Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: service not supported in active session
    Jan 2015
    hey i've been using my microcan cable for a month or so, and now all of sudden i get service not supported in active session when trying to change anything in 09 central electronics. car is 2015 gti, and i've tried version 14.1 as well as 15.1 with same results. here is log file:
    thanks for any advice.....
    Wednesday,28,January,2015,14:36:43:44610
    VCDS Version: 15.1.0.0
    Data version: 20150118
    VIN: 3VW5T7AU7FM032843   License Plate:
    Mileage: 2505km-1556mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9
    VIN: 3VW5T7AU7FM032843   Mileage: 2505km-1556miles
    Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091900122424002F1000
       Shop #: WSC 00066 790 00149
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C79F74E47A5755973-8079
    Readiness: 1110 1101
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 52164000000691
       Coding: 01FA6BA13423096E007F020481C62980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
       VCID: 44A9BFEECF359D199B-8011
       Revision: 00021000    Serial number: 0341788263
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A55C116BDF1DBE9F1-806F
    1057803 - Antenna for Keyless Entry System in Trunk
              B1173 13 [008] - Open Circuit
                        Reset counter: 205
                        Mileage: 2200 km
                        Date: 2015.01.14
                        Time: 16:51:23
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
       Component: AC Manuell    H02 0907
       Revision: 00001K06
       Coding: 00020004200100000000000000000000
       ROD: EV_ACManueBHBVW37X_SE37.rod
       Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
       Component: BCM PQ37BOSCH 028 0106
       Revision: --------    Serial number: 86580909140290
       Coding: 00110A464041A26969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00226
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 46ADA5E6F909AF0985-8013
       Slave 1:
       Subsystem 1 - Part No SW: 5GM 955 119     HW: 5GM 955 119
       Component: WWS    140709  043 0581
       Serial number:         140919072822
       Slave 2:
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S5Y14M08D18H22M10S40
       Coding: 06A8DD
       Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO30186511
       Coding: 181801
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM00V30C
       VCID: 518786BA004778B120-8004
       Seat occupant detection; front passenger side:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J1400019G350I
       Coding: 303331
       Subsystem 2 - Part No SW: -----------    HW: 480 001 807 14
       Serial number: 3570000000020BECA01M
       Subsystem 3 - Part No SW: -----------    HW: 480 001 807 14
       Serial number: 358000000008E73CA01S
       Subsystem 4 - Part No SW: -----------    HW: 480 400 108 14
       Serial number: 3510002AF16DB803B3EK
       Subsystem 5 - Part No SW: -----------    HW: 480 402 707 14
       Serial number: 3520002BD1656B9341C8
       Subsystem 6 - Part No SW: -----------    HW: 480 401 207 14
       Serial number: 3550002BD1656902B23+
       Subsystem 7 - Part No SW: -----------    HW: 480 401 207 14
       Serial number: 3560002BD165690463C6
       Revision: FF032032    Serial number: 20140726400211
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 04297FEE8FB55D19DB-8051
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BAD09122980CF0502086A001000000000000000
       VCID: 6BFB3452822BB2613A-803E
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 14081410000800
       Coding: 0101000820085900EF00002A080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07029
       ROD: EV_GatewConti_VW37.rod
       VCID: 42A5B9F6D5219329A9-8017
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140001470490104292
       Coding: 28FFFF
       Revision: 00000000    Serial number: 14000198008004
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3449EF2E9F952D992B-8061
       Serial number: 020914060502LL
       Coding: 003E13200000040000000000
       VCID: 40A1B3FEDB2D8139BF-8015
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000003428760
       Coding: 011000
       Coding: 8102
       ROD: EV_SteerAssisMQB.rod
       VCID: 354FD22A94EF34911C-8060
       Serial number: 27081406050H7V
       VCID: 3FA3B002A6D3FEC1C6-806A
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000003335720
       Coding: 191000
       Coding: 021A01010B000400
       ROD: EV_HeadlRegulVWAFS_VW37.rod
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B00608141711
       Coding: 027300000000000021220002001800001F0203340100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64E95F6E6FF5FD197B-8031
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS500LZJ
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       Coding: 02730002C2823A017F1E06000000
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB.rod
       VCID: 022579F695A15329E9-8057
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 175
                        Mileage: 2505 km
                        Date: 2015.01.28
                        Time: 14:29:28
       Serial number: 140711200608
    End-------------------------(Elapsed Time: 03:36)--------------------------
    Magdeburg, Germany
    Recode the rain sensor prior to coding the bcm - don't leave the module in between and let us know if that helped.
    Jan 2015
    recoded RLS back to stock settings, and immediately went back to what i was trying to change and recieved same error.
    Jan 2015
    i've uninstalled 14.1 and 15.1 and then re-installed just 14.1.....i can go in and change like A9 Struction borne sound part, but nothing under 09 Central Electronics can be changed, even things i've changed before, such as attempting to get rain closing to work. so if i go to (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active and try to changed it back to not active, i get same error message. i have occasionally seen the can't communicate with 09 central electronics error, but not but 7 or 8 times maybe.....i saw the other thread noting that there have been other users have had issues with micro-can and 09 Central Electronics. has it been verified that HEX-USB+CAN cable does not have same issues? should i just upgrade my cable? thanks for any advice.....
    Quote Originally Posted by chrisa5150 View Post
    No, it hasn't. We've not been able to reproduce this with any of the cars, computers, or interfaces we've got, and that's a pretty good assortment, including a 2015 GTI.
    Let's hear about the computer you're using first. Make, model, CPU, RAM, version of Windows?
    Jan 2015
    Toshiba A305-S6905 3 Gb of RAM 2.0 GHz T6400 Core 2 Duo CPU Windows Vista
  7. #7
    Jan 2015
    another day, another scan log.....this one is more typical of what i've been seeing......i think i had cleared errors on the previous one.....
    Friday,30,January,2015,11:48:57:44610
    Mileage: 1600   Repair Order:
       Revision: --H13---
    Readiness: 0010 0001
       Coding: 030C0C
       Revision: 00001K06
       Slave 1:
       Slave 2:
       Coding: 06A8DD
       Coding: 181801
    329480 - Unknown Error Code
              B1806 F0 [008] - Unknown Error Elaboration
                        Reset counter: 222
                        Mileage: 2553 km
                        Date: 2015.01.29
                        Time: 15:38:10
    Address 15: Airbags
       Coding: 0400
       Coding: 28FFFF
       Coding: 011000
       Coding: 191000
                        Fault Priority: 8
                        Reset counter: 182
                        Mileage: 1048574 km
                        Time: 00:00:00
    End-------------------------(Elapsed Time: 02:55)--------------------------
  8. #8
    OK, we're going to send you a loaner HEX-USB+CAN so to see if those issues are specific to the Micro-CAN. Look for a package early next week.
  9. #9
    Jan 2015
    thanks man......your the man
  10. #10
    Jan 2015
    Monday,02,February,2015,12:01:31:19782
    Mileage: 2662km-1654mi   Repair Order:
    VIN: 3VW5T7AU7FM032843   Mileage: 2662km-1654miles
       Revision: --H13---
       VCID: 2C573FD54746715973-8079
       VCID: 44877775CFD699199B-8011
       Coding: 030C0C
       VCID: 3A7B098DBD12DFE9F1-806F
       Revision: 00001K06
       VCID: 46836D7DF9EAAB0985-8013
       Slave 1:
       Slave 2:
       Coding: 06A8DD
       Coding: 181801
                        Fault Frequency: 13
                        Reset counter: 230
                        Mileage: 2553 km
                        Date: 2015.01.29
                        Time: 15:38:10
       VCID: 51A94E2100A47CB120-8004
       Coding: 303331
       Coding: 0400
       VCID: 0407B7758F565919DB-8051
       VCID: 6BD5FCC982C8B6613A-803E
       VCID: 428B716DD5C29729A9-8017
       Coding: 28FFFF
       VCID: 346727B59F7629992B-8061
       VCID: 408F7B65DBCE8539BF-8015
       Coding: 011000
       Coding: 8102
       VCID: 35611AB1940C30911C-8060
       VCID: 3F8D7899A630FAC1C6-806A
       Coding: 191000
       Coding: 2E0000
       Coding: 2E0000
       VCID: 64C797F56F16F9197B-8031
       VCID: 020BB16D95425729E9-8057
                        Fault Priority: 8
                        Reset counter: 190
                        Mileage: 1048574 km
                        Time: 00:00:00
    End-------------------------(Elapsed Time: 04:07)--------------------------
    new scan with HEX cable.....any other ideas? thanks
    Last edited by Uwe; 02-02-2015 at 01:16 PM. Reason: Moved incorrectly placed /CODE tag
