Results 11 to 20 of 25
Thread: service not supported in active session
    Well, I don't see anything there that says "Cannot be reached". Did you run this on the same computer? Is there anything else different besides the cable? Engine running vs. not? I realize I'm grasping at straws here.
  2. #12
    Jan 2015
    everything exactly the same. engine off but ignition on. front doors open. same computer. same usb port, though all 3 do same. so the only options are my car is screwed up somehow, or my computer took a medium size crap disabling this sort of device from running properly? if i knew for sure it was the computer, i dont have a huge problem buying another, its just that i have 5 macs already, and dont really need a windows device for anything else.....should i clear DTC's and try again? engine on make a difference? i had seen somewhere something about removing wiper fuse??? i'm stumped......
  3. #13
    Administrator Andy's Avatar
    Sector 7G
    Now that you have the HEX-USB+CAN, please try making changes to the 09 and let us know the results.
  4. #14
    Jan 2015
    exact same "service not supported in active session" error when trying to change parameters.....doors open or closed, engine on or just ignition on....
  5. #15
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by chrisa5150 View Post
    Toshiba A305-S6905 3 Gb of RAM 2.0 GHz T6400 Core 2 Duo CPU Windows Vista
    Can you please confirm you're using the native Windows PC/laptop device above?
    People have had all sorts of strange issues trying to run VCDS virtualized on Mac using Parallels and the like. It's not officially supported because of those issues.
    Jason
  6. #16
    Jan 2015
    no its actual toshiba stock windows vista laptop.....i don't run windows on mac.....
  7. #17
    Jan 2015
    success! finally! i hauled an old vista desktop computer out to the shop and after a couple of service not supported in active session errors, i was able to properly code these led taillights....i was using the new 15.2 beta. i went back and put the 15.2 update on the original laptop, and it still never worked.....i guess ill be buying a cheap modern pc laptop to be able to do this coding....thanks to all that contributed.....
  8. Likes jyoung8607, Uwe liked this post
  9. #18
    Jan 2015
    Tuesday,03,February,2015,09:17:51:19782
    VCDS Version: 15.2.0.0
    Data version: 20150130
    VIN: 3VW5T7AU7FM032843   License Plate:
    Mileage: 2675km-1662mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9
    VIN: 3VW5T7AU7FM032843   Mileage: 2675km-1662miles
    Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091900122424002F1000
       Shop #: WSC 00066 790 00149
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C573FD547467158EF-8079
    Readiness: 0010 1101
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 52164000000691
       Coding: 01FA6BA13423096E007F020481C62980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
       VCID: 44877775CFD6991807-8011
       Revision: 00021000    Serial number: 0341788263
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A7B098DBD12DFE86D-806F
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
       Component: AC Manuell    H02 0907
       Revision: 00001K06
       Coding: 00020004200100000000000000000000
       ROD: EV_ACManueBHBVW37X_SE37.rod
              B10CD 00 [008] -  -
                        Reset counter: 233
                        Mileage: 2675 km
                        Date: 2015.02.03
                        Time: 08:35:42
       Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
       Component: BCM PQ37BOSCH 028 0106
       Revision: --------    Serial number: 86580909140290
       Coding: 00110A464041A26969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00226
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 46836D7DF9EAAB0819-8013
       Slave 1:
       Subsystem 1 - Part No SW: 5GM 955 119     HW: 5GM 955 119
       Component: WWS    140709  043 0581
       Serial number:         140919072822
       Slave 2:
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S5Y14M08D18H22M10S40
       Coding: 06A8DD
       Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO30186511
       Coding: 181801
    329480 - Unknown Error Code
              B1806 F0 [008] - Unknown Error Elaboration
                        Reset counter: 233
                        Mileage: 2675 km
                        Date: 2015.02.03
                        Time: 08:36:54
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM00V30C
       VCID: 51A94E2100A47CB0BC-8004
       Seat occupant detection; front passenger side:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J1400019G350I
       Coding: 303331
       Subsystem 2 - Part No SW: -----------    HW: 480 001 807 14
       Serial number: 3570000000020BECA01M
       Subsystem 3 - Part No SW: -----------    HW: 480 001 807 14
       Serial number: 358000000008E73CA01S
       Subsystem 4 - Part No SW: -----------    HW: 480 400 108 14
       Serial number: 3510002AF16DB803B3EK
       Subsystem 5 - Part No SW: -----------    HW: 480 402 707 14
       Serial number: 3520002BD1656B9341C8
       Subsystem 6 - Part No SW: -----------    HW: 480 401 207 14
       Serial number: 3550002BD1656902B23+
       Subsystem 7 - Part No SW: -----------    HW: 480 401 207 14
       Serial number: 3560002BD165690463C6
       Revision: FF032032    Serial number: 20140726400211
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 0407B7758F56591847-8051
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BAD09122980CF0502086A001000000000000000
       VCID: 6BD5FCC982C8B660A6-803E
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 14081410000800
       Coding: 0101000820085900EF00002A080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07029
       ROD: EV_GatewConti_VW37.rod
       VCID: 428B716DD5C2972835-8017
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140001470490104292
       Coding: 28FFFF
       Revision: 00000000    Serial number: 14000198008004
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 346727B59F762998B7-8061
       Serial number: 020914060502LL
       Coding: 003E13200000040000000000
       VCID: 408F7B65DBCE853823-8015
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000003428760
       Coding: 011000
       Coding: 8102
       ROD: EV_SteerAssisMQB.rod
       VCID: 35611AB1940C309080-8060
       Serial number: 27081406050H7V
       VCID: 3F8D7899A630FAC05A-806A
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000003335720
       Coding: 191000
       Coding: 021A01010B000400
       ROD: EV_HeadlRegulVWAFS_VW37.rod
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B00608141711
       Coding: 027300000000000021220002001800001F0203340100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64C797F56F16F918E7-8031
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS500LZJ
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       Coding: 02730002C2823A017F1E06000000
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB.rod
       VCID: 020BB16D9542572875-8057
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 193
                        Mileage: 1048574 km
                        Time: 00:00:00
       Serial number: 140711200608
    End-------------------------(Elapsed Time: 04:35)--------------------------
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Thursday,29,January,2015,15:36:45:44610
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 7 - Reserved_07   Thursday,29,January,2015,15:37:03:44610
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 35 - kombinierte LED Blink-Bremsleuchten   Thursday,29,January,2015,15:37:13:44610
    Address 09:5Q0 937 087 N recoded (ADP-(5)-Leuchte20BR LA71-Lichtfunktion B 20) from Blinken links Hellphase  to not active   Thursday,29,January,2015,15:37:35:44610
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Thursday,29,January,2015,16:08:45:44610
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Friday,30,January,2015,11:41:04:44610
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Friday,30,January,2015,11:41:12:44610
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Friday,30,January,2015,11:41:47:44610
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Friday,30,January,2015,11:43:05:44610
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Friday,30,January,2015,11:43:17:44610
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Monday,02,February,2015,11:48:14:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,11:49:28:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,12:58:41:19782
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Monday,02,February,2015,12:59:35:19782
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Monday,02,February,2015,13:00:22:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:05:02:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:11:07:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:11:22:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:11:37:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:11:49:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 22 - 2* 16W Blinker   Monday,02,February,2015,13:12:00:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:12:10:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:12:19:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,13:40:49:19782
    Address 09:5Q0 937 087 N recoded (ADP-(5)-Leuchte20BR LA71-Lichtfunktion B 20) from Blinken links Hellphase  to not active   Monday,02,February,2015,13:41:07:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,13:41:52:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Access control-Funk bei Klemme 15 ein) from not active  to active   Monday,02,February,2015,15:53:52:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Access control-Funk bei Klemme 15 ein) from active  to not active   Monday,02,February,2015,15:54:03:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,15:54:28:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from not active  to active   Monday,02,February,2015,15:54:38:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,15:55:31:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 33 - LED-Modul Blinkleuchten   Monday,02,February,2015,15:55:47:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,15:56:06:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte21BR RC8-Lasttyp 21) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,15:56:25:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte21BR RC8-Lasttyp 21) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,15:57:42:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte21BR RC8-Lasttyp 21) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,15:57:57:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte21BR RC8-Lasttyp 21) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,15:58:16:19782
    Address 09:5Q0 937 087 N recoded (ADP-(16)-Access control 2-Regenschliessen_art) from Permanent  to once   Monday,02,February,2015,15:59:17:19782
    Address 09:5Q0 937 087 N recoded (ADP-(16)-Access control 2-Regenschliessen_art) from Permanent  to once   Monday,02,February,2015,16:00:25:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:00:44:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:01:33:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:02:24:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:02:36:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:04:29:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:05:36:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:06:36:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from not active  to active   Monday,02,February,2015,16:06:47:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:07:31:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:07:50:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:08:12:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:08:25:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:08:42:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:09:02:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:09:14:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:09:29:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:09:52:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:10:01:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:10:14:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:10:33:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:10:45:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:11:03:19782
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Monday,02,February,2015,16:11:20:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:17:19:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:17:37:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:18:00:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:18:34:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:18:49:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:19:05:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:19:27:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:20:10:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:25:05:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:27:36:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from not active  to active   Monday,02,February,2015,16:27:46:19782
    Address 09:5Q0 937 087 N recoded (ADP-(1)-Leuchte20BR LA71-Lasttyp 20) from 14 - kombinierte Blink- Bremsleuchten  to 34 - LED Bremsleuchten   Monday,02,February,2015,16:29:02:19782
    Address 09:5Q0 937 087 N recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Monday,02,February,2015,16:29:40:19782
    Address 09:5Q0 937 087 N recoded (ADP-(6)-Leuchte20BR LA71-Dimmwert AB 20) from 127  to 100   Tuesday,03,February,2015,08:16:30:19782
    Address 09-02:5Q0 955 559 A recoded (Long Coding) from 06A8DD to 07A8DD  (00066/790/00226)  Tuesday,03,February,2015,08:36:25:19782
    this is after taillight coding changes.....if you notice, i can no longer change RLS coding to 07A8DD in an effort for rain closing to finally work.....i forgot the error, but i have changed it before.....
  10. #19
    Chris: Yes, I can see from your CodingLog.txt file that you have had multiple tries to recode the RLS! Are you using the long coding helper for these attempts? If so, it is likely that your error message is something like "Coding rejected Error 31". One of the VCDS gurus here (can't remember who it was) suggested that the fix for this was to not use the long coding helper, but instead to change the value in the "New entry" box on the coding screen. Give this a try
  11. #20
    If that does make a difference, I would be quite puzzled as to why.
