Results 1 to 4 of 4
Thread: VW Golf MK5 GTi Radio AUX Coding RCD 300
    Mar 2019
    London, United Kingdom
    Recently had someone come in for 56-Radio Aux coding on a VW Golf MK5
    I have tried many codings:
    Coding: 0040402 - Original - Says NO CDC when you press the CD button on RCD300
    Coding: 0040400 - Accepts - No Options
    Coding: 0040401 - Coding Rejected
    Customer has mentioned he's taken the CD changed plug out back of the RCD 300 and replaced it with AUX cable
    Any info would be extremely helpful
    Sunday,16,February,2020,18:45:53:42869
    VIN: WVWZZZ1KZ6W019234   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ6W019234   Mileage: 207640km-129021miles
       Part No SW: 1K0 907 115     HW: 1K0 907 115
       Component: 2.0l R4/4V TFSI  00 0070
       Revision: --H01---    Serial number: VWZ7Z0E2229039
       Coding: 0403000318070060
       Shop #: WSC 00227 210 01318
       VCID: 63925E2E375FCF4FB47-8036
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow - Intermittent
                        Mileage: 206139 km
                        Time: 15:51:56
                        RPM: 758 /min
                        Load: 18.4 %
                        Temperature: 72.0°C
                        Temperature: 23.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 14.097 V
       Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
       Revision: 00T12001
       Coding: 0004738
       Shop #: WSC 01279 785 00200
       VCID: 40D8B1A28689B457895-8014
       Part No: 1K0 907 044 BA
       Component: ClimatronicPQ35 066 0606
       VCID: 678A4A3EC367A36F68F-8032
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000001957958
       Coding: E58D8F2700041800001400001400000000087F075C
       VCID: 2B02F60E1F0F470F4C7-807E
       Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0402
       Coding: 00065493
       Shop #: WSC 01279
       Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 010  1010
       Coding: 00207646
       Shop #: WSC 01279
    01800 - Light Switch (E1)
                        Fault Frequency: 10
                        Reset counter: 101
                        Mileage: 205421 km
                        Voltage: 14.35 V
    00532 - Supply Voltage B+
                        Reset counter: 101
                        Mileage: 206944 km
                        Voltage: 7.30 V
                        Reset counter: 101
                        Mileage: 206944 km
                        Voltage: 6.80 V
       Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
       Component: 2F AIRBAG VW8   015 2100
       Revision: 03015000    Serial number: 0038ED0FV558
       Coding: 0012870
       Shop #: WSC 01269 785 00200
       VCID: 372ADA7ED347F3EF38F-8062
       Subsystem 1 - Serial number: 6332MSME0A6E726BR
       Subsystem 2 - Serial number: 6342MSME0A6E066ES
       Subsystem 3 - Serial number: 6351HSME07651D6EJ
       Subsystem 4 - Serial number: 6361HSME075C221B8
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 634 0070
       Coding: 0000012
       VCID: 76B4177A94CD4AE7E39-8022
       Part No: 1K6 920 962
       Component: KOMBIINSTRUMENT VDD 1012
       Coding: 0003403
       Shop #: WSC 00323 067 57207
       VCID: 6E843F1AEC9D72272B9-803A
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001056140AE1
       Coding: 3D3F0740070003
       VCID: 2A0CF30A10F55E07B71-807E
       Component: IMMO            VDD 1012
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2348
       Coding: 0000692
       VCID: 3634D77AD44D0AE7239-8062
       Part No: 1K2 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 3332EE6EC73F1FCF047-8066
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 01C802087F2D8405485FC69010CC
       Shop #: WSC 00000 785 00200
       VCID: 79AE1C46A5D3259F8EB-802C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1K0 951 177 A
       Component: Innenraumueberw.005 0202
    01134 - Alarm Horn (H12)
       Part No: 1K0 959 702 K
       Coding: 0000692
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
       Part No: 1K0 035 186 P
       Component: Radio BVX       016 0023
       Coding: 0040400
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2422
       Coding: 0000144
       Part No: 1K0 959 704 F
       Coding: 0000144
       VCID: 3430ED72C23118F71DD-8060
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
       VCID: 2D06F816211B493F523-8078
    End----------(Elapsed Time: 01:08, VBatt start/end: 12.3V/12.3V)-----------
    Jul 2014
    Tallinn, Estonia
    Radio part number reveals this is a RCD300 with black buttons? Yeah, this is not going to work. You can't get direct AUX-in and instead will have to use a AUX-in converter (CD changer emulator). A RCD300 with silver buttons would support direct AUX-in like you described.
  3. Likes nazdaq100, Uwe liked this post
    Mar 2019
    Quote Originally Posted by siLc View Post
    Thanks I will keep in mind truly grateful will let the customer know
    Nov 2018
    I have done this before with my Beta in a Golf IV. Here is my blog to this emulator thing. You can also upgrade this with bluetooth in the glove box.
    https://schuett.io/2013/09/avr-raspb...vag-cdc-faker/
