2011 VW Touareg Steering Fault
yecatnodle
Olympia, WA, US
C?ID=395692
I have a 2011 Touareg with a steering fault. I believe I found the problem to be the steering wheel lock module (j764) I ordered and replaced it. But know I can't figure out how to do an adaptation. I open module 5 (acc/start auth) enter the security code, it's excepted, but the adaptation button is still grayed out. Here is my latest auto scan:
Saturday,08,February,2020,17:10:13:36475
VCDS Version: 19.6.2.0 (x64)
VIN: WVGFK9BP4BD002604   License Plate:
Mileage: 131193km-81519mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 65 6C 6D 72
VIN: WVGFK9BP4BD002604   Mileage: 131193km-81519miles
04-Steering Angle -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI FSA    H17 0008
   Revision: 56H17---
   Coding: 292A4012232600050000
   Shop #: WSC 04905 444 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
   ROD: EV_ECM30TDI0117P0907401J_002.rod
   VCID: 3662AEBD89C906FF4D-8062
Readiness: 0 0 0 1 1
Address 02: Auto Trans
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 E    HW: 7P0 907 379 A
   Component: MK25A         H33 0416
   Revision: --------    Serial number: 427900010EC010
   Coding: 5B7613C349242555DAFAC89392D6A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 3F8CCB99A6F3C7B79E-806A
   Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
   Component: BCM2 2.0      H23 0208
   Coding: 0D860000000000000000
   VCID: 72EA52ADAD215ADFA1-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 7218000029898006
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 01100101
                    Reset counter: 193
                    Mileage: 131193 km
                    Date: 2020.02.08
                    Time: 17:03:15
   Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
   Component: Klima 2 Zonen H18 0612
   Coding: B686200A80
   VCID: 79F86581F8572987E0-802C
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0083
   Revision: 15012002    Serial number: 00000000807125
   Coding: 26001012973C5D010020180300005D0C431C460882010261000000020000
   VCID: 295875C140775907D0-807C
   Component: WWS    100924  31  0020
   Serial number: 90243400101002021912
   Coding: 004DBD
   Component: RLFS  H09 0011
   Serial number: 10072558
   Coding: 035223
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000610100458
Address 10: Park/Steer Assist
Address 15: Airbags
   Part No SW: 4H0 953 568 B    HW: 7P6 953 507 A
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815JJ70004V
   Coding: 000C15
   VCID: 326A92AD6DA11ADF61-8066
   Serial number: 0031556
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H09 0231
   Revision: 08240053    Serial number: 658011010593014
   Coding: 8B7733022B00D705020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 479CD379FE238F7726-8012
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000046865
   Coding: 0001037500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387EA08583DDF08F5F-806C
   Serial number: 00000000005650383355
   Revision: AA000000    Serial number: 00001002116776
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 346694B597B514EF73-8060
03776 - Motor for Lumbar Support Adjustment
                    Reset counter: 193
                    Mileage: 131193 km
                    Date: 2020.01.19
                    Time: 18:20:01
   Revision: 00002001    Serial number: 0135916107
   Coding: 0106123A28B9509580A00620010000000000000000000000000000000000
   Subsystem 2 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H05 0006
   Serial number:     WOO1061824$
   Coding: 191100
   Subsystem 3 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H06 0006
   Serial number:     WOO1060068
   Coding: 191100
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811000108600
   VCID: 75E069B1DC4F4DE784-8020
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 471IV0A7531216
   Coding: 020007010000000001
   VCID: 244664F52755846FE3-8070
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H43 0706
   Revision: --------    Serial number: 445IY0A7506711
   Coding: 020200050040E1EF41020B0E00000003F00801010000000000
   VCID: 3978A581B0D7E987A0-806C
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H23 0045
   Serial number: VWZ8Z9K29002BZ
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
                    Reset counter: 193
                    Mileage: 131193 km
                    Date: 2020.01.19
                    Time: 18:20:05
                    Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
                    Reset counter: 193
                    Mileage: 131193 km
                    Date: 2020.01.19
                    Time: 18:20:03
                    Voltage: 10.80 V
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 6C: Back-up Cam.
Address 6D: Trunk Elect.
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 04:47)--------------------------
                Address 05: Acc/Start Auth.  (4H0 907 064 AK)
17:18:46 Group 001: Software Version
  SW-Stand: AUDID4_BCM2_X046 19.05.2010  Software Version
17:18:46 Group 002
  12.250 V  Voltage
  12.375 V  Voltage
  12.375 V  Voltage
  0.0  (no units)
17:18:46 Group 004
  Not Installed
  Not Installed
  Not Installed
Address 19,7P6 907 530 C,channel IDE00002-Transport mode,adapted from,not active ,to,Transport mode ,
Activating transport mode...Done.
Address 19,7P6 907 530 C,channel IDE00002-Transport mode,adapted from,Transport mode ,to,not active ,
De-activating transport mode...Done.
Address 05: DTCs cleared
Where/how did you get the security code you are entering?
How do I get my pin?
Good question.
For some cars, there are specialized "locksmith" tools that can extract it direct from the vehicle. I am not sure what tool would work on yours, and even if you had one that did, I'm not certain that having it would be sufficient to match a new steering column lock module to that vehicle.
I believe the only "official" way to do this is with your vehicle connected to VW's corporate servers, either at a dealer, or at an independent shop that has jumped through all the hoops to get access to those servers.
yecatnodle
Olympia, WA, US
C?ID=395692
Doesn't that violate the right to repair laws?
In my opinion, yes. But my opinion is worthless. What counts is the opinion of a court, which would mean hiring lawyers, and car makers have more money for lawyers than you or I do.
yecatnodle
Olympia, WA, US
C?ID=395692
I found a locksmith that can get the codes for me, but I have to transport the car to my house (my parents live in the boonies and it is not in any service area where is a locksmith, that is will to give me the codes) My question is is there a way to disengage the parking brake through VCDS?
Since the parking brake isn't powered up isn't powered up, VCDS can't talk to it.
Have you tried clearing faults codes in 05 to see if you can get the thing to power up? This used to work in older cars when they had steering column lock failures.
yecatnodle
Olympia, WA, US
C?ID=395692
yep, I have. To no avail, but I will try again, before I try more extreme measures.
yecatnodle
Olympia, WA, US
C?ID=395692
Update: got car on a trailer and back home. Locksmith came out but was unable to decrypt the security codes using his usual methods. Left to do some more research. Apparently sometimes they (as in other locksmiths) desolder an eprom chip code it with corrupt code, reinstall which forces the car into service mode, pull the codes, then desolder again flash a good file and reinstall again. My locksmith was hoping to not have to do that. I might have to brake down and take it to a authorized shop.
AGOOD1
Woodstock, GA, USA
C?ID=395342
I know this is an old thread, but I'm having the same problem. However my Touareg will not even turn on the ignition, so I cannot scan it for codes. Did you get this resolved? If so, do you mind sharing how?
yecatnodle
Olympia, WA, US
C?ID=395692
Correct, the ignition will not turn on. I managed to read the codes by keeping the cars computer awake by opening and closing the door while I started VCDS and started the scan. You can use a jumper wire to keep the computer awake as well.
AGOOD1
Woodstock, GA, USA
C?ID=395342
Thanks for the reply, I will try the door trick, but do you know which pins need to be jumped in case the door trick does not work?
AGOOD1
Woodstock, GA, USA
C?ID=395342
Also, where is this module? In the steering column, I assume? Did you have to take the whole column out to get to it or just drop the column down?
