2015/16 Golf 7 GTI - Can gateway error and implementing Boost gauge...
Hugo99
France
C?ID=389403
Hello from France to you all
So yes, as a good newbie I'm going to bother some of you with questions..:) (hoping you will untertand me..)
First to comply with the forum rules, find hereafter an autoscan of my recently bought GTI:
Tuesday,18,February,2020,17:13:03:12329
VIN: WVWZZZAUZGW1xxxxx   License Plate: WW
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 42 44 52 55 5F A5 A9
VIN: WVWZZZAUZGW168719   Mileage: 66441km-41284miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   Coding: 091D00122424050B2000
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E05F06A009447E76B9-807A
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4902
   Revision: 06253104    Serial number: TFK01510020740
   ROD: EV_TCMDQ250021.rod
   VCID: 186936B29210A957115-804C
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62835000002808
   Coding: 01FA6BA134262974077E0601C1CCA980D62C94E0608395F7004200F8C209
   VCID: 79AF1336895A505F8EB-802C
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100011105000000101002
   VCID: 6A8D3C7AFCFCEBC7771-803E
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061529400465
   Coding: 00001E46C24122F34BE44000001C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F63F6D9BA40DF9EB-805C
   Component: WWS    151002  043 0551
   Serial number:         151012095952
   Component: RLHS  037 0059
   Serial number: S5Y15M11D03H11M45S02
   Coding: 90A8DD
   Revision: --------    Serial number: 39391529904871
   Coding: 0031151011
   VCID: 43D3B1DEBB16DA8F947-8016
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 03101541350302
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372BD50EFFCE862F38F-8062
   Serial number: 003MLR16Y8E7
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5BFD2E977E7E6FB0F-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169667B30101580940
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169668B27101541016
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 610 15
   Serial number: 35767000000A907D371Z
   Subsystem 4 - Part No SW: -----------    HW: 480 001 610 15
   Serial number: 358670000004BB25E61/
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 35165029B1CF1D23E29S
   Subsystem 6 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 3526502AB1CF1D22A13I
   Subsystem 7 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 35565029B1CF1D24514I
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151031400407
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDBBD2ED7FEBE6FF0F-806A
   Part No SW: 5G1 920 756 A    HW: 5G1 920 756 A
   Component: KOMBI         302 6420
   Coding: 07AD09083B80000801086A001400000000000000
   VCID: 2B03F97E338632CF4C7-807E
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 19101510803418
   Coding: 030100043F085900FB00026E9C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013.rod
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29150002141630105441
   Coding: 29FFFF
   Serial number: 9085888203
   Serial number: 270715BGR09063
   Coding: 003F0320D000048000001000
   Serial number: 00000000000007840140
   Coding: 110000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 392FD336C9DA905FCEB-806C
   Serial number: 310715BGU13442
   Coding: 003F0120DE00048000801000
   VCID: 42DDB4DAA40CD3879F1-8016
   Serial number: 00000000000007866442
   Coding: 090000
   Coding: 029203104F000200
   VCID: 40D9BED2AA00C197895-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0627
   Coding: 02730001FF00000051110001000808001F02039401200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6E85306AC01407E72B9-803A
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R3001219
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000453803
   Coding: 0000020001020306000400000000000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C21CA22C6E8A577D5D-8068
   Serial number: 150827202038
   VCID: 6B83397EF306F2CF0C7-803E
End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
So as you can notice the car comes with a MIB2, which seems to cause the error 66052 in address 19 Can Gateway. Is this right?
I'd like to get the performance monitor showing onto the MIB2 along wtih the (useless) Think Blue Monotor..
I could not find any answer yet, except that MIB2 should be able to make it, but how?
Thank you for your help
Regards
Hugo
PetrolDave
Westbury, UK
C?ID=1423
You scan shows no fault codes - where are you seeing the 66052 error?
AFAIK the Performance Monitor is a SWaP function that requires a FEC code? - that's what is required on the Skoda Octavia III (same MQB platform as the Golf 7).
Can't help on the Think Blue Monitor though...
Hugo99
France
C?ID=389403
@ PetrolDave. TY
I do have the Think blue monitor as an option in the scrolling menu of "Car" along with the Data., I do not think the Boost gauge is a FEC code.
Some of the 2016 GTI- US market came with this option.
Ooops, I posted the last scan cleared up.Here we are
Tuesday,18,February,2020,15:30:15:12329
VIN: WVWZZZAUZGWxxxxxx   License Plate: WW
VIN: WVWZZZAUZGW168719   Mileage: 66414km-41267miles
   Revision: --H13---
   Revision: 00001K08
   Coding: 90A8DD
   Coding: 0031151011
   Coding: 333135
   Coding: 333135
   Coding: 0410
   Coding: 29FFFF
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Reset counter: 198
                    Mileage: 65650 km
                    Date: 2020.01.20
                    Time: 11:51:58
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
   Coding: 110000
   Coding: 8103
   Coding: 090000
   Coding: 900000
   Coding: 900000
End----(Elapsed Time: 01:40, VBatt start/end: 11.8V/11.9V. VIgn 11.8V)-----
PetrolDave
Westbury, UK
C?ID=1423
It appears to be market and variant specific - which certainly suggest an FEC code since there is no coding or adaptation option to enable it.
DV52
C?ID=194404
^^ Hugo: hi. I wish my French language skills were as good as your English (IMO, French, and Italian are the ONLY languages for opera) - but I digress !!
Are you sure that you aren't confusing the "Offroad" monitor with the "performance" monitor - both of which are possible on the MIB? I ask because they both have a similar visual display - see below:
The "Offroad" monitor (which doesn't have boost) can be added to MIBII units via a tweak (see HERE), but as Dave has correctly advised, the "performance" display does require fec.
Hugo99
France
C?ID=389403
^^ (IMO, French, and Italian are the ONLY languages for opera) - but I digress !!Don
@Don: About digression a short one: One cannot ignore the German language.. "Die Zauberflöte"..Lohengrin.. Stop…
No I am not confusing between the Offroad and the Sport monitor.
A few weeks ago, I was in touch with my VW car dealer who knew nothing about the Boost gauge..
I've just phoned another dealer who confirm what you said ( as Dave) this is a SWaP..
Thanks to both of you.
