Results 1 to 6 of 6
Thread: Indicator tweak from 3 flashes to 5
    Aug 2015
    Question Indicator tweak from 3 flashes to 5
    Hi guy's, I have an Audi A8L 2017 model and wondered has anyone found a way / code to make the indicator flash 5 times instead of the default 3 flashes it does when you just "tap" the stick instead of the full click.
    Scan here for anyone who might be able to help please.
    Thursday,13,February,2020,14:15:51:17234
    VIN: WAUZZZ4H4HN020264   License Plate: KX17 ZGG
    Mileage: 78018km-48478mi   Repair Order:
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 34 36 3B 42 44 46 47
              52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 AC
    VIN: WAUZZZ4H4HN020264   Mileage: 78018km-48478miles
    Address 01: Engine (J623-CTBD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4H0 997 401 F    HW: 4G0 907 401 E
       Component: 3.0TDI EDC17  X14 0002
       Revision: 58X14---
       Coding: 0A2A4032052601030800
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM30TDI0114H0997401F 001002
       ROD: EV_ECM30TDI0114H0907401Q.rod
       VCID: 3038EB363AA766A7795-8064
       Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
       Component: 0BK 30TDIRdW  H22 1011
       Revision: --H22---
       Coding: 000001
       ASAM Dataset: EV_TCMALX51011 002022
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 7CA00F06A66F52C795D-8028
       Part No SW: 4H0 907 379 AB    HW: 4H0 907 379 AB
       Component: ESP PREMIUM   H10 0930
       Coding: 60E5EB8006A7D701E300
       ASAM Dataset: EV_ESPPremi 005025
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 72BC213EF42B14B7CF1-8026
       Part No SW: 4H0 907 064 HB    HW: 4H0 907 064 HB
       Component: BCM2 2.0      H61 0825
       Coding: 05B76F4E000000000000
       VCID: 70B82B36FAA726A7395-8024
       Serial number: 3217000018256009
       Component: MEM-BFS       H08 0156
       Revision: AA000000    Serial number: 00000245068453
       Coding: 0038320000047201000001010101112131313333283333
       VCID: 3430E726CE3F5A871DD-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
       Component: Klima 4 Zonen H20 0210
       Coding: 362102BE3C0000
       ASAM Dataset: EV_AirCondiFront 003001
       ROD: EV_AirCondiFront_002.rod
       VCID: 2B02FC5A1381057F4C7-807E
       Part No SW: 4H0 907 063 GB    HW: 4H0 907 063 AB
       Component: BCM1 2.0      H20 0368
       Revision: 1902003S    Serial number: 00001624426601
       Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
       VCID: 6E84354EE09330572B9-803A
       Subsystem 1 - Part No SW: 4H2 955 119 D    HW: 4H2 955 119 A
       Component: WWS641 161220  H38 0100
       Serial number:         170109145514
       Coding: 0045F7
       Serial number: 20173521X81A955547A0
       Coding: 02004E
       Component: E1 - LDS  H07 0044
       Serial number: 29 03 2017  00000716
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA126451000028834772
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: 0F088C9800PAG0MUFU03
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0092
       Revision: --------    Serial number: 003P100DAGN5
       Coding: 30333045313430303038554A305234483053
       VCID: 3B22CC1AE3E195FFDC7-806E
       Serial number: 3575HRB405T468HIAP1U
       Serial number: 3585HRB405R468HI59LS
       Serial number: 3515JRB4012597JML9FD
       Serial number: 3525JRB4014597JM89UI
       Serial number: 3554VRB401659GF2IPDS
       Serial number: 3564VRB401659GF2OOV9
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 01335QD6000MQ
       Coding: 000034
       VCID: 372AD02ADF49B19F38F-8062
       Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
       Component: E221 - MFL  H09 0010
       Serial number: 16 12 2016  H0035393
       Part No SW: 4H0 920 910 T    HW: 4H0 920 910 T
       Component: TDieGB------- H55 0903
       Revision: 44081303    Serial number: 658080417592008
       Coding: 33AF08001B412600010000
       ASAM Dataset: EV_RBD4K 004050
       ROD: EV_RBD4K_AU64.rod
       VCID: 3536DA22C5C5438F2A3-8060
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
       Component: Analoguhr D4  H05 0225
       Serial number: 2170227000937
       Part No SW: 4H0 907 468 AH    HW: 4H0 907 468 AC
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002576217
       Coding: C0CD077F08
       VCID: 77AA102A9F49719FF8F-8022
       Subsystem 1 - Part No SW: 4H0 915 181 G    HW: 4H0 915 181 G
       Component: J367-BDM  H08 0270
       Serial number: 54038025081481182402
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 17087002207011200410
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
       Component: Klima Fond    H17 0200
       Coding: 2800000000
       Shop #: WSC 02313 785 00200
       ASAM Dataset: EV_AirCondiHeck 002001
       ROD: EV_AirCondiHeck_AU64.rod
       VCID: 3828D316D2D7BEE7315-806C
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000002795
       Coding: 01010101000000000001000202
       VCID: 649057663E5F8A074DD-8030
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F3AE84A2799795F60F-807A
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000244721443
       Coding: 00383B0000057201000001010101112131313333203333
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA7703TDDN
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372AD02ADFC9B19F38F-8062
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H08 0280
       Revision: --------    Serial number: 0000247627063
       Coding: 011F1E015E0162C202083006
       VCID: 48C8A3D6A2B7CE67415-801C
       Component: RCevo         H54 0202
       Revision: 00000001    Serial number: 0000627986
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2CC91EECDBACF7C71-806E
       Revision: 00002001    Serial number: 0438557057
       Coding: 011B0E2280B93985F320C7C40A0316470000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 959 591 B    HW: 8V3 959 591 A
       Component: J245 PS50.402  H03 0004
       Serial number: 0000FST001J16RI00000
       Coding: 901F00
       Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
       Component: Dachelektroni  H13 0080
       Serial number: A2017000000000155033
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS014  H06 0005
       Serial number:     WOO1000KP4O
       Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 66001288
       Revision: CJ007001    Serial number: 00000000209450
       Coding: 030000
       VCID: 1D6622825DB5FBCFC23-8048
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H08 0280
       Revision: --------    Serial number: 0000246267884
       VCID: 3C20CF06E66F92C7D5D-8068
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002158373
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 323CE13E34AB54B70F1-8066
       Coding: 02F6022022130200
       VCID: 3430E726CEBF5A871DD-8060
       Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7570
       Coding: E00300
       Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7570
       Coding: E00300
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E00300
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E00300
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109CQ0H5019221
       Coding: 010103010000000001
       VCID: 2D06F2422D150B4F523-8078
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4G0 919 129 C    HW: 4G0 919 129
       Component: NGTV-DVB      H04 0690
       Revision: R0043000    Serial number: 06801302534001
       Coding: 03000000
       Part No SW: 4H0 035 654 D    HW: 4H0 035 654 D
       Component: H-BNT-EU      H51 1072
       Revision: --------    Serial number: 449D$0HB004073
       Coding: 02010100000BF1EF45908B1E00000003000101000000000000
       VCID: 270A006A0FE9211FA8F-8072
       Subsystem 1 - Part No: 8R0 060 884 FK
       Component: EUR 2018/2019  2702
       Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
       Component: DU8 D4 SV NB  H63 0060
       Serial number: AUZ8ZDHY901B62$
       Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
       Component: E380 BDT D4  H11 0110
       Serial number: 00000000238757
       Component: CD-Database  9040
                        Reset counter: 192
                        Mileage: 78018 km
                        Date: 2020.02.13
                        Time: 14:11:45
                        Text: DU902A,Front,M,0,0,6
    03623 - Invalid Security/Release Code
                        Reset counter: 192
                        Mileage: 78018 km
                        Date: 2020.02.13
                        Time: 14:11:44
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H08 0280
       Revision: --------    Serial number: 0000250127716
       Coding: 010F1E01400062C202083006
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
       Component: D4-PA RVC Mid H07 0050
       Coding: 024611010201000300
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914_AU64.rod
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
       Component: HDSG-Modul    H12 0049
       Revision: 10012001    Serial number: 090701351
       Coding: 021004C020
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: 6FBA284AE719395F20F-803A
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000229387
       Coding: 220000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6392547A3BD18D3FB47-8036
       Component: TSG HR        H08 0280
       Revision: --------    Serial number: 0000250127711
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
       Component: GSM-RL        H09 0083
       Revision: 0R0D5015    Serial number: SN170123  0022
       ROD: EV_GSM2x3Mono.rod
       VCID: 2C00FF46168F024745D-8078
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H28 0081
       Coding: E0140000
       ROD: EV_OnBoardCamerDPC.rod
       Serial number: 00030660119201
       Coding: 672FF2
       ROD: EV_IVBDriveSideFrnt.rod
       Serial number: 00030660179801
       Coding: 272FF2
       Component: RGS-VL        H16 0080
       Coding: 00060000031F030000030800424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313EEE3231AD6FAF76B-8064
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 170600241
       ROD: EV_RDCMA00100_008.rod
    End----------(Elapsed Time: 02:51, VBatt start/end: 14.5V/14.5V)-----------
       Revision: 58X14---
       Revision: --H22---
       Coding: 000001
       Coding: 0045F7
       Coding: 02004E
       Coding: 020300
       Coding: 000034
       Analog_clock:
       Coding: C0CD077F08
       Voltage stabilizer:
       Coding: 2800000000
       Coding: 008000
       ROD: EV_SARA2.rod
       Coding: 901F00
       Coding: 030000
       Coding: E00300
       Coding: E00300
       Coding: E00300
       Coding: E00300
       Coding: 03000000
                        Reset counter: 192
                        Mileage: 78018 km
                        Date: 2020.02.13
                        Time: 14:11:45
                        Reset counter: 192
                        Mileage: 78018 km
                        Date: 2020.02.13
                        Time: 14:11:44
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
       Coding: 021004C020
       Coding: 220000
       ROD: EV_Ambie.rod
       Coding: E0140000
       Coding: 672FF2
       Coding: 272FF2
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:52, VBatt start/end: 14.6V/14.5V)-----------
    I'm not aware of a way to do that in that series of BCMs.
  3. Likes busterboy liked this post
    Aug 2015
    Oh never mind Ewe, Thank you for your speedy response.
    Quote Originally Posted by busterboy View Post
  6. Likes busterboy, PetrolDave liked this post
    Jun 2014
    Don't know for sure... but found this somewhere on the internet...
    [46-Central Conv.]
    [Adation]
    Search for "Blinkerzyklen"
    Value 1-5
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  8. Likes busterboy, nazdaq100 liked this post
  9. #6
    Quote Originally Posted by Mari View Post
    [46-Central Conv.]
    [Adation]
    Value 1-5
    His BCMs don't use UDS, meaning they don't have named Adaptation channels.....
  10. Likes busterboy, nazdaq100, PetrolDave liked this post
