szymonrs
New Member
- Joined
- Feb 15, 2020
- Messages
- 7
- Reaction score
- 2
- Location
- Poland
- VCDS Serial number
- H11-007412 (2nd hand?)
Hi
I'm new here in this forum, but not new with VCDS. I work with it a few years and had quite expierence with it.
Now having work with A3 E-tron 2018 to make full conversion US->EU including changing front charging port to mennekes Type2 that is used here in EU.
changing port involved of changing AC charger unit C6 from AG to AF HW number.
All works perfect. Car charge through type 2 port and runs as EV, but got check light on dash. As far as I know C6 module is part of drivetrain and any trouble codes in it provide check light.
question?
- does anyone has full scan of EU version of 2018 A3 E-tron to compare engine coding?
I got also some investigation result which bit on C6 coding trigers this fault.
please don't look in 5F module fault codes becouse it's under conversion;-)
regards
Rafal
Niedziela,16,Luty,2020,11:51:20:62428
VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 10 x64
Wersja VCDS: AKP 19.6.2.1 HEX-V2 CB: 0.4508.4
Wersja danych: 20200101 DS308.0
www.vcds.pl
Lista połączeń Gateway: 3Q0 907 530 M
Typ podwozia: FF-AU37 (3Q0)
Skanowanie: 01 02 03 05 08 09 10 13 15 16 17 19 23 29 2B 39 3C 42 44 47
4B 51 52 5F 6C 75 8C BB BC C0 C6 CF D6 D7
VIN: WAUTPBFF0JAxxxxxx Przebieg: 21990km
01-Silnik -- Stan: OK 0000
02-Skrzynia biegów -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
05-Zezwolenie startu -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: OK 0000
10-Asyst.park./kierow. -- Stan: OK 0000
13-Reg.dystansu -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
16-Koło kierownicy -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
23-Wzm.hamowania -- Stan: OK 0000
29-Światła -lewa str. -- Stan: OK 0000
2B-Blokada k.kierow. -- Stan: OK 0000
39-Światła -prawa str. -- Stan: OK 0000
3C-Zmiana pas.ruchu -- Stan: OK 0000
42-Elektr.drzwi kier. -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
47-Sys.nagłaśniający -- Stan: OK 0000
4B-Moduł wielofunkc. -- Stan: OK 0000
51-Napęd elektryczny -- Stan: OK 0000
52-Elektr.drzwi pas. -- Stan: OK 0000
5F-Elektr.informacji -- Stan: Usterka 0010
6C-Kamera wsteczna -- Stan: OK 0000
75-Telematyka -- Stan: OK 0000
8C-Akumulator hybrydowy -- Stan: Usterka 0010
BB-Drzwi tylne s.kier. -- Stan: OK 0000
BC-Drzwi tylne s.pas. -- Stan: OK 0000
C0-Generator dźwięku -- Stan: OK 0000
C6-Ład.akumulatora -- Stan: Usterka 0010
CF-Zmiana pas.ruchu 2 -- Stan: OK 0000
D6-Sterow.LED lewy 2 -- Stan: OK 0000
D7-Sterow.LED prawy 2 -- Stan: OK 0000
Adres 01: Silnik (J623-CXUA) Plik etykiet:. 04E-907-309-V1.clb
Oznaczenie elementu SW: 04E 906 023 BL HW: 04E 907 309 F
Komponent: 1.4 TFSI hy H22 5190
Weryfikacja: X3H22---
Kodowanie: 021D0012632401083000
Kod serwisu: WSC 06314 790 00021
Zbiór danych ASAM: EV_ECM14TFS01104E906023BL 008008
ROD: EV_ECM14TFS01104E906023BL.rod
VCID: 6B833BF4530ACD9F0C4-803E
Nie znaleziono błędów.
Kody gotowości: 1110 1101
Adres 02: Skrzynia biegów (J743) Plik etykiet:. 0BH-927-711.clb
Oznaczenie elementu SW: 0DD 300 046 G HW: 0DD 927 770 C
Komponent: GSG DQ400E H32 1601
Weryfikacja: 00032056 Numer seryjny: TFK01710300169
Kodowanie: 0014
Kod serwisu: WSC 00099 780 00200
Zbiór danych ASAM: EV_TCMDQ400021 001001
ROD: EV_TCMDQ400021_VW41.rod
VCID: 2C01F8E896840AA745E-8078
Adres 03: ABS/hamulce (J104) Plik etykiet: 5Q0-907-379-OMG-V1.clb
Oznaczenie elementu SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Komponent: ESC H62 0855
Weryfikacja: 00000000 Numer seryjny: 62997000000762
Kodowanie: 12FF40923826226F897C0A03A1C32948021C44915085947212A15054828802
Zbiór danych ASAM: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
VCID: 7CA108A826645A2795E-8028
Adres 05: Zezwolenie startu (J518) Plik etykiet:| 5Q0-959-435.clb
Oznaczenie elementu SW: 5Q0 959 435 C HW: 5Q0 959 435
Komponent: VWKESSYMQB 021 0803
Weryfikacja: 00021000 Numer seryjny: 0459643214
Kodowanie: 030C0C
Kod serwisu: WSC 00000 000 00000
Zbiór danych ASAM: EV_KessyHellaMQBAB 002020
VCID: 3C21C8A866E49A27D5E-8068
Adres 08: Klimatyzacja (E87) Plik etykiet:| 8V0-820-043.clb
Oznaczenie elementu SW: 8V0 820 043 S HW: 8V0 820 043 S
Komponent: AC Automat H03 0620
Weryfikacja: 20002000 Numer seryjny: 00000001381275
Kodowanie: 0300001001001000080000000000140001000000
Zbiór danych ASAM: EV_AirCondiFrontNARAU37X 001020
ROD: EV_AirCondiFrontNARAU37X.rod
VCID: 42DDB6500400ECD79F2-8016
Geber fuer Kaeltemitteldruck/Kaeltemitteltemperatur:
Podsystem 1 - Oznaczenie elementu SW: 4M0 959 603 C HW: 4M0 959 603 C
Komponent: G395 pT-Sens1 H11 0009
Sterownik dodatkowego ogrzewania powietrzem / PTC:
Podsystem 2 - Oznaczenie elementu SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Komponent: J848 HV-PTC 200 0204
Numer seryjny: -00104.5U.2C20340014
Czujnik wilgotności powietrza na zewnątrz:
Podsystem 3 - Oznaczenie elementu SW: 4H0 907 658 A HW: 4H0 907 658 A
Komponent: AQ_Hum_Sensor H02 0007
Numer seryjny: D22156D800PAG0MUFU02
Sprężarka układu klimatyzacji Sub:
Podsystem 4 - Oznaczenie elementu SW: 5QE 816 803 C HW: 5QE 816 803 C
Komponent: J842 eKK H02 0006
Numer seryjny: IABB00000K000000042A
Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. 5Q0-937-08X-V2.clb
Oznaczenie elementu SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Komponent: BCM MQBAB MNA H36 0253
Numer seryjny: 01001730600145
Kodowanie: 000000000000000000000000000000000000000000000000000000000000
Zbiór danych ASAM: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 06556A4068A810F7F3A-8052
Sterownik silnika wycieraczek:
Podsystem 1 - Oznaczenie elementu SW: 8V1 955 119 A HW: 8V1 955 119 Plik etykiet: 5QX-955-119-V1.CLB
Komponent: WWS370 171010 043 0580
Numer seryjny: 171018215218
Kodowanie: 0A47F7
Czujnik rozpoznawania deszczu i światła:
Podsystem 2 - Oznaczenie elementu SW: 81A 955 547 A HW: 81A 955 547
Komponent: G397_RLFS H06 0002
Numer seryjny: 21039774X81A955547A0
Kodowanie: 00006C
Przełącznik świateł:
Podsystem 3 - Oznaczenie elementu SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Komponent: E1 - LDS MQB H06 0032
Numer seryjny: 29 06 2017 00001428
Syrena układu alarmowego:
Podsystem 4 - Oznaczenie elementu SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Komponent: Sirene, DWA 005 0314
Numer seryjny: 00000000000000017421
Sterownik odsuwanego dachu:
Podsystem 5 - Oznaczenie elementu SW: 8V3 959 591 A HW: 8V3 959 591 A
Komponent: J245 PS73.404 H04 0005
Numer seryjny: 0000FST001UPNGN00000
Kodowanie: 101F00
Adres 10: Asyst.park./kierow. (J446) Plik etykiet:| 5Q0-919-294.clb
Oznaczenie elementu SW: 5QA 919 294 B HW: 5QA 919 294
Komponent: PDC 8 KanalH07 0044
Numer seryjny: 000308418617300
Kodowanie: 0470155011
Zbiór danych ASAM: EV_EPHVA18AU3700000 009035
VCID: 4BC39B74334A2D9F6C4-801E
Adres 13: Reg.dystansu (J428) Plik etykiet:| 3Q0-907-572.clb
Oznaczenie elementu SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Komponent: ACC BOSCH MQB H10 0571
Kodowanie: D500008119F78428949C8055000024
Zbiór danych ASAM: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
VCID: 3B23CBB463EA9D1FDC4-806E
Adres 15: Airbag (J234) Plik etykiet:| 5Q0-959-655.clb
Oznaczenie elementu SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Komponent: AirbagVW20 010 0830
Numer seryjny: 003GCR09AAPQ
Kodowanie: 9DFCFCC0002000009000001AC24800000065
Zbiór danych ASAM: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47CBA7442F22C9FF48C-8012
Napinacz pasa bezpieczeństwa z lewej strony:
Podsystem 1 - Oznaczenie elementu SW: 5G0 980 945 B HW: 5G0 980 945 B
Komponent: BeltPretRevFL H37 0350
Numer seryjny: 34230167A25101751402
Kodowanie: 333135
Napinacz pasa bezpieczeństwa z prawej strony:
Podsystem 2 - Oznaczenie elementu SW: 5G0 980 946 B HW: 5G0 980 946 B
Komponent: BeltPretRevFR H37 0350
Numer seryjny: 34230168A02111740504
Kodowanie: 333135
Układ rozpoznawania zajęcia siedzenia przedniego pasażera:
Podsystem 3 - Oznaczenie elementu SW: 5C6 959 339 B HW: 5C6 959 339 B
Komponent: BF-Gewichtss. H10 0046
Numer seryjny: 694000000000001NN18W
Kodowanie: 303333
Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
Podsystem 4 - Oznaczenie elementu SW: ----------- HW: 480 003 110 17
Komponent: SideSensor_Df 001 0887
Numer seryjny: 357000000005D085E62P
Kodowanie: 2D2D2D
Czujnik zderzenia bocznej poduszki bezp.po stronie pasażera:
Podsystem 5 - Oznaczenie elementu SW: ----------- HW: 480 003 110 17
Komponent: SideSensor_Pf 001 0887
Numer seryjny: 358000000000E085E62M
Kodowanie: 2D2D2D
Czujnik zderzenia bocznej poduszki bezp.z tyłu po str.kierowcy:
Podsystem 6 - Oznaczenie elementu SW: ----------- HW: 480 400 611 17
Komponent: SideSensor_Dr 000 6149
Numer seryjny: 3510001BB27FACA5360G
Kodowanie: 2D2D2D
Czujnik zderz.bocznej poduszki bezp.z tyłu po str.przedn.pasaż.:
Podsystem 7 - Oznaczenie elementu SW: ----------- HW: 480 400 611 17
Komponent: SideSensor_Pr 000 6149
Numer seryjny: 3520001C7282AB02922Z
Kodowanie: 2D2D2D
Czujnik zderzenia przedniej poduszki bezp.po stronie kierowcy:
Podsystem 8 - Oznaczenie elementu SW: ----------- HW: 480 402 709 17
Komponent: FrontSensor_D 001 6149
Numer seryjny: 35500029F252D872E06C
Kodowanie: 2D2D2D
Czujnik zderzenia przedniej poduszki bezp.po str.przed.pasażera:
Podsystem 9 - Oznaczenie elementu SW: ----------- HW: 480 402 709 17
Komponent: FrontSensor_P 001 6149
Numer seryjny: 3560002A1252D87311E/
Kodowanie: 2D2D2D
Adres 16: Koło kierownicy (J527) Plik etykiet:| 5Q0-953-549.clb
Oznaczenie elementu SW: 8V0 953 521 JR HW: 5Q0 953 549 E
Komponent: Lenks. Modul 003 0140
Weryfikacja: -------- Numer seryjny: 03111704400211
Kodowanie: 2418
Zbiór danych ASAM: EV_SMLSKLOMQB 020002
VCID: 137343142BFAB55F644-8046
Adres 17: Zest.wskaźników (J285) Plik etykiet:| 5G0-920-XXX-17.clb-SRI2
Oznaczenie elementu SW: 8V0 920 894 A HW: 8V0 920 894 A
Komponent: FBenUSA H16 0066
Kodowanie: 08640C512B88CF050283E8101B00000000000000
Zbiór danych ASAM: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3FDBBFA477F2813FF0C-806A
Adres 19: CAN Gateway (J533) Plik etykiet:| 3Q0-907-530-V1.clb
Oznaczenie elementu SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Komponent: GW MQB EV 618 6322
Numer seryjny: 25101710801056
Kodowanie: 0201001726F200005B00100E581000000001010100010000000300000000
Zbiór danych ASAM: EV_GatewNF 013023
ROD: EV_GatewNF.rod
VCID: 392FD1BC69D6AF0FCE8-806C
Sterownik kierownicy wielofunkcyjnej:
Podsystem 1 - Oznaczenie elementu SW: 8W0 951 523 E HW: 8W0 951 523 E
Komponent: J453 MFL H04 0002
Numer seryjny: 20171018233750 22793
Sterownik układu kontroli akumulatora:
Podsystem 2 - Oznaczenie elementu SW: 5QE 915 181 A HW: 5QE 915 181 A
Komponent: J367-BDMHella H10 9070
Numer seryjny: 0055015604
Adres 23: Wzm.hamowania (J539) Plik etykiet:* Brak
Oznaczenie elementu SW: 5QE 909 059 G HW: 5QE 909 059 B
Komponent: EBKV H14 0211
Numer seryjny: 085460012583
Kodowanie: 03720100331A00030002050500
Zbiór danych ASAM: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 52FD8610D4607C572F2-8006
Zasobnik ciśnienia w układzie hamowania:
Podsystem 1 - Oznaczenie elementu SW: 5QE 909 057 D HW: 5QE 909 057 A
Komponent: VX70BrakeAssi H04 0155
Numer seryjny: 05802861041117084604
Adres 29: Światła -lewa str. (J1018) Plik etykiet: 8S0-907-397.clb
Oznaczenie elementu SW: 8S0 907 397 D HW: 8S0 907 397 D
Komponent: LCM_MQB H06 0017
Zbiór danych ASAM: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
Adres 2B: Blokada k.kierow. (J764) Plik etykiet:* 5Q0-905-861.clb
Oznaczenie elementu SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Komponent: ELV-MQBA H01 0120
Weryfikacja: 00000000 Numer seryjny: 17000326246006
Kodowanie: 5D00000000000000
Zbiór danych ASAM: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3431E0884EB452671DE-8060
Adres 39: Światła -prawa str. (J1023) Plik etykiet: 8S0-907-397.clb
Zbiór danych ASAM: EV_LCMRightCONTIAU426 001009
Adres 3C: Zmiana pas.ruchu (J769) Plik etykiet:| 3Q0-907-566.clb
Oznaczenie elementu SW: 3Q0 907 566 F HW: 3Q0 907 566
Komponent: MRR1Rear H21 0610
Kodowanie: 040002
Zbiór danych ASAM: EV_RearRadarS1BoschVW48X 001007
Adres 42: Elektr.drzwi kier. (J386) Plik etykiet:| 5QX-959-X93-42.clb
Oznaczenie elementu SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Komponent: TSG FS 020 0041
Numer seryjny: 191017EJJ02626
Kodowanie: 005D1F204000048000000002
Zbiór danych ASAM: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43D3B3541B1AE5DF944-8016
Adres 44: Wsp.kierownicy (J500) Plik etykiet:| 5Q0-909-144.clb
Oznaczenie elementu SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Komponent: EPS_MQB_ZFLS 128 1072
Kodowanie: C106
Zbiór danych ASAM: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D7AD4C152EDBEFBA0-8010
Adres 47: Sys.nagłaśniający (J525) Plik etykiet:| 81A-035-466.clb
Oznaczenie elementu SW: 81A 035 466 B HW: 81A 035 466
Komponent: MIB2_amp_P_A3 H10 0440
Weryfikacja: 00000001 Numer seryjny: AUZ8ZAH5F00ZQU+
Kodowanie: 0173030000AAAA2AAA0000010000
Zbiór danych ASAM: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 241110C8FE54C2E78DE-8070
Adres 4B: Moduł wielofunkc. (J745) Plik etykiet:| 3Q0-907-338-V1.clb
Oznaczenie elementu SW: 3Q0 907 338 HW: 3Q0 907 338
Komponent: FCM MQB Low 002 0286
Numer seryjny: 26101710522581
Kodowanie: 000000050100142A00112300040000000000000000000000000000000000
Zbiór danych ASAM: EV_MultiModulContiVW48X 001010
VCID: 72BD269074201C57CF2-8026
Adres 51: Napęd elektryczny (J841) Plik etykiet: Brak
Oznaczenie elementu SW: 5G0 907 080 E HW: 5G0 907 080 E
Komponent: LE Gen 3.3H15 1032
Weryfikacja: 00H15000
Kodowanie: 40020000000000000000
Zbiór danych ASAM: EV_DMCM08530115G0907080E 001008
ROD: EV_DMCM08530115G0907080E.rod
VCID: 290F01FC99761F8FBE8-807C
Adres 52: Elektr.drzwi pas. (J387) Plik etykiet:| 5QX-959-X92-52.clb
Oznaczenie elementu SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Komponent: TSG BFS 020 0041
Numer seryjny: 211017EJL22467
Kodowanie: 005D17204000048000110002
Zbiór danych ASAM: EV_DCUPasseSideEWMAXKLO 006003
Adres 5F: Elektr.informacji (J794) Plik etykiet:* Przekier.nieudane!
Oznaczenie elementu SW: 8V1 035 880 C HW: 8V1 035 880
Komponent: MU-P-LNS-US 054 1326
Numer seryjny: A702J0H2504960
Kodowanie: 017393010000000011110002041A00102F0029E5017001047E
Zbiór danych ASAM: EV_MUHig6C3Gen2HBAS 001115
VCID: 3A2DCEB06CD0A417C72-806E
Jednostka wskazań 1 systemu Multimedia:
Podsystem 1 - Oznaczenie elementu SW: 8V0 919 604 C HW: 8V0 919 604 C
Komponent: DU High H49 0014
Numer seryjny: AUZ8Z9H1Y0709K
Jednostka obsługi systemu Multimedia:
Podsystem 2 - Oznaczenie elementu SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Komponent: ControlUnit_H H85 0855
Numer seryjny: ALJAL113101700050472
Baza danych Compact Disc:
Podsystem 3 - Oznaczenie elementu SW: V03 959 800 EG HW: -----------
Komponent: Gracenote2 --- 3012
Numer seryjny: --------------------
4 - ilość znalezionych błędów. Oto one:
1597 - Zestaw danych niewiarygodny
B2012 00 [009] - -
[Control module (data record download) - implausible data record for language]
Potwierdzony - Testowany od skasowania kodów błędów
Ramka zamrożona:
Stan błędu: 00000001
Priorytet błędu: 2
Częstość błędu: 1
Wew.licznik błędów: 41
Przebieg: 21990 km
Data: 2020.02.16
Czas: 11:46:00
Napięcie zacisku 30: 13.6 V
1555 - Sprawdzanie układu zarządzania wersją oprogramowania
B201A 00 [009] - -
Ramka zamrożona:
Priorytet błędu: 6
Częstość błędu: 1
Przebieg: 21990 km
Data: 2020.02.16
Czas: 11:46:06
Napięcie zacisku 30: 13.2 V
Status_Software_Version_Management-module_name: MFC2H37xE/HREU
1556 - Sterownik uszkodzony
B2000 87 [009] - Brak wiadomości
Ramka zamrożona:
Priorytet błędu: 6
Częstość błędu: 1
Przebieg: 21990 km
Data: 2020.02.16
Czas: 11:46:18
Moduły oprogramowania: status-SW_Status_Consistency: 00 20 00
Moduły oprogramowania: status-SW_Status_Device:
2563 - System nawigacji
B126C F1 [009] - Brak bazy danych systemu nawigacji
Ramka zamrożona:
Priorytet błędu: 7
Częstość błędu: 1
Przebieg: 21990 km
Data: 2020.02.16
Czas: 11:46:01
Adres 6C: Kamera wsteczna (J772) Plik etykiet:| 5Q0-980-556.clb
Oznaczenie elementu SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Komponent: RVC Compact H12 0231
Kodowanie: 0273100102002001400040
Zbiór danych ASAM: EV_CamSysRVRVCPANAMQBAB 006009
Adres 75: Telematyka (J949) Plik etykiet:| 5QE-035-285.clb
Oznaczenie elementu SW: 5QE 035 285 A HW: 5QE 035 285 A
Komponent: OCULowMQBUS 009 0570
Kodowanie: 017393011082BA0100F800000000
Zbiór danych ASAM: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
Adres 8C: Akumulator hybrydowy (J840) Plik etykiet: Brak
Oznaczenie elementu SW: 5Q0 915 182 E HW: 5Q0 915 182 C
Komponent: BECM H05 1101
Numer seryjny: V6130111
Kodowanie: 00000000
Zbiór danych ASAM: EV_BECM09620115Q0915182 006042
ROD: EV_BECM09620115Q0915182.rod
VCID: 3537DD8C45CE4B6F2A0-8060
Przełącznik wyłączania akumulatora:
Podsystem 1 - Oznaczenie elementu SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Komponent: BJB H28 0240
Kodowanie: 000000
Sterownik 1 modułu ogniw:
Podsystem 2 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D1 H14 0481
Numer seryjny: V013C1770630036
Kodowanie: 000000
Sterownik 2 modułu ogniw:
Podsystem 3 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D2 H14 0481
Numer seryjny: V013C1770630035
Kodowanie: 000000
Sterownik 3 modułu ogniw:
Podsystem 4 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D3 H14 0481
Numer seryjny: V013C1770630029
Kodowanie: 000000
Sterownik 4 modułu ogniw:
Podsystem 5 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D4 H14 0481
Numer seryjny: V013C1770630020
Kodowanie: 000000
Sterownik 5 modułu ogniw:
Podsystem 6 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D5 H14 0481
Numer seryjny: V013C1770630025
Kodowanie: 000000
Sterownik 6 modułu ogniw:
Podsystem 7 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D6 H14 0481
Numer seryjny: V013C1770630031
Kodowanie: 000000
Sterownik 7 modułu ogniw:
Podsystem 8 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D7 H14 0481
Numer seryjny: V013C1770630032
Kodowanie: 000000
Sterownik 8 modułu ogniw:
Podsystem 9 - Oznaczenie elementu SW: 5QE 915 591 K HW: 5QE 915 591 K
Komponent: 6D8 H14 0481
Numer seryjny: V013C1770630030
Kodowanie: 000000
Znaleziono 1 błąd:
26705 - Nieznany kod błędu
U0337 00 [175] - -
[Diag_F_BCCM_GST07]
MIL zapalona - Potwierdzony - Testowany od skasowania kodów błędów
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 1
Przebieg: 21990 km
Data: 2020.02.16
Czas: 11:50:07
Pack Voltage: 347.7 V
Pack Current: -0.70 A
Isolation Resistance: 3680 kOhm
Maxumum charge current limit: 126 A
Maximum discharge current limit: 246.0 A
Contactor Voltage: 346 V
OBD unlearned counter: 40
Crash status: 00
Pilot Line Status: 00
Fuse Status: 00
(Minus) Contactor Status: 01
(Plus) Contactor Status: 01
Terminal 15 status: 01
Max Cell Temperature: 16 °C
Min Cell Temperature: 15 °C
Air inlet temperature: 20 °C
Air outlet temperature: 19 °C
LV Battery Voltage: 12.7 V
Min.cell voltage: 3.619 V
Max.cell Voltage: 3.624 V
Max.cell SOC: 31 %
Min.cell SOC: 30 %
Hybrid Battery Pack Remaining Life: 29.8 %
Max Charge Pack Current(10s duration): 0 A
Max Discharge Pack Current(10s duration): 0.0 A
Max Pack Voltage(10s duration): 348 V
Min Pack Voltage(10s duration): 346 V
Max.cell Voltage(10s duration): 3.628 V
Min.cell Voltage(10s duration): 3.620 V
Accelerator Pedal Position D: 16.1 %
Calculated LOAD Value: 0.0 %
Engine coolant temperature: 49 °C
Engine RPM: 0.00 /min
Vehicle Speed Sensor: 0 km/h
Ambient Air Temperature: 215 °C
Hybrid Battery Pack Remaining Life: 29.80 %
control module system voltage: 12.751 V
absolute load: 0.0 %
Time After Engine Start: 0 s
Adres BB: Drzwi tylne s.kier. (J388) Plik etykiet:* Brak
Oznaczenie elementu SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Komponent: TSG HFS 020 0041
Numer seryjny: 091017EJ913837
Kodowanie: 000C17204000048000000002
Zbiór danych ASAM: EV_DCURearDriveMINKLO 006003
Adres BC: Drzwi tylne s.pas. (J389) Plik etykiet:* Brak
Komponent: TSG HBFS 020 0041
Numer seryjny: 091017EJ91383C
Zbiór danych ASAM: EV_DCURearPasseMINKLO 006003
Adres C0: Generator dźwięku (----) Plik etykiet:| 5QE-035-335.clb
Oznaczenie elementu SW: 5QE 035 335 L HW: 5QE 035 335 B
Komponent: E_SOUND_SG H09 0212
Numer seryjny: EN172102230000
Kodowanie: 04
Zbiór danych ASAM: EV_ENoiseS1NNVW3707 006013
ROD: EV_ENoiseS1NNVW3707_006.rod
VCID: 4ACD9E703C303497572-801E
Adres C6: Ład.akumulatora (J1050) Plik etykiet:* Brak
Oznaczenie elementu SW: 5QE 915 682 AF HW: 5QE 915 682 AF
Komponent: OBC KOSTAL H31 4114
Weryfikacja: -------- Numer seryjny: 2809160IQ000HL
Kodowanie: 115068627408
Kod serwisu: WSC 05311 115 00008
Zbiór danych ASAM: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
VCID: 117F491C11E6474F568-8044
Znaleziono 1 błąd:
13636608 - Nieprawidłowo zakodowany sterownik silnika (incorectly coded engine control module)
P0610 00 [009] - -
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 1
Przebieg: 21990 km
Data: 2020.02.16
Czas: 11:50:07
Adres CF: Zmiana pas.ruchu 2 (J770) Plik etykiet:. 3Q0-907-566.clb
Oznaczenie elementu SW: 3Q0 907 590 F HW: 3Q0 907 590
Kodowanie: 040002
Zbiór danych ASAM: EV_RearRadarS2BoschVW48X 001007
VCID: 3829D4B852DCB607316-806C
Adres D6: Sterow.LED lewy 2 (A31) Plik etykiet: 7PP-941-572.clb
Oznaczenie elementu SW: 7PP 941 572 AC HW: 7PP 941 572 A
Komponent: LED1L H09 0008
Zbiór danych ASAM: EV_LEDModLeftMELCOAU736 001004
VCID: 176B37043F02997F18C-8042
Adres D7: Sterow.LED prawy 2 (A27) Plik etykiet: 7PP-941-572.clb
Komponent: LED1R H09 0008
Zbiór danych ASAM: EV_LEDModRightMELCOAU736 001004
Koniec (Skanowanie trwało: 02:12, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 13.0V/13.0V)
question?
regards
Rafal
