JMatthews18
New Member
Hi All. My uncle who purchased 3 licenses kindly let me borrow his vcds to run codes to help troubleshoot why I continue to see a parasitic drain. He’s never posted on here but if it’s a concern with me posting on his behalf let me know and I’ll have him call to get squared away and try to repost through his email.
I recently replaced my battery and alternator (reman) - I know bad idea in the reman. Took the reman back after checking diode and failed. Second one passed so I installed however the drain is still there. I’ve pulled all fuses and tested and the only way to get the draw down to reasonable level (20mA or so) is to pull the d pin (think it’s the exciter wire, opposite of the B+). When pulling that it goes from 600 mA down to about 20 mA.
I have already ordered an OEM alternator to remove that variable however if the alternator tests pass for diode etc. is there something else going on as well?
A couple other notes
- all fuses and relays were pulled; no noticeable difference in draw drop.
- voltage at the single wire (d pin / exciter wire) is around 11 V. Should this be 0 or slightly representative of the battery voltage?
- tested multiple multi meters to double check
- pulled fuses three times to triple check.
- battery is a day old and tests fine.
- alternator pulled out passes diode test on multi meter set to diode mode.
My uncle left but will be back in another week so I only have the email he sent me of the codes. I’ve pulled out the ones that show malfunction but if there is anything else noteworthy please don’t hesitate to ask. We’ve been running in circles on this one. Hoping it’s just the reman alternator but in the meantime until it arrives I’m open to double or triple checking other areas to be sure. Thanks in advance.
ddress 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0141
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 3333E3410B3A710F047-8066
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000050576013
Component: ELVAUDIB8 H36 0041
Serial number: 0208000061226013
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 15
Mileage: 215954 km
Date: 2008.05.27
Time: 00:28:00
ddress 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DR11P898
Coding: 8B1209000300D705020000
VCID: 2D07F539ED1E27FF523-8078
00532 - Supply Voltage B+
Reset counter: 55
Mileage: 215938 km
Date: 2008.05.28
Time: 23:27:45
dress 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G088218307
Coding: 000303
VCID: 46D5AA9568A8F4A7B39-8012
02071 - Local Databus
Fault Status: 01101100
Reset counter: 15
Mileage: 215954 km
Date: 2008.05.27
Time: 00:27:58
ddress 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113959993
Coding: 0106023A007A400400B001
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000069985
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H07 0041
00926 - Terminal 30
Fault Status: 01101011
Reset counter: 15
Mileage: 215954 km
Date: 2008.05.27
Time: 00:28:00
