Results 1 to 8 of 8
Thread: 2009 AUDI A4 AVANT - ROUGH IDLE, PROBLEMS SHIFTING
    Jul 2018
    I just purchased this 2009 AUDI A4 AVANT recently. Automatic Transmission. Rough idle. Shifting problems. It started having problems downshifting on the way home from work. Would stay in gears too long not shifting and then would act like it was going to die as if driving a manual transmission but would just rough idle. Showing a lot of different codes and not sure where to start really(P2177, P0299, P0506, P0301, P0303, P0304, P0302, P0300). Owner, where I bought it, is going to have it towed to a shop they work with to have it looked at. Don't know if I really trust this guy too much.
    Monday,17,February,2020,18:46:54:64227
    VIN: WAUGF78K49A166635   License Plate: AUDIA4AVANT
    Mileage: 156540km-97269mi   Repair Order: SILVER
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
              52 53 55 56 62 65 67 6C 72 77
    VIN: WAUGF78K49A166635   Mileage: 156540km-97269miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0001
       Revision: E1H14---
       Coding: 010C010A190F0160
       Shop #: WSC 63368 000 1048576
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79AF11006956FCFF8EB-802C
    10 Faults Found:
              U1113 00 [032] - -
              U1113 00 [032] - -
    2821 - Bank 1; System Too Lean off Idle
              P2177 00 [101] - -
                        Mileage: 156523 km
                        Date: 2020.02.17
                        Time: 17:56:43
                        Engine speed: 1543.00 /min
                        Normed load value: 22.0 %
                        Vehicle speed: 44 km/h
                        Coolant temperature: 95 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 13.028 V
                        Unlearning counter according OBD: 80
    5671 - Boost Pressure Regulation
              P0299 00 [232] - Control Range Not Reached
                        Mileage: 156345 km
                        Date: 2020.02.15
                        Time: 12:57:02
                        Engine speed: 2587.00 /min
                        Normed load value: 76.5 %
                        Vehicle speed: 46 km/h
                        Coolant temperature: 97 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 13.264 V
    4010 - Idle Control System
              P0506 00 [101] - RPM Lower than Expected
                        Mileage: 156536 km
                        Date: 2020.02.17
                        Time: 18:09:40
                        Engine speed: 818.50 /min
                        Normed load value: 20.8 %
                        Coolant temperature: 96 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 12.675 V
    4054 - Cylinder 1
              P0301 00 [101] - Misfire Detected
                        Mileage: 156530 km
                        Date: 2020.02.17
                        Time: 18:04:28
                        Engine speed: 1292.50 /min
                        Normed load value: 7.5 %
                        Vehicle speed: 42 km/h
                        Coolant temperature: 94 °C
                        Intake air temperature: 29 °C
                        Voltage terminal 30: 13.169 V
    4060 - Cylinder 3
              P0303 00 [101] - Misfire Detected
                        Mileage: 156530 km
                        Date: 2020.02.17
                        Time: 18:04:28
    4063 - Cylinder 4
              P0304 00 [101] - Misfire Detected
                        Mileage: 156530 km
                        Date: 2020.02.17
                        Time: 18:04:28
    4057 - Cylinder 2
              P0302 00 [101] - Misfire Detected
                        Mileage: 156530 km
                        Date: 2020.02.17
                        Time: 18:04:28
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [101] - -
                        Mileage: 156530 km
                        Date: 2020.02.17
                        Time: 18:03:54
                        Engine speed: 1523.50 /min
                        Normed load value: 11.0 %
                        Vehicle speed: 33 km/h
                        Intake air temperature: 32 °C
                        Voltage terminal 30: 13.004 V
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 3635DA3C18C8D387239-8062
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 150500
       VCID: 7DA705107DFEC0DFA23-8028
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0145
       Coding: 090200
       VCID: 75B71D3045CE989FEA3-8020
       Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
       Component: FBSAUDIB8 IDG  H50 0071
       Serial number: 0810000104600011
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000081964006
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 340JZ087514939
       Coding: 0001003
       VCID: 43D3B3E8579A762F947-8016
       Subsystem 1 - Part No: 8T0 919 609 A
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000175346
       Subsystem 3 - Serial number: 0117.10.080000000100010434˙
       Subsystem 4 - Serial number: 010434˙
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0150
       Revision: C1000000    Serial number: 01301020081236
       Coding: 64002000
       VCID: 72BD262C34A08FA7CF1-8026
                        Reset counter: 141
                        Mileage: 156183 km
                        Date: 2020.01.13
                        Time: 16:28:59
                        Temperature: 8.0°C
                        Bin. Bits: 00010000
                        Bin. Bits: 00000000
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000157270
       Coding: 26001091063CAF010000080300003D0D0F1C460800010161000000
       VCID: 3039EC24FA2CFDB7795-8064
       Component: WWS 031108  H06 0070
       Serial number: SWF08110036586
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10304341
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0080
       Serial number: 00000000002410081798
       Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
       Component: UGDO HL US  H04 0060
       Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
       Component: MP3-Changer     H43 0390
       Revision: 00043003    Serial number: AUZ5ZBH8652731
       VCID: 2A0DFE4CD0F08767B71-807E
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7H0456649
       Coding: 0000100
       VCID: 313FE920FD26F4BF76B-8064
                        Fault Frequency: 13
                        Reset counter: 116
                        Mileage: 151635 km
                        Date: 2019.07.22
                        Time: 18:24:58
       Part No SW: 8K0 919 475 D    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0020
       Revision: 11001001    Serial number: 52940830804035
       Coding: 200103
       VCID: 3A2DCE0C2C5037E7C71-806E
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD14EZ9M
       Coding: 303836354230303030304A55304C384B3053
       VCID: 40D9BCE44A0C6D37895-8014
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0800001TY7
       Serial number: 6334MSME41461037%
       Serial number: 6344MSME42310F403
       Serial number: 6352QSME2F0E3F0A-
       Serial number: 6362QSME20100F387
       Serial number: 63732SME680E1C085
       Serial number: 63832SME710E0030P
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HJV000JF
       Coding: 000017
       VCID: 3D27C5103D7E00DFE23-8068
    Address 17: Instruments
       Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0095
       Revision: EB500046    Serial number: 4600E08A148112
       Coding: 000303
       VCID: 4EC592DC80D88B470B9-801A
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 1804E08D021008
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       Coding: 020000
       VCID: 2B03FB48D30A9E6F4C7-807E
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001167508
       Coding: 00581300000000000000
       VCID: 77AB17385FC2EA8FF8F-8022
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H52 1100
       Revision: 00000000    Serial number: 341JV087518336
       Shop #: WSC 22128 444 70580
       VCID: 3829D4041E5C25F7315-806C
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008004018
       Coding: 011C03204E00410001
       VCID: 41DFB9E04186643F86B-8014
       Revision: 00002001    Serial number: 0115461284
       Coding: 0126023A207A441400B002
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0040
       Serial number: 00000000000000092451
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS127  H06 0037
       Subsystem 4 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J394 PS222  H06 0037
    02616 - Fuel Tank Cap; Unlock
                        Fault Status: 00101001
                        Reset counter: 152
                        Mileage: 132184 km
                        Date: 2018.01.26
                        Time: 16:04:48
    02615 - Fuel Tank Cap; Lock
                        Reset counter: 152
                        Mileage: 132184 km
                        Date: 2018.01.26
                        Time: 16:52:25
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
       Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
       Component: DSP STD       H08 0300
       Revision: S2600000
       Coding: 020101
       VCID: 70B92C243AACBDB7395-8024
    02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                        Reset counter: 153
                        Mileage: 132184 km
                        Date: 2018.01.26
                        Time: 15:17:52
                        Voltage: 11.70 V
                        Temperature: 20.0°C
                        Bin. Bits: 00000011
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Fault Frequency: 10
                        Reset counter: 99
                        Mileage: 153652 km
                        Date: 2019.09.26
                        Time: 07:40:41
                        Voltage: 11.90 V
                        Temperature: 12.0°C
                        Bin. Bits: 00000011
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007891626
       VCID: 40D9BCE44A8C6D37895-8014
       Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
       Component: EPB Audi B8   H06 0070
       Revision: 00000003    Serial number: 10000000127042
       VCID: 323DE62CF420CFA70F1-8066
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000004
       Shop #: WSC 06334 000 00000
       VCID: 3431E0340234C1971DD-8060
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 357KZ087510952
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000007907177
       Coding: 010C03204000210001
       VCID: 44D1B0F45E947117ADD-8010
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140782039850
       Coding: 0CD154
       Component: SDS 3501 US     H46 0630
       Revision: 00000000    Serial number: 00000810060349
       Shop #: WSC 12336 024 394758
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J8X9027
       Coding: 1000007
       VCID: 372BD73813422A8F38F-8062
       Revision:             Serial number: 0000007907180
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005067752
       Coding: 0010900
       VCID: 28090444CEFCB577A15-807C
    End----(Elapsed Time: 02:16, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    Update: 02/19/2020
    Shop is saying it is a vacuum leak in the oil separator. I thought the PCV valve was it but he stated it was right next to the PCV valve. Will replace and test drive tomorrow.
    Isn't this car under campaign recall for safety and SMOG systems or service action?
    Jul 2018
    That is a good question. I do not know the answer but I will look into it. I checked my VIN on a couple of websites and did not find any recalls associated with my VIN.
    Jul 2018
    After further inspection, I noticed that the hose connecting the PCV valve to the intake manifold was disconnected. It was a pain to get connected again. It might be time for a new hose there. Do you think that would cause the errors I am seeing? I do not have time to give it a test drive as I have to leave for work. I started it up and it sounded better than when I shut it off last night. 1200 RPM at idle though on cold start.
    Jul 2018
    Jul 2018
    Do you have more insight? Vague question
  7. #7
    Did you fix the car yet and or isolate the leaks of intake system to identify the troubled area?
    Did you report concerns or issues to NHTSA or EPA and CARB to seek assistance to let them know your issues?
    What was date of delivery into commerce?
    What is cars entire service history from dealer level in printout posted?
    Did you read the conformity certificate or application to see what is possible for coverage or extended by ORVR if used?
    Where any ADR's reported via FOIA to CARB or EPA?
    Is car driving impaired enough to cause a safety issue that should be addressed according to faults of record, seems so right?
  8. #8
    Jul 2018
    Update:
