleit. fehlgeschl.!
       Teilenummer SW: 3G5 035 816     HW: 3G5 035 816
       Bauteil: MU-O-ND-EU    H12 0156
       Seriennummer: VWZAZ2X0532799
       Codierung: 64600000000020000000000000000000000000000000000000
       ASAM Datensatz: EV_MUOIMQB 001001
       ROD: n.v.
       VCID: 66944FF878E93F5753A-8032
    Keine ASAM Daten verfügbar: "EV_MUOIMQB" (VN75)
    Adresse 69: Anhänger (J345)       Labeldatei: Keine
       Teilenummer SW: 5H0 907 383     HW: 5H0 907 383
       Bauteil: Anhaenger     H09 0040
       Seriennummer: 000000000005412
       Codierung: 0100000202001300
       ASAM Datensatz: EV_TrailFunctGener3Hella 001009
       ROD: n.v.
       VCID: 6B823ECC630B023F0C4-803E
    Keine ASAM Daten verfügbar: "EV_TrailFunctGener3Hella" (VN75)
    Adresse 6D: Heckklappe (J605)       Labeldatei:* Keine
       Teilenummer SW: 7LA 959 107     HW: 4M0 959 107 C
       Bauteil: HDSG-Modul    H14 0672
       Revision: --------    Seriennummer: A2-C769-9790-2
       Codierung: 4100
       ASAM Datensatz: EV_DeckLidCONTIVN46T 001017
       ROD: EV_DeckLidCONTIVN46T.rod
       VCID: 0352766C6B9BEA7FD44-8056
    Adresse 75: Telematik (J949)       Labeldatei: Keine
       Teilenummer SW: 5WA 035 284     HW: 5WA 035 284
       Bauteil: OCUGen3High   H20 0088
       Seriennummer: 0000000911VISM5
       Codierung: 06462000196898209005460160500607
       ASAM Datensatz: EV_OCUGen3High 002115
       ROD: n.v.
    Keine ASAM Daten verfügbar: "EV_OCUGen3High" (VN75)
    2 Fehlercodes gefunden:
    1190912 - ROD - Unbekannter Fehlercode
              - 00 [008]
                        Fehlerpriorität: 4
                        Verlernzähler: 40
                        Datum: 2020.03.21
                        Zeit: 14:57:23
    0081 - ROD - Unbekannter Fehlercode
              - 00 [008]
                        Fehlerpriorität: 6
                        Fehlerhäufigkeit: 11
                        Verlernzähler: 40
                        Kilometerstand: 13 km
                        Datum: 2020.03.16
                        Zeit: 15:57:54
    Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:* Keine
       Teilenummer SW: 2Q0 980 653     HW: 2Q0 980 653
       Bauteil: MQB MFK 3.0   H11 1029
       Seriennummer: E33417011200010
       Codierung: 000108882178C020409F00001030000006010000000000000000000000000000
       ASAM Datensatz: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_004.rod
       VCID: 72BC23A84421D3F7CF2-8026
    Adresse D6: Lichtsteuerung links 2 (A31)       Labeldatei: 7PP-941-572.clb
       Teilenummer SW: 992 941 571 AA    HW: 992 941 571 A
       Bauteil: LED1L         H08 9002
       ASAM Datensatz: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X.rod
       VCID: 619E5CE491C7586FA68-8034
    Adresse D7: Lichtsteuerung rechts 2 (A27)       Labeldatei: 7PP-941-572.clb
       Bauteil: LED1R         H08 9002
       ASAM Datensatz: EV_LLPGen3RKEBODPO68X 001003
    Ende--(Dauer: 01:23, Batt.-Spannung Start/Ende: 11.9V/11.9V. VIgn 11.9V)---
    Looking forwart to the 20.x beta
    Cheers
    P&G
    It would be better if you make sure you install the English version of VCDS (it can be installed alongside your German version) and use that when posting here - most of us don't speak German!
    Jun 2017
    Try the newest 20.4 Release
    @Uwe
    are there any detailed release notes?
    Feb 2018
    Changelog would be nice. Maybe it´s possible @Uwe ?
    VW: VCDS HEX-NET | VCP Inkl. VIM Addon | VAGTacho | RNS Manager | Setconfig
    Porsche: Durametric
    Ford: UCDS | F-Com (ex Fo-Com)
    Opel: AutoScannerCAN Opel Pro | OP-COM
    Fiat: MultiECUScan
    Renault/Dacia: DDT4all
    BMW Motorrad: MotoScan
    Launch X431 Pro3
    Mar 2020
    Switzerland
    I finally had some time to use VCDS 20.4 for a new autoscan in English ;-).
    I'm still looking for some support how to change N279 to engine preheat instead of heating only the drivers cabin.
    Code of the Auxiliary Heater.
    Address 18: Aux. Heat (J364)       Labels:* None
       Part No SW: 5WA 963 272 A    HW: 5WA 963 272 A
       Component: STH-VW37x     006 0010
       Serial number: 000000000000002
       Coding: 3543222054121512DCE519
       ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
       ROD: EV_AuxilHeateWOSVW38X_VW27.rod
       VCID: 4BC29E4C034BE233F60-801E
    I also prepared some screenshots of the diffent pages/settings of the Auxiliary Heater - unfortunately I didn´t save them properly.
    I'll add the to this post asap, but maybe the solution is quite obvious to an expert.
    Thank you for your help!
    Here's the full scan:
    Saturday,11,April,2020,12:49:06:61222
    VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WV2ZZZ7HZLH048100   License Plate:
    Mileage: 391km-242mi   Repair Order:
    Chassis Type: 7H-VN46 (3Q0)
              A5 D6 D7
    VIN: WV2ZZZ7HZLH048100   Mileage: 391km-242miles
    Address 01: Engine (J623-CXFA)       Labels: None
       Part No SW: 04L 906 056 QJ    HW: 04L 907 445 M
       Component: R4 2.0l TDI   H01 9696
       Revision: 23301001
       Coding: 0025401C4366050800000000000000000000000000000000
       Shop #: WSC 00012 790 00025
       ASAM Dataset: EV_ECM20TDI03004L906056QJ 004004
       ROD: EV_ECM20TDI03004L906056QE.rod
       VCID: 0556687465AFD443604-8050
    Readiness: N/A
       Part No SW: 0BT 300 012 E    HW: 0GC 927 711 H
       Component: GSG DQ500     H06 3105
       Revision: 00H06V11
       ROD: EV_TCMDQ500021_VN46.rod
       VCID: 313EECA481A7A8E3ECC-8064
       Part No SW: 7LA 614 517 A    HW: 7LA 614 517
       Component: ESC_high      H01 0700
       Serial number: 08512742200124
       Coding: 10554452C84BE68D085522A413666766383720B8
       ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
       VCID: 3D26C0944DFF5C83784-8068
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 7LA 907 040 A    HW: 7LA 907 040 A
       Component: Climatronic   H01 0502
       Coding: 0030100008101100010009005040010500000000000B1101A08000000000
       ROD: EV_AirCondiBHTCT6PA.rod
       VCID: 392ED48459D760A354C-806C
       Operating and display unit 1 for air conditioning:
       Subsystem 1 - Part No SW: 7LA 907 049 D    HW: 7LA 907 049 D
       Component: E857  H02 0301
       Serial number: 00005066064509121312
       Subsystem 2 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
       Serial number: 00002160120140459602
       Serial number: 01102003700124
       Shop #: WSC 00012 790 00067
       ROD: EV_BCMA0_205.rod
       VCID: 74B025B03E35DDCB47A-8020
       Serial number: S4Y20M01D03H12M21S31
       Coding: 02B8EE
       Subsystem 2 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
       Serial number: 00000000000037989366
       Coding: 130007
       Subsystem 3 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
       Serial number: 00000000000038015494
       Coding: 090007
       Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
       Component: PLA 3.0 12K   H08 0061
       Serial number: 000150057220032
       Coding: 0279167851
       ASAM Dataset: EV_EPHVA2CAU3700000 009048
       ROD: EV_EPHVA2CAU3700000_VW27.rod
       VCID: 55F67834D58FA4C3504-8000
       Coding: 3204678B49FF8748949C815580508700000000000000000004
       ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
       VCID: 43D2B66C2B1B2A730E0-8016
       Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0130
       Serial number: 03012041350574
       ROD: EV_DRCONTITEMIC_VW27.rod
       Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
       Component: VW22Airbag    015 0506
       Revision: --------
       Coding: 88CFC00000000000800000CF000C40000065
       ROD: EV_AirbaVW22BPAVW27X_VW27.rod
       VCID: 005879607A8DF16B532-8054
       Subsystem 1 - Part No SW: -----------    HW: 442 062 801 20
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y519933C68C4F2DT
       Subsystem 2 - Part No SW: -----------    HW: 442 062 801 20
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y51A53398AA124DC
       Subsystem 3 - Part No SW: -----------    HW: 442 0D2 401 20
       Component: SideSensor_Dr  30F 1108
       Serial number: 351CF11C733144D1E48Q
       Subsystem 4 - Part No SW: -----------    HW: 442 0D2 401 20
       Component: SideSensor_Pr  30F 1108
       Serial number: 352CF11C733144D2555H
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 7LA 920 320     HW: 7LA 920 320
       Component: KOMBI         503 4193
       Coding: 04A408087D8C00080188620B1001000800601E02
       ASAM Dataset: EV_DashBoardVDDMQBA0 001042
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_Audio_0x31 keine Kommunikation]
                        Reset counter: 53
                        Mileage: 264 km
                        Date: 2020.04.01
                        Time: 18:50:19
    16711681 - Ethernet Databus
              U11C4 00 [008] - No Communications
                        Fault Frequency: 79
                        Reset counter: 56
                        Mileage: 85 km
                        Date: 2020.03.21
                        Time: 14:57:22
       Serial number: 25012010520609
       Coding: 030100344F05730499100218900F00010001070000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 70B829A04A2DE1EBA32-8024
       Component: 4-00-11-01-04
       Serial number: PR6-0440036028200972
       Coding: 2C1D00
       Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
       Serial number: 77197200001912070507
       Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
       Component: Haldex4Motion H56 7822
       Serial number: HA1-00011.12.19
       Coding: 0001
       VCID: 4EC49758F059D71B91E-801A
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Component: HRE3_Kl15_Mst H06 0150
       Serial number: 00000536744459
       Coding: 52954640
       ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
    Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
       Coding: 9306
       ROD: EV_SteerAssisMNB_VN46.rod
       VCID: 45D6A874252F1443204-8010
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0080
       Coding: 0C82020009210003
       Shop #: WSC 00012 790 00156
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
       VCID: 41DEBC64310738631CC-8014
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 3G5 035 816     HW: 3G5 035 816
       Serial number: VWZAZ2X0532799
       Coding: 64600000000020000000000000000000000000000000000000
       ROD: EV_MUOIMQB_SE27.rod
       VCID: 66944FF878E93F5BC9E-8032
    Address 69: Trailer (J345)       Labels:* None
       Part No SW: 5H0 907 383     HW: 5H0 907 383
       Component: Anhaenger     H09 0040
       Serial number: 000000000005412
       Coding: 0100000202001300
       ASAM Dataset: EV_TrailFunctGener3Hella 001009
       ROD: EV_TrailFunctGener3Hella_VW27.rod
       VCID: 6B823ECC630B0233960-803E
    Address 6D: Trunk Elect. (J605)       Labels:* None
       Part No SW: 7LA 959 107     HW: 4M0 959 107 C
       Component: HDSG-Modul    H14 0672
       Revision: --------    Serial number: A2-C769-9790-2
       Coding: 4100
       ASAM Dataset: EV_DeckLidCONTIVN46T 001017
       VCID: 0352766C6B9BEA734E0-8056
       Component: OCUGen3High   H20 0088
       Serial number: 0000000911VISM5
       Coding: 06462000196898209005460160500607
       ROD: EV_OCUGen3High_002_AU27.rod
    2566 - GPS Antenna
              B1054 13 [008] - Open Circuit
              [GPS-Antenna - Interruption]
                        Reset counter: 40
                        Time: 00:00:00
                        Voltage terminal 30: 12.7 V
    1190912 - Ethernet Databus Branch 1
              U122C 00 [008] - No Communication
                        Fault Frequency: 81
                        Reset counter: 37
                        Mileage: 85 km
                        Date: 2020.03.21
                        Time: 14:57:23
                        Ethernet counter checksum error: branch 1: 0
                        Ethernet counter connection interruptions: branch 1: 1
    0081 - Databus
              [Ethernet Databus missing message - Infotainment Unit]
                        Fault Frequency: 81
                        Reset counter: 37
                        Mileage: 13 km
                        Date: 2020.03.16
                        Time: 15:57:54
                        Voltage terminal 30: 12.4 V
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1029
       Serial number: E33417011200010
       Coding: 000108882178C020409F00001030000006010000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_VW27.rod
       VCID: 72BC23A84421D3FB556-8026
       Part No SW: 992 941 571 AA    HW: 992 941 571 A
       Component: LED1L         H08 9002
       ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X_SK25.rod
       VCID: 619E5CE491C758633CC-8034
       Component: LED1R         H08 9002
       ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    End----------(Elapsed Time: 01:24, VBatt start/end: 12.1V/12.1V)-----------
    Thanks again!
    P&G
