Results 1 to 5 of 5
Thread: Skoda Superb ecu coding
    Aug 2019
    Derbyshire, UK
    2011 Skoda Superb 2.0 engine ecu coding
    Hi im new to the forum, not verified so can only post here
    Iv got a 2011 skoda superb which has come to me having a replacement engine ecu fitted. the car is running but has no coding for the module
    Iv tried entering something (although im not sure what it should be if anyone could help) but get the error request rejected out of range
    Tuesday,18,February,2020,11:48:13:55244
    Dealer/Shop Name: Birchwood Motor Co
    VIN: TMBME73T2C9030246   License Plate: CK61MXJ
    Mileage: 134440km-83537mi   Repair Order:
    Gateway Installation List:  7N0 907 530 K
    Last edited by birchwoodmotorco; 02-18-2020 at 11:24 AM. Reason: Split CODE sections
    Hi and welcome.
    We're going to need the whole Auto-Scan, not just the Gateway Installation List in order to have any reasonable chance of helping with this (but even then, there's no guarantee).
    PS: Got you verified. Moving to Car Repair Support.
    Aug 2019
    Derbyshire, UK
    Hope this helps thanks
    Tuesday,18,February,2020,17:26:41:55244
    Workshop Code: 555 55555 055555
    Chassis Type: 3T-SK46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 37 42 44 46 4F 52 55
              56 62 69 72 77
    VIN: TMBME73T2C9030246   Mileage: 134440km-83537miles
       Part No SW: 03L 906 018 EF    HW: 03L 906 018 BR
       Component: R4 2.0l TDI   H25 9977
       Revision: 42H25---    Serial number: 00000000000000
       Coding: 00000000000000000000
       Shop #: WSC 46305 463 00000
       ASAM Dataset: EV_ECM20TDI01103L906018EF 003008
       ROD: EV_ECM20TDI01103L906018EE.rod
       VCID: 72BC2F7F04225D57CF1-8026
    10095 - Engine Control Unit Incorrectly Coded
              P0610 00 [167] - -
                        Mileage: 134448 km
                        Date: 2020.02.18
                        Time: 03:25:45
                        Engine speed: 777.50 /min
                        Normed load value: 34.1 %
                        Coolant temperature: 33 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 14.380 V
                        Counter for regeneration time of diesel particle filter: 0.00 s
                        Particle filter: kilometers since last regeneration: 60251 m
                        Particle filter: soot mass measured: 13.20 g
                        Particle filter: soot mass calculated: 10.47 g
                        Particle filter: differential pressure: dynamic offset: 0 hPa
       Part No SW: 02E 300 014     HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2711
       Revision: 05351113    Serial number: 00001109241370
       Shop #: WSC 33361 790 00999
       VCID: 4FFA868BBBD050BF00F-801A
       Revision: 00H31001
       Coding: 863D6016092500FA610D06E8901F0082340000
       Shop #: WSC 33361 790 00101
       VCID: 7BA2025B53E81C1F9C7-802E
       Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
       Component: Climatronic   H18 0506
       Revision: 00001007
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SK46.rod
       VCID: 7DA60C434D7C122FA23-8028
       Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
       Component: BCM PQ35  H+  110 0651
       Revision: 00110 AC
       Coding: 48010ABBE85BF1C040080080310089E4437000AE736D85605C8140000040
       VCID: 71BE207301A4664F36B-8024
       Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 28091  26  0602
       Coding: 00D7B7
       Component: RLS 061011 05  54  0403
       Coding: 0730ED
       Subsystem 3 - Part No: 7N0 951 171
       Component: DWA-Sensor 00  002 0205
       Component: LIN BACKUP HO  H11 9005
    Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
       Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
       Component: PARKHILFE 4K  H11 0005
       Revision: --H11---    Serial number: 32901127200068
       Coding: 118115
       ASAM Dataset: EV_EPHVA14SKxxx0000 001001
       ROD: EV_EPHVA14SKxxx0000_001.rod
       VCID: 3332EA7B3BB8145F047-8066
       Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
       Component: J234__LAU VW10 HI   1918
       Revision: 20014000    Serial number: 003K2PLCA6AN
       Coding: 0016725
       VCID: 41DEB0B37D84B6CF86B-8014
       Subsystem 1 - Serial number: 6332MTS669212671
       Subsystem 2 - Serial number: 6342MTS638062681
       Subsystem 3 - Serial number: 6351HTS6842VDAKJ
       Subsystem 4 - Serial number: 6361HTS6D6QSDAKR
       Subsystem 5 - Serial number: 63727TS6IQDLFAKJ
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110809301099
       Coding: 188A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EA40B4F407A0937BB9-802A
       Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO  H07 0012
       Coding: 820000
    617736 - Selector Lever Park Position Lock Switch
              B1162 29 [009] - Signal Implausible
                        Reset counter: 115
                        Mileage: 134448 km
                        Date: 2020.02.18
                        Time: 03:25:41
       Part No SW: 3T2 920 941 K    HW: 3T2 920 941 K
       Component: KOMBI         H05 0607
       Coding: 411F01
       VCID: 3D26CC430DFCD22FE23-8068
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 011011F2001011
       Coding: 359303
       VCID: 3828DD57225EF707315-806C
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 45D6A4A369AC9AEFBA3-8010
       Component: IMMO          H05 0607
       VCID: 6A8C371F2CF29597771-803E
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 C    HW: 3C8 959 760 A
       Component: Sitzmemory    H05 2901
       Revision: 00H05000
       Coding: 00003B
       Shop #: WSC 12336 024 394758
       VCID: 3536D463354C0A6F2A3-8060
       Part No SW: 3T0 035 680 C    HW: 3T0 035 680 C
       Component: RNS-MID       H60 4024
       Revision: AB001001    Serial number: SKZ6Z7L5281188
       Coding: 04000402000400810000
       VCID: 3038E577CA2E2F47795-8064
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
       Component: TSG FA        H09 0410
       Coding: 011D0220DE01001000
       VCID: 4FFA868BB7D050BF00F-801A
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 196    3201
       Revision: 00H20000
       VCID: 3430E967323613671DD-8060
       Component: EZE_2         H40 1620
       Coding: 050B0500
       VCID: 6FBA260B179070BF20F-803A
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
       Component: TSG BF        H09 0410
       VCID: 4EC49B8FB0DA59B70B9-801A
       Coding: 1377095
       Coding: 00000021
       Coding: 00000021
       Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
       Component: TSG HL        H06 0409
       Coding: 010C00200001001000
       Revision: 3A001001    Serial number: 00008200729231
       Coding: 0100000100000000
       Component: TSG HR        H06 0409
       Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
       Component: Telefon       011 0723
       Revision: --------    Serial number: 35909603241755
       Coding: 020100000100010000000000
       ASAM Dataset: EV_UHVPremi A02003
       ROD: EV_UHVPremi_A02.rod
       VCID: 221C1F3F94428DD7FF1-8076
    End----------(Elapsed Time: 01:36, VBatt start/end: 14.2V/14.2V)-----------
  4. Likes Uwe liked this post
    So coding for that module is fairly reasonably documented in the Long Coding Helper for that ECU.
    In addition, here's a scan from a car with the exact same ECU:
    https://forums.ross-tech.com/showthread.php?20760
  6. Likes nazdaq100 liked this post
    Aug 2019
    Derbyshire, UK
    I'll take a look tomorrow
