2011 VW Tiguan SE Cylinder/Fuel Pump Relay Problems - Please Help
DannyKCMO
C?ID=324092
Hi all - This is my first post here, so I apologize if I missed something. Trying to follow the guide on posting for support here, so....
1 - https://i.imgur.com/Lj0gdAN.jpg
2 - Car is stock except for replacing original radio with RCD330 CarPlay Desay 187B and installing backup cam.
3 -
Monday,17,February,2020,17:57:15:07409
VIN: WVGBV7AX0BWXXXXXX   License Plate:
Mileage: 100930km-62714mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53 56
          62 65 72 77
VIN: WVGBV7AX0BWXXXXXX   Mileage: 100930km-62714miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 P    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 01 0399
   Revision: P3H06---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 57915 001 1048576
   VCID: 42DDB71F488E1E079F1-8016
               P0300 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 100904 km
                    Date: 2020.02.17
                    Time: 11:47:36
                    RPM: 3397 /min
                    Load: 76.0 %
                    Speed: 65.0 km/h
                    Temperature: 79.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.097 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - MIL ON
                    Mileage: 100904 km
                    Date: 2020.02.17
                    Time: 11:47:36
                    RPM: 3397 /min
                    Load: 76.0 %
                    Speed: 65.0 km/h
                    Temperature: 79.0°C
                    Temperature: 17.0°C
                    Voltage: 14.097 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Mileage: 100904 km
                    Date: 2020.02.17
                    Time: 11:47:56
                    RPM: 2323 /min
                    Load: 80.0 %
                    Speed: 15.0 km/h
                    Temperature: 87.0°C
                    Temperature: 20.0°C
                    Voltage: 14.351 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 100912 km
                    Date: 2020.02.17
                    Time: 12:56:12
                    RPM: 895 /min
                    Load: 34.9 %
                    Temperature: 73.0°C
                    Temperature: 44.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 13.843 V
   Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
   Component: AQ 250 6F           1771
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 0B435A3B3F449F4FAC7-805E
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V24D 0006
   Revision: --H28---    Serial number: 00000003209840
   Coding: 0002336
   VCID: 392FD0F325585DDFCEB-806C
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B71CC34540F9BFEA3-8020
   Part No SW: 5K0 937 087 L    HW: 5K0 937 087 L
   Component: BCM PQ35 H+   111 0135
   Revision: BL111001
   Coding: 6D580A1B80232EC4808800851000050440015186524D8D605C8000000040
   VCID: 3E25C3EF30767AE7FB9-806A
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 020910 03  32  0010
   Coding: 009795
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 54
                    Mileage: 97845 km
                    Date: 2019.10.18
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.15 V
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 22014000    Serial number: 003GJPK08FM%
   Coding: 0012340
   VCID: 4ACD9F3F70BEC647571-801E
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 0000000000848S
   Subsystem 3 - Serial number: 0016.08.000000100000640015ÿ†63
   Subsystem 4 - Serial number: 640015ÿ†6332MTS651902500 ÿ†63
   Subsystem 5 - Serial number: 02500 ÿ†6342MTS632402500 ÿ†63
   Subsystem 6 - Serial number: 02500 ÿ†6351HTS6FNSKE9KR ÿ†63
   Subsystem 7 - Serial number: KE9KR ÿ†6361HTS67H7KE9KJ ÿ†63
   Subsystem 8 - Serial number: KE9KJ ÿ†63727TS608BBD9KR ÿ†63
   Subsystem 9 - Serial number: BD9KR ÿ†63827TS6601CB6KR ÿ
   Subsystem 10 - Serial number: CB6KR ÿ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20180909200228
   Coding: 198A140000
   VCID: 025D771F048EDE07DF1-8056
   Serial number: 0126338
   Coding: 820000
   Part No SW: 5N0 920 972 B    HW: 5N0 920 972 B
   Component: KOMBI         H20 0420
   Coding: 210F00
   VCID: 323DE7DFF4AEAE870F1-8066
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 170910F1002108
   Coding: FD827F0740061300006002
   VCID: 2E05F3AFEC168A676B9-807A
                    Reset counter: 58
                    Mileage: 100748 km
                    Date: 2020.02.10
                    Time: 18:25:48
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4CC199277ACAD87765D-8018
   Component: IMMO          H20 0420
   VCID: 6A8D3FBF1CFE2647771-803E
   Revision: A1001003    Serial number: 7668640040
   Coding: 020000
   VCID: 270B068BCFECDB2FA8F-8072
Address 37: Navigation
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2101
   Coding: 0001205
   VCID: 3635DBCF1446B2A7239-8062
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.286 1501
   Revision: 1BH04843    Serial number: 00183020086101
   Coding: 0000258
   Component: EZE_2         H25 5603
   Coding: 050B0500
   VCID: 6FBB2EAB279CC36F20F-803A
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Coding: 0001204
   VCID: 372BD6CB134C4BAF38F-8062
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000090942
   Coding: 0023057
   VCID: 323DE7DFF82EAE870F1-8066
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2Q7096262
   Coding: 1600044004000A
   Shop #: WSC 14990 001 1048576
   VCID: 46D5AB0F68A62227B39-8012
00532 - Supply Voltage B+
                    Reset counter: 94
                    Mileage: 97845 km
                    Date: 2022.03.26
                    Time: 06:35:45
                    Reset counter: 94
                    Mileage: 97845 km
                    Date: 2022.03.26
                    Time: 06:31:41
   Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
   Component: Tuer-SG         007 2102
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
   Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
   Coding: 0001168
   VCID: 3A2DCFFF205E56C7C71-806E
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668517410
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Fault Frequency: 29
                    Reset counter: 77
                    Mileage: 100748 km
                    Date: 2020.02.10
                    Time: 18:25:44
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 58
                    Mileage: 100748 km
                    Date: 2020.02.10
                    Time: 18:25:44
End----------(Elapsed Time: 01:33, VBatt start/end: 12.5V/12.4V)-----------
4 - Wife called Sunday 2/9/2020 stating engine light had come on and car was struggling. I got it, saw the EPC light had come on and drove it around. The car was rumbling/vibrating and I limped it home. On the following Monday I hooked up my VAGCOM and pulled a full scan. Scan revealed much of the same as above scan, except it did not have a cylinder 3 misfire, only cylinder 4. I went to the auto parts store and picked up an ignition coil (Intermotor E1075) and swapped it out for cylinder 4. The car seemed to be running fine after this, so I cleared the faults and considered it done.
The following Saturday I replaced all the plugs for good measure (Autolite XP Iridium XP 3923). I looked up the standard gap on the plugs which was ~ 1mm, or 39 MILS. The plugs were slightly larger than that, but I figured they were within tolerance so didnt mess with them and installed them. I did break the #3 cylinder ignition pack clip when doing this, but the connector still seemed to seat fine (I ordered a replacement plug and plan on fixing this when it arrives, but I doubt it's related to what's going on).
The following Monday (yesterday), wife called again and said the same thing was happening. Engine light and EPC light on and car strugling. I picked it up, limped it home and ran a diagnosis. This time it showed cylinder 3 and cylinder 4 misfire (among the other faults listed above). So, I took the plugs back out, re-gapped them to about 38-39 MILS. After starting the car it still sounded like it was misfiring and "rumbly" so I called it quits and here I am asking for advice.
I suspect the fuel pump relay fault needs to be addressed, but I'm not really sure where to start. I did pay for access to VW's site where they keep maintenance and repair manuals a long time ago. Searching through that I didn't see much on addressing this issue. I did see that the relay appears to be above the left foot of the driver and that I would need to remove the lower trim panel to access it.
5 - Currently have aftermarket plugs (Autolite XP Iridium XP 3923) and an ignition coil (Intermotor E1075) in Cylinder 4. No other aftermarket parts or anything installed.
6 - Specific problem is the motor sounds awful. It's misfiring and rumbling and I'm not sure what to go after next (or to call in the experts). I DO HAVE AN APPOINTMENT WITH MY MECHANIC ON MONDAY 2/24/2020, BUT I'M HOPING I CAN MAKE HEADWAY BEFORE THEN AND AVOID THE TRIP. I don't mind taking it to him and trust him, but would prefer to avoid paying for something I could fix on my own (if that's the case).
Welcome to the VCDS forum?
Did you know there is a campaign recall for fuel pumps, relay or control module & injectors for this vehicle and useful life warranty is still active?
Also did you know there is a TSB for the wire harness and TV or EPC related aforementioned by you?
Did you want to provide the VIN number for full disclosure?
Did you read the entire JPPSG thread every page?
Can you please post all OBD2 mode data too, especially mode 3 & 9?
Did you know you can seek reimbursement for the diagnosis path or time spent at private repair shops or even your VCDS system costs if you read the JPPSG as per EPA guide?
Did you observe the fuel pump relay current tracks in WD in RTFB?
Do you have RTFB?
DannyKCMO
C?ID=324092
No, I was not aware. I will call the dealership where I bought it in the morning and inquire about this. Thanks!
I did not.
I can if it's needed?
No. I will now, apologies. Appears there's useful info in there I should have read beforehand.
Sure, if I dont get anywhere with the dealership I will follow up with this information.
I was not aware, I will inquire with the dealership. Thanks again.
I did not, and do not have that book. Sounds like I may need to invest in one.
Do you have RTFB?
See above.
If you think this is a fueling issue, please have a look at the fuel pressures (specified and actual) as well as the fuel pump duty cycle in MVB 106.
I think (but am not certain) that the fault in 09 could cause hard starting, because the transfer pump probably doesn't run when the door is opened, but without the transfer pump running at all when the ignition is on, I don't think the engine would run at all...?
Did you know mechanical tests are never to be substituted for block values with FP PSI because sensors can report air with no volume present?
Did you know if the block values show dead, or deviation from spec well that indicates that?
Have you checked battery health and charging system function because if low voltage is present and indeed was present on FP relay DTC, it could raise an amperage draw to the TV during crank process and wires are known to be insufficient already to this device or even the FP?
DannyKCMO
C?ID=324092
So I felt like I was getting in over my head and took the car into the VW dealership. They just called me and said the #3 and #4 coils need to be replaced. They said the coil I used in #4 is not an OEM part and so it may be causing issues. They also said the plugs I put in were not OEM and may also be contributing to the problem. They recommended replacing all 4 coils and plugs with OEM.
I asked them about the fuel pump relay code and they said their scan did not reveal any fuel pump relay fault. I find this a bit odd.
So, I'm going to have them just do the coils and plugs.
