hey i've been using my microcan cable for a month or so, and now all of sudden i get service not supported in active session when trying to change anything in 09 central electronics. car is 2015 gti, and i've tried version 14.1 as well as 15.1 with same results. here is log file:
thanks for any advice.....
Wednesday,28,January,2015,14:36:43:44610
VCDS Version: 15.1.0.0
Data version: 20150118
VIN: 3VW5T7AU7FM032843 License Plate:
Mileage: 2505km-1556mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9
VIN: 3VW5T7AU7FM032843 Mileage: 2505km-1556miles
Address 01: Engine (J623-CXCA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 091900122424002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C79F74E47A5755973-8079
Readiness: 1110 1101
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 52164000000691
Coding: 01FA6BA13423096E007F020481C62980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 44A9BFEECF359D199B-8011
Revision: 00021000 Serial number: 0341788263
Coding: 030C0C
VCID: 3A55C116BDF1DBE9F1-806F
1057803 - Antenna for Keyless Entry System in Trunk
B1173 13 [008] - Open Circuit
Reset counter: 205
Mileage: 2200 km
Date: 2015.01.14
Time: 16:51:23
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 R HW: 5G0 907 426 R
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00020004200100000000000000000000
ROD: EV_ACManueBHBVW37X_SE37.rod
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 N HW: 5Q0 937 087 N
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580909140290
Coding: 00110A464041A26969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00226
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_VW37.rod
VCID: 46ADA5E6F909AF0985-8013
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119
Component: WWS 140709 043 0581
Serial number: 140919072822
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S5Y14M08D18H22M10S40
Coding: 06A8DD
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO30186511
Coding: 181801
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00V30C
VCID: 518786BA004778B120-8004
Seat occupant detection; front passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J1400019G350I
Coding: 303331
Subsystem 2 - Part No SW: ----------- HW: 480 001 807 14
Serial number: 3570000000020BECA01M
Subsystem 3 - Part No SW: ----------- HW: 480 001 807 14
Serial number: 358000000008E73CA01S
Subsystem 4 - Part No SW: ----------- HW: 480 400 108 14
Serial number: 3510002AF16DB803B3EK
Subsystem 5 - Part No SW: ----------- HW: 480 402 707 14
Serial number: 3520002BD1656B9341C8
Subsystem 6 - Part No SW: ----------- HW: 480 401 207 14
Serial number: 3550002BD1656902B23+
Subsystem 7 - Part No SW: ----------- HW: 480 401 207 14
Serial number: 3560002BD165690463C6
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140726400211
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 04297FEE8FB55D19DB-8051
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD09122980CF0502086A001000000000000000
ROD: EV_DashBoardVDDMQBAB_VW37.rod
VCID: 6BFB3452822BB2613A-803E
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 14081410000800
Coding: 0101000820085900EF00002A080F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_VW37.rod
VCID: 42A5B9F6D5219329A9-8017
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29140001470490104292
Coding: 28FFFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000198008004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449EF2E9F952D992B-8061
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 020914060502LL
Coding: 003E13200000040000000000
VCID: 40A1B3FEDB2D8139BF-8015
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000003428760
Coding: 011000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 354FD22A94EF34911C-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 27081406050H7V
VCID: 3FA3B002A6D3FEC1C6-806A
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000003335720
Coding: 191000
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
ROD: EV_HeadlRegulVWAFS_VW37.rod
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00608141711
Coding: 027300000000000021220002001800001F0203340100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64E95F6E6FF5FD197B-8031
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS500LZJ
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2823A017F1E06000000
Shop #: WSC 00066 790 00123
ROD: EV_OCULowMQB.rod
VCID: 022579F695A15329E9-8057
2103041 - Control Module
Fault Priority: 8
Reset counter: 175
Mileage: 2505 km
Date: 2015.01.28
Time: 14:29:28
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 140711200608
End-------------------------(Elapsed Time: 03:36)--------------------------
