Results 1 to 7 of 7
Thread: VW T6 DSG torque limiter removal??
    Feb 2020
    hi all
    i have just purchaced VDCS to make some changes to my 2016 T6 DSG. one of the changes i would like to make is removal of the torque limiter within the DSG/engine. before i purchased VDCS i done some reasearch to see what i had to do, and seen most people de activated "start vibration control" or somthing along those lines. i received the vdcs lead today ran straight out to my van after i set it all up and im now sat here scratching my head as i cannot find the option i need? i have found things similer to do with torque settings but the options seem to have to be a numerical value as apposed to activate/deactivate.
    the reason for this is i currently have a CAFA 180 bi tdi engine with a stage 1 mapp. I would like to actually feel the added torque i released from the mapp!!!.
    sorry if this has been covered many times but i could not find much about it.
    Jul 2014
    Poland
    Go to a good tuner, and make proper DSG remap. Removing limiter only will destroy your gearbox. Raise TQ limit, raise clutch pressures, change shift times and you will see a diference. And no, this is not possible with VCDS.
    ESP OFFLINE coding for all VAG 2010->/ Certified GeKo user/ Retrofitting, Chip-tuning, Flash updates, ECU programming, key coding, clusters and many more...
  3. Likes Boki Ar, nazdaq100, Uwe, PetrolDave liked this post
    Mar 2019
    London, United Kingdom
    Quote Originally Posted by Sarge. View Post
    hi all
    You need to do extensive research in my opinion it a going to cause wear tear a lot more quicker the Usain lightning bolt. Had a golf Mk7.5 gone within 2 months car will not move an inch. luckily I was under warranty even than they haggled me over because Clutch and flywheel were not part of the warranty it’s a service requirement
  5. Likes Uwe, PetrolDave liked this post
  6. #4
    i cannot find the option i need?:
    Please post an Auto-Scan so we can see exactly what TCU you've got.
    But please note: I'm not in any way endorsing this change. I believe the other folks are correct; it's not the right way to do this.
  8. #5
    Feb 2020
    Wednesday,19,February,2020,17:27:00:01227
    VIN: WV1ZZZ7HZGX014951   License Plate:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 02 03 04 08 09 10 15 17 19 25 5F 61 0B
    VIN: WV1ZZZ7HZGX014951   Mileage: 219390km-136322miles
    Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 906 019 HL    HW: 03L 907 309 L
       Component: R4 2,0L EDC   X38 8372
       Revision: 22X38---    Serial number: 00000000000000
       Coding: 01254012232401080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20BTD01103L906019HL 003005
       ROD: EV_ECM20BTD_003.rod
       VCID: 7CA1F3AFF66B2B5795D-8028
    Readiness: 0 0 0 0 X
       Part No SW: 0BT 300 045 T    HW: 0BH 927 711 G
       Component: DSG DQ500-7F  H11 2402
       Revision: 00H11V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 46D55147F827A187B39-8012
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 43465000001245
       Coding: 517E4098256384828A7E027BA48321D6390000
       Shop #: WSC 35110 790 50316
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3FDB44A3A7FDF04FF0F-806A
       Component: LENKW.SENSOR  H07 0070
       Serial number: 02121513470383
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA5F9A7E0773947BB9-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E0 907 047 T    HW: 7E0 907 047 T
       Component: Climatic-T5   H22 0607
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis.rod
       VCID: 3B2330B3B3E5EC6FDC7-806E
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0771 342150432
       Coding: A0A4303A0A6134B393284F746EEB8E74BFA0708F60CC6960320400220800
       Shop #: WSC 02010 002 104857
       VCID: 6889BFFF927397F7615-803C
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 161215 03  37  0059
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8654
       Serial number: KU0KU025111553297622
       Coding: 1400B1
       Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8654
       Serial number: KU0KU018111553222421
       Coding: 0400A1
       Subsystem 4 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 7E1 951 172
       Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29150002404690025486
       Coding: A4FFFF
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 R    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0210
       Revision: --------    Serial number: 32961530802427
       Coding: 10810A
       ASAM Dataset: EV_VW75XParkAssis4K 001012
       ROD: EV_VW75XParkAssis4K_001.rod
       VCID: 41DF425BD10986BF86B-8014
       Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
       Component: VW10Airbag00J 008 0016
       Revision: --------    Serial number: 003PH0021HJ+
       Coding: 00000000000000000000000000000000304A
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 372B2C838FCDC80F38F-8062
       Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
       Component: KOMBI         H05 1008
       Coding: 470B010100
       VCID: 333318939BB5242F047-8066
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 042305
       Component: IMMO          H05 1008
       VCID: 6A8DC5F78CFFA5E7771-803E
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
       Component: MU-E-D-ER     857 6495
       Serial number: 07111500011376
       Coding: 065700003C00000041111101008000001F0000860000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 270BFCC35F6D588FA8F-8072
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0736
       Coding: 030B1A73
       Shop #: WSC 35110 377 08192
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
       Serial number: 62327414091261125510
    End----(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
  9. Likes Uwe liked this post
  10. #6
    Feb 2020
    thanks for replys, yes i understand the risks involved. when the van was mapped the company who did it offered to "match the torque of the mapp to the DSG" for a fee of course!!, quite high too!!. i was offered this as a option without the need for a remap of the dsg tune. i was told that if i had a DSG tune too then i would not be charged for the torque match as it would be part of the DSG remap. this is when i started to look into to it myself and realised/thought that what they were offering as a option was to plug in a VCDS and carry out the adjustment of the torque settings. The price of the torque match was just over half the price of a vcds cable!!
  11. #7
    I see no option for anything like "start vibration control" in that TCU software.
